Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Creates a miscdev at /dev/tegra-throughput which gl will use to set a
target frame rate. In addition it receives notifications from dc on
flip events. On each notification the percentage ratio of the actual
frame time to the target frame time is calculated. In subsequent
changes this ratio will be reported to other modules as a throughput
hint.
Bug 991589
Change-Id: Ieaa2b2755b63d2d071de31e3ef819d4c3b51a956
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/116865
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
The one shot thread will clock gate the modules periodically. This will ensure
relevant paths in dc driver have an active dc clock and dsi host.
Bug 1013172
Change-Id: Ibb505e35044f31405c06cb9fa0d6fdf78aafd4a6
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/117137
GVS: Gerrit_Virtual_Submit
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/111371
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 961009
Change-Id: Ifdcc7bc8a40d270e70a63329f46caff541bf01e2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/109461
During programming of a frame or at frame end, force the use of the new EMC
bandwidth instead of the previous frame's bandwidth.
Moved copy of new_bandwidth out of tegra_dc_set_latency_allowance() to match
the semantics of the rest of tegra_dc_program_bandwidth().
bug 949015
Change-Id: I881f3a2c75f3438e3bbb3208b518f15a4574bc91
Reviewed-on: http://git-master/r/110149
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Move #include directives for nvhost headers from dc_priv.h to the
source files that need the #includes. This allows #including
dc_priv.h without access to all nvhost headers.
Also adds nvhost to the #include path of dc to allow making dev.h a
stub in a later commit.
Bug 982965
Change-Id: Icfe7084d295f57926195b178174f81047eb01187
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/108225
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 990586
Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/107714
Bug 936337
Bug 899053
Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e
Reviewed-on: http://git-master/r/106313
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
Makes function pointer type for mode_filter match the function in hdmi.c
Change-Id: Id61f319a4ddef003b79782391e9e7f2f8cb32dda
Reviewed-on: http://git-master/r/102630
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Add display feature table so that user and kernel could set and
update window attributes properly.
Bug 962353
Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7
Reviewed-on: http://git-master/r/101078
Call dc_hdmi_mode_filter to validate a videomode. X prepares its
own modedb of supported HDMI modes, but all of them may not be
supported from the HDMI driver. This call makes sure a X-mode is
listed only if supported in DC driver.
Bug: 959676
Change-Id: I8aff65f4e08fcc4471af096150e3972b5913a95a
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/99650
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Reviewed-on: http://git-master/r/99046
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
add trace_printk to log useful debug information.
Bug 870685
Change-Id: I29c0b1600f234ebb06d19c8b6c713b16f6e7643c
Reviewed-on: http://git-master/r/89204
Reviewed-by: Prashant Malani <pmalani@nvidia.com>
Change-Id: Ib1b0fc6015a9dd45982a97231972dadba6b5a92e
Reviewed-on: http://git-master/r/96966
Handle mode set for FBIOPUT_VSCREENINFO at the end of a frame (during
vblank). This elimiates the work around that requires disabling then
enabling display to change modes.
Adds a spinlock to protect irq code from updates to tegra_dc_mode structure.
Bug 560152
Change-Id: I5d2175f01a177a32d685b46e5af4f78efeec0786
Reviewed-on: http://git-master/r/90688
Remove old overlay interface, it is replaced with TEGRA_DC_EXTENSIONS
External functions made static now that overlay.c no longer needs them.
Change-Id: I5d080ceb19ad90d3b5cc4bf20494c967687293a5
Reviewed-on: http://git-master/r/92661
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Add lock to prevent race condition between cancellation of old delayed
work and schedule of new delayed work.
Bug 936337
Change-Id: I52df82e92279163841546127c72be9879ef810d0
Reviewed-on: http://git-master/r/86730
Bug 932840
Change-Id: I12d8d2d2cd42d0dafea38463ad77b44f7e64d7c1
Reviewed-on: http://git-master/r/83645
Reviewed-on: http://git-master/r/76406
Change-Id: I6e5b37a88d6be4ba2cc81417fe3eadfd129bc899
Reviewed-on: http://git-master/r/77306
Use standard drvdata interface for storing and accessing nvhost_master.
Reviewed-on: http://git-master/r/72846
Change-Id: I191987c8f6d313a6ede9b59f723269cb6a197e8a
Reviewed-on: http://git-master/r/76815
In one-shot mode(DSI) report emc rate as disabled to reduce bandwidth in
this idle state. Use this same tegra_dc_clear_bandwidth() function to handle
display disable for all types of displays.
Bug 914917
Change-Id: I84ca1341d71999b3558f9dadb103b258a1a6ab6f
Reviewed-on: http://git-master/r/74652
Tested-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/75536
This reverts commit 20f43dfc590d22ad1e80b7b948f108b17038b084.
drivers/video/tegra/dc/dc.c
This fix is no longer needed to boot.
Change-Id: Ie8d877207b6a1d70c63834f234d7a7cc68a372bf
Reviewed-on: http://git-master/r/74884
Reviewed-on: http://git-master/r/75151
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Move underflow handling out of the irq handler and into a workqueue.
Change-Id: I289d0a4c4e632a229e46d8e7f82e637409813807
Reviewed-on: http://git-master/r/74427
Reviewed-on: http://git-master/r/75143
Move all device data from nvhost_channeldesc, nvhost_moduledesc and
nvhost_module to nvhost_device. nvhost_devices are also assigned into
a hierarchy to prepare for implementation of runtime power management.
Change-Id: I1e18daae8fe538086cd1f453d316e0f73e9d7d92
Reviewed-on: http://git-master/r/72844
Reviewed-on: http://git-master/r/74560
Move source files related to host1x into an own directory.
Bug 871237
Change-Id: I6fa3ef057f8b788c37dd2ab698271cf7508711c6
Reviewed-on: http://git-master/r/71783
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
dc vsync, hsync, DE and pclk polarity in kernel
can be different with bootloader setting for a short time
when default polarity value is written.
This can generate momentary panel flicker in kernel boot.
Set the first polarity based on board dc out pin polarity
information directly if needed.
Bug 891444
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/59895
(cherry picked from commit 8e5bfd5702067309171b62a6be5471bfab68a31e)
Change-Id: I80c703792ea5a9596d4cf42ef19115cbf4d556f6
Reviewed-on: http://git-master/r/69711
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Tested-by: Min-wuk Lee <mlee@nvidia.com>
Mark the dependencies of dc driver on switch class explicit,
using proper pre-processors.
Bug 877239
Change-Id: Ie5931aaf4f279e6379b85a00a30bd3cb910614d0
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/55774
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R229bab237a55cacd22f5071eaca1a60503fdbb0d
Original-Change-Id: I3b060b622a593d48319a442072a21d0c4f9527ae
Reviewed-on: http://git-master/r/19049
Rebase-Id: Ra9c6d91a0cb402b3b660e417a87480b36933a92f
V_BLANK_INT was used to mark frame end for other tasks. However, it occurs
at frame start. Switch to FRAME_END_INT to mark the end of frame.
Bug 875448
Reviewed-on: http://git-master/r/52694
(cherry picked from commit 078a2688c67c46cf840f191405cd4324cb9c4574)
[jmayo@nvidia.com: wrapped commit message, fixed bug in S_TO_MS()]
Change-Id: I507148772c2f3037befd30289e5b3a56fe417ee9
Reviewed-on: http://git-master/r/63369
Tested-by: Jon Mayo <jmayo@nvidia.com>
Rebase-Id: R5dbcf2d7ff3fd627194ae1a6163a300e6e48ff7c
Add support to set a global gamma correction table via fbdev cmap
API. The 3 Tegra DC windows have their own local gamma tables, which
can either override or alter the global table.
Bug 868060
Change-Id: I0be1c5e4afa8fd8c010b772c7808c883c0848ab4
Reviewed-on: http://git-master/r/60201
Rebase-Id: R7e613b1c8ac469242172bd81db9dfba25176e0c3
Collect individual underflow counts for underflow statistics to provide
a more accurate number of underflows. Changed stats to use 64-bit numbers
due to the larger numbers involved, about 100x from previously.
Reviewed-on: http://git-master/r/52940
(cherry picked from commit 1d39d430ad90a027be43323f65eef85a3a30faab)
Change-Id: I4d253346dfcb01185a93a7602b7a1c971ea1ebb4
Reviewed-on: http://git-master/r/56301
Rebase-Id: Rf931d627fedc7ce8d9a37c1c54bb76aa2caf9ff1
This change adds support for userspace to query the syncpoint that
display autoincrements every vblank. This can be useful for
applications to time buffer submissions to throttle rendering and
prevent excessive host stalls.
bug 818525
Original-Change-Id: I050e4dcd08609da802f10eeec5b70da181b21717
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/40529
Rebase-Id: Rac929d8ba6b14e469fef4c2753b040e02fae0b8e
The Tegra display windows are not entirely symmetric; only some of them
support filtering in either direction. This change makes the kernel
only enable filtering when it's supported by the hardware.
bug 818525
Original-Change-Id: I0f85f52fcc5c6785c75003c54c8aee12fcd0a220
Reviewed-on: http://git-master/r/40524
Rebase-Id: R7306a484983f91d501bcb122d5fc3cf25c5006d7
This makes the core dc driver keep track of whether a particular input
in enabled. It is up to the output ops to maintain the connected status
if a detect op is plugged in, otherwise it is assumed that the output is
always connected.
bug 818525
Original-Change-Id: I794d7e2db347f63bbb1a7d80bca1a53d9d10c210
Reviewed-on: http://git-master/r/40522
Rebase-Id: Rfeeae486b6a39b95d9f1d95b697132b476735f50
Reserve one syncpoint per window per display controller instead of one
for the entire display controller. This is necessary to allow multiple
windows on a single display controller to flip asynchronously.
bug 818525
Original-Change-Id: Ide1de2bf2ed0bfea7f6abe9aa93815efd0824db1
Reviewed-on: http://git-master/r/40516
Rebase-Id: R49886938a74e71db0c8f53edc8ac45e5015ffe84
This adds the infrasturcture for an enhanced driver interface to program
extended capabilities of the Tegra display controller.
It exposes a new set of device nodes for userspace clients distinct from
the traditional fbdev device nodes. This is necessary due to
limitations in the fbdev infrastructure that don't allow drivers to
store file-private data.
bug 818525
Original-Change-Id: I06cecf894792b9904c73f9ebcdeb746ff7455f6e
Reviewed-on: http://git-master/r/40512
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: Rfa3969804d7f52c841be1ff96305c9463077e1c5
Determine which windows are overlapping, and apply bandwidth calculations
for emc clock scaling and latency allowance appropriately.
Bug 856234
Bug 850602
Original-Change-Id: If587c46e8929b3885b25125f054f5cc2d22b2b58
Reviewed-on: http://git-master/r/44772
Rebase-Id: R841ce1734a7afab1311d3367a72ba9755d6d539c
Export following functions:
- panel read
- panel write
- register write
- register read
Bug 830296
Original-Change-Id: Ie0854e0b8eb213ac2c7fd54f8883ec28e523e1a3
Reviewed-on: http://git-master/r/45529
Tested-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R69d9bed3b6c66384316a849bd646726cd321b1b2
Tegra3 also supports LPDDR2 which has no tiled memory inefficiency as in DDR3.
This patch adds one memory controller API to retrive tiled memory efficiency.
BUG 847731
Original-Change-Id: I407914c6035389b696040947e7aebc6ecdb92bb1
Reviewed-on: http://git-master/r/40074
Rebase-Id: R5675398d3066d01d3d46f26267eddbba1accc815
Overlay was requesting emc 400MHz always during video playback.
Playback happens in overlay which was calculated incorrectly.
Reducing it to match accurate requirement.
Calculate overlay EMC bandwidth requirement same as DC.
Original-Change-Id: I5816d9ca1b42cd04048ca16b3e23e6d6ea312137
Reviewed-on: http://git-master/r/42507
Rebase-Id: Rc82d603742d5f9b5769b3f18a84ef8e718782b3b
remove the support to delay changing emc clock.
Bug 850852
Original-Change-Id: Ibc125e7789ad96059c53c82eb51091afd7b880fc
Reviewed-on: http://git-master/r/40133
Rebase-Id: Rc136721574d4337ce8538abcf852d4d64857cdbf
Not all windows are created equal, only set vertical or horizontal
filters when the window supports them.
Bug 850852
Original-Change-Id: I69b40ff47fd8ed8499857408c249ddd35299ae95
Reviewed-on: http://git-master/r/40132
Rebase-Id: R339412d8ca44cd3bbe69f4af8c9bdde32a6d56c7
- Add attribute in sys to read TEGRA_DC_CRC_CHECKSUM_LATCHED
- Fix some minor formatting issue of dc_sysfs.c
Bug 834332
Original-Change-Id: I48f75fcb1d5403ab40d0da438200a5552ba4e6ff
Reviewed-on: http://git-master/r/37912
Rebase-Id: Rde819259112b14ed1ae67b41d66b1785d68a2b7f
Original-Change-Id: I7a2d2e3016a0289b9df6e73e5d0234f6ace07904
Reviewed-on: http://git-master/r/39306
Rebase-Id: Ra44aa094ba19c367576af4e2cfa5e571e1e05ef9
Original-Change-Id: Ia203886a3b013612b4159393ff43a25a313d1ece
Reviewed-on: http://git-master/r/35911
Rebase-Id: R01b763362c13e09111f60700c3d3a7d2a9a3fc1c
BUG 844499
Original-Change-Id: Ib99a921456f4a6e8e3e2d40907a91d492daf4bc0
Reviewed-on: http://git-master/r/38773
Rebase-Id: R6dccc88053c055d9e4828d6f4d4e18932f0502f2
If the screen is idle (no POST for some time), reduce the DC EMC clock
according the windows size. If external display connected, the EMC clock
will not be reduced.
BUG 828306
Original-Change-Id: I6fb62ce6baf3380737c76b71f16e38ad6465a667
Reviewed-on: http://git-master/r/37106
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: Re2b2c8b1a57c2a04b61c338b0b50e41d8c11ad65
