drivers/video/tegra/dc/dsi.c: In function 'tegra_dsi_read_fifo':
drivers/video/tegra/dc/dsi.c:2515:3: error: this 'if' clause does not
guard... [-Werror=misleading-indentation]
if (rd_fifo_cnt << 2 > DSI_READ_FIFO_DEPTH)
drivers/video/tegra/dc/dsi.c:2518:4: note: ...this statement, but the
latter is misleadingly indented as if it is guarded by the 'if'
break;
When connected display EDID presents
aspect ratio that is in valid range,
but it's not in a table of valid ratios
accept it with a warning message.
Connecting unsuported screen to HDMI
resulted in kernel panic.
(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/mmc/host/sdhci.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
The pixel clock polarity setting was wrong: The kernel display flags
are rather somewhat confusing: The flags specify the edge where the
data should be driven by the controller (and hence not sampled by the
display!).
Please note that we don't change the default pixel clock polarity.
Our move to modedb lead to the HDMI display controller always being
enabled (unless forced off by vidargs). This patch makes sure it gets
disabled upon boot disconnected as well as upon later disconnect.
Note: This also fixes DVFS on Colibri T30 in the sense that it will
again stay at 400 MHz EMC as long as no DVI-D aka HDMI display is
connected during boot.
Make sure that we dont enter infinite loop due to
negative value of pins in some cases. Also remove
debugging check for refcount.
Bug 1478467
Change-Id: I7df8efa5b3cf8927a0c18363add4f031aca48e48
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/450209
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
There could be race in refcount update leading to
access of module registers without enabling the clock
and power.This patch tries to catch such instances
and enables power.
Bug 1478467
Change-Id: Ia32da44bfcd7838e312815b6261ccadf4470a761
Reviewed-on: http://git-master/r/448701
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
nvhost_job_unpin should always get the nvmap_handle_ref
from rb_entry after validating handle and presence
in the tree.
Bug 1478467
Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448
Reviewed-on: http://git-master/r/436076
Don't initialize the whole display controller (dc) when framebuffer
mode is set to off.
This avoids creation of the /dev/tegra_dc_x device. The tegra X
driver requires for each tegra_dc_x device an framebuffer device
with the same id. This patch avoids creation of both, which makes
the tegra X driver load correctly.
Note: Turning off tegrafb0 still leads to kernel crash due to
hard coded device enumeration.
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
Hack to avoid 24 Hz mode in X resulting in no display at all. This has
been encountered using e.g. a Samsung SyncMaster F2380 if connected by
HDMI.
root@colibri-t20:~# xrandr
Screen 0: minimum 256 x 128, current 1920 x 1080, maximum 2048 x 2048
LVDS-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 0mm x 0mm
1920x1080 60.0*+
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 160mm x 90mm
1920x1080 60.0 + 24.0*
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
1024x768 75.0 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 72.8 66.7 59.9
720x400 70.1
This is really just enabling the same hack from Apalis/Colibri T30
which is now relevant on the Colibri T20 as well due to the modedb
changes:
3a6fc5303b9e798295caa01d2cfe75b05fdccf55
Before updating modes on HDMI hotplug, check if framebuffer is
registered at all. This allows to disable framebuffers completely.
Allow to change clock polarity for RGB display output using the
keywords outputen/pixclockpol/vsync and hsync. Add them right
after the driver specification, use 0/1 to specifiy high/low
polarity, e.g. video=tegrafb0:pixclockpol:1,800x480
Remove special clocks for Tegra 2, but use backup clock source
instead. This allows to run all common used resolution within
the drivers -1/+9% allowed band for pixelclock exactness.
Allow the "user" nvmap client to access the
nvmap memory handle of "videobuf2-dma-nvmap" client.
Bug 1421388
Change-Id: Id7a28c06214508d807098a6b258345023192a601
Signed-off-by: Rahool Paliwal <rpaliwal@nvidia.com>
Reviewed-on: http://git-master/r/344620
verify variable screeninfo by checking xres and yres before
validating aspect ratio.
bug 1417318
Change-Id: I473f3e2f30888c053ca53559e33355f216d2a8d3
Signed-off-by: Pankaj Dabade <pdabade@nvidia.com>
Reviewed-on: http://git-master/r/340236
Reviewed-by: Jong Kim <jongk@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Add some more modes e.g. for full HD panel.
Also add tweaked pixel clock for Tegra 2 because the clock is always
a child of the peripherial clock and only some divisors are available.
HDMI.
root@apalis-t30:~# xrandr
axis) 0mm x 0mm
1920x1080 58.6*+
axis) 160mm x 90mm
1920x1080 60.0*+
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
832x624 74.6
720x576 50.0
720x480 59.9
720x400 70.1
This is basically a revamp of the following commit which got scrapped
by the modedb changes:
8174d21e5fe0d086cb5824161c58eb065f412281
Update and synchronize DC window after enabling DC while unblanking.
bug 1416339
Change-Id: I404004e1cbb3908cceade8aa033a660dc488d400
Reviewed-on: http://git-master/r/344778
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
When grepping through sysfs, grep tries to read all sysfs files
which are available. Some of them lead to error due to null pointers.
Therefor check for null pointers before using them.
Updated several comments to make code easier to read and understand.
Also use the front_porch workaround in any case, for HDMI output
too.
In order to find a viable resolution we not only parse VESA mode,
we also parse CEA (multimedia) modes and our own small modedb (for
specific touch screens).
Use new modedb based framebuffer settings by defining default_mode
in the display controllers platform data. Also impelmented the
fallback logic to this default_mode in case no kernel cmd line
parameter was set.
Allow to specify framebufffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
After suspend, mode filter might be called with empty yres. This leads
to division by zero when checking aspect ratio. Return as invalid mode
when yres is zero.
The tweaks are only specific to r16-r2 branch
and will not go into mainline.
- Pass nvmap memory handle to the user through
the mmap'd buffer allocated by videobuf2 client.
- Allow the "user" nvmap client to access the
Re-arranging the copyright message in nvmap_dev.c
for Automatic validation to pass.
Bug 1369083
Change-Id: Ia27d172253860e79557911c2e848bc9084d662d4
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/309494
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
When hotpluging hdmi the read of edid often fails.
Add up to 4 retries with a 500ms delay before giving up.
Initialisation of the framebuffer console on DVI-D aka HDMI always
failed on monitors which report the vertical front porch to be 1
in their EDID.
The fix now changes also the modedb and not only the list of
videomodes with a compatible timing.
This was particularly bad on Apalis T30 where this is activated
by default. On Colibri T30 this was observed when enabling it using the
fbcon=map:1 boot argument.
HDMI.
LVDS-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 58.6*+
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
832x624 74.6
720x576 50.0
720x480 59.9
720x400 70.1
Move paddr to correct ifdef to enable CONFIG_NVMAP_PAGE_POOLS=n
compilation.
The VI client within drivers/video/tegra is mutually exclusive with the
Tegra V4L2 framework, since they both want to own the camera hardware.
Change-Id: Idebd0f619f5fc7eb6323b2e08c29c9692c8887a0
Signed-off-by: Andrew Chew <achew@nvidia.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/200221
Make it accessible outside of drivers/video/tegra. V4L2 driver needs
to set some platform_data.
Add suport for T20.
Change-Id: I98353c2874ea28cfa0a7a5dd8a1dc4c586af4dd7
Reviewed-on: http://git-master/r/200220
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Use 1x1 as the minimum window size.
Bug 1193195
Change-Id: I42e13fec82bbc2dc37bde6416088f3ae49b304b7
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/173302
(cherry picked from commit 3f160560b48fdf501547b9fc1f7c5bf8bd5e32af)
Reviewed-on: http://git-master/r/190810
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Tested-by: Eric Brower <ebrower@nvidia.com>
Fix manual rebase error
Change-Id: I3b2165488b11bddda271cecdc979341c130def9b
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/173554
Send change all vc's notification from HDMI hot-plug reader to
fbcon, so that the new selected mode can be applied on all the
vc's from vc1 to vc6. This sometimes causes corruption on HDMI
hot plugin, when fbcon is mapped to HDMI
Bug 1166008
Change-Id: Id173de3014597f79c8c8b31bbbee7c9c560547b6
Reviewed-on: http://git-master/r/168683
When porting change from mainline to balance dc irq, the change
of enable/disable order was not ported, thus dc irq is disabled
if dc is enabled during probe.
This is part of http://git-master/r/146107.
Original change is big for many bugs, only port one here.
bug 1173177
bug 1173038
bug 1008313
Change-Id: Idd703daca9f980e905b185eeeae19dc6309d76e5
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/162868
(cherry picked from commit 6ddd8b02f7a17d2269290d06159c20860ffb92e9)
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/173249
Unconditionally update line_length using disply width to avoid discrepancy
between line_length and actual display width.
bug 1186388
Change-Id: I8ef2f9cf76a61764c2121f3c2c013b72b830ce2e
Reviewed-on: http://git-master/r/170664
Add this function, to be able to set the global field of an
nvmap_handle while preserving the nvmap API's encapsulation
mechanisms.
Change-Id: I62de773a65119722f059b114e2d0e906c7e04e83
Reviewed-on: http://git-master/r/169834
Add a companion function to nvhost_client_device_get_resources()
called nvhost_client_device_put_resources() that does the opposite
thing. This is useful for any nvhost clients that need to be loaded
as modules, since the driver removal path will be exercised in that
case.
Change-Id: Ib5cec6fce7b05c780b135b03fcd88e068f772244
Reviewed-on: http://git-master/r/169833
Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
