path: root/drivers/video/vfb.c
2010-05-25fbdev: section cleanup in vfbHenrik Kretzschmar
Fix up the section in the vfb driver, by moving the variables vfb_default and vfb_fix from .init.data to .devinit.data This fixes the following warnings issued by modpost: WARNING: drivers/video/vfb.o(.devinit.text+0xf8): Section mismatch in reference from the function vfb_probe() to the variable .init.data:vfb_default The function __devinit vfb_probe() references a variable __initdata vfb_default. If vfb_default is only used by vfb_probe then annotate vfb_default with a matching annotation. WARNING: drivers/video/vfb.o(.devinit.text+0x114): Section mismatch in reference from the function vfb_probe() to the variable .init.data:vfb_fix The function __devinit vfb_probe() references a variable __initdata vfb_fix. If vfb_fix is only used by vfb_probe then annotate vfb_fix with a matching annotation. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: <stable@kernel.org> [if "platform-drivers: move probe to .devinit.text in drivers/video" was merged] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07platform-drivers: move probe to .devinit.text in drivers/videoUwe Kleine-König
A pointer to a probe callback is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Adrian Bunk <bunk@stusta.de> Cc: Alberto Mardegan <mardy@users.sourceforge.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andriy Skulysh <askulysh@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Frans Pop <elendil@planet.nl> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Helge Deller <deller@gmx.de> Cc: Huang Ying <ying.huang@intel.com> Cc: Ian Molton <spyro@f2s.com> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Kaj-Michael Lang <milang@tal.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Magnus Damm <damm@igel.co.jp> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Roland Stigge <stigge@antcom.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Vincent Sanders <vince@simtec.co.uk> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Peter Jones <pjones@redhat.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-13fbdev: fix color component field length documentationMichal Januszewski
The documentation about the meaning of the color component bitfield lengths in pseudocolor modes is inconsistent. Fix it, so that it indicates the correct interpretation everywhere, i.e. that 1 << length is the number of palette entries. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <syrjala@sci.fi> Acked-by: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vfb: fix memory leaks in removal pathAndres Salomon
We were leaking the cmap memory. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24vfb: only enable if explicitly requested when compiled inFrans Pop
The Kconfig help for the vfb driver says: Do NOT enable it for normal systems! To protect the innocent, it has to be enabled explicitly at boot time using the kernel option `video=vfb:'. This change lets the code match the description. Support for vfb:disable is kept for backwards compatibility; vfb:off works because it is tested at a higher level. Note: any undefined option (e.g. vfb:enable) will also enable this driver. The relevant code has been unchanged since before the migration to git (2.6.12). This patch fixes bugzilla #9310 and was the root cause behind http://lkml.org/lkml/2008/5/31/220. Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Antonino A. Daplas <adaplas@gmail.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16vfb: make virtual framebuffer mmapableIlya Yanok
Changed things: 1. vmalloc()/vfree() replaced with rvmalloc()/rvfree() (taken from drivers/media/video/se401.c) 2. mmap method implemented (mostly taken from drivers/media/video/se401.c) 3. smem_start and smem_len fields of struct fb_fix_screeninfo initialized. (smem_start initialized with virtual address, don't know if it is really bad...) [adaplas: sparse warning fix] Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vfb: use fb_sys_read() and fb_sys_write()Antonino A. Daplas
Since vfb's framebuffer is vmalloc'ed, use the fb_sys_read() and fb_sys_write(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vfb: use sys instead of cfb drawing functionsAntonino A. Daplas
Since vfb's framebuffer is vmalloc'ed, use the sys_* drawing functions instead of cfb_*. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] vfb: Update platform codeAntonino A. Daplas
Update platform code to dynamically allocate the platform device Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] Mark empty release functions as brokenGreg Kroah-Hartman
Come on people, this is just wrong... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
