Signed-off-by: Chong Zhang <chzhang@nvidia.com>
Original-Change-Id: I53eea3b14852aecd589dfbd0461258e064835cc9
Reviewed-on: http://git-master/r/11405
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R4c2c1bba6eeeee16cf3d99061717c236c695eaf7
CEA defines multiple timings with dual timing ratios that cannot
be distinguished from timings parameters. Added 2 new fb flags
to specify 4:3 or 16:9 display ratios.
Also added a flag that denotes CEA formats that require repeating
pixels.
Change-Id: I75d413babdcb4048a0ccce6548ed386ad0e52318
Signed-off-by: Lajos Molnar <molnar@ti.com>
These mode are directly from the CEA-861-E spec.
Change-Id: Ic29390fb8dfc4605da1f95aaee0e2e775dfc0a4a
Signed-off-by: Erik Gilling <konkers@android.com>
This makes the default case in fb_find_best_display ("last resort, use
the very first mode") actually use the first mode added.
Change-Id: Ia43ac4a4251522cd30c0da514da23e47b2906e2c
If there is no EDID but an LCD panel is detected, generate a CVT
mode from the panel resolution (at 60 Hz), and use this as a
default mode instead of the hardcoded 800x600x8 mode.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
A part of file: drivers/video/modedb.c was not as per the coding guidelines.
The cleanup includes:
1) Converting spcaes to tabs
2) Adding spaces on either sides of "|" operator
Signed-off-by: Mayuresh Janorkar <mayur@ti.com>
This adds a new entry to the modedb for 864x480 TAAL panels, the default
configuration for many OMAP boards. This enables omapfb to make use of
the standard mode parsing.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
Refresh rate nearness is not calculated or reset when nearest resolution
changes.
This patch resets the refresh rate differential measurement whenever a
new nearest resolution is discovered. This fixes two error cases;
first, wherein the first mode's refresh rate differential is never
calculated and second, when the closest refresh rate from a previous
nearest resolution is erroneously preserved.
Signed-off-by: Andrew Kephart <andrew.kephart@alereon.com>
Some of the modes were missing the correct sync polarities.
This was causing a corrupt or left shifted picture on my TV.
Additionally format #35 had a wrong refresh rate and pixel clock.
This patch fixes those issues.
Signed-off-by: Arnd Hannemann <arnd@arndnet.de>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Add parsing of E-EDID SVD entries. In this first version only a few
CEA/EIA-861E modes are implemented, more can be added as needed.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The function name must be followed by a space, hypen, space, and a short
description.
Kernel has simple_strtol() implementation which could be used as atoi().
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
This patch was taken from vga-sync-field version 0.0.3 [1][2].
[1] http://lowbyte.de/vga-sync-fields/vga-sync-fields-0.0.3.tgz
[2] http://git.hellersdorfer-jugendchor.de/?p=3Dvga2scart.git;a=3Dcommit;h=
=3Dc5c8ed6c51fc9879dbf38d8b91d5db6f4300ea03
Signed-off-by: Thomas Hilber <sparkie@lowbyte.de>
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net>
When I viewed drivers/video/modedb.c, I noticed a very old typo already
contained in 2.6.0.
This typo remained unheeded at least 5 years. Clear evidence of its
importance. ;)
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Frame buffer and mode setting drivers can be built as modules,
so fb_mode_option needs to be exported to support these.
Prevents this error:
ERROR: "fb_mode_option" [drivers/ps3/ps3av_mod.ko] undefined!
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
The temporary structure for calculated CVT mode is not initialized. Few
fields have only bits or-ed or and-ed so they may be left in incorrect
(random) state.
Testing of the tridentfb seems like a good exercise for the fbdev layer.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Antonino A. Daplas <adaplas@gmail.com>
Cc: Antonino Daplas <adaplas@pol.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Adrian Bunk <bunk@stusta.de>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Ben Dooks <ben-linux@fluff.org>
mode
Currently, if a perfect match in terms of resolution is not found,
fb_find_mode() only looks for a best-fit mode among modes with a higher
resolution than the one requested. Thus, if the user requests a resolution
higher than the largest supported one, they are dropped to the default mode
(usually a low resolution one).
Change this behaviour so that all valid video modes are considered when
looking for a best-fit mode, while still preferring modes with a higher
resolution.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Fix http://bugzilla.kernel.org/show_bug.cgi?id=9762
Framebuffer is ok only with default parameters only (it is 1280x800-8@60). If
parameters are video=radeonfb:1280x800-32@60 then xres, yres and xres_virtual
are ok but yres_virtual is 1024. It can be corrected by fbset utility so I
think it can be corrected in the driver code also.
Steps to reproduce: video=radeonfb:1280x800-32@60 or
video=radeonfb:1280x800-16@60
Add 1280x800 mode into modedb
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Move the extern declaration for global_mode_option to <linux/fb.h> and rename
the variable to fb_mode_option.
Currently, if the refresh rate is not specified, fb_find_mode() returns the
first known video mode with the requested resolution, which provides no
guarantees wrt the refresh rate. Change this so that the mode with the
highest refresh rate is returned when the driver provides a custom video mode
database and the monitor limits, and a mode with the safe 60 Hz refresh rate
otherwise.
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
Reported by: John Lumby <johnlumby@hotmail.com>
Some of the entries in the mode database does not match the comments and/or
the refresh field. Adjust the timings so they match with both the comments
and the refresh rate.
Make fb_destroy_modelist an exported symbol for use in the uvesafb driver.
Following the programming advice laid down in the gcc manual, make
sure the case "..." operator has spaces on either side.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
fb_videomode_to_var(): reset the virtual screen parameters when converting
from an fb_videomode to an fb_var_screeninfo.
Without this the old virtual screen parameters are kept. Hence you cannot
switch to a video mode with a lower resolution on frame buffer devices that
don't support virtual screens and panning, as values are not supposed to be
rounded down when they don't fit.
I also reordered the assignments to match the order of the individual members.
Cc: James Simmons <jsimmons@infradead.org>
fbdev modedb: make more input and output pointer parameters const
fbdev modedb: Take into account the specified refresh rates for video modes
specified by name, so e.g. all of `720p', `720p@60', and `720p@50' work.
If no default mode is specified, it should be grabbed from the supplied
database, not the default one.
[teanropo@jyu.fi: fix it]
[akpm@osdl.org: simplify it]
[akpm@osdl.org: remove pointless DEFAULT_MODEDB_INDEX]
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Signed-off-by: Tero Roponen <teanropo@jyu.fi>
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a
function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h
allows all of the framebuffer and VT console drivers to remove their
dependency on tty.h.
[akpm@osdl.org: fix alpha build]
Signed-off-by: Jon Smirl <jonsmir@gmail.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
This patch removes the following unused EXPORT_SYMBOL's:
- fbcvt.c: fb_find_mode_cvt
- fbmem.c: fb_con_duit
- fbmem.c: fb_new_modelist
- macmodes.c: mac_var_to_vmode
- modedb.c: fb_delete_videomode
- modedb.c: fb_destroy_modelist
It's a false positive, but let's suppress it anyway.
Adds 1366x768 @ 60Hz to drivers/video/modedb.c.
Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of ARRAY_SIZE. Some coding style and trailing whitespaces are
also fixed.
Compile-tested where possible (some are other arch or BROKEN)
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Add a modeline for the Philips 200W display. aty128fb does not do DDC, it
picks 1920x1440 or similar. It works ok with nvidiafb because it can ask
for DDC data.
mode "1680x1050-60"
# D: 146.028 MHz, H: 65.191 kHz, V: 59.863 Hz
geometry 1680 1050 1680 1050 16
timings 6848 280 104 30 3 176 6
hsync high
vsync high
rgba 5/11,6/5,5/0,0/0
endmode
hwinfo --monitor
20: None 00.0: 10000 Monitor
[Created at monitor.206]
Unique ID: rdCR.pzUFTofo1S4
Parent ID: 002j.bJRsY88eNSC
Hardware Class: monitor
Model: "PHILIPS Philips 200W"
Vendor: PHL "PHILIPS"
Device: eisa 0x0832 "Philips 200W"
Serial ID: "VN 016596"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@67Hz
Resolution: 640x480@72Hz
Resolution: 640x480@75Hz
Resolution: 800x600@56Hz
Resolution: 800x600@60Hz
Resolution: 800x600@72Hz
Resolution: 800x600@75Hz
Resolution: 832x624@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@70Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1152x864@70Hz
Resolution: 1152x864@75Hz
Resolution: 1280x960@60Hz
Resolution: 1280x1024@60Hz
Resolution: 1680x1050@60Hz
Driver Info #0:
Max. Resolution: 1680x1050
Vert. Sync Range: 56-85 Hz
Hor. Sync Range: 30-93 kHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #5 (VGA compatible controller)
Signed-off-by: Olaf Hering <olh@suse.de>
Acked-by: "Antonino A. Daplas" <adaplas@pol.net>
This patch adds the framebuffer mode required for an Apple PowerBook G4
Titanium.
Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch>
Add new helper, fb_find_best_display(), which will search the modelist for the
best mode for the attached display. This requires an EDID block that is
converted to struct fb_monspecs and a private modelist. The search will be
done in this manner:
- if 1st detailed timing is preferred, use that
- else if dimensions of the display are known, use that to estimate xres and
- else if modelist has detailed timings, use the first detailed timing
- else, use the very first entry from the modelist
Currently the fb_find_nearest_mode() function finds a mode with screen
resolution closest to that described by the 'var' argument and with some
arbitrary refresh rate (eg. in the following sequence of refresh rates: 70 60
53 85 75, 53 is selected).
This patch fixes the function so that it looks for the closest mode as far as
both resolution and refresh rate are concerned. The function's first argument
is changed to fb_videomode so that the refresh rate can be specified by the
caller, as fb_var_screeninfo doesn't have any fields that could directly hold
this data.
The Coordinated Video Timings (CVT) is the latest standard approved by VESA
concerning video timings generation. It addresses the limitation of GTF which
is designed mainly for CRT displays. CRT's have a high blanking requirement
(as much as 25% of the horizontal frame length) which artificially increases
the pixelclock. Digital displays, on the other hand, needs to conserve the
pixelclock as much as possible. The GTF also does not take into account the
different aspect ratios in its calculation.
The new function added is fb_find_mode_cvt(). It is called by fb_find_mode()
if it recognizes a mode option string formatted for CVT. The format is:
<xres>x<yres>[M][R][-<bpp>][<at-sign><refresh>][i][m]
The 'M' tells the function to calculate using CVT. On it's own, it will
compute a timing for CRT displays at 60Hz. If the 'R' is specified, 'reduced
blanking' computation will be used, best for flatpanels. The 'i' and the 'm'
is for 'interlaced mode' and 'with margins' respectively.
To determine if CVT was used, check for dmesg for something like this:
CVT Mode - <pix>M<n>[-R], ie: .480M3-R (800x600 reduced blanking)
where: pix - product of xres and yres, in MB
M - is a CVT mode
n - the aspect ratio (3 - 4:3; 4 - 5:4; 9 - 16:9, 15:9; A - 16:10)
-R - reduced blanking
Reported by:Vincent Fortier (Bugzilla Bug 4768)
"At boot time the screen appears moved to the mid right portion of the actual
video pannel making the end of the line appears at the left edge... It simply
looks like moved half way to the right"
His particular hardware has a display with an unusual dimension (1920x1200) but
unfortunately has no EDID block. None of the entries in the global mode
database is correct for this particular display, and it particularly has
difficulty scaling up 640x480 (the default startup mode of nvidiafb) to
1920x1200 which causes the above described problem.
1, Add 1920x1200 to the global mode database.
2. Let nvidiafb base the startup mode from the flatpanel dimensions only if the
EDID block is absent, no boot mode parameter is specified by the user, and
a flatpanel/LCD display is attached.
infrastructure for it.
Let it rip!
