path: root/drivers/video/s1d13xxxfb.c
2010-12-21s1d13xxxfb: drop unused codeAndres Salomon
Silence warnings such as - drivers/video/s1d13xxxfb.c:421: warning: ‘bltbit_wait_bitset’ defined but not used Just drop the unused code. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-16fbdev: s1d13xxxfb: add accelerated bitblt functionsKristoffer Ericson
Add accelerated bitblt functions to s1d13xxx based video chipsets, more specificly functions copyarea and fillrect. It has only been tested and activated for 13506 chipsets but is expected to work for the majority of s1d13xxx based chips. This patch also cleans up the driver with respect of whitespaces and other formatting issues. We update the current status comments. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fbdev: update s1d13xxxfb to differ between revisions and production idsKristoffer Ericson
The s1d13xxx chip provides two values of identification value: the Production id (e.g 13506/13505/13806..) and a revision number 0,1,2,3). Together these can help us to differentiate between similiar setups. This patch adds the proper way of grabbing both those values and save them for future reference (in order to decide what functions a card supports, e.g acceleration). We also move away from the concept of all s1d13xxx = s1d13806 when we really support alot more. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: simplify s1d13xxxfb_probe()] Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16fbdev: allow more chip revisions in Epson s1d13... video driverKristoffer Ericson
The Epson s1d13xxx hardware is common in many handhelds, but our driver is currently locked to a single chip revision. This patch adds an array of known to work revisions (which can be extended). [akpm@linux-foundation.org: cleanups] Signed-off-by: Kristoffer Ericson <Kristoffer.Ericson@gmail.com> Acked-by: Thibaut Varène <varenet@parisc-linux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14drivers/video/s1d13xxxfb.c: fix build as module with dbgStanislav Brabec
Attached patch fixes two compilation problems of s1d13xxxfb.c: - Fixes outdated dbg() message to fix compilation error with debugging enabled. - Do not read kernel command line options when compiled as module. Signed-off-by: Stanislav Brabec <utx@penguin.cz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-11[PATCH] s1d13xxxfb: Fix resource leakAntonino A. Daplas
struct info may not be released in the driver's error path. Coverity Bug 672 Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] swsusp: fix remaining u32 vs. pm_message_t confusionPavel Machek
Fix remaining bits of u32 vs. pm_message confusion. Should not break anything. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] m32r: framebuffer device supportHirokazu Takata
This patch is for supporting Epson s1d13xxx framebuffer device for m32r. # Sorry, a little bigger. The Epson s1d13806 is already supported by 2.6.12 kernel, and its driver is placed as drivers/video/s1d13xxxfb.c. For the m32r, a header file include/asm-m32r/s1d13806.h was prepared for several m32r target platforms. It was originally generated by an Epson tool S1D13806CFG.EXE, and modified manually for the m32r platforms. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] s1d13xxxfb linkage fixAndrew Morton
s1d13xxxfb_remove() is referenced from s1d13xxxfb_probe(), which is marked __devinit(). So s1d13xxxfb_remove() cannot be marked __devexit. Does this all make sense? Clearly the __devexit section will still be in core when the __devinit code is run, if the driver was loaded as a module. But I suppose that if the driver is statically linked, the __devexit section might be dropped early in boot. Still, we wouldn't drop __devexit prior to initcall completion, at which point the __devinit code has all been run anyway. verdict: this code was legal and made sense. Is this a generic problem, or an arm-specific problem? UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 `.exit.text' referenced in section `.init.text' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o Cc: Russell King <rmk@arm.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
