path: root/drivers/video/xilinxfb.c
2011-02-28dt/video: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/video. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21fbdev/xilinxfb: Microblaze driver supportMichal Simek
DCR bus is natively used for PowerPC. Microblaze has no infrastructure for compile DCR that's why is necessary to exclude it. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca> CC: Andrei Konovalov <akonovalov@ru.mvista.com> CC: "David S. Miller" <davem@davemloft.net> CC: linux-kernel@vger.kernel.org
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-01of/xilinxfb: update tft compatible versionsAdrian Alonso
* Add tft display module compatibility for new hardware modules Signed-off-by: Adrian Alonso <aalonso00@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-17fbdev/xilinxfb: Fix improper casting and tighen up probe pathGrant Likely
The xilinxfb driver is improperly casting a physical address to a u32, and the probe routine isn't as straight forward as it could be. (discovered by gcc spitting out warnings on most recent change to xilinxfb driver). This patch fixes the cast and simplifies the probe path. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: John Linn <john.linn@xilinx.com>
2009-06-06fbdev: Add PLB support and cleanup DCR in xilinxfb driver.John Linn
Added support for the new xps tft controller. The new core has PLB interface support in addition to existing DCR interface. Removed platform device support as both MicroBlaze and PowerPC use device tree. Previously, the dcr interface was assumed to be used in mmio mode, and the register space of the dcr interface was precomputed and stuffed into the device tree. This driver now makes use of the new dcr infrastructure to represent the dcr interface. This enables the dcr interface to be connected directly to a native dcr interface in a clean way. Added compatibility for ml507 dvi core. Signed-off-by: Suneel <suneelg@xilinx.com> Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
2008-11-14powerpc/virtex: fix various format/casting printk mismatchesGrant Likely
Various printk format string in code used by the Xilinx Virtex platform are not 32-bit/64-bit safe. Add correct casting to fix the bugs. Reported-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06[POWERPC] Xilinx: Update compatible to use values generated by BSP generator.Stephen Neuendorffer
Mainly, this involves two changes: 1) xilinx->xlnx (recognized standard is to use the stock ticker) 2) In order to have the device tree focus on describing what the hardware is as exactly as possible, the compatible strings contain the full IP name and IP version. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-02-06[POWERPC] Fix incorrectly tagged __devinitdata structuresGrant Likely
Fix compile errors in the xilinxfb, xsysace and uartlite drivers used by the Xilinx Virtex platform Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2007-10-14XilinxFB: typo bugfixGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[POWERPC] XilinxFB: Allow fixed framebuffer base addressGrant Likely
Allow a fixed framebuffer address to be assigned to the framebuffer device instead of allocating the framebuffer from the consistent memory pool. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-12[POWERPC] XilinxFB: Add support for custom screen resolutionGrant Likely
Some custom implementations of the xilinx fb can use resolutions other than 640x480. This patch allows the resolution to be specified in the device tree or the xilinx_platform_data structure. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-12[POWERPC] XilinxFB: Use pdata to pass around framebuffer parametersGrant Likely
The call to xilinxfb_assign is getting unwieldy when adding features to the Xilinx framebuffer driver. Change xilinxfb_assign() to accept a pointer to a xilinxfb_platform_data structure to prepare for adding additition configuration options. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-10[POWERPC] XilinxFB: sparse fixesGrant Likely
2007-10-09[POWERPC] XilinxFB: Make missing pdata structure non-fatalGrant Likely
Missing pdata structure is not a fatal error. The device can still be initialized without it. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-09[POWERPC] XilinxFB: add of_platform bus bindingGrant Likely
Adds the of_platform bus binding to the xilinxfb driver. Needed to use framebuffer devices described in the OF device tree (used by arch/powerpc). Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-09[POWERPC] XilinxFB: cleanup platform_bus binding to use platform bus API.Grant Likely
Change the platform bus binding to make use of the established platform_bus API. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-09[POWERPC] XilinxFB: Split device setup from bus bindingGrant Likely
Split the device setup code away from the platform bus binding. This is in preparation for adding the of_platform bus binding to this driver and most of the setup code is common between the two busses. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-09[POWERPC] XilinxFB: rename failout labels to reflect failureGrant Likely
Labels and gotos are used in xilinxfb_assign to unwind allocations on device registration failures. Rename the labels to reflect the error which occured. This change is being made to make it easier to add new failout paths (which occurs in a subsuquent patch) and to make reviewing the failout path easier. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-09[POWERPC] XilinxFB: Replace calls to printk with dev_dbg, dev_err, etc.Grant Likely
The dev_dbg, dev_err, etc functions provide more context that plain vanilla printk which is useful for debugging. Where appropriate, change printk calls to the appropriate dev_*() call. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-09[POWERPC] XilinxFB: add banner output to probe routine when DEBUG is definedGrant Likely
Debug support: when DEBUG is defined, output relevant details to the log about the framebuffer registration. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andrei Konovalov <akonovalov@ru.mvista.com>
2007-10-03[POWERPC] XilinxFB: Move xilinxfb_platform_data definition to a shared ↵Grant Likely
header file XilnixFB can be used by more than just arch/ppc. Move the data structure definition into include/linux/xilinxfb.h so it can be used by microblaze and arch/powerpc Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-07-31xilinxfb: Don't bail if the xilinxfb platform device doesn't have any pdataGrant Likely
Lack of pdata is not a fatal omission. The driver can still be used even if we do not know the screen dimensions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Andrei Konovalov <akonovalov@ru.mvista.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31xilinxfb:Remove __initdata from xilinx_fb_fix and xilinx_fb_varGrant Likely
xilinxfb_drv_probe refers to both tables, but it cannot be initdata. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Andrei Konovalov <akonovalov@ru.mvista.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08xilinxfb: xilinx framebuffer device driverAndrei Konovalov
Add support for the video controller IP block included into Xilinx ML300 and ML403 reference designs. Signed-off-by: Andrei Konovalov <akonovalov@ru.mvista.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
