Hack to prevent boot lock-up if HDMI is not connected.
This has been observed on recent T20 SoC production lots produced some
when after mid 2015.
Don't initialize the whole display controller (dc) when framebuffer
mode is set to off.
This avoids creation of the /dev/tegra_dc_x device. The tegra X
driver requires for each tegra_dc_x device an framebuffer device
with the same id. This patch avoids creation of both, which makes
the tegra X driver load correctly.
Note: Turning off tegrafb0 still leads to kernel crash due to
hard coded device enumeration.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Fix manual rebase error
Change-Id: I3b2165488b11bddda271cecdc979341c130def9b
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/173554
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Send change all vc's notification from HDMI hot-plug reader to
fbcon, so that the new selected mode can be applied on all the
vc's from vc1 to vc6. This sometimes causes corruption on HDMI
hot plugin, when fbcon is mapped to HDMI
Bug 1166008
Change-Id: Id173de3014597f79c8c8b31bbbee7c9c560547b6
Reviewed-on: http://git-master/r/168683
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
When porting change from mainline to balance dc irq, the change
of enable/disable order was not ported, thus dc irq is disabled
if dc is enabled during probe.
This is part of http://git-master/r/146107.
Original change is big for many bugs, only port one here.
bug 1173177
bug 1173038
bug 1008313
Change-Id: Idd703daca9f980e905b185eeeae19dc6309d76e5
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/162868
(cherry picked from commit 6ddd8b02f7a17d2269290d06159c20860ffb92e9)
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/173249
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
- Set frame duration to 0 in NULL modeset.
bug 1039104
Reviewed-on: http://git-master/r/127603
(cherry picked from commit 604cda21d79ed168e9863f0122eb0c23fa1a901b)
Change-Id: I0be1b96529e40a374e4507ecd3da990677d4cbd4
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/130943
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Set default mode for probe and resume to enable initialization of dc.1
Skipping this initialization results in hard system hang.
bug 1030415
Reviewed-on: http://git-master/r/124001
(cherry picked from commit 50fa5e50b74a0534d7524fb6d7dcaa65b2e6e74c)
Change-Id: Id9ad95e114a27c1667f0286443534a23b7fa64d4
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/128533
Reviewed-by: Simone Willett <swillett@nvidia.com>
Set default videomode happens during probe and resume. _tegra_dc_enable
is also called during hotplug, setting default videomode there causes
hdcp test failure.
Bug 991805
Reviewed-on: http://git-master/r/121052
(cherry picked from commit 7d4e0461a88b8cf638963e69829274824fecc38b)
Change-Id: I98be07e883699ba9fa6e222bb1d8ea68d199dfc6
Reviewed-on: http://git-master/r/128532
Add wait for vsync support for one-shot panels. The code supports extension
of this feature to other panels.
Bug 1033411.
Change-Id: Ie4d6cb45e5de81083458169ccdfa33230235ed72
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/128927
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
This patch adds:
1. A kernel config option that hints to DC driver
to use the current value of the color depth
register as the default for initializing the FB
driver.
2. Checks to see if DC is enabled before reading
off the color depth register in tegra_dc_probe.
Change-Id: I852cc1328fcf42f33052f46b86d753e691744329
Signed-off-by: Christopher Freeman <cfreeman@nvidia.com>
Reviewed-on: http://git-master/r/127297
bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Robert Morell <rmorell@nvidia.com>
In case tegra_dc_init fails, this change will prevent unbalanced call
to dc->out_ops->disable().
Also mark tegra_dc_io_end in case tegra_dc_controller_enable
fails, this is required to not stop device from going into suspend mode.
Bug 1003874
Change-Id: I5af6b46fc50e1ae8e54f9f4eb8540d751364fed7
Signed-off-by: Gaurav Batra <gbatra@nvidia.com>
Reviewed-on: http://git-master/r/120108
change printk to trace_printk
Bug 995270
Change-Id: I71caadb76f6101f377e44ad3f3dc24ede0a099d5
Signed-off-by: Jay Cheng <jacheng@nvidia.com>
The one shot thread will clock gate the modules periodically. This will ensure
relevant paths in dc driver have an active dc clock and dsi host.
Bug 1013172
Change-Id: Ibb505e35044f31405c06cb9fa0d6fdf78aafd4a6
Reviewed-on: http://git-master/r/117137
GVS: Gerrit_Virtual_Submit
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
After making pclk output ahead of LVDS_SHDN# , data output is later than
panel ready then caused partial black screen. Force triggered data output to
get it fixed.
Bug 972377
Bug 976081
Bug 1001434
Change-Id: Icd455d7439f622e46295158a5435286c521526aa
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/113164
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Allows overidding the default disp mode without having to recompile
the kernel. Boot args can be specified in the following format:
disp_params=<rgb|hdmi|dsi>:pclk,h_active,v_active,h_ref_to_sync,
v_ref_to_sync,h_sync_width,v_sync_width,h_back_porch,v_back_porch,
h_front_porch,v_front_porch;<rgb|hdmi|dsi>:pclk,h_active,...
Bug 969088
Change-Id: Id0acf608de145493f6749d5b799d4bbb8162ba72
Signed-off-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-on: http://git-master/r/104604
Freeze vblank worker while suspending by adding the work into
system freezewq. This eliminates a kernel panic caused by nvsd
reading brightness valuesfrom display while clock gated.
Bug 1006180
Bug 1003969
Bug 1003730
Change-Id: Ice9bfb18e5c826ae063c2b901421b1047ff9d2f0
Signed-off-by: Mark Zhang <markz@nvidia.com>
Reviewed-on: http://git-master/r/112880
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
- Gpio freeing function does disabling job.
- If backlight pin is an sfio, we have to claim the gpio. So that we can use
the gpio api's to configure it as sfio.
bug 984440
bug 858120
Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/109564
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/111371
Change-Id: I6584c856356d6be123a66731bde414e4925ffe07
Reviewed-on: http://git-master/r/111184
Bug 961009
Change-Id: Ifdcc7bc8a40d270e70a63329f46caff541bf01e2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/109461
Part of panel settings need to be done before/after pixel clock
is disabled. Add support for these actions to meet panel
spec.
bug 976081
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/102542
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit dcecdc64d4d0fd4d9f69df52c9d200dfbf1dd7fc)
Change-Id: Ibfede68d67a4815156f73c2d1cdca90f3f771755
Reviewed-on: http://git-master/r/110296
Bug 1000789
Bug 1003730
Change-Id: I7fbd703dde2044f2790e6a9b356ef8dca89ad8f3
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/110146
During programming of a frame or at frame end, force the use of the new EMC
bandwidth instead of the previous frame's bandwidth.
Moved copy of new_bandwidth out of tegra_dc_set_latency_allowance() to match
the semantics of the rest of tegra_dc_program_bandwidth().
bug 949015
Change-Id: I881f3a2c75f3438e3bbb3208b518f15a4574bc91
Reviewed-on: http://git-master/r/110149
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
When a DC window is being released, a NULL flip is used to indicate
that the window should be disabled. To disable a window, 0 is
written to WIN_OPTIONS.
The MC_DECERR on window shutdown is a symptom of forgetting step 2)
below when disabling windows, leaving no indication that there is
anything to wait for. This causes DC to erroneously unpin the
scanout buffer while the buffer is still actively being used.
Summary of flip (window update) synchronization in DC:
1) program some window registers
2) set win->dirty=1
3) schedule the activation of the registers
4) request VBLANK or HBLANK interrupts
5) wait for win->dirty==0
In the trigger_windows ISR (every VBLANK or HBLANK):
1) if there is no window update pending in HW, clear dirty flag to
indicate that ACTIVE registers are up-to-date.
bug 991572
bug 995614
bug 989119
bug 983251
bug 960424
bug 866711
Change-Id: I8b710aac874b202838c3989608b7e0bd15425382
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/109370
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Move #include directives for nvhost headers from dc_priv.h to the
source files that need the #includes. This allows #including
dc_priv.h without access to all nvhost headers.
Also adds nvhost to the #include path of dc to allow making dev.h a
stub in a later commit.
Bug 982965
Change-Id: Icfe7084d295f57926195b178174f81047eb01187
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/108225
The tegra_dc_trigger_windows function was improperly using the
WIN_x_UPDATE bits to determine when a flip has occurred instead of the
WIN_x_ACT_REQ bits. Without this change, it's possible for the postflip
syncpoint for a buffer to get incremented before it actually flips.
Still need to figure out why that's even possible...
Fixes bug 902955
Change-Id: I67ba093a0114646977cc8cb95a040ec4178cebfc
Reviewed-on: http://git-master/r/65389
Reviewed-by: Nate Huang <nhuang@nvidia.com>
Tested-by: Nate Huang <nhuang@nvidia.com>
Reviewed-on: http://git-master/r/98024
Bug 990586
Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547
Reviewed-on: http://git-master/r/107714
Bug 936337
Bug 899053
Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e
Reviewed-on: http://git-master/r/106313
Clear out all overlays and disable DC on .shutdown
Change-Id: I4bc78fddb0ed8bd621733df191f305ecb279e3f7
Reviewed-on: http://git-master/r/106549
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
remove and rename unused variable in tega_dc_get_stride
Change-Id: I0d101de22c08609f9727469ad7e4708de8de59ef
Reviewed-on: http://git-master/r/106072
drivers/media/video/tegra/nvavp/nvavp_dev.c
Change-Id: I7779b0ce58004f80cccf6193148ac49551ce5da5
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Reviewed-on: http://git-master/r/106075
Detect the stride size used by the bootloader.
If DC is not enabled, fallback to a default stride size.
Bug 973111
Change-Id: If04647ddf04a44987cd841062ff30e03fa4d6a02
Reviewed-on: http://git-master/r/104031
arch/arm/mach-tegra/pm.c
drivers/power/smb349-charger.c
include/linux/smb349-charger.h
include/trace/events/power.h
Change-Id: Ia8c82e2acfe3463ae6778bdd03aac8da104f7ad3
- currently, function pointers are inside nvhost_device
- these functions abstract the device specific implementation
of a functionality per SoC
- move them to nvhost_driver so that nvhost_device can be
instantiated from arch code using board files/device trees
- add support to use single driver for multiple devices using
concept of id_table. this will be useful in supporting
multiple SoC devices binding single driver
- also add some notes about how device name is expected
Bug 871237
Change-Id: I4c75d7121d26c3bdc50f058e0d144d89ca0edbd9
Reviewed-on: http://git-master/r/100985
Remove the efficiency factor in the bandwidth calculation.
Clock API will take care off setting the right clock based factoring the
efficiency.
Change-Id: I2b549197778b5afaf1aab3cc87a84debb08172e8
Reviewed-on: http://git-master/r/91659
Reviewed-on: http://git-master/r/103682
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
1. set UF_LINE_FLUSH to 0 by default.
2. if it gets 4 consecutive frames with underflows, enable UF_LINE_FLUSH to
get rid of underflow condition.
Change-Id: I6d647d958484ee355809036bec7ca1b0c716017b
Reviewed-on: http://git-master/r/103227
Reviewed-by: Michael I Gold <gold@nvidia.com>
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Reviewed-on: http://git-master/r/101806
Bug 955184
Change-Id: I7ac0a290c2b6acd454de05d094bd676b88f4b476
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/101546
-Move _tegra_dc_enable to before irq_request and remove
disable_dc_irq.
-It will remove warning of "IRQ when DC not powered!".
Bug 955184
Change-Id: If9b039f3f1635d92f10bfc54af08101972fc3d57
Reviewed-on: http://git-master/r/101498
Add display feature table so that user and kernel could set and
update window attributes properly.
Bug 962353
Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7
Reviewed-on: http://git-master/r/101078
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Reviewed-on: http://git-master/r/100656
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15.
It is reviewed on http://git-master/r/99635
It will cause HDMI power ON and emc clock bump up to 667Mhz
after resume from LP0.
bug 930136
Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7
Signed-off-by: Hunk Lin <hulin@nvidia.com>
Reviewed-on: http://git-master/r/100202
Xinit.
Bug: 930136
Change-Id: Ieaf5c69eefa4a6584893425ad4fd772bcd91ea11
Reviewed-on: http://git-master/r/99635
