(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/mmc/host/sdhci.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
Make sure that we dont enter infinite loop due to
negative value of pins in some cases. Also remove
debugging check for refcount.
Bug 1478467
Change-Id: I7df8efa5b3cf8927a0c18363add4f031aca48e48
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/450209
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
There could be race in refcount update leading to
access of module registers without enabling the clock
and power.This patch tries to catch such instances
and enables power.
Bug 1478467
Change-Id: Ia32da44bfcd7838e312815b6261ccadf4470a761
Reviewed-on: http://git-master/r/448701
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
nvhost_job_unpin should always get the nvmap_handle_ref
from rb_entry after validating handle and presence
in the tree.
Bug 1478467
Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448
Reviewed-on: http://git-master/r/436076
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
The VI client within drivers/video/tegra is mutually exclusive with the
Tegra V4L2 framework, since they both want to own the camera hardware.
Change-Id: Idebd0f619f5fc7eb6323b2e08c29c9692c8887a0
Signed-off-by: Andrew Chew <achew@nvidia.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/200221
Make it accessible outside of drivers/video/tegra. V4L2 driver needs
to set some platform_data.
Add suport for T20.
Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7
Reviewed-on: http://git-master/r/200220
Add a companion function to nvhost_client_device_get_resources()
called nvhost_client_device_put_resources() that does the opposite
thing. This is useful for any nvhost clients that need to be loaded
as modules, since the driver removal path will be exercised in that
case.
Change-Id: Ib5cec6fce7b05c780b135b03fcd88e068f772244
Reviewed-on: http://git-master/r/169833
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
When a throughput hint is available, still keep track of the idle time
percentage and use both in gpu scaling. Also modifying fallback
scaling code to use same idle estimate used when a throughput hint is
available. Dropping different time frames for scaling up and down.
Bug 1034948
Bug 965517
Change-Id: Ib3945642768e36a6c0c50f4195c89e3bb67f8442
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/129410
(cherry picked from commit 1e9974097286a78f34367683a3921c9b5bf77d4d)
Reviewed-on: http://git-master/r/131155
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
As WAR, limit 3d clock frequency and emc clock frequency
when camera is on and chip is AP37. 3d clock is set to
361MHz and 437MHz is requested for emc clock with this
change. This change allows 3d to request 1.1V in Core
instead of 1.3V in AP37.
Bug 1001262
Bug 1019309
Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/130945
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
This patch fixes wait base handling in CDMA timeouts.
Bug 1025617
Change-Id: Ia93e55631c1159da161d5c4f257d3beebf0d3149
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/129278
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Sync point values are unsigned, but sysfs creates the text
representation as signed. Correct to use unsigned representation.
Bug 1039058
Change-Id: I96de13952eeeba9510bae179a036459ddee18dcd
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/128075
Reviewed-by: Michal Pecio <mpecio@nvidia.com>
Disable host1x interrupts when clock gating host1x. This fixes a race
where host1x interrupt was raised at the same time when host1x clock
is turned off.
Bug 1031724
Change-Id: I169cd5796608b8888a6b48ed99bb5da754559b2c
Reviewed-on: http://git-master/r/125129
job_size() calculates the size of a job structure based on a struct
passed as a ioctl parameter. This calculation was not checked for
overflow.
Bug 1038551
Change-Id: I13d087dbd5aad5fef1c5d13ceb23e50f565acf95
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/127185
Process wait list when removing a waiter. This clears the interrupt
once it is no longer needed.
Bug 1031724
Change-Id: Ifb46672f70c8bbd6359d0a8aeaac0d718a5394b2
Reviewed-on: http://git-master/r/125230
nvhost_3dctx_alloc_common correctly checks the return value of an
allocator function, and attempts to perform cleanup. However, this
particular allocation API returns ERR_PTR values in case of failure,
which then gets passed to the deallocation function, causing a crash.
Also, the return value of that allocator API is checked with IS_ERR
in some places, and with IS_ERR_OR_NULL in others. For consistency
and avoiding surprises if the allocation implementation changes,
use IS_ERR_OR_NULL in all places.
Bug 1035878
Change-Id: I65ce97e11f9712b2e9630b38183f6e70bc14b254
Reviewed-on: http://git-master/r/124657
nvhost_module_remove_client assumes that a client structure
to be freed exists in the linked list. However, if an allocation fails
in nvhost_module_add_client, no client structure is allocated, and
during cleanup, nvhost_module_remove_client would then attempt
to free an invalid pointer.
Bug 1034729
Change-Id: Ie1a641071b86f8246951e9be824a6003f14b04b6
Reviewed-on: http://git-master/r/124096
When 3D register is read, and we need to do a context switch, the old
context reference is incremented, but it never gets decremented. Fix
by using nvhost_job_get_hwctx() to acquire the reference.
Bug 1031746
Change-Id: Ic72637cb2399f960e2297733bfe45e585a8ec180
Reviewed-on: http://git-master/r/123678
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
host1x interrupts have been left on at suspend due to using wrong
constant for the interrupt register. Disable host1x interrupts at
suspend.
Change-Id: I915fc4e663e6ad90fccacff6fb223c5080e21fcd
Reviewed-on: http://git-master/r/123055
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Reviewed-on: http://git-master/r/120884
Reviewed-by: Simone Willett <swillett@nvidia.com>
Invalidate the FDC before submitting the context
save pushbuffer to ensure cache coherency across
both GPU cores.
Bug 1020291
Reviewed-on: http://git-master/r/121945
(cherry picked from commit cef956d07ec717f4714f5101805bbe2f0f149e71)
Change-Id: I43ffee6a77122b4f2fe17f063dc6756c501e59c7
Reviewed-on: http://git-master/r/122323
Tested-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
- replace the usage of strncmp with strcmp in
nvhost_bus_match()
- strncmp was needed when we had device name as
<name.ip-version>. but now the device name is <name>
which matches with the driver name.
- multiple devices get bind with the same driver using
id_table which uses .version field as an index in id_table
Change-Id: If0b6f0ee18626d5e7ff801b8515ef5168069c3f2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/117953
Reviewed-by: Ken Adams <kadams@nvidia.com>
enable using frame rate information in 3d frequency scaling by default
Bug 991589
Change-Id: I410c86e3a56ddf00610133333dd518b4f46aa9ec
Reviewed-on: http://git-master/r/116867
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
adding support for using a throughput hint given by the tegra-gfx misc
device in the 3d scaling code. If throughput hint usage is enabled and
the latest throughput hint is recent enough (less than 1 second old),
the throughput hint is used to control 3d frequency scaling. Otherwise
the existing idle time percentage estimate is used.
Bug 991589
Change-Id: I68893e5ce7ef922b95ce5f5b3664eb8e1fdd4027
Reviewed-on: http://git-master/r/116866
- host1x_save_context() explicitly updated the ref count on context
- with the re-factoring of nvhost_job code, nvhost_job_alloc()
takes a ref count on context
- this caused the explicit ref count in host1x_save_context()
redundant and lead to memory leak. hence remove it
Bug 1015924
Change-Id: Id18c74412e8659b60288700972690d1b895de4c1
Reviewed-on: http://git-master/r/116409
(cherry picked from commit c98d0cfbbdacdda8e540b5d9e0d513e279b3b2f5)
Reviewed-on: http://git-master/r/117326
This was accidently reverted to be set to max with commit 9774bbe31a.
With 2d clock at max, there is a hit on video power numbers.
Change-Id: Iaf73c6f7800d56229d35fb6a2b00f61d460e986d
Reviewed-on: http://git-master/r/117589
This change is for programming VI and EPP through ISP channel
to support RGB input and dual video capturing.
1. Added syncpt in the ISP channel to submit the channel.
2. Added epp clock to use VI2EPP for RGB capture.
Note: To use this channel, EPP should be free from 2D.
Bug 988546
Change-Id: I17fe278c9325aac2ea1e29cbaf50c8a4499d8551
Signed-off-by: Songhee Baek <sbaek@nvidia.com>
Reviewed-on: http://git-master/r/113965
- Handled warning of, possible use of uninitialized variable and unused
function.
bug 949219
Change-Id: I0d7d345e66774f08e52a12e653a5e7aa6a7a8591
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/113905
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Force serialization of 2D jobs by inserting a host wait for previous
maximum at the beginning of the job.
Bug 1002293
Change-Id: I667ad4565cc32186ea7ccf16845c68d1b1bbdf78
Reviewed-on: http://git-master/r/111475
Reviewed-by: Daniel Parker <dparker@nvidia.com>
Reviewed-by: Francis Hart <fhart@nvidia.com>
This patch removes the possibility to disable the second GPU of T30
using a fuse.
Change-Id: I73cd4b7bd52035322e5fc1b040ffeda6d600a90e
Reviewed-on: http://git-master/r/109434
It seems with building with different tool chains, when compiling
nvhost_acm it doesn't end up with drivers/video/tegra/host in its
include path and therefore it fails to find some header files.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: Ic3d72c863d4b5e501222d21077ba9735315ec65c
Reviewed-on: http://git-master/r/110592
Reviewed-by: Allen Martin <amartin@nvidia.com>
- add public APIs for power & sync-point management
- all these APIs end with string _ext
- all these APIs can be found in linux/nvhost.h
- all these APIs take nvhost_device as first argument
- all these APIs are based on the fact that host1x hardware
driver is parent of all the host1x client driver
- this allows clients of host1x which are outside host1x
driver code to just include nvhost.h & use host1x driver
interfaces
- this also hides the implementation details of power &
sync-point inside host1x driver code
- move sync point ids for dc and nvavp to nvhost.h
Bug 961009
Change-Id: I1a9ca074df87656c4d4bd246853e039a7850d56a
Reviewed-on: http://git-master/r/109219
Compile power management suspend and resume functions only when
CONFIG_PM is enabled.
Change-Id: If349984d62ed002594ba60ac25cd4dddd956aa6c
Reviewed-on: http://git-master/r/109425
Make all chip specific functions static. Include the chip specific
functions in SoC files after including the hardware headers. This
makes the chip specific functions to be compiled per SoC, and with
the correct hardware definitions.
Bug 982965
Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e
Reviewed-on: http://git-master/r/107581
Give names to the structures inside nvhost_chip_support. This way
they can be referred to individually.
Change-Id: I9b727bfc232d11957a8bd3e3570583d47cff778e
Reviewed-on: http://git-master/r/109103
Remove unused functions in CDMA and debug. They were left unused
when debug dump started using sync queue instead of channel
registers for detecting current position.
Change-Id: Ib1f0bc8f702667d0453079e6d5f5d8ca08f8db09
Reviewed-on: http://git-master/r/109102
Call drain fifo and save context functions via nvhost_chip_support.
Earlier client drivers called into host1x code directly, which
makes each client driver SoC specific.
Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a
Reviewed-on: http://git-master/r/109101
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Reviewed-on: http://git-master/r/108827
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Reviewed-on: http://git-master/r/108501
Add parameters in host1x nvhost_device on
* number of sync points
* number of wait bases
* number of channels
* number of mlocks
* client managed bitmask
* naming of sync points
Add automatically generated headers and use symbols from them to
access hardware.
Move host1x device definition from generic host1x to SoC specific
source files t20.c and t30.c.
Bug 982965
Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1
Reviewed-on: http://git-master/r/104974
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
Add configuration variable for default timeout for clients. Set it to
30s for silicon and infinity for simulation.
Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862
Reviewed-on: http://git-master/r/105331
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
Initialize host1x generic irq at bootup.
Bug 971602
Change-Id: I03fb426a0538c1549fdb5360166c4e4b516e75d6
Reviewed-on: http://git-master/r/106167
Remove BUG_ON()s in error cases:
* If IOCTL size is too large, return error instead
* If sync point id is out of range, return error. Prevents panics in
sanity checks nvhost_cdma.
Bug 993642
Change-Id: I3cfa7a23dc557c811e20b726885f82666437de7f
Reviewed-on: http://git-master/r/105866
Register access (read/write) to modules MPE, ISP and VI lack sanity
check for the register number. Add checks to ensure only aperture is
accessed. Also make sure that the check accounts for wrapping of
values of offset and count.
Also fixes the register offset for reads which are done in multiple
blocks.
Bug 992938
Change-Id: I35f30cbd1dda31956286e48c5995b24fd262d1ae
Reviewed-on: http://git-master/r/105585
Remove nvhost dsi driver. Real dsi driver is in tegradc.
Bug 982965
Change-Id: I86044ba586d796ae8d049471a154dcf37bd0e6ed
Reviewed-on: http://git-master/r/104975
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
