path: root/drivers/video/sa1100fb.c
2010-03-07platform-drivers: move probe to .devinit.text in drivers/videoUwe Kleine-König
A pointer to a probe callback is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Adrian Bunk <bunk@stusta.de> Cc: Alberto Mardegan <mardy@users.sourceforge.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andriy Skulysh <askulysh@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Frans Pop <elendil@planet.nl> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Helge Deller <deller@gmx.de> Cc: Huang Ying <ying.huang@intel.com> Cc: Ian Molton <spyro@f2s.com> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Kaj-Michael Lang <milang@tal.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Magnus Damm <damm@igel.co.jp> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Roland Stigge <stigge@antcom.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Vincent Sanders <vince@simtec.co.uk> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Peter Jones <pjones@redhat.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sa1100fb: fix color component length for pseudocolor modesMichal Januszewski
sa1100fb incorrectly sets the length of the color fields to 8 bits for PSEUDOCOLOR modes for which only 4 bits are used per pixel. Fix this by setting the length to 4 bits for these modes. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-25[ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.hRussell King
2009-02-21[ARM] 5407/1: SA1100: drop broken for ages iPAQ h3800 supportDmitry Artamonow
Code has never been in buildable state since initial merge. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] remove memzero()Russell King
As suggested by Andrew Morton, remove memzero() - it's not supported on other architectures so use of it is a potential build breaking bug. Since the compiler optimizes memset(x,0,n) to __memzero() perfectly well, we don't miss out on the underlying benefits of memzero(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24sa1100fb: convert ctrlr_sem in a mutexMatthias Kaehlcke
The semaphore ctrlr_sem is used as a mutex. Convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-17[ARM] 4035/1: fix collie compilationPavel Machek
Thanks to Al Viro, here's fix to 2.6.20-rc1-git, so that collie compiles, again. It was broken by INIT_WORK changes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: video: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] handle errors returned by platform_get_irq*()David Vrabel
platform_get_irq*() now returns on -ENXIO when the resource cannot be found. Ensure all users of platform_get_irq*() handle this error appropriately. Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[ARM] Remove asm/irq.h includes from ARM driversRussell King
Many ARM drivers do not need to include asm/irq.h - remove this unnecessary include from some ARM drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-14[PATCH] zaurus: fix compilation with cpufreq disabledPavel Machek
This fixes compilation with CPU_FREQ disabled. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-07[PATCH] ARM: Make sa1100fb_display_dma_period() an inline functionRussell King
This function produces a warning when CPU_FREQ=n. Since it's a very simple calculation, make it inline instead of adding preprocessor directives around it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-16[PATCH] fix u32 vs. pm_message_t in driver/videoPavel Machek
This fixes u32 vs. pm_message_t confusion in drivers/video. Should change no code. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
