path: root/drivers/video/logo
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: generated logo sources depend on scripts/pnmtologoSam Ravnborg
The generated logo sources are not automatically regenerated if scripts/pnmtologo.c has changed. Add the missing dependency to fix this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-27Revert "linux.conf.au 2009: Tuz"Linus Torvalds
This reverts commit 8032b526d1a3bd91ad633dd3a3b5fdbc47ad54f1. Hey, it was only meant to be a single release. Now they can all die as far as I'm concerned. [ Just kidding. They're cute and cuddly. Except when they have horrible nasty facial diseases. Oh, and I guess they're not actually that cuddly even when disease-free. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-16linux.conf.au 2009: TuzRusty Russell
Impact: help prevent extinction of species The Tasmanian Devil is a shy iconic Australian creature named for its spine-chilling screech. It is threatened with extinction due to a scientifically interesting but horrific transmissible facial cancer. This one is standing in for Tux for one release using the far less-known Devil Facial Tux Disguise. Save The Tasmanian Devil http://tassiedevil.com.au Signed-off-by: Linux.conf.au Hobart Team <contact@marchsouth.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14video/logo: add support for Blackfin/Linux logo for framebuffer consoleRobin Getz
This art design is beautiful, isn't it? And you can watch our demo on YouTube: http://youtube.com/watch?v=fKyQOntPEFs Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18logo.c: get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95 so I recently deleted this from everywhere except the last instance in logo.c. This patch removes the last two instances in logo.c. They conditions were not useful anyway as when compiled in they would always evaluate as true. Last not least this is necessary to get the SGI IP22 and DECstation kernels to compile again. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbcon: logo: disable logo at bootRandy Dunlap
Add logo.nologo kernel boot option to disable the logo in order to provide more screen space for kernel messages; especially useful when debugging and screen space is more critical. newport_con driver changes are untested. [akpm@linux-foundation.org: cleanups, coding-style fixes] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (33 commits) xtensa: use DATA_DATA in xtensa powerpc: add missing DATA_DATA to powerpc cris: use DATA_DATA in cris kallsyms: remove usage of memmem and _GNU_SOURCE from scripts/kallsyms.c kbuild: use -fno-optimize-sibling-calls unconditionally kconfig: reset generated values only if Kconfig and .config agree. kbuild: fix the warning when running make tags kconfig: strip 'CONFIG_' automatically in kernel configuration search kbuild: use POSIX BRE in headers install target Whitelist references from __dbe_table to .init modpost white list pattern adjustment kbuild: do section mismatch check on full vmlinux kbuild: whitelist references from variables named _timer to .init.text kbuild: remove hardcoded _logo names from modpost kbuild: remove hardcoded apic_es7000 from modpost kbuild: warn about references from .init.text to .exit.text kbuild: consolidate section checks kbuild: refactor code in modpost to improve maintainability kbuild: ignore section mismatch warnings originating from .note section kbuild: .paravirtprobe section is obsolete, so modpost doesn't need to handle it ...
2007-07-18fbdev: make fb_append_extra_logo() depend on fb=yArnd Bergmann
We can't show the extra logo from boot code if FB is built as a module. Make the FB_LOGO_EXTRA depend on FB=y. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Cell: Draw SPE helper penguin logosGeert Uytterhoeven
Let spu_management_ops.enumerate_spus() return the number of found SPEs and use that information to draw some little helper penguin logos. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-By: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: SPE helper penguin logoGeert Uytterhoeven
Add the SPE helper penguin logo Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Cc: Arnd Bergmann <arnd@arndb.de> Acked-By: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: Add fb_append_extra_logo()Geert Uytterhoeven
Add fb_append_extra_logo(), to append extra lines of logos below the standard Linux logo. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-By: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16kbuild: remove hardcoded _logo names from modpostSam Ravnborg
Replaced this with a __init_refok marker in front of fb_find_logo(). I think that the __initdata marker for the logo's are wrong but I have not justified this so I did not remove it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-08Use menuconfig objects II: video/logoJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-30kbuild: drivers/video/logo/ - fix ident glitchSam Ravnborg
Jan Engelhardt <jengelh@linux01.gwdg.de> wrote: while compiling 2.6.17-rc2 with allyesconfig, this showed up: ... LOGO drivers/video/logo/logo_superh_clut224.c CC drivers/video/logo/logo_linux_mono.o ... A tab had sneaked in. Convert it to a few spaces. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-10spelling: s/retreive/retrieve/Adrian Bunk
2005-12-22[SPARC]: introduce a SPARC Kconfig symbolAdrian Bunk
Introduce a Kconfig symbol SPARC that is defined on both the sparc and sparc64 architectures. This symbol makes some dependencies more readable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] framebuffer: add some help text in KconfigRandy.Dunlap
Frame buffer driver help text changes: - Move S3 Trio next to S3 Savage; - add or clarify help text for several FB drivers; - add help text for FB console; - add help text for bootup logos; Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] m32r: framebuffer device supportHirokazu Takata
This patch is for supporting Epson s1d13xxx framebuffer device for m32r. # Sorry, a little bigger. The Epson s1d13806 is already supported by 2.6.12 kernel, and its driver is placed as drivers/video/s1d13xxxfb.c. For the m32r, a header file include/asm-m32r/s1d13806.h was prepared for several m32r target platforms. It was originally generated by an Epson tool S1D13806CFG.EXE, and modified manually for the m32r platforms. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SPARC]: Enable sun logo on sparc32Bob Breuer
This enables the sun linux logo to be selected on sparc32. Signed-off-by: Bob Breuer <breuerr@mc.net> Signed-off-by: David S. Miller <davem@davemloft.net>
