After making pclk output ahead of LVDS_SHDN# , data output is later than
panel ready then caused partial black screen. Force triggered data output to
get it fixed.
Bug 972377
Bug 976081
Bug 1001434
Change-Id: Icd455d7439f622e46295158a5435286c521526aa
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/113164
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
This is similar to commit a62be5b5595ad86411ced81bceeb3d6a693426d2
pushed for rel-14 branch.
Bug 1004341
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/111227
(cherry-picked from fbfce3106da8dad18948103c812bdd9d45ffdd06)
Change-Id: Ib459094fd6499b3cc63bc534bf36e57dc98ce62b
Reviewed-on: http://git-master/r/114584
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Allows overidding the default disp mode without having to recompile
the kernel. Boot args can be specified in the following format:
disp_params=<rgb|hdmi|dsi>:pclk,h_active,v_active,h_ref_to_sync,
v_ref_to_sync,h_sync_width,v_sync_width,h_back_porch,v_back_porch,
h_front_porch,v_front_porch;<rgb|hdmi|dsi>:pclk,h_active,...
Bug 969088
Change-Id: Id0acf608de145493f6749d5b799d4bbb8162ba72
Signed-off-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-on: http://git-master/r/104604
- Adding flag to treat warning as error.
- Handled warning of unused function.
bug 949219
Change-Id: Ic6edfc28bae95b8395cbd51e80f14aa4aa663f61
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/114624
Introduce IOMMU backend functions which use DMA API familiy
internally. Replace tegra_iovmm_*() API with arm_iommu_*iova*() and
dma_(un)map_page_(at)().
Change-Id: I0b014926ffedc12bf8f868b163982c6082d050b6
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/114216
GVS: Gerrit_Virtual_Submit
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Allow tegra_iovmm_alloc_client() to take struct device * instead of
const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to
support IOVMM and IOMMU simultaneously.
Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb
Reviewed-on: http://git-master/r/114215
This change is for programming VI and EPP through ISP channel
to support RGB input and dual video capturing.
1. Added syncpt in the ISP channel to submit the channel.
2. Added epp clock to use VI2EPP for RGB capture.
Note: To use this channel, EPP should be free from 2D.
Bug 988546
Change-Id: I17fe278c9325aac2ea1e29cbaf50c8a4499d8551
Signed-off-by: Songhee Baek <sbaek@nvidia.com>
Reviewed-on: http://git-master/r/113965
- Handled warning of, possible use of uninitialized variable and unused
function.
bug 949219
Change-Id: I0d7d345e66774f08e52a12e653a5e7aa6a7a8591
Reviewed-on: http://git-master/r/113905
- Handled warning of unused label.
bug 949219
Change-Id: I72e22063b199562c4a4c065419c1656e3e8ff7ff
Reviewed-on: http://git-master/r/113880
Freeze vblank worker while suspending by adding the work into
system freezewq. This eliminates a kernel panic caused by nvsd
reading brightness valuesfrom display while clock gated.
Bug 1006180
Bug 1003969
Bug 1003730
Change-Id: Ice9bfb18e5c826ae063c2b901421b1047ff9d2f0
Signed-off-by: Mark Zhang <markz@nvidia.com>
Reviewed-on: http://git-master/r/112880
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
- Gpio freeing function does disabling job.
- If backlight pin is an sfio, we have to claim the gpio. So that we can use
the gpio api's to configure it as sfio.
bug 984440
bug 858120
Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b
Reviewed-on: http://git-master/r/109564
Reviewed-by: Simone Willett <swillett@nvidia.com>
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/111371
Send specified DC frames to 720p panel during power up/down sequencing.
Bug 997484.
Change-Id: I3927e98322ec93f68cabf635c71485b64750d7f9
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/109917
(cherry picked from commit e1d10bc056031fbc2f68101978d76317c44fc7af)
Reviewed-on: http://git-master/r/111944
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Force serialization of 2D jobs by inserting a host wait for previous
maximum at the beginning of the job.
Bug 1002293
Change-Id: I667ad4565cc32186ea7ccf16845c68d1b1bbdf78
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/111475
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-by: Daniel Parker <dparker@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Francis Hart <fhart@nvidia.com>
- Grouping variables around bitwise operators for safe operation.
bug 949219
Change-Id: I8edf7fb241eb79ac07b63ab856d206fc453308f1
Reviewed-on: http://git-master/r/109577
This patch removes the possibility to disable the second GPU of T30
using a fuse.
Change-Id: I73cd4b7bd52035322e5fc1b040ffeda6d600a90e
Reviewed-on: http://git-master/r/109434
Change-Id: I6584c856356d6be123a66731bde414e4925ffe07
Reviewed-on: http://git-master/r/111184
We support 3 different aggressiveness levels of disabling DSI runtime.
The larger the aggressive level is, the higher DSI power we can save.
Bug 936337
Change-Id: Idadcb49b364e29ddd0a05dde1c6d3dfda6cd493e
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/106361
It seems with building with different tool chains, when compiling
nvhost_acm it doesn't end up with drivers/video/tegra/host in its
include path and therefore it fails to find some header files.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: Ic3d72c863d4b5e501222d21077ba9735315ec65c
Reviewed-on: http://git-master/r/110592
Reviewed-by: Allen Martin <amartin@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Bug 961009
Change-Id: Ifdcc7bc8a40d270e70a63329f46caff541bf01e2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/109461
Part of panel settings need to be done before/after pixel clock
is disabled. Add support for these actions to meet panel
spec.
bug 976081
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/102542
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit dcecdc64d4d0fd4d9f69df52c9d200dfbf1dd7fc)
Change-Id: Ibfede68d67a4815156f73c2d1cdca90f3f771755
Reviewed-on: http://git-master/r/110296
- add public APIs for power & sync-point management
- all these APIs end with string _ext
- all these APIs can be found in linux/nvhost.h
- all these APIs take nvhost_device as first argument
- all these APIs are based on the fact that host1x hardware
driver is parent of all the host1x client driver
- this allows clients of host1x which are outside host1x
driver code to just include nvhost.h & use host1x driver
interfaces
- this also hides the implementation details of power &
sync-point inside host1x driver code
- move sync point ids for dc and nvavp to nvhost.h
Bug 961009
Change-Id: I1a9ca074df87656c4d4bd246853e039a7850d56a
Reviewed-on: http://git-master/r/109219
Bug 1000789
Bug 1003730
Change-Id: I7fbd703dde2044f2790e6a9b356ef8dca89ad8f3
Reviewed-on: http://git-master/r/110146
During programming of a frame or at frame end, force the use of the new EMC
bandwidth instead of the previous frame's bandwidth.
Moved copy of new_bandwidth out of tegra_dc_set_latency_allowance() to match
the semantics of the rest of tegra_dc_program_bandwidth().
bug 949015
Change-Id: I881f3a2c75f3438e3bbb3208b518f15a4574bc91
Reviewed-on: http://git-master/r/110149
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Compile power management suspend and resume functions only when
CONFIG_PM is enabled.
Change-Id: If349984d62ed002594ba60ac25cd4dddd956aa6c
Reviewed-on: http://git-master/r/109425
Change-Id: I2a5f0c9305bd53c42df181556d97efa5d6792ad7
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/106500
Reviewed-by: Bo Yan <byan@nvidia.com>
When a DC window is being released, a NULL flip is used to indicate
that the window should be disabled. To disable a window, 0 is
written to WIN_OPTIONS.
The MC_DECERR on window shutdown is a symptom of forgetting step 2)
below when disabling windows, leaving no indication that there is
anything to wait for. This causes DC to erroneously unpin the
scanout buffer while the buffer is still actively being used.
Summary of flip (window update) synchronization in DC:
1) program some window registers
2) set win->dirty=1
3) schedule the activation of the registers
4) request VBLANK or HBLANK interrupts
5) wait for win->dirty==0
In the trigger_windows ISR (every VBLANK or HBLANK):
1) if there is no window update pending in HW, clear dirty flag to
indicate that ACTIVE registers are up-to-date.
bug 991572
bug 995614
bug 989119
bug 983251
bug 960424
bug 866711
Change-Id: I8b710aac874b202838c3989608b7e0bd15425382
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/109370
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Make all chip specific functions static. Include the chip specific
functions in SoC files after including the hardware headers. This
makes the chip specific functions to be compiled per SoC, and with
the correct hardware definitions.
Bug 982965
Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e
Reviewed-on: http://git-master/r/107581
Give names to the structures inside nvhost_chip_support. This way
they can be referred to individually.
Change-Id: I9b727bfc232d11957a8bd3e3570583d47cff778e
Reviewed-on: http://git-master/r/109103
Reviewed-by: Ken Adams <kadams@nvidia.com>
Remove unused functions in CDMA and debug. They were left unused
when debug dump started using sync queue instead of channel
registers for detecting current position.
Change-Id: Ib1f0bc8f702667d0453079e6d5f5d8ca08f8db09
Reviewed-on: http://git-master/r/109102
Call drain fifo and save context functions via nvhost_chip_support.
Earlier client drivers called into host1x code directly, which
makes each client driver SoC specific.
Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a
Reviewed-on: http://git-master/r/109101
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Reviewed-on: http://git-master/r/108827
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Reviewed-on: http://git-master/r/108501
Move #include directives for nvhost headers from dc_priv.h to the
source files that need the #includes. This allows #including
dc_priv.h without access to all nvhost headers.
Also adds nvhost to the #include path of dc to allow making dev.h a
stub in a later commit.
Bug 982965
Change-Id: Icfe7084d295f57926195b178174f81047eb01187
Reviewed-on: http://git-master/r/108225
Add parameters in host1x nvhost_device on
* number of sync points
* number of wait bases
* number of channels
* number of mlocks
* client managed bitmask
* naming of sync points
Add automatically generated headers and use symbols from them to
access hardware.
Move host1x device definition from generic host1x to SoC specific
source files t20.c and t30.c.
Bug 982965
Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1
Reviewed-on: http://git-master/r/104974
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
The tegra_dc_trigger_windows function was improperly using the
WIN_x_UPDATE bits to determine when a flip has occurred instead of the
WIN_x_ACT_REQ bits. Without this change, it's possible for the postflip
syncpoint for a buffer to get incremented before it actually flips.
Still need to figure out why that's even possible...
Fixes bug 902955
Change-Id: I67ba093a0114646977cc8cb95a040ec4178cebfc
Reviewed-on: http://git-master/r/65389
Reviewed-by: Nate Huang <nhuang@nvidia.com>
Tested-by: Nate Huang <nhuang@nvidia.com>
Reviewed-on: http://git-master/r/98024
Bug 990586
Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547
Reviewed-on: http://git-master/r/107714
Add configuration variable for default timeout for clients. Set it to
30s for silicon and infinity for simulation.
Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862
Reviewed-on: http://git-master/r/105331
Bug 936337
Bug 899053
Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e
Reviewed-on: http://git-master/r/106313
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
Initialize host1x generic irq at bootup.
Bug 971602
Change-Id: I03fb426a0538c1549fdb5360166c4e4b516e75d6
Reviewed-on: http://git-master/r/106167
Clear out all overlays and disable DC on .shutdown
Change-Id: I4bc78fddb0ed8bd621733df191f305ecb279e3f7
Reviewed-on: http://git-master/r/106549
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
removed tegra_dc_hdmi_mode_equal.
It was replaced by tegra_dc_hdmi_cvt_mode_equal
Change-Id: I7988d02a1c0b91eed88fdf573d8c993b6ee7be8d
Reviewed-on: http://git-master/r/106074
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
remove and rename unused variable in tega_dc_get_stride
Change-Id: I0d101de22c08609f9727469ad7e4708de8de59ef
Reviewed-on: http://git-master/r/106072
drivers/media/video/tegra/nvavp/nvavp_dev.c
Change-Id: I7779b0ce58004f80cccf6193148ac49551ce5da5
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Reviewed-on: http://git-master/r/106075
Added void to function prototypes and initialized some variables.
Change-Id: I69250f5e17560f900fffddec9697e496af6ad4d2
Reviewed-on: http://git-master/r/106073
