When connected display EDID presents
aspect ratio that is in valid range,
but it's not in a table of valid ratios
accept it with a warning message.
(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/mmc/host/sdhci.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
Our move to modedb lead to the HDMI display controller always being
enabled (unless forced off by vidargs). This patch makes sure it gets
disabled upon boot disconnected as well as upon later disconnect.
Note: This also fixes DVFS on Colibri T30 in the sense that it will
again stay at 400 MHz EMC as long as no DVI-D aka HDMI display is
connected during boot.
Before updating modes on HDMI hotplug, check if framebuffer is
registered at all. This allows to disable framebuffers completely.
verify variable screeninfo by checking xres and yres before
validating aspect ratio.
bug 1417318
Change-Id: I473f3e2f30888c053ca53559e33355f216d2a8d3
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Reviewed-on: http://git-master/r/340236
Reviewed-by: Jong Kim <jongk@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
After suspend, mode filter might be called with empty yres. This leads
to division by zero when checking aspect ratio. Return as invalid mode
when yres is zero.
When hotpluging hdmi the read of edid often fails.
Add up to 4 retries with a 500ms delay before giving up.
Ported Peter's original change 86413 to main.
board-p1852-panel.c:
Add support for primary and secondary LVDS displays, and secondary HDMI display.
board-p1852-pinmux.c:
Add configuration for HDMI and LVDS
board-p1852.c:
board-p1852.h:
Support for determining which p1852 sku is in use
hdmi.c:If no edid retrieved, but there's a hardwired mode, enable it
(used to support HDMI->LVDS output on p1852 sku 2)
devices.c:added secondary display data.
Bug 977859
Bug 994011
Change-Id: Ide8fb6bf7dd873b1d50269fb98d7c1687e4d9073
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/100438
Reviewed-by: Simone Willett <swillett@nvidia.com>
Without the CONFIG_SWITCH enabled, there are multiple unused
variable warnings that get treated as error.
bug 949219
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I39512367fa4bbd3b00a435d0d7a31cfede9e712f
Reviewed-on: http://git-master/r/115428
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
- Handled warning of unused label.
bug 949219
Change-Id: I72e22063b199562c4a4c065419c1656e3e8ff7ff
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/113880
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/111371
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
removed tegra_dc_hdmi_mode_equal.
It was replaced by tegra_dc_hdmi_cvt_mode_equal
Change-Id: I7988d02a1c0b91eed88fdf573d8c993b6ee7be8d
Reviewed-on: http://git-master/r/106074
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
GVS: Gerrit_Virtual_Submit
We support dynamic pixel-clock setting now, so open HDMI mode
filter by not rejecting a mode due to pixel clock mismatch. If the
mode's requested pixclock is within the suppoted range, check few
constraints of hardware and allow it.
Add aspect ratio check to reject modes with awkward aspect ratio.
Bug 967458
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Change-Id: Ife474dbfe4137a000a4a43b0e1ff72847f2a8b0a
Reviewed-on: http://git-master/r/96163
Set correct VIC value for 1080p/30Hz mode in AVI infoframe.
Bug 969243
Change-Id: I6da9236124dbad7e4d74f3cf6dad7e273bd7778b
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-on: http://git-master/r/100553
(cherry picked from commit 41858f2fd99face9dc0c47bd2870045291a6c0b6)
Reviewed-on: http://git-master/r/102378
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
To avoid border color making limited range test of MHL
certification failed.
Bug 966615
Bug 969243
Signed-off-by: Vick Yu <vyu@nvidia.com>
Change-Id: I5c9659358a1c8dac9c6a5194bbc6f59b8230f116
Reviewed-on: http://git-master/r/100552
(cherry picked from commit 20774a3db055630ba0e59669e2e7cbd412f03178)
Reviewed-on: http://git-master/r/102377
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Tested-by: Youngjin Kim <nkim@nvidia.com>
Call dc_hdmi_mode_filter to validate a videomode. X prepares its
own modedb of supported HDMI modes, but all of them may not be
supported from the HDMI driver. This call makes sure a X-mode is
listed only if supported in DC driver.
Bug: 959676
Change-Id: I8aff65f4e08fcc4471af096150e3972b5913a95a
Reviewed-on: http://git-master/r/99650
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Reviewed-on: http://git-master/r/100656
Bug 953210
Change-Id: Id40b3fe90174a2a8c9a6faf3f35f61d9f7eeb642
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/98477
add trace_printk to log useful debug information.
Bug 870685
Change-Id: I29c0b1600f234ebb06d19c8b6c713b16f6e7643c
Reviewed-on: http://git-master/r/89204
Reviewed-by: Prashant Malani <pmalani@nvidia.com>
Bug 949759
Add new 1080p timing support, or 1080p playback is not available on
some monitors like Acer H243HX
Change-Id: I8a8a3a5b2de71d5a56dad233f953e09176f85b76
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/91732
Add following VGA video modes in tegra_dc_hdmi_supported_modes list:
Resolution Refresh rate(Hz)
640x480 75
720x400 59
800x600 60
800x600 75
1024x768 75
1024x768 60
1152x864 75
1280x800 60
1280x960 60
1280x1024 60
1368x768 60
1440x900 60
1600x1200 75
1680x1050 60
Add CVT representation of all above modes to make sure they pass all the
HDMI constraints.
Add a new function tegra_dc_reload_mode to pick up CVT representation of
matching mode.
Bug 883911
Change-Id: I5227644207d38ca83a0452d3c078ef202e40a508
Reviewed-on: http://git-master/r/89126
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
fix some build warnings and bad code style.
Change-Id: I907296ce0e5437dfd6acd0b2b3c119b6dbde7b1c
Reviewed-on: http://git-master/r/89634
There are HDMI modes which have different margin/sync values
although resolution and pixel clock are the same. One example
is 1080p/24Hz and 1080p/30Hz case.
Those modes are not distinguished when we check if given two
modes are equal. So clocks per frame also should be validated
to decide sameness of the modes.
Bug 950935
Reviewed-on: http://git-master/r/89026
(cherry picked from commit b9e6316850a47445be7545aaec85c6a247c44cb9)
Change-Id: I06d3c0f41e63d65f1908614d09df4d16028895f0
Reviewed-on: http://git-master/r/90030
Add a config option to limit HDMI stereo 3D output to 74.25MHz pixel clock.
When this option is set,
substitute the frame pack stereo modes
for side-by-side (half) left-right stereo modes
to meet this pixel clock restriction.
By default, do not use it (use frame packed HDMI mode as usual).
Bug 938807
Change-Id: I2ce2ca72cbb15ac1939af0f3386dd23650262435
Reviewed-on: http://git-master/r/84252
Reviewed-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Tested-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
When HDMI NULL sample injection is enabled codec inserts null samples
into the audio FIFO for each Azalia frame in which it did not receive
any samples. This support is needed to prevent audio loss for HDMI
devices from some vendor(e.g. sony).
Bug 924926
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/79227
(cherry picked from commit 898fd83d94506de3bd604f75d25084d9bcb6dd9e)
Change-Id: I81f55cab52c92377b49ab94635c8e8aa394b6739
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82724
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Don't check if dc is NULL after we've already dereferenced it.
Reviewed-on: http://git-master/r/63647
Change-Id: I0af6c829b6143b21a1f7de47a1ccfeac4bda99e0
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/78434
TVs/monitors which do not support underscan will crop HDMI picture.
Underscan information might be needed in userspace to adjust HDMI
resolution so that the picture will be shown correctly on such devices.
Bug 911580
Bug 912187
Change-Id: I1eec810d860e13dafef895cb85b32fd8187a4e02
Signed-off-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Reviewed-on: http://git-master/r/68616
Use TEGRA_NVHDCP to enable/disable support for NVHDCP on HDMI.
Change-Id: If65267e7a4c82c5497271c19ac985bfa8881bca1
Reviewed-on: http://git-master/r/67883
Calling sychronous function cancel_delayed_work from interrupt context will put it
on hold till work is cancelled, which is not recommended in ISR. Using similar
function __cancel_delayed_work which works asynchronouly.
Bug 885275
Change-Id: I356af7bf8a22f14aceda4b0171466884e0080da2
Reviewed-on: http://git-master/r/67681
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Test function is invoked by hdmi test module to test DC1, HDMI and
EDID modules.
Bug 834332
Reviewed-on: http://git-master/r/56482
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Tested-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
(cherry picked from commit 8a2ec9a20d88db2f96e17cb7136d81560b989542)
Change-Id: I196802fda78a753391298b0c3b6874cedbf1e197
Reviewed-on: http://git-master/r/60467
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: R2fb40403527aff9b5ca312df475420c7015c53f5
Mark the dependencies of dc driver on switch class explicit,
using proper pre-processors.
Bug 877239
Change-Id: Ie5931aaf4f279e6379b85a00a30bd3cb910614d0
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/55774
Rebase-Id: R229bab237a55cacd22f5071eaca1a60503fdbb0d
When tegra_dc_hdmi_detect is triggered with high HPD Interrupt,
but there's no previous trigger of low HPD interrupt,
by some specific HW design,
then, there's no switch change, no hotplug_handling is getting
called because 1=>1 change do nothing in switch_set_state.
Add this change for safe operation.
Bug 779317
Original-Change-Id: I79f9ad24616388a9eb5156d53b12676b96665c38
Reviewed-on: http://git-master/r/16285
Rebase-Id: R329952d27a0f27a997489452d47f31b68dbe98bb
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Export a new API from HDMI driver which can be used by HDA driver
to forcefully send a new presence detect event. Whenever this API
is called HDMI driver will reset presence detect bit and will setup
ELD buffer if HDMI device is plugged in. If this API is called while
HDMI is not plugged in it will return an error.
Tegra HDA controller does not support detection of plug event when
HDA clocks are disabled. With help of this API HDA controller will
be able to request HDMI driver to generate a new presence detect
event after enabling it's clocks so that it can get proper ELD
information.
Bug 904530
Change-Id: I0c7eb671e2311dbb454b758d21496e6ffd30b0ae
Reviewed-on: http://git-master/r/66825
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R85a08fd28f71eaa0e00ab1ac5c682b5095a9647b
Add code to manage HDA related clocks from HDMI driver. When no HDMI
device is connected to device HDA clocks are disabled to save power.
Whenever HDMI hot plug in happend HDMI driver needs to enable these
clocks before setting HDA presense bit so that HDA controller recieves
the interrupt.
Bug 862023
Change-Id: If62113ad2c71657419056000f5dfe363762bd697
Reviewed-on: http://git-master/r/66091
Rebase-Id: R7367eac67b14907effdee571cd71a04b81b6945e
EDID modules.
Bug 834332
Rebase-Id: Raea2dcac0ecfca42b8a2a56461828bcd1c7d055f
This reverts commit ec6673c1d2021df64e3920cc9c6a06e52e9ffbcb.
Revert this commit since HDA clock names will be changed in order
to add support for HDA driver.
Bug 872652
Change-Id: Ia4899672899189f199fae63a454b178dc29af812
Reviewed-on: http://git-master/r/59617
Rebase-Id: R81e80436981bd78f47b20f2a24efd5d9d2a01cca
the interrupt.
Bug 862023
Change-Id: I975daa1621098eea2175244ce5774312bc396649
Reviewed-on: http://git-master/r/57846
Rebase-Id: R35c55b5c492c15bb79c1b17e29fd6293f1764d3f
Audio frequency and source should be always stored in HDMI driver
context whenever tegra_hdmi_setup_audio_freq_source() gets called.
This is required to avoid overwriting of audio frequency and source
with default values when HDMI driver mode change happens.
Bug 872652
Change-Id: Iddbd7525b8994c2a94523f387439cc3e438c0d29
Reviewed-on: http://git-master/r/54958
Rebase-Id: Reeed80d1308cfb0dea62d84d53a404b223525b24
Resolution wise the pixel clock of the peripheral and supported resolution
mode if found different was checked whether in permissible range or not.
PICOS2KHZ macro argument is taken as denominator in division, in multiple
argument case care should be taken.
Bug 878912
Similar Bug 872389
Reviewed-on: http://git-master/r/54050
(cherry picked from commit 927b647e437133a9d28336ed697447e41b09b9c7)
Change-Id: I6056cbb01d6eea9c1f01168e55d78356ed00108a
Reviewed-on: http://git-master/r/55142
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Rebase-Id: Rd019e00ceac2bd3280dd3a847b49a4601dabc82a
This change implements the TEGRA_DC_EXT_CONTROL_GET_OUTPUT_EDID ioctl in
the dc_ext interface.
It first adds a way for the tegra dc EDID module to export EDID data
safely, without the risk of reading an incomplete or corrupted EDID in
the presence of hotplug, by moving the actual data to a substructure
with a lifetime maintained by a kref. Then, that support is plumbed
through the hdmi block (which is currently the only way to get at the
EDID) and out to userspace.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Bug 817119
Original-Change-Id: I78cd170e15322011b428cb71ffad2c0c3ea058ac
Reviewed-on: http://git-master/r/49127
Rebase-Id: Rafafc0a6fbacda5494b12162ad99a8c70ceeb2e0
Picture Aspect Ratio for 576p mode was wrong, it was always 4:3
if aspect ratio is 16:9. It is fixed.
Bug 863854
Reviewed-on: http://git-master/r/49120
(cherry picked from commit 5537288a3faf4ba7b6677dab8790a022d06d638b)
Original-Change-Id: I7e4ff4e2908a9809f9681f1a09c4f56118418674
Reviewed-on: http://git-master/r/49586
Reviewed-by: BK Kim <bkk@nvidia.com>
Tested-by: BK Kim <bkk@nvidia.com>
Reviewed-by: Bo Kim <bok@nvidia.com>
Tested-by: Bo Kim <bok@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: R0ad2bc3df1b7e43f398b162e934a5bf7a678b22c
- Update the upper layer about hdmi removal in suspended state.
- Removes the redundant variable hpd_pending.
Bug 857122
Reviewed-on: http://git-master/r/44326
(cherry picked from commit ef32636d02cb3405f7f0232d34fb29a33fc5ad94)
Original-Change-Id: Ic1c4cfedfadd318eb0be67d19b528d8e767a7d89
Reviewed-on: http://git-master/r/46642
Tested-by: Manjula Gupta <magupta@nvidia.com>
Rebase-Id: Rfc4ee020f2fab2c8bcc0bad74d2d592f71152c00
To prepare for kernel modularization, nvhost include files need to be
moved from mach-tegra/include to kernel/include. At the same time
user space specific part is split into nvhost_ioctl.h.
Bug 854182
Original-Change-Id: I3694a40d786028733310ecf5b59341282af571be
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/43211
Rebase-Id: Rc4fadf65d59ddfb5bb924e7adfccd39e86a0b2c7
Original-Change-Id: I933f64a82b74025f3ea05a2a20a24cba7948b039
Reviewed-on: http://git-master/r/46995
Reviewed-by: Alok Ahuja <alahuja@nvidia.com>
Tested-by: Dhiren Bhatia <dbhatia@nvidia.com>
Rebase-Id: R3b58044e1c821040ffba6adee54fb4b7131dd489
This makes the core dc driver keep track of whether a particular input
in enabled. It is up to the output ops to maintain the connected status
if a detect op is plugged in, otherwise it is assumed that the output is
always connected.
bug 818525
Original-Change-Id: I794d7e2db347f63bbb1a7d80bca1a53d9d10c210
Reviewed-on: http://git-master/r/40522
Rebase-Id: Rfeeae486b6a39b95d9f1d95b697132b476735f50
This device exposes control over everything that's not specific to one
of T20's two display controllers. It supports:
- output devices
- event delivery
- hotplug events
bug 818525
Original-Change-Id: I3a46f1dddc483b08ed3ee91a4f9c64111c1fd7eb
Reviewed-on: http://git-master/r/40520
Rebase-Id: R9e49fe41f3327b797ec65c3729f4f94edbb45307
Fixed the issue where comparing the pixel clocks of two modes can have a
subtraction result of 0, when this is passed to PICOS2KHZ a divide by
zero occurs.
Bug 850852
Original-Change-Id: I6cb22af6f1bbadd412d033982cbfb2ae31793b55
Reviewed-on: http://git-master/r/42241
Rebase-Id: Rc46985f9393b16e227aaa3f32d211babd5de1485
Avoid reseting eld_retrieved flag during tegra_dc_hdmi_disable(). It
will ensure if tegra_dc_hdmi_disable() is called due to resolution
change, cached eld data is used. It will be reset to zero if during
hotplug HDMI driver fails to get valid eld data.
Bug 854284
Original-Change-Id: I08c8f48eded0c6a469faf63d601f28627a71602f
Reviewed-on: http://git-master/r/42599
Rebase-Id: Rb9636052979360707443ecc151a758f574b03a21
As HDMI is not a wakeup source. To detect HDMI peripheral which is
connected after suspend, we scan for it during HDMI resume.
Bug 846365
Reviewed-on: http://git-master/r/39776
(cherry picked from commit fd1134f413845f8e0b3944153eb7406f713a9709)
Original-Change-Id: Idee461e66edce494214814ced3854f716e8a44e3
Reviewed-on: http://git-master/r/41545
Rebase-Id: R01d0a5d61afb386240ae35da73fe12f38e26ed28
