This reverts commit 90b79e5712300baab889772a5af348559ac95836.
Bug 955393
Change-Id: I0e2a15b7d0898dbbb62f09d8bd3502ec93366664
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/99261
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-by: Adam Cheney <acheney@nvidia.com>
Tested-by: Adam Cheney <acheney@nvidia.com>
Change-Id: I8aa25b03fe6801882b65209cb1a6e125ef27ac2c
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Reviewed-on: http://git-master/r/98319
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
add trace_printk to log useful debug information.
Bug 870685
Change-Id: I29c0b1600f234ebb06d19c8b6c713b16f6e7643c
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/89204
Reviewed-by: Prashant Malani <pmalani@nvidia.com>
TEGRA_DC_EXT_SET_LUT programmed the proper shadow registers
but did not copy the shadow registers to the active set.
Signed-off-by: Adam Cheney <acheney@nvidia.com>
bug 947281
Change-Id: Id734e128bb708f1a75c0cad22b0c51b083d8df3b
Reviewed-on: http://git-master/r/91368
Reviewed-by: Simone Willett <swillett@nvidia.com>
Change-Id: Ib1b0fc6015a9dd45982a97231972dadba6b5a92e
Reviewed-on: http://git-master/r/96966
Handle mode set for FBIOPUT_VSCREENINFO at the end of a frame (during
vblank). This elimiates the work around that requires disabling then
enabling display to change modes.
Adds a spinlock to protect irq code from updates to tegra_dc_mode structure.
Bug 560152
Change-Id: I5d2175f01a177a32d685b46e5af4f78efeec0786
Reviewed-on: http://git-master/r/90688
Change to using kbytes/sec to avoid overflowing 32-bit integer in
bandwidth calculation.
Changing efficiency adjustment to ~35%.
Bug 958016
Change-Id: Ia8bdf79e4b3e4bc65517db18d9f351a5f840805e
Reviewed-on: http://git-master/r/92658
Enabled recovery of DC from resetting. When underflow triggered serveral
times(current > 4 for tegra2), DC driver will reset itself to prevent
data corruption. Reopend nvhost connection when resetting finished. That
helps system to show frames instead of a blank screen again.
Fixed Bug 936613
Change-Id: I314c37258a4a446dc07167ac60d0420e79a5fb2d
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/89406
Remove old overlay interface, it is replaced with TEGRA_DC_EXTENSIONS
External functions made static now that overlay.c no longer needs them.
Change-Id: I5d080ceb19ad90d3b5cc4bf20494c967687293a5
Reviewed-on: http://git-master/r/92661
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Set dc clock rate dynamically to requested pixel rate.
Using modes specified in monitor's EDID data.
Return mode set errors on unsupported clock tolerances.
Bug 931908
Change-Id: I60990ecbc2fbeab542987036b8ccc30b8dababe8
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/86073
Not disabling emc clock when it's being set to zero results in incorrect
reference count when a call is made to clear bandwidth. This happens when
two worker threads try to handle dc emc rate. A deep-sleep/wake-up cycle
easily shows this scenario.
With this fix, disp.emc's ref count is properly managed even after multiple
deep-sleep/wake-up cycles.
Bug 947228
Change-Id: I045fafbd483af1e3d492b8d0395275e45642d059
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/90100
Bug 951626
Change-Id: Ia7c7474aa0f066cba8bd1519a98e302c4b3992e0
Reviewed-on: http://git-master/r/89076
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Remove unnecessary 100ms delay for primary panel since
this is needed for HDMI type only.
Bug 940012
Change-Id: Id27966fb28faa73ade3a868a9f89cadbde76e227
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/87613
Add lock to prevent race condition between cancellation of old delayed
work and schedule of new delayed work.
Bug 936337
Change-Id: I52df82e92279163841546127c72be9879ef810d0
Reviewed-on: http://git-master/r/86730
There exits an issue that if window number is less than DC_N_WINDOWS,
window option of some windows won't be cleared. So although it should
be disabled, it might not be disabled properly. This will lead to the
failure of scan-out on screen.
Bug 943846
Change-Id: I604399abaa590b27ab4ea41ed9eb2706be16a75a
Reviewed-on: http://git-master/r/86230
GENERAL_ACT_REQ causes double-buffered registers to become active.
This register needs to be programed to reduce the latency of pixel clock after
dc enabled by tegra_dc_enable().
bug 926189
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/83346
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit f39c5ddd1867c508900c9aa2d4eead7eb3082343)
Change-Id: I741c9be9074709c1ab571aa631cb462599d5fb78
Reviewed-on: http://git-master/r/84561
A V_BLANK interrupt for each frame does not allow long lp2 idle intervals.
If all windows are clean, mask V_BLANK interrupt after processing it
for updating smart dimmer. It's unmasked again when a new window update
is performed. This will schedule a work for updating smart dimmer for
the new frame.
Bug 920110
Reviewed-on: http://git-master/r/85137
(cherry picked from commit 68398090aee22cf02069e5767c3e9a062b0fc2f6)
Change-Id: I588328bfd0d6036febed236dc07f441878aa81d1
Reviewed-on: http://git-master/r/85166
Add a config option to limit HDMI stereo 3D output to 74.25MHz pixel clock.
When this option is set,
substitute the frame pack stereo modes
for side-by-side (half) left-right stereo modes
to meet this pixel clock restriction.
By default, do not use it (use frame packed HDMI mode as usual).
Bug 938807
Change-Id: I2ce2ca72cbb15ac1939af0f3386dd23650262435
Reviewed-on: http://git-master/r/84252
Reviewed-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Tested-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
When dc gets many underflows, instances of reset worker can race
to perform reset. dc ext was getting disabled outside critical region
affecting display path. disable dc ext after getting the lock.
Bug 936545
Reviewed-on: http://git-master/r/83108
(cherry picked from commit f9dcf7eee8ca8db28cee6fa9550044d1f746e843)
Change-Id: Ie29dc66eb52c9be472c2d0db8c0014bfe1837ad4
Reviewed-on: http://git-master/r/83406
Bug 932840
Change-Id: I12d8d2d2cd42d0dafea38463ad77b44f7e64d7c1
Reviewed-on: http://git-master/r/83645
Enable GENERAL_ACT_REQ and HOST_TRIG_ENABLE at the same time.
Bug 930840
Reviewed-on: http://git-master/r/78638
(cherry picked from commit 2f78c8e3c243b4c866ad54a550167abd94c200c1)
Change-Id: If0ef97c4a2b1a0621152c02728edbbed064a5e34
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82715
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
DC ext is enabled only from _tegra_dc_controller_enable() which is not used
from reset worker. Enable dc ext from _tegra_dc_controller_reset_enable()
as well.
Bug 933391
Reviewed-on: http://git-master/r/78753
(cherry picked from commit a099c612f91cc12a99325e39609b1f9001525be0)
Change-Id: Ia95df85ea602174c2fd66888b21f7a6d264c176e
Reviewed-on: http://git-master/r/82714
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
dc irqs are required in display client disable to flag
stopping of dc stream.
Bug 930453
Reviewed-on: http://git-master/r/77808
Change-Id: I0e057ca14078d9e608cb32380123fade813c4041
Signed-off-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-on: http://git-master/r/78898
Reviewed-on: http://git-master/r/76406
Change-Id: I6e5b37a88d6be4ba2cc81417fe3eadfd129bc899
Reviewed-on: http://git-master/r/77306
Add backup clock source option in dc platform configuration. Use
backup source if fixed frequency pllp is specified as main source,
but its rate can not be divided into pixel clock within required
tolerance.
928260
Change-Id: I19bd9173276c6ea087f86361956809787875e979
Reviewed-on: http://git-master/r/76033
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/76818
Use standard drvdata interface for storing and accessing nvhost_master.
Reviewed-on: http://git-master/r/72846
Change-Id: I191987c8f6d313a6ede9b59f723269cb6a197e8a
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/76815
When dc->emc_clk_rate goes from 0 to non-zero the dispX.emc clock is
enabled. This works with the sequence for probe and hotplug to have emc
clock in the correct enable/disable state.
Bug 927785
Bug 917769
Reviewed-on: http://git-master/r/76208
Change-Id: I53cc8c5091967ce021dd3ec1e2bc75405dc8c45c
Reviewed-on: http://git-master/r/76813
In one-shot mode(DSI) report emc rate as disabled to reduce bandwidth in
this idle state. Use this same tegra_dc_clear_bandwidth() function to handle
display disable for all types of displays.
Bug 914917
Change-Id: I84ca1341d71999b3558f9dadb103b258a1a6ab6f
Reviewed-on: http://git-master/r/74652
Tested-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/75536
This reverts commit 20f43dfc590d22ad1e80b7b948f108b17038b084.
drivers/video/tegra/dc/dc.c
This fix is no longer needed to boot.
Change-Id: Ie8d877207b6a1d70c63834f234d7a7cc68a372bf
Reviewed-on: http://git-master/r/74884
Reviewed-on: http://git-master/r/75151
Move underflow handling out of the irq handler and into a workqueue.
Change-Id: I289d0a4c4e632a229e46d8e7f82e637409813807
Reviewed-on: http://git-master/r/74427
Reviewed-on: http://git-master/r/75143
Move all device data from nvhost_channeldesc, nvhost_moduledesc and
nvhost_module to nvhost_device. nvhost_devices are also assigned into
a hierarchy to prepare for implementation of runtime power management.
Change-Id: I1e18daae8fe538086cd1f453d316e0f73e9d7d92
Reviewed-on: http://git-master/r/72844
Reviewed-on: http://git-master/r/74560
This reverts commit af9a6eb54c031a8cca1477134d07e1ef2b807be3.
Test reports were inconclusive on the effectiveness of this change.
Change-Id: I859a14d2e2dcd9eed3a1c64f35e4f1c077660311
Reviewed-on: http://git-master/r/74021
Reviewed-on: http://git-master/r/74550
The tegra display controller supports the YUV422R planar surface format, but
this was not handled by the dc driver.
This change also fixes the YUV422RA planar format variation.
Bug 914375
Change-Id: I73ffd2f7434c71d8353c7e16ada5ac6b13fee86b
Reviewed-on: http://git-master/r/69446
(cherry picked from commit a085ef1eeb332116f102d82af25f7a6451eb6329)
Reviewed-on: http://git-master/r/73950
Apply the highest bandwidth setting before windows are programmed rather
than waiting for vblank.
Bug 914917
Change-Id: Iaaede9966191fdfc896bbbb19fbbadf9c4598bff
Reviewed-on: http://git-master/r/72301
Tested-by: Michael I Gold <gold@nvidia.com>
Fix dc stream randomly failing to stop.
Add stablization delay during dsi interface reset.
Bug 913019
Change-Id: I1cf3013659de75d15cb1ff41b27c63abd953d614
Reviewed-on: http://git-master/r/71952
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
dc vsync, hsync, DE and pclk polarity in kernel
can be different with bootloader setting for a short time
when default polarity value is written.
This can generate momentary panel flicker in kernel boot.
Set the first polarity based on board dc out pin polarity
information directly if needed.
Bug 891444
Reviewed-on: http://git-master/r/59895
(cherry picked from commit 8e5bfd5702067309171b62a6be5471bfab68a31e)
Change-Id: I80c703792ea5a9596d4cf42ef19115cbf4d556f6
Reviewed-on: http://git-master/r/69711
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Tested-by: Min-wuk Lee <mlee@nvidia.com>
We'd better place clock set-up in dc as HDMI. It makes code cleaner.
Also eliminate a false warning.
Bug 902786
Bug 850852
Reviewed-on: http://git-master/r/65024
(cherry picked from commit e570e8dd45a66f11f0fc432f5919c5a036e34ba0)
Change-Id: I90d73602048e2b3c706550128ba04665c307da22
Reviewed-on: http://git-master/r/68863
Tested-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Mark the dependencies of dc driver on switch class explicit,
using proper pre-processors.
Bug 877239
Change-Id: Ie5931aaf4f279e6379b85a00a30bd3cb910614d0
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/55774
Rebase-Id: R229bab237a55cacd22f5071eaca1a60503fdbb0d
Change-Id: I613ad237bda9845c928b27b96db227e484b95f7d
Reviewed-on: http://git-master/r/41077
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rbc20d94729500157b45207bac4ab0d4340297af2
Original-Change-Id: I3b060b622a593d48319a442072a21d0c4f9527ae
Reviewed-on: http://git-master/r/19049
Rebase-Id: Ra9c6d91a0cb402b3b660e417a87480b36933a92f
If an overlay is not being used, do not program the latency allowance.
This is to avoid underflows that occur at a resolution of 19x12. When the
unused overlays are reenabled, they underflow if the latency allowance has
previously been increased to a very high value.
Change-Id: Id381a74f5cc602d47199cb42d17f77b1086de70e
Reviewed-on: http://git-master/r/58195
Reviewed-by: Joel Kenny <jkenny@nvidia.com>
Tested-by: Joel Kenny <jkenny@nvidia.com>
Tested-by: Gerrit_Virtual_Submit
(cherry picked from commit cbc4e10451137a972ef694d7698c7dab26017377)
Change-Id: Id7101997db77e54861ef1045df5eccdfa4ee09eb
Reviewed-on: http://git-master/r/64065
Rebase-Id: R8338a8bee51d297d66d8e0708f91627d202269ec
Use the enable irq register during init, and mask irq register to
control the interrupts to avoid a race in clearing interrupt status.
Clear mask and enable during DC disable.
Bug 888207
Bug 870801
Reviewed-on: http://git-master/r/57603
(cherry picked from commit 4640498bd8d46b6c5c1898d8ca8c9760416d1eae)
Change-Id: I8d93746533da5021919cc4152a467adc6889c4c6
Reviewed-on: http://git-master/r/63370
Rebase-Id: Ra3d62939458871c4c1cc09fe6010922cc95e4a1c
V_BLANK_INT was used to mark frame end for other tasks. However, it occurs
at frame start. Switch to FRAME_END_INT to mark the end of frame.
Bug 875448
Reviewed-on: http://git-master/r/52694
(cherry picked from commit 078a2688c67c46cf840f191405cd4324cb9c4574)
[jmayo@nvidia.com: wrapped commit message, fixed bug in S_TO_MS()]
Change-Id: I507148772c2f3037befd30289e5b3a56fe417ee9
Reviewed-on: http://git-master/r/63369
Tested-by: Jon Mayo <jmayo@nvidia.com>
Rebase-Id: R5dbcf2d7ff3fd627194ae1a6163a300e6e48ff7c
During the K39 merge an additional call to tegra_periph_reset_assert
was added. The call in this place was moved by the following two
commits and needs to be removed from where it currently is.
e9f069bc video: tegra: dc: Fix introduced regression.
884cc8a9 tegra: dc: fix dc hang during dc reset
Bug 895713
Change-Id: Ibfe1445f23dbc92498696a6d0743f4b5f92e049e
Reviewed-on: http://git-master/r/62510
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: Re923f258ce13fa9c3fc4f9643762784729df63ae
Add support to set a global gamma correction table via fbdev cmap
API. The 3 Tegra DC windows have their own local gamma tables, which
can either override or alter the global table.
Bug 868060
Change-Id: I0be1c5e4afa8fd8c010b772c7808c883c0848ab4
Reviewed-on: http://git-master/r/60201
Rebase-Id: R7e613b1c8ac469242172bd81db9dfba25176e0c3
This change supports PM313 with 19X12 panel.
The change uses PM313 in "Single input to Dual output" mode
Bug ID : 822980
Reviewed-on: http://git-master/r/50215
(cherry picked from commit b83e795747fa860b5b7fb66b2067ebe4f15bcfd0)
Change-Id: Iabf707ded2976e9877481c215d0b1f1940781f14
Reviewed-on: http://git-master/r/60085
Rebase-Id: Re8eadc35c75fa21b0a5f3cb3bee0e8cb77dc3238
Preserve YUV-to-RGB and gamma correction tables over suspend-resume
Bug 868060
Change-Id: I5ea2224f7ab0dfbe24d741b89d727034be3ebf68
Reviewed-on: http://git-master/r/58016
Rebase-Id: R84115584b766900004b5c6cdc3cc8d693fb0db5a
Settings in DIDIM driver are now phased in over a defined
number of steps in order to minimize the perception of changes
to the settings during runtime
Bug 840155
Reviewed-on: http://git-master/r/52495
(cherry picked from commit a33d4f5c677b657751fd017f8419df88016122a5)
Change-Id: I0af84609d0f2ebadf23463473ebf0211dfa594a3
Reviewed-on: http://git-master/r/55789
Rebase-Id: R759433a3cfd9b4c07216da4b2c9de6e515a8530d
- enable gamma look-up hardware only when needed to save power
- add flags field to ioctl TEGRA_DC_EXT_SET_LUT for forward compatibility
Bug 868060
Change-Id: I690f8b8856e0b1acd6215907ca8bd78ecaf30b17
Reviewed-on: http://git-master/r/57736
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Rebase-Id: Rf6081a9372ba7d6e53a66b9b58a50a62ad409d9a
Revert d3408e77 partailly which was causing NULL pointer derefence on
HDMI hotplug in WIN_IS_ENABLED.
Bug 881945
Change-Id: I2aa5757a9c4d4d7d010544941e4a05a7ba4db5f7
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/56218
Rebase-Id: R8a1ee743deca53371073b9d622d4cc171d739443
