path: root/drivers/video/pm3fb.c
2009-01-06pm3fb: fix sparse warningHannes Eder
Fix this sparse warning: drivers/video/pm3fb.c:543:3: warning: returning void-valued expression Signed-off-by: Hannes Eder <hannes@hanneseder.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pm3fb: change option mode to mode_optionKrzysztof Helt
Add the option "mode_option". This is one step toward changing all fb drivers to have common "mode_option" parameter. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/video/pm3fb.c section fixAdrian Bunk
WARNING: vmlinux.o(.text+0x46e456): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e45c): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e49b): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e4a0): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e4bc): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e4c2): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e5c1): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') WARNING: vmlinux.o(.text+0x46e5c7): Section mismatch: reference to .init.data: (between 'pm3fb_size_memory' and 'update_crtc2') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: replace busy waiting with cpu_relaxKrzysztof Helt
This patch replaces busy waiting with the cpu_relax() call. This makes scrolling faster. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: hardware cursor supportKrzysztof Helt
This patch adds hardware cursor support to the pm3fb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: checkpatch fixesKrzysztof Helt
This patch fixes all errors detected by checkpatch.pl script in the pm3fb.c file. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: mtrr support and noaccel optionKrzysztof Helt
This patch adds usage of MTRR registers and two new options: noaccel and nomtrr. [bunk@kernel.org: make pm3fb_init() static again] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: improvements and cleanupsKrzysztof Helt
This patch contains improvements: - it adds ROP_XOR in pm3fb_fillrect() - it conforms closer to coding style - it removes redundant parentheses and setting bits with 0 value - it checks if hardware acceleration is disabled in pm3fb_imageblit - it adds module description Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: 3 small fixesKrzysztof Helt
This patch contains 3 small improvements: - it corrects scan line width calculation in pm3fb_imageblit() - it corrects mmio mapping for big endian machines - it enables panning acceleration constants Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: imageblit improvedKrzysztof Helt
This patch removes the pm3_imageblit() restriction to blit only images with width divisable by 32. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: header file reductionKrzysztof Helt
This patch removes constants named AAA_DISABLE with value 0. They are redudant and misleading ( a |= AAA_DISABLE does nothing and usually should be a &= ~AAA_ENABLE). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16pm3fb: copyarea and partial imageblit supporKrzysztof Helt
This patch adds accelerated copyarea and partially accelerated imageblit functions. There is also fixed one register address in the pm3fb.h file. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17pm3fb: possible cleanupsAdrian Bunk
- remove the empty pm3fb_setup() and corresponding code - pm3fb_init() can become static [adaplas] - retain call to fb_get_options() for global options Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17pm3fb: fillrect accelerationKrzysztof Helt
This is a port of accelerated fillrect function from the 2.4 kernel driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01pm3fb: switching between X and fb fixKrzysztof Helt
This patch correctly restores console state after switching from X. Otherwise, screen is always off after switching from X. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23pm3fb: various fixesKrzysztof Helt
- fix 16-bit RGBA 4444 and 5551 modes (use fbset -rgba to set them) - kill wmb() after each register write by PM3_SLOW_WRITE_REG - kill inaccurate comments (leftovers from skeletonfb.c) - kill PCI class restriction, now it is more general and shorter - white spaces and other minor fixes and source reducing Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-12pm3fb: Fix compile error if moduleAntonino A. Daplas
pm3fb_setup() should only compiled if pm3fb is built statically in the kernel. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11pm3fb: Preliminary 2.4 to 2.6 portKrzysztof Helt
This is a basic port from 2.4 kernel to 2.6. Acceleration is lost and big endian support probably too. The driver works in 8, 16 and 32 bit mode. [adaplas] - change VESA_* to FB_BLANK_* constants - removed unused function clear_memory - fix uninitialized variable compiler warning - some whitespace cleaning [akpm@linux-foundation.org: Nuke pestiferous CVS string] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] pm3fb: kill pci_find_device usageAlan
Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] drivers/video: Replace custom macro with isdigit()Tobias Klauser
Replace the custom CHAR_IS_NUM() macro with isdigit() from <linux/ctype.h> Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Acked-by: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] pm3fb typo fixAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
