Change-Id: Ic7fab1575312afd27430b46a50aa6f7a7de0ac4e
Reviewed-on: http://git-master/r/53843
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R44abb981f52475b4431975c5d38611e7ca93b59a
Fix GART lockups caused by fragmentation by evicting
mapped areas from iovm space after unsuccessful array
pinning attempt.
Fix double unpin error happening during interrupted
submit.
Fix possible sleep in atomic context in iovmm code
(semaphore inside spinlock) by replacing spinlock
with mutex.
Fix race between handle_unpin and pin_handle.
bug 838579
bug 838073
bug 818058
Original-Change-Id: I420447ffb4e02fb78a7987e22a537eefc16ff524
Reviewed-on: http://git-master/r/36129
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R893c97003f2ec2f69e224f35d99d3488f673d620
nvmap provides an interface for user- and kernel-space clients to
allocate and access memory "handles" which can be pinned to enable
the memory to be shared with DMA devices on the system, and may
also be mapped (using caller-specified cache attributes) so that
they are directly accessible by the CPU.
the memory handle object gives clients a common API to allocate from
multiple types of memory: platform-reserved physically contiguous
"carveout" memory, physically contiguous (order > 0) OS pages,
or physically discontiguous order-0 OS pages that can be remapped
into a contiguous region of the DMA device's virtual address space
through the tegra IOVMM subsystem.
unpinned and unmapped memory handles are relocatable at run-time
by the nvmap system. handles may also be shared between multiple
clients, allowing (for example) a window manager and its client
applications to directly share framebuffers
Change-Id: Ie8ead17fe7ab64f1c27d922b1b494f2487a478b6
Signed-off-by: Gary King <gking@nvidia.com>
