path: root/drivers/video/s3fb.c
2011-04-20s3fb: fix up DDC build with MTRR disabled.Paul Mundt
drivers/video/s3fb.c: In function 's3_pci_remove': drivers/video/s3fb.c:1388: error: 'par' undeclared (first use in this function) Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-04-19s3fb: add DDC supportOndrej Zary
Add I2C support for the DDC bus and also default mode initialization by reading monitor EDID to the s3fb driver. Tested on Trio64V+ (2 cards), Trio64V2/DX, Virge (3 cards), Virge/DX (3 cards), Virge/GX2, Trio3D/2X (4 cards), Trio3D. Will probably not work on Trio32 - my 2 cards have DDC support in BIOS that looks different from the other cards but the DDC pins on the VGA connector are not connected. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-31s3fb: fix Virge/GX2Ondrej Zary
Fix Virge/GX2 support in s3fb: - fix IDs: 86C357 is GX2, 86C359 is GX2+, 86C356 probably does not exist - add memory size detection - drive it the same way as Trio3D/2X The original IDs most likely came from S3 website which claims that: - 356 is Virge/GX2 with ID=8A10, driver included in Windows 2K, XP - 357 is Virge/GX2+ with ID=8A11, driver included in Windows ME - 359 is Virge/GX2+ with ID=8A12, driver included in Windows ME but: - google search for 86C356 only reveals references to Trio3D (probably because of a typo - Trio3D is 86C365) - my card is clearly marked as 86C357, Virge/GX2 and has ID=8A10 - there is no driver for IDs 8A11 and 8A12 in Windows ME - there is a driver for ID 8A10 in Windows ME that says it's GX2 (357) Tested with #9 Reality 334 (86C357 Virge/GX2, ID=0x8A10). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: use new start address registerOndrej Zary
Use "new" start address register 0x69 (bits 16-20) instead of "old" 0x31 (bits 16-17) and 0x51 (bits 18-19). This is needed for panning to work correctly on Trio3D/2X cards (and does no harm on other ones). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: enable DTPCOndrej Zary
Enable Data Transfer Position Control (DTPC). This is needed at least on Virge/DX to correctly display at higher pixclocks. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: fix 15/16bpp modes with over 115MHz pixclocks on 86C365 Trio3DOndrej Zary
Enable pixel multiplexing in 15/16bpp modes when pixclock is over 115MHz on Trio3D (86C365) cards to fix artifacts on the left side of screen. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: add support for 86C365 Trio3DOndrej Zary
Add support for S3 Trio3D (86C365) cards to s3fb driver. Tested with one 4MB card. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: maximize virtual vertical size for fast scrollingOndrej Zary
Maximize virtual vertical framebuffer size during init to allow fast scrolling (accelerated by panning). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: Compute VGA base iomem pointer explicitly.David Miller
This allows the driver to work in multi-domain PCI configurations. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22s3fb: Don't clobber par->state.vgabase during open method.David Miller
2011-03-22s3fb: Pass par->state.vgabase to vga_*() calls.David Miller
Instead of just plain NULL. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22svga: Make svga_set_timings() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_tilecursor() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_set_textmode_vga_regs() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_set_default_crt_regs() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_wcrt_mask() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_wseq_mask() take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_set_default_seq_regs take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_set_default_atc_regs take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_set_default_gfx_regs take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_wcrt_multi take an iomem regbase pointer.David Miller
2011-03-22svga: Make svga_wattr take an iomem regbase pointer.David Miller
And use vga_{r,w}(). Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27add support for S3 Trio3D/1X/2XOndrej Zary
Add support for S3 Trio3D/1X (86C360) and S3 Trio3D/2X (86C362 and 86C368) cards to s3fb driver. Tested with 86C362 AGP and 86C368 PCI&AGP. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-13s3fb: fix color component length for pseudocolor modesMichal Januszewski
s3fb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 or 4 bits are used per pixel. Fix this by setting the length to 8 or 4, respectively. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05vt8623fb: fix kernel oopsOndrej Zajicek
commit 20e061fb750d36ec0ffcb2e44ed7dafa9018223b Author: Ondrej Zajicek <santiago@crfreenet.org> Date: Mon Apr 28 02:15:18 2008 -0700 fbdev: framebuffer_alloc() fixes Correct the dev arg of framebuffer_alloc() in arkfb, s3fb and vt8623fb. causes a null-pointer deref because "info->dev is NULL, info was just kzallocated". Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Reported-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net> Tested-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <stable@kernel.org> [2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: framebuffer_alloc() fixesOndrej Zajicek
Correct the dev arg of framebuffer_alloc() in arkfb, s3fb and vt8623fb. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28s3fb: add option mode_optionKrzysztof Helt
Add the option "mode_option". It also moves mtrr variable to devinitdata section. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16s3fb: do not allow incorrect pixclock settingsKrzysztof Helt
This patch adds check if selected pixclock is valid (is in the PLL range). Previously, if the pixclock could not be set, the new mode resolution was set but pixclock was not set which led to incorrect timings sent to monitor. [adaplas] Fixed a few misplaced curly braces. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16svgalib: mode selection updatesOndrej Zajicek
This patch changes mode selection matching algorithm. It allows to choose mode with matching depth even when requested color lengths are greater than color lengths of every mode with requested color depth. It also fixes bug in s3fb - wrong error value returned when format is not supported by chip. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09svgalib: move fb_get_caps to svgalibAntonino A. Daplas
Move fb_get_caps() method to svgalib.c as svga_get_caps() so it can be used by s3fb, arkfb and vt8623fb. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: updatesOndrej Zajicek
Move s3fb_get_tilemax to svgalib.c as svga_get_tilemax, because it reports limitation of other code from svgalib (svga_settile, svga_tilecopy, ...) Limit font width to 8 pixels in 4 bpp mode. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: implement fb_get_capsAntonino A. Daplas
Implement fb_get_caps(). This will allow the driver to tell upper layer that it can only support 256 8x16 bitmaps when in tileblitting mode (var->bits_per_pixel == 0); Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: driver fixesOndrej Zajicek
This fixes broken fbcon on Virge VX in 24 bpp mode, and contains several other small updates. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: implement fb_get_tilemax()Antonino A. Daplas
Implement fb_get_tilemax(). It just returns 256. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: limit 8x16 rectangles when tileblitting is enabledAntonino A. Daplas
If tileblitting is enabled (text mode), the hardware can only accept 8x16 bitmaps. Advertise this to the upper layer. And to ensure that an appropriate font is always available, select an 8x16 font in Kconfig. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: add sparse annotationsAntonino A. Daplas
Add sparse annotations and use fb_read/fb_write and family to access the framebuffer. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: fix PCI must_checksRandy Dunlap
drivers/video/s3fb.c:1078: warning: ignoring return value of 'pci_enable_device', declared with attribute warn_unused_result Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-22[PATCH] drivers/video/s3fb.c: fix a use-before-checkAdrian Bunk
NULL checks should be before the first dereference. Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26[PATCH] Fix build-failure in drivers/video/s3fb.cOndrej Zajicek
Toralf Förster pointed out that drivers/video/s3fb.c would fail to compile: > ... > CC drivers/video/s3fb.o > drivers/video/s3fb.c: In function `s3_pci_remove': > drivers/video/s3fb.c:1003: warning: unused variable `par' > drivers/video/s3fb.c: In function `s3fb_setup': > drivers/video/s3fb.c:1141: error: `mtrr' undeclared (first use in this function) > drivers/video/s3fb.c:1141: error: (Each undeclared identifier is reported only once > drivers/video/s3fb.c:1141: error: for each function it appears in.) > make[2]: *** [drivers/video/s3fb.o] Error 1 > make[1]: *** [drivers/video] Error 2 > make: *** [drivers] Error 2 Here is fix, it also fixes broken boot options. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fbdev driver for S3 Trio/VirgeOndrej Zajicek
Add a driver for S3 Trio / S3 Virge. Driver is tested with most versions of S3 Trio and with S3 Virge/DX, on i386. (akpm: We kind-of have support for this hardware already, but... virgefb.c - amiga/zorro specific, - broken (according to Kconfig), - uses obsolete/nonexistent interface (struct display_switch) - recent Adrian Bunk's patch removes this driver S3triofb.c - ppc/openfirmware specific - minimal functionality - broken (according to Kconfig), - uses obsolete/nonexistent interface (struct display_switch) ) Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
