path: root/drivers/video/s3c2410fb.h
2014-04-17video: move fbdev to drivers/video/fbdevTomi Valkeinen
The drivers/video directory is a mess. It contains generic video related files, directories for backlight, console, linux logo, lots of fbdev device drivers, fbdev framework files. Make some order into the chaos by creating drivers/video/fbdev directory, and move all fbdev related files there. No functionality is changed, although I guess it is possible that some subtle Makefile build order related issue could be created by this patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rob Clark <robdclark@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2009-06-16s3c-fb: CPUFREQ frequency scaling supportBen Dooks
Add support for CPU frequency scaling in the S3C24XX video driver. Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: clean out changelog header and tidyBen Dooks
Remove the old changelog entries which are now out of date and should be extractable from git anyway. Also tidy up the copyright for the driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06FB/S3C2412: add S3C2412 support to S3C2410 fb driverBen Dooks
Add support for the S3C2412 to the S3C2410 frame buffer driver by ensuring that any moved registers can be dealt with. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Vincent Sanders <vince@simtec.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: source code improvementsKrzysztof Helt
This patch: - moves more display mode preparations to s3c2410fb_check_var() - reduces number of fields in s3c2410fb_info - removes redundant values setting in s3c2410fb_probe() - removes static mach_info pointer - releases fb_info structure in s3c2410fb_remove() - changes s3c2410fb_init to __init from __devinit - fixes few typos in comments and removes unused includes Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: multi-display supportKrzysztof Helt
This patch adds a new structure to describe and handle more than one panel (display mode) for the s3c2410 framebuffer. This structure is added after the pxafb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3c2410fb: remove fb_info pointer from s3c2410fb_infoKrzysztof Helt
This patch removes redundant fb field from the s3c2410fb_info structure. This breaks circular reference fb_info -> s3c2410fb_info -> fb_info again. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31s3c2410fb: fix s3c2410 compilationBen Dooks
The implicit mapping has been removed from the arch as this should be handled in the driver, this patch fixes the s3c2410_fb driver to ioremap() the necessary registers. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-09-09[PATCH] s3c2410fb: ARM S3C2410 framebuffer driverArnaud Patard
This set of two patches add support for the framebuffer of the Samsung S3C2410 ARM SoC. This driver was started about one year ago and is now used on iPAQ h1930/h1940, Acer n30 and probably other s3c2410-based machines I'm not aware of. I've also heard yesterday that it's working also on iPAQ rx3715/rx3115 (s3c2440-based machines). Signed-Off-By: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Ben Dooks <ben@trinity.fluff.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
