path: root/drivers/video/kyro
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] kyrofb: Fix uninitialized valueAntonino A. Daplas
Initialize Variable 'count' in DisableVGA to zero. Coverity Bug 874 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] drivers/video/: possible cleanupsAdrian Bunk
This patch contains the possible cleanups including the following: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static - kyro/STG4000Interface.h: #include video/kyro.h and linux/pci.h instead of a manual "struct pci_dev" - i810_main.{c,h}: prototypes for static functions belong to the C file Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: kyrofb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - use framebuffer_alloc/framebuffer_release to allocate/free memory - the pseudo_palette is always u32 regardless of bpp if using generic drawing functions Signed-off-by: Antonino Daplas <adaplas@pol.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
