When allocation is bigger than L2 size it is more optimal to
flush or writeback whole L2 instead of doing maintenance
for each allocated page.
bug 983964
Signed-off-by: Kirill Artamonov <kartamonov@nvidia.com>
Change-Id: Ieaa70875b92920567ad7cd75eca6eac8197f46de
Reviewed-on: http://git-master/r/108511
Reviewed-by: Simone Willett <swillett@nvidia.com>
Add support to alloc zeroed pages for user space alloc requests. Also
define a config option to force userspace allocation requests to be
zeroed.
Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/122549
NVMAP_CONVERT_CARVEOUT_TO_IOVMM is only available for IOMMU less SoCs.
This was introduced by:
commit b8b0b4c42fc77d94b8deadaa46f795784f3bbb5e
video: tegra: nvmap: Make IOMMU/IOVMM selectable in Kconfig
Bug 1017112
Change-Id: I2a6f101b15085ece600f77690bc77adc042eb29f
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/117976
Tested-by: Meghana Kankarej <mkankarej@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This patch allows nvmap to use the standard IOMMU API as its backend
engine instead of the legacy tegra IOVMM by Kconfig.
Enable TEGRA_IOMMU_{GART,SMMU} under IOMMU in config, and it
automatically disables IOVMM, instead.
Change-Id: I71112ef8072591aac4a93075623ca31c8851a960
Reviewed-on: http://git-master/r/114217
Add configuration variable for default timeout for clients. Set it to
30s for silicon and infinity for simulation.
Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/105331
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Add config option to enable/disable cache maintenance by set/ways.
Change-Id: Ie795e19650b2c05cd4789dbc1e8f04f9edc70bf1
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/104290
GVS: Gerrit_Virtual_Submit
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Add config option to enable/disable nvmap page pools.
Change-Id: I873e81a675fecd768534d4ce03c2f8fdd3c6a063
Reviewed-on: http://git-master/r/100424
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
This is necessary to introduce DMA iommu mapping API in nvmap.
Change-Id: I9c043460ca08cc25c4688811a2021820aed5c9f7
Reviewed-on: http://git-master/r/96378
Remove old overlay interface, it is replaced with TEGRA_DC_EXTENSIONS
External functions made static now that overlay.c no longer needs them.
Change-Id: I5d080ceb19ad90d3b5cc4bf20494c967687293a5
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/92661
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Add a config option to limit HDMI stereo 3D output to 74.25MHz pixel clock.
When this option is set,
substitute the frame pack stereo modes
for side-by-side (half) left-right stereo modes
to meet this pixel clock restriction.
By default, do not use it (use frame packed HDMI mode as usual).
Bug 938807
Change-Id: I2ce2ca72cbb15ac1939af0f3386dd23650262435
Reviewed-on: http://git-master/r/84252
Reviewed-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Tested-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
User space components have been converted from using overlay display
driver to using display driver extensions. Overlay driver thus can be
disabled.
Bug 905578
Change-Id: I1666e21adce2c9382b3ce0561dbfa168a6c06007
Reviewed-on: http://git-master/r/70268
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Tested-by: Michael Frydrych <mfrydrych@nvidia.com>
Use TEGRA_NVHDCP to enable/disable support for NVHDCP on HDMI.
Change-Id: If65267e7a4c82c5497271c19ac985bfa8881bca1
Reviewed-on: http://git-master/r/67883
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Display driver extensions must be enabled along with overlay
display driver to enable transition of user space components
from using overlay driver to using driver extensions. Once the
transition is completed, overlay driver will be disabled.
Bug 905578
Change-Id: I2635802eea8b0953865f6c86c64cd5e154095562
Reviewed-on: http://git-master/r/64111
Tested-by: Jon Mayo <jmayo@nvidia.com>
By default Tegra graphics host driver is turned on. This
CL removes the default 'yes' for this driver. However,
the option is turned on in defconfig files, for an easier
out of box experience.
Bug 888777
Change-Id: I1ec969f9b0097dc9beccb00ed8cee0ebc7608c41
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/57959
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R5a0866bec84d1b17e8574026f35aee35439fbe50
Cuts dependencies to nvhost by adding a Kconfig dependency from DC to
GRHOST and from HD Audio to DC. Configure out calls to nvhost in board
panel files if GRHOST is not present.
Bug 870898
Change-Id: If7830528e321e951bcadc2a10515e6cab58a6cdf
Reviewed-on: http://git-master/r/56370
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Chris Dragan <kdragan@nvidia.com>
Rebase-Id: R16d9286d67235b0697c914476e7d6462eec7f3ac
Reviewed-on: http://git-master/r/51026
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
(cherry picked from commit 060055eea2082adb6da4cf27462ff699fdf2b4e9)
Change-Id: I9244dff21e9cd62b14f97bfb5a5349eb46f73847
Reviewed-on: http://git-master/r/56107
Rebase-Id: Rd3f4f8799a3acad27234422b39a4def0a439e3f3
GRHOST should be buildable without IOVMM (i.e. with carveout only)
Bug 870898
(cherry picked from commit bcea6f229ef9467b427549d65fabf69ea4ed09ce)
Change-Id: Ibd5eb004e001e481992e8b9c1a7c53108f276ff9
Reviewed-on: http://git-master/r/54511
Tested-by: Hiro Sugawara <hsugawara@nvidia.com>
Rebase-Id: Rc227bee6c67508a5354646104c63b175775697a0
This adds the infrasturcture for an enhanced driver interface to program
extended capabilities of the Tegra display controller.
It exposes a new set of device nodes for userspace clients distinct from
the traditional fbdev device nodes. This is necessary due to
limitations in the fbdev infrastructure that don't allow drivers to
store file-private data.
bug 818525
Original-Change-Id: I06cecf894792b9904c73f9ebcdeb746ff7455f6e
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/40512
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: Rfa3969804d7f52c841be1ff96305c9463077e1c5
CONFIG_TEGRA_ENABLE_SUPPORT_FOR_1080p_30HZ define is not needed
anymore since this can be filtered from user space driver
Bug: 815409
(cherry picked from commit 14e0e21a7357722b8be6bba191665e3ead17dd11)
Original-Change-Id: I914d2811d757228864d0ae13950d0fc5cce7f972
Reviewed-on: http://git-master/r/37026
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Rebase-Id: R74b621cfd8928797b348ee20bcbcf27492085959
Bug 828027
Original-Change-Id: I890e0481be5aade59bc68510c9fe5929bb3b64a2
Reviewed-on: http://git-master/r/31902
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R7daa676019d94684e5245d850a49274903578332
Adding a build time CONFIG option to enable forcing of conversion
of non-IRAM CarveOut memory allocation requests to IOVM requests.
Default is "y" to force the conversion.
Each forced conversion is reported to console.
Allocation alignments larger than page size for IOVM are enabled.
Single page CarveOut allocations are converted to system memory.
CarveOut memory reservation has been removed for aruba, cardhu,
and enterprise.
Original-Change-Id: I3a598431d15b92ce853b3bec97be4b583d021264
Reviewed-on: http://git-master/r/29849
Rebase-Id: R602260e283f721b7e0f0d802092516ff68c068fe
Bug 793366
Bug 794499
Original-Change-Id: Id49d86dd7760b75ef4947f5bdab9e37f0333391d
Reviewed-on: http://git-master/r/#change,18950
Reviewed-on: http://git-master/r/22508
Rebase-Id: R28d85faa28119d5803ab717831d610ee8ad37700
Adding support for 1080p@30Hz.Disabled by default.
Fixes Bug 789164
Original-Change-Id: I2fd37d6c19aa30daee321c9cdafbdb7ed1b6a271
Reviewed-on: http://git-master/r/20349
Tested-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Rebase-Id: R554f273bb68642fbfde5b61123912b41fe7ac566
bug 762482
Original-Change-Id: Ifadebc1b0c4eb0df89e179091acca0ff6e527e56
Reviewed-on: http://git-master/r/15743
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Tested-by: Kirill Artamonov <kartamonov@nvidia.com>
Rebase-Id: R639e7f09f44c8919bd57a16a577b87db91160555
This creates a new device node per head - /dev/tegra_dc%u. There are a
number of ioctls in linux/tegra_overlay.h to open, close, and flip
overlays.
This is a replacement for the extensions in the tegra fb interface, but
does not remove that functionality for compatibility reasons. Once
everyone has moved, we can remove the tegra fb extensions.
Original-Change-Id: Id78a94482637a7ce229ec64eb5feaf2dec2b7804
Reviewed-on: http://git-master/r/16700
Rebase-Id: R0d6e864cd50ce69c2e432bbac96b4932ec2bc476
This change attempts to reclaim carveout memory by killing
other carveout users when an allocation fails. Processes
are killed in order of priority from lowest to highest, and then
from largest to smallest users.
Change-Id: Iee8a6f36269bc8165d691000a153dbf9f4337775
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
remove the dependency that nvmap has on the arm_attrib_allocator
and the lowmem in PTEs change by adding a private page allocator
utility function and calling vm_map_ram unconditionally for all
sysmem handles.
also, add Kconfig variables to allow platforms to disallow the
SYSMEM heap, and to optionally restrict the SYSMEM and IOVMM
heaps to just HIGHMEM.
Change-Id: I3dab1c7323f54a8ab3994dc672b27fd79a9057d7
Signed-off-by: Gary King <gking@nvidia.com>
nvmap provides an interface for user- and kernel-space clients to
allocate and access memory "handles" which can be pinned to enable
the memory to be shared with DMA devices on the system, and may
also be mapped (using caller-specified cache attributes) so that
they are directly accessible by the CPU.
the memory handle object gives clients a common API to allocate from
multiple types of memory: platform-reserved physically contiguous
"carveout" memory, physically contiguous (order > 0) OS pages,
or physically discontiguous order-0 OS pages that can be remapped
into a contiguous region of the DMA device's virtual address space
through the tegra IOVMM subsystem.
unpinned and unmapped memory handles are relocatable at run-time
by the nvmap system. handles may also be shared between multiple
clients, allowing (for example) a window manager and its client
applications to directly share framebuffers
Change-Id: Ie8ead17fe7ab64f1c27d922b1b494f2487a478b6
This is needed for HDMI.
Signed-off-by: Erik Gilling <konkers@android.com>
The host (or host1x) bus sits between the cpu core and the 3d, 2d, camera,
display, and mpeg encoder functions. It contains provides DMA channels,
hardware mutexes, and synchronization points.
Notable ommisions:
* support for anything but lvds panels
* inegration with nvhost driver to sync updates with 3D
* FB physical geometry is not set
* lacks interface to set overlay/window x,y offset
v2 changes:
* suspend/resume support
* move code into drivers/video/tegra/dc
* modularize output support
* clean register dumping, add debugfs register file
* code review feedback
* make the display controller register the framebuffer devices
