Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
The situation in which the problem occurred was with a Plugable UGA-2K-A
connected to a Samsung EX2220X display. The driver indicates that
1920x1080 is a valid mode (the first mode available, in fact), but
proceeds to set the framebuffer size to 1600x1200.
The patch corrects what seems to be a logic error, regarding unsetting
the FB_MISC_1ST_DETAIL flag, if the first (top/best) mode is invalid.
The existing code unset the flag if ANY mode was invalid.
Signed-off-by: William Katsak <william.katsak@alcatel-lucent.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Many stupid corrections of duplicated includes based on the output of
scripts/checkincludes.pl.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
Commit e66eed651fd1 ("list: remove prefetching from
regular list iterators") removed the include of prefetch.h from list.h,
so we need to include it explicitly, now.
fixes this build error on powerpc:
drivers/video/udlfb.c: In function 'dlfb_compress_hline':
drivers/video/udlfb.c:421: error: implicit declaration of function 'prefetch_range'
build warning:
drivers/video/udlfb.c:1590: warning: ignoring return value of ‘device_create_file’, declared with attribute warn_unused_result
drivers/video/udlfb.c:1592: warning: ignoring return value of ‘device_create_bin_file’, declared with attribute warn_unused_result
So add two checks to get rid of 'em.
Signed-off-by: Liu Yuan <tailai.ly@taobao.com>
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (510 commits)
staging: speakup: fix failure handling
staging: usbip: remove double giveback of URB
Staging: batman-adv: Remove batman-adv from staging
Staging: hv: Use only one txf buffer per channel and kmalloc/GFP_KERNEL on initialize
staging: hv: remove unneeded osd_schedule_callback
staging: hv: convert channel_mgmt.c to not call osd_schedule_callback
staging: hv: convert vmbus_on_msg_dpc to not call osd_schedule_callback
staging: brcm80211: Fix WL_<type> logging macros
Staging: IIO: DDS: AD9833 / AD9834 driver
Staging: IIO: dds.h convenience macros
Staging: IIO: Direct digital synthesis abi documentation
staging: brcm80211: Convert ETHER_TYPE_802_1X to ETH_P_PAE
staging: brcm80211: Remove unused ETHER_TYPE_<foo> #defines
staging: brcm80211: Remove ETHER_HDR_LEN, use ETH_HLEN
staging: brcm80211: Convert ETHER_ADDR_LEN to ETH_ALEN
staging: brcm80211: Convert ETHER_IS<FOO> to is_<foo>_ether_addr
staging: brcm80211: Remove unused ether_<foo> #defines and struct
staging: brcm80211: Convert ETHER_IS_MULTI to is_multicast_ether_addr
staging: brcm80211: Remove unused #defines ETHER_<foo>_LOCALADDR
Staging: comedi: Fix checkpatch.pl issues in file s526.c
Fix up trivial conflict in drivers/video/udlfb.c
This kills off all of the dl_xxx() printk wrappers and simply stubs in a
pr_fmt() definition to accomplish the same thing.
The edid length is fixed, so use the standard definition consistently.
udlfb selects all of the options it presently ifdef conditionalizes, so
none of the statements have any effect outside of aggravating eye strain.
udlfb has undergone a fair bit of cleanup recently and is effectively at
the point where it can be liberated from staging purgatory and promoted
to a real driver.
The outstanding cleanups are all minor, with some of them dependent on
drivers/video headers, so these will be done incrementally from udlfb's
new home.
Requested-by: Bernie Thompson <bernie@plugable.com>
