path: root/drivers/video/sis/sis_main.c
2014-04-17video: move fbdev to drivers/video/fbdevTomi Valkeinen
The drivers/video directory is a mess. It contains generic video related files, directories for backlight, console, linux logo, lots of fbdev device drivers, fbdev framework files. Make some order into the chaos by creating drivers/video/fbdev directory, and move all fbdev related files there. No functionality is changed, although I guess it is possible that some subtle Makefile build order related issue could be created by this patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rob Clark <robdclark@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-10-29framebuffer: Use fb_<level>Joe Perches
Neaten and shorten the code using the new fb_<level> macros. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-09-19video: sisfb: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-01-03Drivers: video: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-08video/sis: Annotate SiS_DRAMType as __devinitconstPeter Huewe
SiS_DRAMType is const and only used by sisfb_post_300_rwtest which is marked __devinit we can annotate SiS_DRAMType with __devinitconst and move it into the file scope in order to not have it created on the stack. This patch decreases the compiled module size by about 100bytes. And since hardcoded values are bad we use ARRAY_SIZE for determining the size of SiS_DRAMType ;) Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2011-08-19sisfb: use display information in info not in var for panningLaurent Pinchart
We must not use any information in the passed var besides xoffset, yoffset and vmode as otherwise applications might abuse it. Fix checkpatch.pl warnings in the surrounding code. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2011-03-22sisfb: add support for XGI Z9 DDR2 POSTAaro Koskinen
Add support for ZGI Z9 DDR2 POST. The init sequence is from XGI's xgifb driver. Tested with ARM board using a PCI card with XGI Z9s and 32 MB DDR2 memory. After a cold reset the POST succeeds. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sisfb: move XGI POST DDR2 bootup code into subroutinesAaro Koskinen
Move DDR2 register setting code into separate subroutines. No changes in functionality. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sisfb: add RAM type detection for XGI Z9Aaro Koskinen
Detect the XGI Z9 RAM type as "documented" by the XGI's xgifb driver. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sisfb: add subroutine for detecting XGI Z9Aaro Koskinen
Z7 and Z9 have the same PCI ID, so additional checking is needed to detect Z9. The method was "documented" in XGI's xgifb driver. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sisfb: move XGI POST RAM type detection into a subroutineAaro Koskinen
Move XGI POST RAM type detection into a separate subroutine to make further code changes easier. No changes in functionality Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22sisfb: POST should fail if R/W test failsAaro Koskinen
Currently there is no indication if R/W test fails during POST. This can happen e.g. when user plugs in a card with unsupported type of memory. Since the driver will be unusable, it's better to fail the whole POST if the memory cannot be configured properly. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: eliminate compiler warningsAaro Koskinen
Convert some bit masks to 8-bit values to avoid the following compiler warnings: drivers/video/sis/sis_main.c:3858: warning: large integer implicitly truncated to unsigned type drivers/video/sis/init301.c:5855: warning: large integer implicitly truncated to unsigned type drivers/video/sis/init301.c:5869: warning: large integer implicitly truncated to unsigned type Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace setSISIDXREG with SiS_SetRegANDORAaro Koskinen
Replace setSISIDXREG() with SiS_SetRegANDOR(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace andSISIDXREG with SiS_SetRegANDAaro Koskinen
Replace andSISIDXREG() with SiS_SetRegAND(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace orSISIDXREG with SiS_SetRegORAaro Koskinen
Replace orSISIDXREG() with SiS_SetRegOR(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace outSISIDXREG with SiS_SetRegAaro Koskinen
Replace outSISIDXREG() with SiS_SetReg(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace inSISIDXREG with SiS_GetRegAaro Koskinen
Replace inSISIDXREG() with SiS_GetReg(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace outSISREG with SiS_SetRegByteAaro Koskinen
Replace outSISREG() with SiS_SetRegByte(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: replace inSISREG with SiS_GetRegByteAaro Koskinen
Replace inSISREG() with SiS_GetRegByte(). Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22sisfb: eliminate unused variable compiler warningAaro Koskinen
Eliminate the following compiler warning on non-x86 platforms by limiting the variable scope: drivers/video/sis/sis_main.c:4108: warning: unused variable 'temp' Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: move the CONFIG warning to sis_main.cAaro Koskinen
sis_main.c is always compiled, so we can check Kconfig options there. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: delete fallback code for pci_map_rom()Aaro Koskinen
If pci_map_rom() fails, there is some fallback code that basically duplicates pci_map_rom() on non-x86 platforms. No point in that. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: delete obsolete PCI ROM bug workaroundAaro Koskinen
Delete a workaround for a PCI ROM bug that has been fixed ages ago by the commit 761a3ac08c63718dacde12aaf0ec6d6760e8c2b7. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10sisfb: limit POST memory test according to PCI resource lengthAaro Koskinen
If the POST memory test fails, the driver may access illegal memory areas. Instead of hard coding the maximum size, set it according to the PCI resource length (an additional check is needed in sisfb_post_map_vram() to ensure it's big enough). DRAM sizing will later adjust video_size to the correct value. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-22drivers/video/sis/sis_main.c: prevent reading uninitialized stack memoryDan Rosenberg
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16 bytes of uninitialized stack memory, because the "reserved" member of the fb_vblank struct declared on the stack is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25sis: strcpy() => strlcpy()Dan Carpenter
These are different size buffers (40 chars vs 16), we may as well be cautious. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12fbdev: remove obsolete CONFIG_FB_SOFT_CURSORChristoph Egger
The config Option FB_SOFT_BUFFER was removed in c465e05a03209651078b95686158648fd7ed84c5 ("fbcon/fbdev: Move softcursor out of fbdev to fbcon"). While moving to fbcon this single driver has it left as a select in KConfig / #ifdef in source. This last occurence is removed here so the option is really gone Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: TV_PALN bit set twice in sisfb_detect_VB_connect()Roel Kluin
The TV_PALN bit was tested twice, replace one by TV_PALM. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23sisfb: read buffer overflowRoel Kluin
If called with mode_idx = 1, rate = 68, a read occurs from sisfb_vrate[-1].refresh. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-06sisfb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove redundant call to the sisfb_get_fix() before sis frambuffer is registered. This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30fbdev: add mutex for fb_mmap lockingKrzysztof Helt
Add a mutex to avoid a circular locking problem between the mm layer semaphore and fbdev ioctl mutex through the fb_mmap() call. Also, add mutex to all places where smem_start and smem_len fields change so the mutex inside the fb_mmap() is actually used. Changing of these fields before calling the framebuffer_register() are not mutexed. This is 2.6.31 material. It removes one lockdep (fb_mmap() and register_framebuffer()) but there is still another one (fb_release() and register_framebuffer()). It also cleans up handling of the smem_start and smem_len fields used by mutexed section of the fb_mmap(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: use framebuffer_release() for freeing fb_info structuresKrzysztof Helt
Use the framebuffer_release() for freeing fb_info structures allocated with framebuffer_alloc(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sisfb: fix color component length for pseudocolor modesMichal Januszewski
sisfb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 bits are always used per pixel. Fix this by setting the length to 8. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Thomas Winischhofer <thomas@winischhofer.net> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24video/sis/: remove compat codeAdrian Bunk
This patch removes compat code for older kernel versions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23fbdev: fix integer as NULL pointer warningHarvey Harrison
drivers/video/aty/atyfb_base.c:3359:26: warning: Using plain integer as NULL pointer drivers/video/aty/radeon_base.c:2280:32: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/sis/sis_main.c:5790:44: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/video: remove unnecessary pci_dev_putJulia Lawall
pci_get_class implicitly does a pci_dev_put on its second argument, so pci_dev_put is only needed if there is a break out of the loop. The semantic match detecting this problem is as follows: // <smpl> @@ expression dev; expression E; @@ * pci_dev_put(dev) ... when != dev = E ( * pci_get_device(...,dev) | * pci_get_device_reverse(...,dev) | * pci_get_subsys(...,dev) | * pci_get_class(...,dev) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fix ! versus & precedence in various placesAlexey Dobriyan
Fix various instances of if (!expr & mask) which should probably have been if (!(expr & mask)) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01USB: sisusb: *_ioctl32_conversion functions do not exist in recent kernelsFernando Luis Vázquez Cao
Remove dead code while at it. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-14video/sis/: fix negative array indexAdrian Bunk
This patch fixes the possible usage of a negative value as an array index spotted by the Coverity checker. sisfb_validate_mode() could return a negative error code and we must check for that prior to using its return value as an array index. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17sisfb: fix pseudo_palette array size and overrunAntonino A. Daplas
- the pseudo_palette is only 16 elements long. - do not write to the pseudo_palette if regno (array index) is more than 15. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08drivers/video/sis/: remove more kernel 2.4 codeAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/video/sis: Convert to generic booleanRichard Knutsson
Convert: FALSE -> false TRUE -> true BOOLEAN -> bool Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Thomas Hellstrom <thomas@tungstengraphics.com> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] drivers/video/sis/sis_main.c: removal of old codeMichal Piotrowski
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
