If one used display timings in devicetree the display_flags like
pixelclk-active have not been applied.
This commit fixes that and puts some nice debug messages so one can
see from where those timings are applied.
This fixes commit f397f60efbb24c2906cd95f443607b2642b49b24
"video: fbdev: mxsfb: allow setting display timings via kernel
command line"
(cherry picked from commit 17652e758b1236c49d2e1d336d81a832452b7c53)
This commit should not be in 4.14 and was accidentally introduced from
4.1 to 4.9 merge.
It originally was deleted with commit:
"f397f60e video: fbdev: mxsfb: allow setting display timings via
kernel command line"
This reverts commit 721dee144c883aebd6e997a53eed3ab3c24cef79.
This patch enables the backlight in any case. Mainline assumes now
that backlight is turned on from an appropriate driver to get
flickerless backlight experience.
Theres no such thing in downstream, so get rid of the code part that
blocks backlight from turning on.
Honor the native-mode property by adding only that mode to the
mode list. With that we loose the list of modes, but we currently
don't make use of it anyway. Also, the mode list lacks the pixel
clock polarity information since struct fb_videomode does not store
this information.
(cherry picked from commit 3cb3771edb98e2ae79a887368fc042b89456da7e)
Use the timing count from the parsed struct display_timings instead
of looping through the device tree again.
(cherry picked from commit 65be28e2a2b3761d088b20c43994be97d74c342f)
The PIXDATA flags of the display_flags enum are controller centric,
e.g. NEGEDGE means the controller shall drive the data signals on
pixelclocks negative edge. However, the drivers flag is display
centric: Sample the data on negative (falling) edge.
Therefore, change the if statement to check for the POSEDGE flag
(which is typically not set):
Drive on positive edge => sample on negative edge
(cherry picked from commit 5652dc1ad78303fb246f050ba23c563319d823cf)
Add support to allow configuring the display timings via
kernel command line.
e.g.:
video=mxsfb:800x480M-16@60,pixclockpol=1,outputen=1
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit 22db6beb45cba5a67cab9e9a55cd60d7471591d9)
drivers/video/fbdev/mxsfb.c
Using the mode_str passed via device tree
as default fall back, fb_find_mode fails
while finding the mode, so avoid using the
non standard mode_str passed via device tree
and use the mode_str from command line as is.
(cherry picked from commit 50e26af30f04d24f4783dae15206c5dba889fd2b)
Use force suspend/resume to trigger runtime PM when entering system
suspend.
(cherry picked from commit ebf45652f2e9ec2ab19831d852363deadeb6407e)
Add support for LVDS frame buffer configuration via kernel boot arguments.
Fix use of the device tree native-mode property.
(cherry picked from commit 122acb64708ac40faa8c5755624a0bcfbebcb9e8)
(cherry picked from commit 735d4f8addae71ef4a70eb16a9639bd6204fd2b9)
Without this the kernel hangs during boot when HDMI is attached.
It looks like we get an overflow IRQ storm. overflow is related
to HDMI audio.
(cherry picked from commit ab9e816efb07dcaec23d3c55d3db1773b745ae47)
(cherry picked from commit d2e0de0ea4c48d0cbbadc28ac4785bd0ed202ea4)
copy/paste error in pixelclock frequency
(cherry picked from commit 291333761167e85e53fb21cbb4a6b97d618a41c8)
(cherry picked from commit 1fe0cf435e9a938d61a3750140026292183c097c)
The keepalive module variable allows to not go into a disconnected
state. Fix the case when keepalive is set to go to disconnect.
Add a precompiler directive which allows to only evaluate the HPD signal
for HDMI monitor detection. Default is to react on the status bits for
HPD and the TMDS signal line detection to detect an attached monitor.
While at it cleanup parameter documentation and whitespace.
(cherry picked from commit b15fed911e022b383295cb5443872d427e756677)
(cherry picked from commit 6bf9ef90b27fea00ae27f719473a5b7fca30a72e)
(cherry picked from commit 2d67c557073a6e728cfe5888323b9aed79392b90)
Copy of mxc_lcdif.c
Adds a second parallel output which drives a Video DAC
available on the second IPU, first DI on a Apalis iMX6 module
Only RGB565 is supported.
video=mxcfb0:dev=vdac,800x480M@60,if=RGB565
(cherry picked from commit 5a330af3bf30a72ca8f086c90e9dbfcbde3aa252)
(cherry picked from commit 0bcaad8a16e6ceca9d964946890aff6727d7e10f)
FusionF10A: 1024x600, used with external parallel to LVDS converter
FusionF07A: 800x480
EDT-VGA: 640x480
EDT-480x272: 480x272
(cherry picked from commit b235eb4d8b06a6334f39de15526d1a4266bec859)
(cherry picked from commit 4e6509cc7b11a7187e419e64621c3add01e23b27)
pixeldata is sampled on the positve pixelclk edge.
(cherry picked from commit 4891f02dae2559af072c31903111bf9ec349320e)
(cherry picked from commit 85aff6446f712f72b33c29f3fd1e80843f923673)
Signed-off-by: Daniel Kochmanski <dkochmanski@antmicro.com>
(cherry picked from commit 98b68aee3695ae898ef19aa547267fcdb69cf7eb)
(cherry picked from commit f6620779981e6aebe40e7a400568e454d6a7408f)
(cherry picked from commit 95e8be3a2e2fb156279897241c80a96cd84b1fda)
When this boolean parameter is true, only add
CEA modes to modelist.
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
(cherry picked from commit a78fe11904ebd4d3f72438f8b14dfa4eaab7d638)
(cherry picked from commit d69533a9575de0aaeeaca19b4f5ed8ef794257a6)
[rebased to 4.9, use bool as data type]
If enabled too early, a flood of interrupts can happen, and as
console_lock is held, you cannot see any messages being printed.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
(cherry picked from commit 38c65caf872e5f9534b7812395224670dd56c297)
(cherry picked from commit 04abce77f44b3e61b0fe5db1b33109e68e6600bc)
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
(cherry picked from commit db1100f05d89ef2d90c856dfe742e9748d25df10)
(cherry picked from commit de5231fc1c395c1b63f5aa81b818fc5fd5377568)
(cherry picked from commit 6877ada3d15adf762cae8b7edce979a77ebc0313)
(cherry picked from commit 51394b5f2b7ecfcc87c43c41e630c3e49fce3003)
(cherry picked from commit 4d751666e1211ea8a378b8a4af2ad0f6820b650e)
(cherry picked from commit 89a914b029644dc8872410c1f26daec909f76fef)
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
(cherry picked from commit f57ace3fcce595dfbd5c4eb70d0392c8a8f6282d)
(cherry picked from commit e2d1fdbfb1c4c276925def59a3987474c26210ae)
The overlay fb can only be enabled when the LCDIF is not in
running, otherwise overlay display may look like image shift.
So during the system resume procedure, the overlay fb should
be resumed before mxsfb unblank.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
(cherry picked from commit f39662a3a38a2da082d55a006e634766cc85e347)
[ Upstream commit cec2b18832e26bc866bef2be22eff4e25bbc4034 ]
gpiod_get_value() gives out a warning if access to the underlying gpiochip
requires sleeping, which is common for I2C based chips:
WARNING: CPU: 0 PID: 77 at drivers/gpio/gpiolib.c:2500 gpiod_get_value+0xd0/0x100
Modules linked in:
CPU: 0 PID: 77 Comm: kworker/0:2 Not tainted 4.14.0-rc3-00589-gf32897915d48-dirty #90
Hardware name: Allwinner sun4i/sun5i Families
Workqueue: events deferred_probe_work_func
[<c010ec50>] (unwind_backtrace) from [<c010b784>] (show_stack+0x10/0x14)
[<c010b784>] (show_stack) from [<c0797224>] (dump_stack+0x88/0x9c)
[<c0797224>] (dump_stack) from [<c0125b08>] (__warn+0xe8/0x100)
[<c0125b08>] (__warn) from [<c0125bd0>] (warn_slowpath_null+0x20/0x28)
[<c0125bd0>] (warn_slowpath_null) from [<c037069c>] (gpiod_get_value+0xd0/0x100)
[<c037069c>] (gpiod_get_value) from [<c03778d0>] (pwm_backlight_probe+0x238/0x508)
[<c03778d0>] (pwm_backlight_probe) from [<c0411a2c>] (platform_drv_probe+0x50/0xac)
[<c0411a2c>] (platform_drv_probe) from [<c0410224>] (driver_probe_device+0x238/0x2e8)
[<c0410224>] (driver_probe_device) from [<c040e820>] (bus_for_each_drv+0x44/0x94)
[<c040e820>] (bus_for_each_drv) from [<c040ff0c>] (__device_attach+0xb0/0x114)
[<c040ff0c>] (__device_attach) from [<c040f4f8>] (bus_probe_device+0x84/0x8c)
[<c040f4f8>] (bus_probe_device) from [<c040f944>] (deferred_probe_work_func+0x50/0x14c)
[<c040f944>] (deferred_probe_work_func) from [<c013be84>] (process_one_work+0x1ec/0x414)
[<c013be84>] (process_one_work) from [<c013ce5c>] (worker_thread+0x2b0/0x5a0)
[<c013ce5c>] (worker_thread) from [<c0141908>] (kthread+0x14c/0x154)
[<c0141908>] (kthread) from [<c0107ab0>] (ret_from_fork+0x14/0x24)
This was missed in commit 0c9501f823a4 ("backlight: pwm_bl: Handle gpio
that can sleep"). The code was then moved to a separate function in
commit 7613c922315e ("backlight: pwm_bl: Move the checks for initial power
state to a separate function").
The only usage of gpiod_get_value() is during the probe stage, which is
safe to sleep in. Switch to gpiod_get_value_cansleep().
Fixes: 0c9501f823a4 ("backlight: pwm_bl: Handle gpio that can sleep")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit a5399db139cb3ad9b8502d8b1bd02da9ce0b9df0 ]
There is no clipping on the x or y axis for logos larger that the framebuffer
size. Therefore: a logo bigger than screen size leads to invalid memory access:
[ 1.254664] Backtrace:
[ 1.254728] [<c02714e0>] (cfb_imageblit) from [<c026184c>] (fb_show_logo+0x620/0x684)
[ 1.254763] r10:00000003 r9:00027fd8 r8:c6a40000 r7:c6a36e50 r6:00000000 r5:c06b81e4
[ 1.254774] r4:c6a3e800
[ 1.254810] [<c026122c>] (fb_show_logo) from [<c026c1e4>] (fbcon_switch+0x3fc/0x46c)
[ 1.254842] r10:c6a3e824 r9:c6a3e800 r8:00000000 r7:c6a0c000 r6:c070b014 r5:c6a3e800
[ 1.254852] r4:c6808c00
[ 1.254889] [<c026bde8>] (fbcon_switch) from [<c029c8f8>] (redraw_screen+0xf0/0x1e8)
[ 1.254918] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:c070d5a0 r5:00000080
[ 1.254928] r4:c6808c00
[ 1.254961] [<c029c808>] (redraw_screen) from [<c029d264>] (do_bind_con_driver+0x194/0x2e4)
[ 1.254991] r9:00000000 r8:00000000 r7:00000014 r6:c070d5a0 r5:c070d5a0 r4:c070d5a0
So prevent displaying a logo bigger than screen size and avoid invalid
memory access.
Signed-off-by: Manfred Schlaegl <manfred.schlaegl@ginzinger.com>
Signed-off-by: Martin Kepplinger <martin.kepplinger@ginzinger.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit ace6033ec5c356615eaa3582fb1946e9eaff6662 ]
User space Android code identifies pixclock == 0 as a sign for emulation
and will set the frame rate to 60 fps when reading this value, which is
the desired outcome.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Peter Maydell <peter.maydell@linaro.org>
Signed-off-by: Roman Kiryanov <rkir@google.com>
commit 5fb5caee92ba35a4a3baa61d45a78eb057e2c031 upstream.
Before this patch the enable signal was set before the PWM signal and
vice-versa on power off. This sequence is wrong, at least, it is on
the different panels datasheets that I checked, so I inverted the sequence
to follow the specs.
For reference the following panels have the mentioned sequence:
- N133HSE-EA1 (Innolux)
- N116BGE (Innolux)
- N156BGE-L21 (Innolux)
- B101EAN0 (Auo)
- B101AW03 (Auo)
- LTN101NT05 (Samsung)
- CLAA101WA01A (Chunghwa)
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Jingoo Han <jingoohan1@gmail.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Fixed CID 17375, Unsigned compared against 0. Removed code with no effect.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from commit b86debc52acd4131515f62130f52c2d0f48cdbfe)
mipid_hx8369_get_lcd_videomode and mipid_hx8369_lcd_setup are now exported
for the module build.
The hdmi_drm_infoframe_pack() was wrongly packing the HDR metadata. It
was setting the x display primaries followed by the y display primaries.
Instead, in the specifications, each x display primary should be
followed by the corresponding y display primary.
Also, byte 8 of the frame payload was being skipped. Fixed that too.
Signed-off-by: Laurentiu Palcu <laurentiu.palcu@nxp.com>
Reported-by: Jared Hu <jared.hu@nxp.com>
[ Upstream commit 2122b40580dd9d0620398739c773d07a7b7939d0 ]
When unregistering fbdev using unregister_framebuffer(), any bound
console will unbind automatically. This is working fine if this is the
only framebuffer, resulting in a switch to the dummy console. However if
there is a fb0 and I unregister fb1 having a bound console, I eventually
get a crash. The fastest way for me to trigger the crash is to do a
reboot, resulting in this splat:
[ 76.478825] WARNING: CPU: 0 PID: 527 at linux/kernel/workqueue.c:1442 __queue_work+0x2d4/0x41c
[ 76.478849] Modules linked in: raspberrypi_hwmon gpio_backlight backlight bcm2835_rng rng_core [last unloaded: tinydrm]
[ 76.478916] CPU: 0 PID: 527 Comm: systemd-udevd Not tainted 4.20.0-rc4+ #4
[ 76.478933] Hardware name: BCM2835
[ 76.478949] Backtrace:
[ 76.478995] [<c010d388>] (dump_backtrace) from [<c010d670>] (show_stack+0x20/0x24)
[ 76.479022] r6:00000000 r5:c0bc73be r4:00000000 r3:6fb5bf81
[ 76.479060] [<c010d650>] (show_stack) from [<c08e82f4>] (dump_stack+0x20/0x28)
[ 76.479102] [<c08e82d4>] (dump_stack) from [<c0120070>] (__warn+0xec/0x12c)
[ 76.479134] [<c011ff84>] (__warn) from [<c01201e4>] (warn_slowpath_null+0x4c/0x58)
[ 76.479165] r9:c0eb6944 r8:00000001 r7:c0e927f8 r6:c0bc73be r5:000005a2 r4:c0139e84
[ 76.479197] [<c0120198>] (warn_slowpath_null) from [<c0139e84>] (__queue_work+0x2d4/0x41c)
[ 76.479222] r6:d7666a00 r5:c0e918ee r4:dbc4e700
[ 76.479251] [<c0139bb0>] (__queue_work) from [<c013a02c>] (queue_work_on+0x60/0x88)
[ 76.479281] r10:c0496bf8 r9:00000100 r8:c0e92ae0 r7:00000001 r6:d9403700 r5:d7666a00
[ 76.479298] r4:20000113
[ 76.479348] [<c0139fcc>] (queue_work_on) from [<c0496c28>] (cursor_timer_handler+0x30/0x54)
[ 76.479374] r7:d8a8fabc r6:c0e08088 r5:d8afdc5c r4:d8a8fabc
[ 76.479413] [<c0496bf8>] (cursor_timer_handler) from [<c0178744>] (call_timer_fn+0x100/0x230)
[ 76.479435] r4:c0e9192f r3:d758a340
[ 76.479465] [<c0178644>] (call_timer_fn) from [<c0178980>] (expire_timers+0x10c/0x12c)
[ 76.479495] r10:40000000 r9:c0e9192f r8:c0e92ae0 r7:d8afdccc r6:c0e19280 r5:c0496bf8
[ 76.479513] r4:d8a8fabc
[ 76.479541] [<c0178874>] (expire_timers) from [<c0179630>] (run_timer_softirq+0xa8/0x184)
[ 76.479570] r9:00000001 r8:c0e19280 r7:00000000 r6:c0e08088 r5:c0e1a3e0 r4:c0e19280
[ 76.479603] [<c0179588>] (run_timer_softirq) from [<c0102404>] (__do_softirq+0x1ac/0x3fc)
[ 76.479632] r10:c0e91680 r9:d8afc020 r8:0000000a r7:00000100 r6:00000001 r5:00000002
[ 76.479650] r4:c0eb65ec
[ 76.479686] [<c0102258>] (__do_softirq) from [<c0124d10>] (irq_exit+0xe8/0x168)
[ 76.479716] r10:d8d1a9b0 r9:d8afc000 r8:00000001 r7:d949c000 r6:00000000 r5:c0e8b3f0
[ 76.479734] r4:00000000
[ 76.479764] [<c0124c28>] (irq_exit) from [<c016b72c>] (__handle_domain_irq+0x94/0xb0)
[ 76.479793] [<c016b698>] (__handle_domain_irq) from [<c01021dc>] (bcm2835_handle_irq+0x3c/0x48)
[ 76.479823] r8:d8afdebc r7:d8afddfc r6:ffffffff r5:c0e089f8 r4:d8afddc8 r3:d8afddc8
[ 76.479851] [<c01021a0>] (bcm2835_handle_irq) from [<c01019f0>] (__irq_svc+0x70/0x98)
The problem is in the console rebinding in fbcon_fb_unbind(). It uses the
virtual console index as the new framebuffer index to bind the console(s)
to. The correct way is to use the con2fb_map lookup table to find the
framebuffer index.
Fixes: cfafca8067c6 ("fbdev: fbcon: console unregistration from unregister_framebuffer")
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
[ Upstream commit f75df8d4b4fabfad7e3cba2debfad12741c6fde7 ]
Blitting an image with "negative" offsets is not working since there
is no clipping. It hopefully just crashes. For the bootup logo, there
is protection so that blitting does not happen as the image is drawn
further and further to the right (ROTATE_UR) or further and further
down (ROTATE_CW). There is however no protection when drawing in the
opposite directions (ROTATE_UD and ROTATE_CCW).
Add back this protection.
The regression is 20-odd years old but the mindless warning-killing
mentality displayed in commit 34bdb666f4b2 ("fbdev: fbmem: remove
positive test on unsigned values") is also to blame, methinks.
Fixes: 448d479747b8 ("fbdev: fb_do_show_logo() updates")
Signed-off-by: Peter Rosin <peda@axentia.se>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Fabian Frederick <ffrederick@users.sourceforge.net>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
cc: Geoff Levand <geoff@infradead.org>
Cc: James Simmons <jsimmons@users.sf.net>
[ Upstream commit fdac751355cd76e049f628afe6acb8ff4b1399f7 ]
clps711x_fb_probe() increments refcnt of disp device node by
of_parse_phandle() and leaves it undecremented on both
successful and error paths.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Alexander Shiyan <shc_work@mail.ru>
The problem is that the kthread from submit workqueue aquires the queue_mutex
and blocks the kthread from interrupt workqueue. But the kthread from interrupt
workqueue is the one that should update the used_luts variable (on which the
kthread from submit workqueue keeps polling), but it doesn't have a chance to
do it (because it is blocked by mutex), even if the LUT complete interrupts are
triggered. So the fix is, after the polling to release the mutex so that the
kthread from interrupt workqueue can process the LUT complete interrupts and
update the used_luts variable accordingly.
Signed-off-by: Bogdan Chircu <bogdan-petru.chircu-mare@nxp.com>
Signed-off-by: Robby Cai <robby.cai@nxp.com>
After suspend, the qos setting is lost. This patch restores it after resume.
Fix structurally dead code reported by coverity. Assign the return value
to ret, instead of returning it so there will be a proper clean up.
Signed-off-by: Robert Chiras <robert.chiras@nxp.com>
Fixing two coverity issues:
1. Checking disp_videomode against 0, which will always be true, since
disp_videomode is a char array. So, fix it by checking it's first byte
instead.
2. Possible division by zero, if clk_get_rate returns 0 (which is
possible).
The Driver IC 'RM68191' is used in the MIPI panel
'RK055IQH042' whose default mode is '540x960@60Hz'.
So this commit adds a new FBDEV driver for 'RM68191'
and enables the 'RK055IQH042' panel on IMX7ULP1-EVKB
platform with Northwest MIPI DSI controller.
The Driver IC 'RM68200' is used in the MIPI panel
'RK055AHD042' whose default mode is '720x1280@60Hz'.
So this commit adds a new FBDEV driver for 'RM68200'
and enables the 'RK055AHD042' panel on IMX7ULP1-EVKB
This fixes Coverity issue where an unsigned variable is tested for
less-than-zero value.
Make val a signed integer instead.
CC: Sandor Yu <sandor.yu@nxp.com>
This fixes less-then-zero comparison Coverity issue. roi_param->roi_n is
unsigned, hence the comparison is not needed.
This fixes Coverity issue since the function does nothing. The function
only returns some values which are never used.
CC: Fancy Fang <chen.fang@nxp.com>
This fixes Coverity issue since num_pix_x and num_pix_y are unsigned and
the conditions are never true.
Some HDMI Sink may failed to work when running HDCP enable/disable
stress test. HDMI sink may not support change HDCP state on the fly.
So reset HDMI PHY and controller to resolve the issue.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
This driver registers itself as a fb_client and handles notifications
from all FB in the system.
It can end up trying to call fb_draw_logo on an overlay FB and this will
crash because overlay_fb_ops has no fb_imageblit function.
It also handles blank/unblank indiscriminately and for example if you
connect a second LVDS display on 6sx and blank/unblank it then HDMI will
also incorrectly blank/unblank. This last issue even affects imx_4.9.y
Fix by only processing notifications from the FB that it's bound to.
Bind to the first FB whose name starts with "mxs-lcdif" by checking
fb_info->fix.id on FB_EVENT_FB_REGISTERED.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Acked-by: Robert Chiras <robert.chiras@nxp.com>
For overlay framebuffer, when its grayscale is '0' and the format
bpp is 32, enable the global alpha blending by default which can
make the overlay fb can display the framebuffer content as long as
it is unblanked.
imx8 hdmi fb driver is not maintain.
imx8 hdmi function have implemented with DRM framework
in driver/gpu/drm/imx folder.
So remove hdmi fb driver.
