path: root/drivers/video/neofb.c
2009-01-06neofb: fix sparse warningsHannes Eder
Fix this sparse warnings: drivers/video/neofb.c:1456:4: warning: returning void-valued expression drivers/video/neofb.c:1464:3: warning: returning void-valued expression Signed-off-by: Hannes Eder <hannes@hanneseder.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16neofb: remove open_lock mutexKrzysztof Helt
Remove mutex from the fb_open/fb_release functions as these operations are mutexed at fb layer. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16neofb: kill some redundant codeKrzysztof Helt
Move common code outside if/else or switch/case clauses. Drop checks done twice inside the neofb_check_var(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16neofb: reduce panning functionKrzysztof Helt
Reduce panning function by deleting checks done by higher layer and folding remaining function into the called one. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24neofb: drop the xtimings structureKrzysztof Helt
Remove the xtimings structure which only stored some values to be used later (mostly once). Calculate and use these values in places they are needed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24neofb: drop redundant codeKrzysztof Helt
Drop structure which is only set but never read. Drop variables which are only set and never read. Convert one long switch into two shorter ones. Add cpu_relax() in busy waiting loop. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24neofb: simplify clock calculationKrzysztof Helt
There is nothing to gain by converting value in kHz to fixed point MHz. Just calculate everything in kHz. A reorder of the loop allows reducing number of iterations (check if frequency is not too high already). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06neofb: avoid overwriting fb_info fieldsAndrew Morton
Fix bug identified by Marcio Buss in http://bugzilla.kernel.org/show_bug.cgi?id=9565 - neofb can overwrite a field in the fb_info struct. This fix will result in truncated device identification strings - perhaps fb_innfo.fix.id can be made larger? Cc: Marcio Buss <marciobuss@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Christian Trefzer <ctrefzer@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-31neofb: Fix pseudo_palette array overrun in neofb_setcolregAntonino A. Daplas
The pseudo_palette has room for 16 entries only, but in truecolor mode, it attempts to write 256. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: Tero Roponen <teanropo@jyu.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08neofb: fill transp->msb_right with the correct valueAntonino A. Daplas
Fill transp->msb_right with the correct value. fbcon ignores this, but user apps may not. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Video: fb, add true ref_count atomicityJiri Slaby
Some of fb drivers uses atomic_t in bad manner, since there are still some race-prone gaps. Use mutexes to protect open/close code sections with ref_count testing and finally use simple uint. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Denis Oliver Kropp <dok@directfb.org> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] proper prototype for tosh_smm()Adrian Bunk
Add a proper prototype for tosh_smm() to include/linux/toshiba.h Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] video: neofb stray bracket fixMariusz Kozlowski
This code is '#if 0'ed. Anyway if anyone wants to dump neo registers better to have it fixed. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] neofb: fix unblank logic interfering with lid toggled backlightChristian Trefzer
This is a fix for the most annoying problem that remained with neofb: After "setterm -powersave powerdown" the console blanker will disable the backlight after the given timeout expires. If this happens after the lid has been shut, we read "LCD off" from the register and store that in the driver. Once the lid is opened, the backlight turns on, but any key press that would awaken the blanked console will switch the backlight off again. The workaround so far was to use the "display config toggle" Fn key combo - once if no external display is attached, otherwise as often as required to restore the desired display setup. The following patch fixes the issue at least for the LCD-only case, with no external monitor attached. Other display setup permutations are pending further testing, but so far I can guarantee at least no negative change in behaviour, if any at all. Signed-off-by: Christian Trefzer <ctrefzer@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] drivers/video: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of ARRAY_SIZE. Some coding style and trailing whitespaces are also fixed. Compile-tested where possible (some are other arch or BROKEN) Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] neofb: Fix uninitialized valueAntonino A. Daplas
Remove insignificant and unitialized variable "waitcycles" from neo2200_sync. Coverity Bug 895 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] neofb: avoid resetting display config on unblank (v2)Christian Trefzer
There were two mistakes in the register-read-on-(un)blank approach. - First, without proper register (un)locking the value read back will always be zero, and this is what I missed entirely until just now. Due to this, the logic could not be verified at all and I tried some bogus checks which are completely stupid. - Second, the LCD status bit will always be set to zero when the backlight has been turned off. Reading the value back during unblank will disable the LCD unconditionally, regardless of the state it is supposed to be in, since we set it to zero beforehand. So this is what we do now: - create a new variable in struct neofb_par, and use that to determine whether to read back registers (initialized to true) - before actually blanking the screen, read back the register to sense any possible change made through Fn key combo - use proper neoUnlock() / neoLock() to actually read something - every call to neofb_blank() determines if we read back next time: blanking disables readback, unblanking (FB_BLANK_UNBLANK) enables it This should give us a nice and clean state machine. Has been thoroughly tested on a Dell Latitude CPiA / NM220 Chip docked to a C/Dock2 with attached CRT in all possible combinations of LCD/CRT on/off. I changed the config via Fn key, let the console blank, unblanked by keypress - works flawlessly. Signed-off-by: Christian Trefzer <ctrefzer@gmx.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] neofb: avoid resetting display config on unblankChristian Trefzer
Fix issues with the NeoMagic framebuffer driver. It nicely complements my previous fix already in linus' tree. The only thing missing now is that the external CRT will not be activated at neofb init when external-only is selected, either by register read or module/kernel parameter. Testing was done on a Dell Latitude CPi-A/NM2200 chip. Previous behaviour: - before booting linux, set the preferred display config X via FN+F8 - boot linux, neofb stores the register values in a private variable - change the display config to Y via keystroke - leave the machine in peace until display is blanked - touching any key will result in display config X being restored - booting up, the BIOS will acknowledge config Y, though... Current behaviour: At the time of unblanking, config Y is honoured because we now read back register contents instead of just overwriting them with outdated values. Signed-off by: Christian Trefzer <ctrefzer@gmx.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] neofb: take existing display configuration as defaultChristian Trefzer
On a Dell Latitude CPi-A I noticed a strangeness wrt. the handling of an external monitor by the neomagic framebuffer driver, namely when the laptop is docked in a C/Dock II with the lid shut. A cold boot would result in the BIOS configuring the video chip to use the "external monitor only" mode, yet neofb would default to "internal LCD only". An attempt for a quick fix by using the Fn-F8 keystroke to toggle the display combination modes resulted in a reproductible hard lock, powering down being the only solution. The attached patch makes neofb probe the register for the current display mode, using that value as a default if nothing was specified as kernel/module parameter. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: neofb: Driver cleanupsAntonino A. Daplas
- remove unneeded casts - move memory for pseudo_palette inside struct neofb_par Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
