path: root/drivers/video/imsttfb.c
2011-08-19imsttfb: use display information in info not in var for panningLaurent Pinchart
We must not use any information in the passed var besides xoffset, yoffset and vmode as otherwise applications might abuse it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28drivers/video/imsttfb.c: add missing curly bracketsRoel Kluin
in #if 0 inactivated function msttfb_load_cursor_image() the call eieio() occurs after rather than in the loop due to missing curly brackets. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Check for PPC32 in imsttfbStephen Rothwell
This is the correct fix according to Paul Mackerras and allows an allyesconfig on PPC64 to build. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] drivers/video: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of ARRAY_SIZE. Some coding style and trailing whitespaces are also fixed. Compile-tested where possible (some are other arch or BROKEN) Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] imsttfb: Remove dead codeAntonino A. Daplas
clk_p is always 0. Coverity Bug 67 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] imsttfb: Fix resource leakAntonino A. Daplas
The struct info and device resource may not be released in the driver's error path. Fix. Coverity Bug 671 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: imsttfb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - the pseudo_palette, if using the generic drawing functions, must always be u32 regardless of the bpp - use framebuffer_alloc/framebuffer_release to allocate memory Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-26[PATCH] imsttfb missing iomem annotationsAl Viro
write_reg_le32() and read_reg_le32() expect iomem pointers... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
