Clear out all overlays and disable DC on .shutdown
Change-Id: I4bc78fddb0ed8bd621733df191f305ecb279e3f7
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/106549
Reviewed-by: Simone Willett <swillett@nvidia.com>
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
GVS: Gerrit_Virtual_Submit
removed tegra_dc_hdmi_mode_equal.
It was replaced by tegra_dc_hdmi_cvt_mode_equal
Change-Id: I7988d02a1c0b91eed88fdf573d8c993b6ee7be8d
Reviewed-on: http://git-master/r/106074
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
remove and rename unused variable in tega_dc_get_stride
Change-Id: I0d101de22c08609f9727469ad7e4708de8de59ef
Reviewed-on: http://git-master/r/106072
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Reviewed-on: http://git-master/r/106075
Added void to function prototypes and initialized some variables.
Change-Id: I69250f5e17560f900fffddec9697e496af6ad4d2
Reviewed-on: http://git-master/r/106073
Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/105776
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Change to correct behavior for changing settings while
phase_in_adjustments is set. Manual K values should not be overridden
in the case where DIDIM was on and aggressiveness was changed.
They should maintain state to avoid flickering.
Bug 992995
Change-Id: Ic35c32a0fd5c6caaeee147dff114649ea25770c5
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/105523
Detect the stride size used by the bootloader.
If DC is not enabled, fallback to a default stride size.
Bug 973111
Change-Id: If04647ddf04a44987cd841062ff30e03fa4d6a02
Reviewed-on: http://git-master/r/104031
Enable dsi panel B by setting the first bit
in APB_MISC_GP_MIPI_PAD_CTRL_0 register.
Bug 935764
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I9e958e0c9d9e934edf77688fd6a987b5e863392b
Reviewed-on: http://git-master/r/96672
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
We support dynamic pixel-clock setting now, so open HDMI mode
filter by not rejecting a mode due to pixel clock mismatch. If the
mode's requested pixclock is within the suppoted range, check few
constraints of hardware and allow it.
Add aspect ratio check to reject modes with awkward aspect ratio.
Bug 967458
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Change-Id: Ife474dbfe4137a000a4a43b0e1ff72847f2a8b0a
Reviewed-on: http://git-master/r/96163
- currently, function pointers are inside nvhost_device
- these functions abstract the device specific implementation
of a functionality per SoC
- move them to nvhost_driver so that nvhost_device can be
instantiated from arch code using board files/device trees
- add support to use single driver for multiple devices using
concept of id_table. this will be useful in supporting
multiple SoC devices binding single driver
- also add some notes about how device name is expected
Bug 871237
Change-Id: I4c75d7121d26c3bdc50f058e0d144d89ca0edbd9
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/100985
Remove the efficiency factor in the bandwidth calculation.
Clock API will take care off setting the right clock based factoring the
efficiency.
Change-Id: I2b549197778b5afaf1aab3cc87a84debb08172e8
Reviewed-on: http://git-master/r/91659
Reviewed-on: http://git-master/r/103682
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Change-Id: Ie6d425f06911008d77c2ed87dc7b40611755ee6a
Signed-off-by: Chao Xu <cxu@nvidia.com>
Reviewed-on: http://git-master/r/103396
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Change-Id: I13f0f7502aea7f43b2ddff12e9664c22a1d9bd21
Reviewed-on: http://git-master/r/103210
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Reviewed-on: http://git-master/r/101806
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: Ibfa271191bfce371986df29a7971b1da077c3f06
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102722
Set correct VIC value for 1080p/30Hz mode in AVI infoframe.
Bug 969243
Change-Id: I6da9236124dbad7e4d74f3cf6dad7e273bd7778b
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-on: http://git-master/r/100553
(cherry picked from commit 41858f2fd99face9dc0c47bd2870045291a6c0b6)
Reviewed-on: http://git-master/r/102378
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
To avoid border color making limited range test of MHL
certification failed.
Bug 966615
Bug 969243
Signed-off-by: Vick Yu <vyu@nvidia.com>
Change-Id: I5c9659358a1c8dac9c6a5194bbc6f59b8230f116
Reviewed-on: http://git-master/r/100552
(cherry picked from commit 20774a3db055630ba0e59669e2e7cbd412f03178)
Reviewed-on: http://git-master/r/102377
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Tested-by: Youngjin Kim <nkim@nvidia.com>
Move WinB's format limitations to a list of preferred formats.
Bug 985197
Change-Id: Ife37c79441b2737592ace51e94ab0c80af4af917
Reviewed-on: http://git-master/r/102629
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Makes function pointer type for mode_filter match the function in hdmi.c
Change-Id: Id61f319a4ddef003b79782391e9e7f2f8cb32dda
Reviewed-on: http://git-master/r/102630
Use static for functions that are not called externally.
Change-Id: Iacccb83e31e860d10f92897041421298231e45b1
Reviewed-on: http://git-master/r/102623
Tested-by: Jon Mayo <jmayo@nvidia.com>
Bug 955184
Change-Id: I7ac0a290c2b6acd454de05d094bd676b88f4b476
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/101546
-Move _tegra_dc_enable to before irq_request and remove
disable_dc_irq.
-It will remove warning of "IRQ when DC not powered!".
Bug 955184
Change-Id: If9b039f3f1635d92f10bfc54af08101972fc3d57
Reviewed-on: http://git-master/r/101498
WAR comprises of soft reset dsi controller followed by
explicitly clearing host trigger.
Bug 982919
Change-Id: Ia8c497dd496435e429cd5b5ee8aaf1b7d78dc797
Signed-off-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-on: http://git-master/r/102204
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Add display feature table so that user and kernel could set and
update window attributes properly.
Bug 962353
Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7
Reviewed-on: http://git-master/r/101078
Call dc_hdmi_mode_filter to validate a videomode. X prepares its
own modedb of supported HDMI modes, but all of them may not be
supported from the HDMI driver. This call makes sure a X-mode is
listed only if supported in DC driver.
Bug: 959676
Change-Id: I8aff65f4e08fcc4471af096150e3972b5913a95a
Reviewed-on: http://git-master/r/99650
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Reviewed-on: http://git-master/r/100656
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/99046
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15.
It is reviewed on http://git-master/r/99635
It will cause HDMI power ON and emc clock bump up to 667Mhz
after resume from LP0.
bug 930136
Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7
Signed-off-by: Hunk Lin <hulin@nvidia.com>
Reviewed-on: http://git-master/r/100202
Bug 933653
Change-Id: If7ce4dc5129782a7e3487028d2dba01c9380ba90
Reviewed-on: http://git-master/r/98256
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Xinit.
Bug: 930136
Change-Id: Ieaf5c69eefa4a6584893425ad4fd772bcd91ea11
Reviewed-on: http://git-master/r/99635
This reverts commit 90b79e5712300baab889772a5af348559ac95836.
Bug 955393
Change-Id: I0e2a15b7d0898dbbb62f09d8bd3502ec93366664
Reviewed-on: http://git-master/r/99261
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-by: Adam Cheney <acheney@nvidia.com>
Tested-by: Adam Cheney <acheney@nvidia.com>
Bug 951349
Change-Id: I79fb2e49fa38b83af78323b5f5cf6dbca8fd83c2
Reviewed-on: http://git-master/r/98512
Bug 953210
Change-Id: Id40b3fe90174a2a8c9a6faf3f35f61d9f7eeb642
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/98477
Inform DC register updated after we programmed. This eliminates
the display corruption while device enters and resumes from LP0.
Signed-off-by: Mark Zhang <markz@nvidia.com>
bug 964626
Change-Id: I4c655d4800474c675d4cdb6204d6fe66e8c6c4b5
Reviewed-on: http://git-master/r/98336
Tested-by: Mark Zhang <markz@nvidia.com>
Reviewed-by: Peer Chen <pchen@nvidia.com>
Change-Id: I8aa25b03fe6801882b65209cb1a6e125ef27ac2c
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Reviewed-on: http://git-master/r/98319
add trace_printk to log useful debug information.
Bug 870685
Change-Id: I29c0b1600f234ebb06d19c8b6c713b16f6e7643c
Reviewed-on: http://git-master/r/89204
Reviewed-by: Prashant Malani <pmalani@nvidia.com>
TEGRA_DC_EXT_SET_LUT programmed the proper shadow registers
but did not copy the shadow registers to the active set.
Signed-off-by: Adam Cheney <acheney@nvidia.com>
bug 947281
Change-Id: Id734e128bb708f1a75c0cad22b0c51b083d8df3b
Reviewed-on: http://git-master/r/91368
Change-Id: Ib1b0fc6015a9dd45982a97231972dadba6b5a92e
Reviewed-on: http://git-master/r/96966
Provide /sys/class/graphics/fb0/device/nvdps to change video mode
on-the-fly without resetting window layout like fb_set_var(). This
allows flicker free changes in refresh rate.
nvdps sysfs file takes an integer, and selects the closest matching mode
with the same or higher refresh rate. Reading the file displays the
current refresh rate.
Bug 560152
Change-Id: Id5c1eafaf338b99fa9742202b38ccbfc238b77d5
Reviewed-on: http://git-master/r/95473
Handle mode set for FBIOPUT_VSCREENINFO at the end of a frame (during
vblank). This elimiates the work around that requires disabling then
enabling display to change modes.
Adds a spinlock to protect irq code from updates to tegra_dc_mode structure.
Bug 560152
Change-Id: I5d2175f01a177a32d685b46e5af4f78efeec0786
Reviewed-on: http://git-master/r/90688
bug 949219
Change-Id: I1ed8d08de4bdba4643b2ae4e8320db6f9c97a18f
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92310
This reverts commit 75009bc2b1a0a2d2efbe1d166647e789b8a1b9f1.
In order to work around bug 869099,
this mode has been temporarily disabled.
Since the bug is not so visible, enable again.
Change-Id: Ie71dac4ecf620cd96796e2fde361b45dc7141497
Reviewed-on: http://git-master/r/92157
Reviewed-by: Alok Ahuja <alahuja@nvidia.com>
Reviewed-by: Aleksandar Odorovic <aodorovic@nvidia.com>
Reviewed-by: Dhiren Bhatia <dbhatia@nvidia.com>
Reviewed-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Tested-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Change to using kbytes/sec to avoid overflowing 32-bit integer in
Changing efficiency adjustment to ~35%.
Bug 958016
Change-Id: Ia8bdf79e4b3e4bc65517db18d9f351a5f840805e
Reviewed-on: http://git-master/r/92658
Enabled recovery of DC from resetting. When underflow triggered serveral
times(current > 4 for tegra2), DC driver will reset itself to prevent
data corruption. Reopend nvhost connection when resetting finished. That
helps system to show frames instead of a blank screen again.
Fixed Bug 936613
Change-Id: I314c37258a4a446dc07167ac60d0420e79a5fb2d
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/89406
Bug 949759
Add new 1080p timing support, or 1080p playback is not available on
some monitors like Acer H243HX
Change-Id: I8a8a3a5b2de71d5a56dad233f953e09176f85b76
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/91732
Remove old overlay interface, it is replaced with TEGRA_DC_EXTENSIONS
External functions made static now that overlay.c no longer needs them.
Change-Id: I5d080ceb19ad90d3b5cc4bf20494c967687293a5
Reviewed-on: http://git-master/r/92661
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
This change adds a flag to flip windows in cursor mode. Cursor mode
will cause flips to be skipped over if there are newer flip requests
waiting in the workqueue.
Add CURSOR_MODE to caps bitfield.
bug 942762
Change-Id: Ib52a0a5565f961cdd9650e4204cd65b86f96fee1
Reviewed-on: http://git-master/r/90418
Set dc clock rate dynamically to requested pixel rate.
Using modes specified in monitor's EDID data.
Return mode set errors on unsupported clock tolerances.
Bug 931908
Change-Id: I60990ecbc2fbeab542987036b8ccc30b8dababe8
Reviewed-on: http://git-master/r/86073
