When a throughput hint is available, still keep track of the idle time
percentage and use both in gpu scaling. Also modifying fallback
scaling code to use same idle estimate used when a throughput hint is
available. Dropping different time frames for scaling up and down.
Bug 1034948
Bug 965517
Change-Id: Ib3945642768e36a6c0c50f4195c89e3bb67f8442
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/129410
(cherry picked from commit 1e9974097286a78f34367683a3921c9b5bf77d4d)
Reviewed-on: http://git-master/r/131155
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
As WAR, limit 3d clock frequency and emc clock frequency
when camera is on and chip is AP37. 3d clock is set to
361MHz and 437MHz is requested for emc clock with this
change. This change allows 3d to request 1.1V in Core
instead of 1.3V in AP37.
Bug 1001262
Bug 1019309
Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/130945
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
nvhost_3dctx_alloc_common correctly checks the return value of an
allocator function, and attempts to perform cleanup. However, this
particular allocation API returns ERR_PTR values in case of failure,
which then gets passed to the deallocation function, causing a crash.
Also, the return value of that allocator API is checked with IS_ERR
in some places, and with IS_ERR_OR_NULL in others. For consistency
and avoiding surprises if the allocation implementation changes,
use IS_ERR_OR_NULL in all places.
Bug 1035878
Change-Id: I65ce97e11f9712b2e9630b38183f6e70bc14b254
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/124657
GVS: Gerrit_Virtual_Submit
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/120884
Reviewed-by: Simone Willett <swillett@nvidia.com>
Invalidate the FDC before submitting the context
save pushbuffer to ensure cache coherency across
both GPU cores.
Bug 1020291
Reviewed-on: http://git-master/r/121945
(cherry picked from commit cef956d07ec717f4714f5101805bbe2f0f149e71)
Change-Id: I43ffee6a77122b4f2fe17f063dc6756c501e59c7
Reviewed-on: http://git-master/r/122323
Tested-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
enable using frame rate information in 3d frequency scaling by default
Bug 991589
Change-Id: I410c86e3a56ddf00610133333dd518b4f46aa9ec
Reviewed-on: http://git-master/r/116867
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
adding support for using a throughput hint given by the tegra-gfx misc
device in the 3d scaling code. If throughput hint usage is enabled and
the latest throughput hint is recent enough (less than 1 second old),
the throughput hint is used to control 3d frequency scaling. Otherwise
the existing idle time percentage estimate is used.
Bug 991589
Change-Id: I68893e5ce7ef922b95ce5f5b3664eb8e1fdd4027
Reviewed-on: http://git-master/r/116866
This patch removes the possibility to disable the second GPU of T30
using a fuse.
Change-Id: I73cd4b7bd52035322e5fc1b040ffeda6d600a90e
Reviewed-on: http://git-master/r/109434
Compile power management suspend and resume functions only when
CONFIG_PM is enabled.
Change-Id: If349984d62ed002594ba60ac25cd4dddd956aa6c
Reviewed-on: http://git-master/r/109425
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Make all chip specific functions static. Include the chip specific
functions in SoC files after including the hardware headers. This
makes the chip specific functions to be compiled per SoC, and with
the correct hardware definitions.
Bug 982965
Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e
Reviewed-on: http://git-master/r/107581
Call drain fifo and save context functions via nvhost_chip_support.
Earlier client drivers called into host1x code directly, which
makes each client driver SoC specific.
Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a
Reviewed-on: http://git-master/r/109101
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Reviewed-on: http://git-master/r/108501
Add parameters in host1x nvhost_device on
* number of sync points
* number of wait bases
* number of channels
* number of mlocks
* client managed bitmask
* naming of sync points
Add automatically generated headers and use symbols from them to
access hardware.
Move host1x device definition from generic host1x to SoC specific
source files t20.c and t30.c.
Bug 982965
Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1
Reviewed-on: http://git-master/r/104974
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
When a submit fails, the related nvhost_job is not freed. Add an
explicit free. Also, 3D is mapping the save buffer, but it is not
unmapped.
Bug 991972
Change-Id: Ie335adb5e64f54557e76d12dfb6a9a1557781e8d
Reviewed-on: http://git-master/r/105152
- remove usage of custom interface of nvmap to patch the relocs and
and pin the gathers/relocs
- convert code that references nvmap_handle to nvmap_handle_ref
- add logic to pin and map only unique gathers and relocs
- rename nvhost_channel_gather to nvhost_job_gather, because it's
used in nvhost_job code only
Bug 965206
Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/95299
- currently, function pointers are inside nvhost_device
- these functions abstract the device specific implementation
of a functionality per SoC
- move them to nvhost_driver so that nvhost_device can be
instantiated from arch code using board files/device trees
- add support to use single driver for multiple devices using
concept of id_table. this will be useful in supporting
multiple SoC devices binding single driver
- also add some notes about how device name is expected
Bug 871237
Change-Id: I4c75d7121d26c3bdc50f058e0d144d89ca0edbd9
Reviewed-on: http://git-master/r/100985
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: I9a44471dc77d1ed7aa3b6e61a5eca4833fe6dc25
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102721
Add context switch to the ftrace dump.
Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45
Reviewed-on: http://git-master/r/101523
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Reviewed-on: http://git-master/r/99046
Sometimes 3D unit comes up with incorrect scissor configuration.
Earlier patch added the scissor registers to the context save list,
but that did not solve the problem. Remove the extra registers, and
reset 3D after powering it up.
Bug 939307
Change-Id: Id795f2d99ec3c6b907da2785b1816ce753af7a3f
Reviewed-on: http://git-master/r/87654
Reviewed-by: Graziano Misuraca <gmisuraca@nvidia.com>
Tested-by: Graziano Misuraca <gmisuraca@nvidia.com>
Context handler init functions are referred to from non-init section.
The functions should not have __init attribute, even though they're
only used in init time.
Change-Id: I1b6bca48504fd7989edaa037c4b022a76244b0f6
Reviewed-on: http://git-master/r/93216
Initialize scale3d worker even though scale3d would be disabled.
Bug 954879
Change-Id: Iaf3a12740d1d377d949cdfbf7e11fa00568e72fe
Reviewed-on: http://git-master/r/93488
- if user space does not open 3d channel, 3d scaling
algorithm is not initialized. so return safely when
3d scaling is disabled
- also do not call nvhost_module_suspend() explicitly
for host1x client modules. nvhost_channel_suspend()
takes care to suspend the module if ref count = 0
- call nvhost_module_suspend() only for host1x device
as it does not use actual hardware channel
Bug 953451
Change-Id: Iba2b771b71d9b41c8ed978112566181872c56259
Reviewed-on: http://git-master/r/92506
Tested-by: Peer Chen <pchen@nvidia.com>
Reviewed-by: Emily Jiang <ejiang@nvidia.com>
- split the nvhost clients into their own directories
- each client is a nvhost_device and nvhost_driver
- all the code related to host1x control node is centralized
at single place in dev.c
- all the code related to host1x modules nodes is centralized
at single place in bus_client.c
- update the copyright notice & year for new files
Bug 871237
Change-Id: Ief85064699e35ad02b48a7e54496928d7f085af4
Reviewed-on: http://git-master/r/83491
Update nvmap_alloc api to take heap_mask as arg.
This is to let clients specify the specific heap needed.
Change-Id: I9950b3e60e6dac0301b6dc66be3e9d0bab8e0fee
Reviewed-on: http://git-master/r/90471
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Currently nvhost hard codes usage of context handler and sync point
id. Split the context handler and context structures into generic and
host1x specific parts, and move the allocation to happen via a
function pointer in nvhost_device.
Also updates gr3d and mpe to use sync point id and waitbase from
nvhost_device.
Bug 926690
Change-Id: I7f00b450cac99f3816baa27b37ee4e4cf68cfe24
Reviewed-on: http://git-master/r/84901
Replace license information in nvhost with GPLv2. Also adds
copyright year 2012 in files which have been changed in 2012.
Change-Id: I86e8ed27095df13d99e0250e57e244d531fdacec
Reviewed-on: http://git-master/r/89735
Save and restore new gr3d registers. This is a workaround for
hardware not always initializing the registers to proper state
after un-powergating.
Bug 914785
Reviewed-on: http://git-master/r/75698
Change-Id: Id9d65d93d16daf68e29b1433b7dd3284cb439ffc
Reviewed-on: http://git-master/r/78025
Allowing user to write sysfs nodes breaks CTS. 3D scaling should be
enabled in all current power modes and does not need to be toggled
by user / system code. Hence disabling user write permission.
Bug 906796
Reviewed-on: http://git-master/r/77058
Change-Id: I164926b5e65a05d63928c9e7c5970ea930cde37b
Reviewed-on: http://git-master/r/77754
Use standard drvdata interface for storing and accessing nvhost_master.
Reviewed-on: http://git-master/r/72846
Change-Id: I191987c8f6d313a6ede9b59f723269cb6a197e8a
Reviewed-on: http://git-master/r/76815
Remove one duplicate include and relative paths in includes. Replace one
include with forward declaration. Make dependencies to t20 and t30
explicit.
Change-Id: I195020bedbb46277dbd6a92b65be2cde5f6276b8
Reviewed-on: http://git-master/r/72903
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/75885
Move all device data from nvhost_channeldesc, nvhost_moduledesc and
nvhost_module to nvhost_device. nvhost_devices are also assigned into
a hierarchy to prepare for implementation of runtime power management.
Change-Id: I1e18daae8fe538086cd1f453d316e0f73e9d7d92
Reviewed-on: http://git-master/r/72844
Reviewed-on: http://git-master/r/74560
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Move source files related to host1x into an own directory.
Bug 871237
Change-Id: I6fa3ef057f8b788c37dd2ab698271cf7508711c6
Reviewed-on: http://git-master/r/71783
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Move source files related to gr3d into own directory.
Bug 871237
Change-Id: I5118ad792d6ec136d2ec2575eff931e112d5f3b2
Reviewed-on: http://git-master/r/71782
