path: root/drivers/video/hecubafb.c
2011-06-24hecubafb: add module_put on error path in hecubafb_probe()Pavel Shved
In hecubafb_probe(), after a successful try_module_get, vzalloc may fail and make the hecubafb_probe return, but the module is not put on this error path. This patch adds an exit point that calls module_put in such situation. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Pavel Shved <shved@ispras.ru> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-02video: Convert vmalloc/memset to vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22video: hecubafb: add __devexit_p around reference to hecubafb_removeaxel lin
hecubafb_remove is marked __devexit, thus add __devexit_p around reference to hecubafb_remove. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03fb-defio: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers.Konrad Rzeszutek Wilk
The framebuffers (screenbase) these drivers present are actually vmalloc-ed pages. There is no need for them to have the VM_IO flag set. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
2008-04-28fbdev: platforming hecubafb and n411Jaya Kumar
This patch splits hecubafb into the platform independent hecubafb and the platform dependent n411. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: hecubafb bugfixJaya Kumar
This patch is a bugfix for hecubafb_write which would return an incorrect error value for the bytecount from framebuffer writes. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08hecubafb: use fb_sys_read()Antonino A. Daplas
Since hecubafb's framebuffer is vmalloc'ed, use fb_sys_read(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: pass struct fb_info to fb_read and fb_writeAntonino A. Daplas
It is unnecessary to pass struct file to fb_read() and fb_write() in struct fb_ops. For consistency with the other methods, pass struct fb_info instead. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08hecubafb: use sys instead of cfb drawing functionsAntonino A. Daplas
Since hecubafb's framebuffer is vmalloc'ed, use the sys_* drawing functions instead of cfb_*. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08hecubafb: kill sparse warningsAntonino A. Daplas
The framebuffer memory is allocated from system RAM (vmalloc'ed). Add __force annotations. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08drivers/video/hecubafb.c: make 4 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - hcb_wait_for_ack() - hcb_wait_for_ack_clear() - apollo_send_data() - apollo_send_command() Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: hecuba Framebuffer DriverJaya Kumar
This patch implements support for the E-Ink/hecuba display device. It uses deferred IO support. [akpm@linux-foundation.org: linker section fixes] Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
