path: root/drivers/video/mb862xx
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-26drivers/video/mb862xx/mb862xxfbdrv.c needs uaccess.hAndrew Morton
alpha allmodconfig: drivers/video/mb862xx/mb862xxfbdrv.c: In function 'mb862xxfb_ioctl': drivers/video/mb862xx/mb862xxfbdrv.c:323: error: implicit declaration of function 'copy_to_user' drivers/video/mb862xx/mb862xxfbdrv.c:327: error: implicit declaration of function 'copy_from_user' Cc: Paul Mundt <lethal@linux-sh.org> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25video: mb862xx: udelay need linux/delay.hStephen Rothwell
Fix this: drivers/video/mb862xx/mb862xx-i2c.c: In function 'mb862xx_i2c_wait_event': drivers/video/mb862xx/mb862xx-i2c.c:25: error: implicit declaration of function 'udelay' caused by commit f8a6b1f44833 ("video: mb862xx: add support for controller's I2C bus adapter"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24video: mb862xxfb: add support for L1 displayingAnatolij Gustschin
Allow displaying L1 video data on top of the primary L0 layer. The L1 layer position and dimensions can be configured and the layer enabled/disabled by using the appropriate L1 controls added by this patch. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-05-24video: mb862xx: add support for controller's I2C bus adapterAnatolij Gustschin
Add adapter driver for I2C adapter in Coral-P(A)/Lime GDCs. So we can easily access devices on controller's I2C bus using i2c-dev interface. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-05-24video: mb862xxfb: relocate register space to get contiguous vramAnatolij Gustschin
By default the GDC registers are located in the middle of the 64MiB area for video RAM and registers. When 32MiB VRAM or more is used, relocate the register space to the top of the 64MiB space so that we get the contiguous VRAM for GDC frame buffer layers, drawing frames, capture and cursor buffers. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-05-24video: mb862xxfb: use pre-initialized configuration for PCI GDCsAnatolij Gustschin
If the bootloader has already initialized the display controller, do not re-initialize it in the driver. Take over the bootloader's configuration instead. This is already supported for non PCI GDCs Lime and Mint. Add this functionality for PCI GDCs Coral-P and Coral-PA. It is useful to avoid flicker and also avoids unneeded init delays while booting. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-05-24video: mb862xxfb: correct fix.smem_len field initializationAnatolij Gustschin
Initialize smem_len field to the actual frame buffer size and not to the whole video RAM size. This prevents overwriting other video memory (which could be used by other layers, cursors or accelerated drivers) by frame buffer applications relying on fix.smem_len. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-02-28dt/video: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/video. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-02of/video: fix build breakage in FB driversAnatolij Gustschin
Fixes build errors in a number of framebuffer drivers caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-04-07mb862xxfb: update Valentin's email addressAlexander Shishkin
Since Valentin's email address @siemens.com is no longer valid, it's time to change it to the one that actually works so that I don't have to manually forward patches against mb862xx to him every time. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Acked-by: Valentin Sitdikov <v.sitdikov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07mb862xxfb: fix acceleration module licenseRandy Dunlap
mb862xxfb_accel built as a separate module, but it does not have a MODULE_LICENSE, so it taints the kernel. Add a MODULE_LICENSE to it (same as mb862xxfb license). mb862xxfb_accel: module license 'unspecified' taints kernel. Or should mb862xxfb_accel be built into the mb862xxfb binary file instead? Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Alexander Shishkin <virtuoso@slind.org> Cc: Valentin Sitdikov <v.sitdikov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12obsolete config in kernel source: LWMON5Christoph Egger
There was some conditionalizing for the LWMON5 boards in kernel source. However infrastructure for enabling this isn't here so probably the special case code can go as well. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Acked-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16mb862xxfb: add acceleration support for Coral-P/Coral-PA. * imageblt * ↵Valentin Sitdikov
copyarea * fillrect [akpm@linux-foundation.org: clean up comments, remove do-nothing tests, use min()] [akpm@linux-foundation.org: fix Alexandr's email address] [akpm@linux-foundation.org: export mb862xxfb_init_accel] Signed-off-by: Valentin Sitdikov <valentin.sitdikov@siemens.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OFArnd Bergmann
With this change, the driver builds fine on Microblaze, which helps allyesconfig compile tests. I did not test sparc, but the change should have the same effect there. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Anatolij Gustschin <agust@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10drivers/video/mb862xx/mb862xxfb.c: fix printkAndrew Morton
sparc64: drivers/video/mb862xx/mb862xxfb.c:929: warning: long long unsigned int format, resource_size_t arg (arg 4) drivers/video/mb862xx/mb862xxfb.c:931: warning: long long unsigned int format, resource_size_t arg (arg 4) We don't know what type the architecture uses to implement u64, hence they cannot be printed. Cc: Anatolij Gustschin <agust@denx.de> Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Matteo Fortini <m.fortini@selcomgroup.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fbdev: add new framebuffer driver for Fujitsu MB862xx GDCsAnatolij Gustschin
Add a framebuffer driver for the Fujitsu Carmine/Coral-P(A)/Lime graphics controllers. Lime GDC support is known to work on PPC440EPx based lwmon5 and MPC8544E based socrates embedded boards, both equipped with Lime GDC. Carmine/Coral-P PCI GDC support is known to work on PPC440EPx based Sequoia board and also on x86 platform. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Matteo Fortini <m.fortini@selcomgroup.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
