path: root/drivers/video/omap/blizzard.c
2011-03-22omap: use list_move() instead of list_del()/list_add() combinationKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-27drivers/video/omap/blizzard.c: suspected typo in assignmentNicolas Kaiser
Untested, but looks like an obvious typo to me. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Cc: Tomi Valkeinen <tomi.valkeinen@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09OMAP: OMAPFB: split omapfb.hTomi Valkeinen
Split arch/arm/plat-omap/include/mach/omapfb.h into two files: include/linux/omapfb.h - ioctls etc for userspace and some kernel stuff for board files drivers/video/omap/omapfb.h - for omapfb internal use This cleans up omapfb.h and also makes it easier for the upcoming new DSS driver to co-exist with the old driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-06omapfb: Blizzard: constify register address tablesTommi Rantala
Constify register address tables Cc: Tomi Valkeinen <tomi.valkeinen@nokia.com> Cc: Imre Deak <imre.deak@nokia.com> Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-06omapfb: Blizzard: fix pointer to be constTommi Rantala
Fixes a compiler warning: warning: assignment discards qualifiers from pointer target type Cc: Tomi Valkeinen <tomi.valkeinen@nokia.com> Cc: Imre Deak <imre.deak@nokia.com> Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-23omapfb: add support for rotation on the Blizzard LCD ctrlRodrigo Vivi
The LCD controller (EPSON S1D13744) supports rotation (0, 90, 180 and 270 degrees) on hardware just setting the bits 0 and 1 of 0x28 register (LCD Panel Configuration Register). Now it is possible to use this caps only setting the angle degree on var rotate of fb_var_screeninfo using the FBIOPUT_VSCREENINFO ioctl. Fixed-by: Siarhei Siamashka <siarhei.siamashka@nokia.com> Signed-off-by: Rodrigo Vivi <rodrigo.vivi@openbossa.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Imre Deak <imre.deak@nokia.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17OMAP: add external Epson Blizzard LCD controller supportImre Deak
- Adds Epson Blizzard lcd controller driver; used in Nokia Internet Tablet products. Signed-off-by: Trilok Soni <soni.trilok@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
