path: root/drivers/video/matrox/matroxfb_maven.c
2010-10-27drivers/video/matrox/matroxfb_maven.c: fix unsigned return typeJulia Lawall
The function has an unsigned return type, but returns a negative constant to indicate an error condition. The result of calling the function is only tested by comparison to 0, and thus unsigned is not needed and can be dropped from the return type. A sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ identifier f; constant C; @@ unsigned f(...) { <+... * return -C; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-23matroxfb: get rid of unneeded macro MINFO_FROMJean Delvare
With multihead support always enabled, macros MINFO_FROM and MINFO_FROM_INFO are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macros ACCESS_FBINFO and MINFOJean Delvare
With multihead support always enabled, these macros are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12matrox maven: convert to a new-style i2c driverJean Delvare
The legacy i2c model is going away soon, so switch to the new model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12matrox maven: fix a broken error pathJean Delvare
I broke an error path with d03c21ec0be7787ff6b75dcf56c0e96209ccbfbd, sorry about that. The machine will crash if the i2c_attach_client() or maven_init_client() calls fail, although nobody has yet reported this happening. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27i2c: normal_i2c can be made const (remaining drivers)Jean Delvare
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17drivers/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables in drivers/* with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-27[PATCH] drivers/video: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of ARRAY_SIZE. Some coding style and trailing whitespaces are also fixed. Compile-tested where possible (some are other arch or BROKEN) Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] matrox maven: memory allocation and other cleanupsJean Delvare
A few cleanups which were done to almost all i2c drivers some times ago, but matroxfb_maven was forgotten: * Don't allocate two different structures at once. * Use kzalloc instead of kmalloc+memset. * Use strlcpy instead of strcpy. * Drop duplicate error message on client deregistration failure. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] matroxfb: simply return what i2c_add_driver() doesArthur Othieno
insmod will tell us when the module failed to load. We do no further processing on the return from i2c_add_driver(), so just return what i2c_add_driver() did, instead of storing it. Add __init/__exit annotations while we're at it. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[PATCH] i2c: drop empty i2c_driver.command implementationsLaurent Riffard
Given that implementing i2c_driver.command is optional, there is no point in an empty implementation thereof. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Michael Geng <linux@MichaelGeng.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 9 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the matroxfb driver. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (5/7)Jean Delvare
Merge the algorithm id part (16 upper bits) of the i2c adapters ids into the definition of the adapters ids directly. After that, we don't need to OR both ids together for each i2c_adapter structure. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: Kill address ranges in non-sensors i2c chip driversJean Delvare
Some months ago, you killed the address ranges mechanism from all sensors i2c chip drivers (both the module parameters and the in-code address lists). I think it was a very good move, as the ranges can easily be replaced by individual addresses, and this allowed for significant cleanups in the i2c core (let alone the impressive size shrink for all these drivers). Unfortunately you did not do the same for non-sensors i2c chip drivers. These need the address ranges even less, so we could get rid of the ranges here as well for another significant i2c core cleanup. Here comes a patch which does just that. Since the process is exactly the same as what you did for the other drivers set already, I did not split this one in parts. A documentation update is included. The change saves 308 bytes in the i2c core, and an average 1382 bytes for chip drivers which use I2C_CLIENT_INSMOD, 126 bytes for those which do not. This change is required if we want to merge the sensors and non-sensors i2c code (and we want to do this). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/Documentation/i2c/writing-clients ===================================================================
