path: root/drivers/video/tegra
2012-07-27video: tegra: nvmap: Set PAGELIST_VMALLOC_MIN size correctKrishna Reddy
page list array size greater than PAGE_SIZE should use vmalloc. Change-Id: Ic03668ba7ff716bfb3cc08aaef5f86214ee0a9df Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/116875 Reviewed-by: Alex Waterman <alexw@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com> Tested-by: Hiroshi Doyu <hdoyu@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> (cherry picked from commit ddacaacd2a9fff10187e026eaa0d898694eeb95f) Reviewed-on: http://git-master/r/118194
2012-07-25video: tegra: nvmap: Fix breakage for T20Hiroshi DOYU
NVMAP_CONVERT_CARVEOUT_TO_IOVMM is only available for IOMMU less SoCs. This was introduced by: commit b8b0b4c42fc77d94b8deadaa46f795784f3bbb5e video: tegra: nvmap: Make IOMMU/IOVMM selectable in Kconfig Bug 1017112 Change-Id: I2a6f101b15085ece600f77690bc77adc042eb29f Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Reviewed-on: http://git-master/r/117976 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Meghana Kankarej <mkankarej@nvidia.com> Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2012-07-25video: tegra: dc: synchronize dsi clock-gatingRakesh Iyer
The one shot thread will clock gate the modules periodically. This will ensure relevant paths in dc driver have an active dc clock and dsi host. Bug 1013172 Change-Id: Ibb505e35044f31405c06cb9fa0d6fdf78aafd4a6 Signed-off-by: Rakesh Iyer <riyer@nvidia.com> Reviewed-on: http://git-master/r/117137 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Animesh Kishore <ankishore@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-07-24video: tegra: host: fix memory leak in ctx saveMayuresh Kulkarni
- host1x_save_context() explicitly updated the ref count on context - with the re-factoring of nvhost_job code, nvhost_job_alloc() takes a ref count on context - this caused the explicit ref count in host1x_save_context() redundant and lead to memory leak. hence remove it Bug 1015924 Change-Id: Id18c74412e8659b60288700972690d1b895de4c1 Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-on: http://git-master/r/116409 (cherry picked from commit c98d0cfbbdacdda8e540b5d9e0d513e279b3b2f5) Reviewed-on: http://git-master/r/117326 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-23video: tegra: 2d: reset 2d clock to minimumBharat Nihalani
This was accidently reverted to be set to max with commit 9774bbe31a. With 2d clock at max, there is a hit on video power numbers. Change-Id: Iaf73c6f7800d56229d35fb6a2b00f61d460e986d Reviewed-on: http://git-master/r/117589 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Donghan Ryu <dryu@nvidia.com>
2012-07-19video: tegra: dsi: Implement dcs video + hostAnimesh Kishore
Send host commands to panel during vertical blanking of a frame. Implementation is generic enough to handle both long and short packets. Bug 1009863 Change-Id: I9a80641df2d8b67eb3649d220c028543b246a5f3 Signed-off-by: Animesh Kishore <ankishore@nvidia.com> Reviewed-on: http://git-master/r/114990 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-07-16ARM: tegra: p1852: Dual-display support for all SKUsDongfang Shi
Ported Peter's original change 86413 to main. board-p1852-panel.c: Add support for primary and secondary LVDS displays, and secondary HDMI display. board-p1852-pinmux.c: Add configuration for HDMI and LVDS board-p1852.c: board-p1852.h: Support for determining which p1852 sku is in use hdmi.c:If no edid retrieved, but there's a hardwired mode, enable it (used to support HDMI->LVDS output on p1852 sku 2) devices.c:added secondary display data. Bug 977859 Bug 994011 Change-Id: Ide8fb6bf7dd873b1d50269fb98d7c1687e4d9073 Signed-off-by: Dongfang Shi <dshi@nvidia.com> Reviewed-on: http://git-master/r/100438 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-07-16video: tegra: nvmap: Make IOMMU/IOVMM selectable in KconfigHiroshi DOYU
This patch allows nvmap to use the standard IOMMU API as its backend engine instead of the legacy tegra IOVMM by Kconfig. Enable TEGRA_IOMMU_{GART,SMMU} under IOMMU in config, and it automatically disables IOVMM, instead. Change-Id: I71112ef8072591aac4a93075623ca31c8851a960 Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Reviewed-on: http://git-master/r/114217 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2012-07-13video: tegra: fix compilation warningRhyland Klein
Without the CONFIG_SWITCH enabled, there are multiple unused variable warnings that get treated as error. bug 949219 Signed-off-by: Rhyland Klein <rklein@nvidia.com> Change-Id: I39512367fa4bbd3b00a435d0d7a31cfede9e712f Reviewed-on: http://git-master/r/115428 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
2012-07-13video: tegra: dc: fix build error in print_modeJon Mayo
Use the right number of parameters for tegra_dc_calc_fresh() when called from print_mode(). This code is only used for debug. Change-Id: I4d0bb8b1700f670644057039fe8d0bc315b27c1d Signed-off-by: Jon Mayo <jmayo@nvidia.com> Reviewed-on: http://git-master/r/115485 Reviewed-by: Automatic_Commit_Validation_User
2012-07-13tegra: dc: Make data output along with pixel clock.Roger Hsieh
After making pclk output ahead of LVDS_SHDN# , data output is later than panel ready then caused partial black screen. Force triggered data output to get it fixed. Bug 972377 Bug 976081 Bug 1001434 Change-Id: Icd455d7439f622e46295158a5435286c521526aa Signed-off-by: Roger Hsieh <rhsieh@nvidia.com> Reviewed-on: http://git-master/r/113164 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-12video: tegra: dc: consider bandwidth efficiency for tegra2Bharat Nihalani
This is similar to commit a62be5b5595ad86411ced81bceeb3d6a693426d2 pushed for rel-14 branch. Bug 1004341 Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-on: http://git-master/r/111227 (cherry-picked from fbfce3106da8dad18948103c812bdd9d45ffdd06) Change-Id: Ib459094fd6499b3cc63bc534bf36e57dc98ce62b Reviewed-on: http://git-master/r/114584 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2012-07-12video: tegra: dc: support disp mode override via boot argsNirav Patel
Allows overidding the default disp mode without having to recompile the kernel. Boot args can be specified in the following format: disp_params=<rgb|hdmi|dsi>:pclk,h_active,v_active,h_ref_to_sync, v_ref_to_sync,h_sync_width,v_sync_width,h_back_porch,v_back_porch, h_front_porch,v_front_porch;<rgb|hdmi|dsi>:pclk,h_active,... Bug 969088 Change-Id: Id0acf608de145493f6749d5b799d4bbb8162ba72 Signed-off-by: Nirav Patel <nipatel@nvidia.com> Reviewed-on: http://git-master/r/104604 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-11video: tegra: treat compilation warning as errorSanjay Singh Rawat
- Adding flag to treat warning as error. - Handled warning of unused function. bug 949219 Change-Id: Ic6edfc28bae95b8395cbd51e80f14aa4aa663f61 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/114624 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-11video: tegra: nvmap: Introduce IOMMU backend instead of IOVMMHiroshi DOYU
Introduce IOMMU backend functions which use DMA API familiy internally. Replace tegra_iovmm_*() API with arm_iommu_*iova*() and dma_(un)map_page_(at)(). Change-Id: I0b014926ffedc12bf8f868b163982c6082d050b6 Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Reviewed-on: http://git-master/r/114216 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2012-07-11ARM: tegra: iovmm: Allow alloc_client to take struct deviceHiroshi DOYU
Allow tegra_iovmm_alloc_client() to take struct device * instead of const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to support IOVMM and IOMMU simultaneously. Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Reviewed-on: http://git-master/r/114215 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2012-07-09video: tegra: host: t30: Add syncpt/epp in ISP chSonghee Baek
This change is for programming VI and EPP through ISP channel to support RGB input and dual video capturing. 1. Added syncpt in the ISP channel to submit the channel. 2. Added epp clock to use VI2EPP for RGB capture. Note: To use this channel, EPP should be free from 2D. Bug 988546 Change-Id: I17fe278c9325aac2ea1e29cbaf50c8a4499d8551 Signed-off-by: Songhee Baek <sbaek@nvidia.com> Reviewed-on: http://git-master/r/113965 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-09video: tegra: host: resolve compilation time warningsSanjay Singh Rawat
- Handled warning of, possible use of uninitialized variable and unused function. bug 949219 Change-Id: I0d7d345e66774f08e52a12e653a5e7aa6a7a8591 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/113905 Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
2012-07-09video: tegra: resolve compilation time warningsSanjay Singh Rawat
- Handled warning of unused label. bug 949219 Change-Id: I72e22063b199562c4a4c065419c1656e3e8ff7ff Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/113880 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2012-07-09video: tegra: dc: vblank workerMark Zhang
Freeze vblank worker while suspending by adding the work into system freezewq. This eliminates a kernel panic caused by nvsd reading brightness valuesfrom display while clock gated. Bug 1006180 Bug 1003969 Bug 1003730 Change-Id: Ice9bfb18e5c826ae063c2b901421b1047ff9d2f0 Signed-off-by: Mark Zhang <markz@nvidia.com> Reviewed-on: http://git-master/r/112880 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2012-07-03video: backlight: use gpio request and free apis for backlight pinSanjay Singh Rawat
- Gpio freeing function does disabling job. - If backlight pin is an sfio, we have to claim the gpio. So that we can use the gpio api's to configure it as sfio. bug 984440 bug 858120 Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/109564 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-07-02video: tegra: dc: split dc.c into smaller filesJon Mayo
Moved mode setting code into mode.c Move window code info window.c Moved clock related code into clock.c Moved LUT and gamma related code into lut.c Moved csc(color space conversion) into csc.c Removed unnecessary static function prototypes from header. Moved many short inline functions to dc_priv.h Cleaned up copyright headings. Cleaned up formatting and indent in all files. Fixed build warnings. Bug 870907 Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792 Signed-off-by: Jon Mayo <jmayo@nvidia.com> Reviewed-on: http://git-master/r/111371 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-07-01video: tegra: dsi: 720p panel power fixRakesh Iyer
Send specified DC frames to 720p panel during power up/down sequencing. Bug 997484. Change-Id: I3927e98322ec93f68cabf635c71485b64750d7f9 Signed-off-by: Rakesh Iyer <riyer@nvidia.com> Reviewed-on: http://git-master/r/109917 (cherry picked from commit e1d10bc056031fbc2f68101978d76317c44fc7af) Reviewed-on: http://git-master/r/111944 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Animesh Kishore <ankishore@nvidia.com> Reviewed-by: Jon Mayo <jmayo@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-07-01video: tegra: host: Serialize 2D jobsTerje Bergstrom
Force serialization of 2D jobs by inserting a host wait for previous maximum at the beginning of the job. Bug 1002293 Change-Id: I667ad4565cc32186ea7ccf16845c68d1b1bbdf78 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/111475 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Donghan Ryu <dryu@nvidia.com> Reviewed-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-by: Daniel Parker <dparker@nvidia.com> Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Francis Hart <fhart@nvidia.com>
2012-06-29video: tegra: nvmap: resolve compilation time warningSanjay Singh Rawat
- Grouping variables around bitwise operators for safe operation. bug 949219 Change-Id: I8edf7fb241eb79ac07b63ab856d206fc453308f1 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/109577 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-28video: tegra: host: T30 uses two GPUs alwaysArto Merilainen
This patch removes the possibility to disable the second GPU of T30 using a fuse. Change-Id: I73cd4b7bd52035322e5fc1b040ffeda6d600a90e Reviewed-on: http://git-master/r/109434 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-28video: tegra: dc: Fix the check of dirty window.Kevin Huang
Change-Id: I6584c856356d6be123a66731bde414e4925ffe07 Reviewed-on: http://git-master/r/111184 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-06-27video: tegra: dc: Deactivate DSI runtime when DC is idle.Kevin Huang
We support 3 different aggressiveness levels of disabling DSI runtime. The larger the aggressive level is, the higher DSI power we can save. Bug 936337 Change-Id: Idadcb49b364e29ddd0a05dde1c6d3dfda6cd493e Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/106361 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-26video: host: Add host to EXTRA_CFLAGSRhyland Klein
It seems with building with different tool chains, when compiling nvhost_acm it doesn't end up with drivers/video/tegra/host in its include path and therefore it fails to find some header files. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Change-Id: Ic3d72c863d4b5e501222d21077ba9735315ec65c Reviewed-on: http://git-master/r/110592 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Allen Martin <amartin@nvidia.com> Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2012-06-26video: tegra: use public APIs exposed by host1x driverMayuresh Kulkarni
Bug 961009 Change-Id: Ifdcc7bc8a40d270e70a63329f46caff541bf01e2 Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-on: http://git-master/r/109461 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-06-25video: tegra: dc: Support for pre power-off actionsKen Chang
Part of panel settings need to be done before/after pixel clock is disabled. Add support for these actions to meet panel spec. bug 976081 Signed-off-by: Ken Chang <kenc@nvidia.com> Reviewed-on: http://git-master/r/102542 Reviewed-by: Lokesh Pathak <lpathak@nvidia.com> Tested-by: Lokesh Pathak <lpathak@nvidia.com> (cherry picked from commit dcecdc64d4d0fd4d9f69df52c9d200dfbf1dd7fc) Change-Id: Ibfede68d67a4815156f73c2d1cdca90f3f771755 Reviewed-on: http://git-master/r/110296 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-25video: tegra: host: add public APIs for power & syncpoint managementMayuresh Kulkarni
- add public APIs for power & sync-point management - all these APIs end with string _ext - all these APIs can be found in linux/nvhost.h - all these APIs take nvhost_device as first argument - all these APIs are based on the fact that host1x hardware driver is parent of all the host1x client driver - this allows clients of host1x which are outside host1x driver code to just include nvhost.h & use host1x driver interfaces - this also hides the implementation details of power & sync-point inside host1x driver code - move sync point ids for dc and nvavp to nvhost.h Bug 961009 Change-Id: I1a9ca074df87656c4d4bd246853e039a7850d56a Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-on: http://git-master/r/109219 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-06-22video: tegra: dc: Skip the vblank_int work if DC is disabled.Kevin Huang
Bug 1000789 Bug 1003730 Change-Id: I7fbd703dde2044f2790e6a9b356ef8dca89ad8f3 Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/110146 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2012-06-22video: tegra: dc: force the use of new bandwidthJon Mayo
During programming of a frame or at frame end, force the use of the new EMC bandwidth instead of the previous frame's bandwidth. Moved copy of new_bandwidth out of tegra_dc_set_latency_allowance() to match the semantics of the rest of tegra_dc_program_bandwidth(). bug 949015 Change-Id: I881f3a2c75f3438e3bbb3208b518f15a4574bc91 Signed-off-by: Jon Mayo <jmayo@nvidia.com> Reviewed-on: http://git-master/r/110149 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Daniel Solomon <daniels@nvidia.com> Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
2012-06-21video: tegra: host: Exclude suspend/resume if disabledTerje Bergstrom
Compile power management suspend and resume functions only when CONFIG_PM is enabled. Change-Id: If349984d62ed002594ba60ac25cd4dddd956aa6c Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/109425 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-06-21video: tegra: nvmap: Use trace points in NvMap.Krishna Reddy
Change-Id: I2a5f0c9305bd53c42df181556d97efa5d6792ad7 Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/106500 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bo Yan <byan@nvidia.com>
2012-06-20video: tegra: dc: fix MC_DECERR display0_win errors on shutdownAdam Cheney
When a DC window is being released, a NULL flip is used to indicate that the window should be disabled. To disable a window, 0 is written to WIN_OPTIONS. The MC_DECERR on window shutdown is a symptom of forgetting step 2) below when disabling windows, leaving no indication that there is anything to wait for. This causes DC to erroneously unpin the scanout buffer while the buffer is still actively being used. Summary of flip (window update) synchronization in DC: 1) program some window registers 2) set win->dirty=1 3) schedule the activation of the registers 4) request VBLANK or HBLANK interrupts 5) wait for win->dirty==0 In the trigger_windows ISR (every VBLANK or HBLANK): 1) if there is no window update pending in HW, clear dirty flag to indicate that ACTIVE registers are up-to-date. bug 991572 bug 995614 bug 989119 bug 983251 bug 960424 bug 866711 Change-Id: I8b710aac874b202838c3989608b7e0bd15425382 Signed-off-by: Adam Cheney <acheney@nvidia.com> Reviewed-on: http://git-master/r/109370 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Robert Morell <rmorell@nvidia.com> Reviewed-by: Nirav Patel <nipatel@nvidia.com> Reviewed-by: Jon Mayo <jmayo@nvidia.com>
2012-06-19video: tegra: host: Support per Soc hardware headersTerje Bergstrom
Make all chip specific functions static. Include the chip specific functions in SoC files after including the hardware headers. This makes the chip specific functions to be compiled per SoC, and with the correct hardware definitions. Bug 982965 Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/107581 Reviewed-by: Automatic_Commit_Validation_User
2012-06-18video: tegra: host: Give names to chip_support partsTerje Bergstrom
Give names to the structures inside nvhost_chip_support. This way they can be referred to individually. Change-Id: I9b727bfc232d11957a8bd3e3570583d47cff778e Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/109103 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Ken Adams <kadams@nvidia.com>
2012-06-18video: tegra: host: Remove unused functionsTerje Bergstrom
Remove unused functions in CDMA and debug. They were left unused when debug dump started using sync queue instead of channel registers for detecting current position. Change-Id: Ib1f0bc8f702667d0453079e6d5f5d8ca08f8db09 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/109102 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Ken Adams <kadams@nvidia.com>
2012-06-18video: tegra: host: Use chip_ops for save contextTerje Bergstrom
Call drain fifo and save context functions via nvhost_chip_support. Earlier client drivers called into host1x code directly, which makes each client driver SoC specific. Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/109101 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Ken Adams <kadams@nvidia.com>
2012-06-18video: tegra: host: expose power management paramters via sysfsMayuresh Kulkarni
this commit exposes following power management parameter through sysfs: - clockgate_delay: delay after which module is clock gated after it goes idle. this read/write attribute & unit is ms. - powergate_delay: delay after which module is power gated after it is clock gated. this is read/write attribute & unit is ms. - refcount: current reference count on the module. this is read-only attribute. path is: /sys/devices/host1x/<device-name>/acm/ where <device-name> = name of device node like gr2d or gr3d etc Bug 845598 Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-on: http://git-master/r/108827 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Francis Hart <fhart@nvidia.com> Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2012-06-14video: tegra: host: Remove version from dev nameTerje Bergstrom
Remove version from nvhost_device name, and use a new field, version, to distinguish between IP versions. This restores the sysfs API for 3D clock scaling back to its original path. Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/108501 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-14video: tegra: dc: Move #includes from dc_priv.hTerje Bergstrom
Move #include directives for nvhost headers from dc_priv.h to the source files that need the #includes. This allows #including dc_priv.h without access to all nvhost headers. Also adds nvhost to the #include path of dc to allow making dev.h a stub in a later commit. Bug 982965 Change-Id: Icfe7084d295f57926195b178174f81047eb01187 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/108225 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-14video: tegra: host: Parametrize host1xTerje Bergstrom
Add parameters in host1x nvhost_device on * number of sync points * number of wait bases * number of channels * number of mlocks * client managed bitmask * naming of sync points Add automatically generated headers and use symbols from them to access hardware. Move host1x device definition from generic host1x to SoC specific source files t20.c and t30.c. Bug 982965 Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/104974 Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-06-14video: tegra: host: Register devices in SoC filesTerje Bergstrom
Move the device structures to the driver source code files. Register all nvhost_device's in one loop which is called from board file. host1x driver code is moved to live under host1x, too. This causes a need to add host to include path of tegradc and nvavp. Bug 982965 Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/104076 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-06-14video: tegra: dc: fix bug causing drawing before flippingI-Gene Leong
The tegra_dc_trigger_windows function was improperly using the WIN_x_UPDATE bits to determine when a flip has occurred instead of the WIN_x_ACT_REQ bits. Without this change, it's possible for the postflip syncpoint for a buffer to get incremented before it actually flips. Still need to figure out why that's even possible... Fixes bug 902955 Change-Id: I67ba093a0114646977cc8cb95a040ec4178cebfc Reviewed-on: http://git-master/r/65389 Reviewed-by: Jon Mayo <jmayo@nvidia.com> Reviewed-by: Nate Huang <nhuang@nvidia.com> Tested-by: Nate Huang <nhuang@nvidia.com> Reviewed-on: http://git-master/r/98024 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-06-13video: tegra: dc: Use ref-count to mask vblank interrupt.Kevin Huang
Bug 990586 Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547 Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/107714 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com>
2012-06-11video: tegra: host: Add config option for timeoutTerje Bergstrom
Add configuration variable for default timeout for clients. Set it to 30s for silicon and infinity for simulation. Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/105331 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-06-11video: tegra: dc: Clock-gate display modules dynamically.Kevin Huang
Bug 936337 Bug 899053 Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/106313 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
