bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
do_heap_alloc locates a suitable free block from a nvmap heap given a
size and alignment. Unfortunately, if a heap block happens to be
smaller than the alignment passed to the function, an integer overflow
will occur, and a block that's too small gets accidentally returned.
Bug 1032642
Change-Id: Ic650c520409134d753e968f62f144ddeb065ccc7
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/123076
GVS: Gerrit_Virtual_Submit
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Check return code for set_page_array_* calls.
Change-Id: Ie62ac78b82321939d5bd9d2a636d72dadea50d28
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/123544
nvmap_map_into_caller_ptr takes a memory handle from usermode
and adds a memory mapping for the handle. However, the handle
is not checked for being allocated. An unallocated handle
would cause a kernel panic later on from a NULL dereference.
Change-Id: I73987b097a0c843b913660445e8bd1b4755dac61
Reviewed-on: http://git-master/r/119689
Reviewed-by: Simone Willett <swillett@nvidia.com>
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/123103
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
When 3D register is read, and we need to do a context switch, the old
context reference is incremented, but it never gets decremented. Fix
by using nvhost_job_get_hwctx() to acquire the reference.
Bug 1031746
Change-Id: Ic72637cb2399f960e2297733bfe45e585a8ec180
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/123678
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Add support to alloc zeroed pages for user space alloc requests. Also
define a config option to force userspace allocation requests to be
zeroed.
Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/122549
host1x interrupts have been left on at suspend due to using wrong
constant for the interrupt register. Disable host1x interrupts at
suspend.
Change-Id: I915fc4e663e6ad90fccacff6fb223c5080e21fcd
Reviewed-on: http://git-master/r/123055
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Lock was missing around one state set, so we add it here.
Bug 1024031
Change-Id: Iab013fff7e8519e8bcc91e84a5ca7cd6e6e783da
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/122802
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Reviewed-on: http://git-master/r/120884
nvmap_pin_ids accepts a list of handles to pin, which are passed
directly from usermode when called from nvmap_ioctl_pinop.
However, if invalid handles are passed in, the function might
still access them as valid handles, and cause a crash.
Bug 1023954
Change-Id: I6b98a2ef448bb496be7d569ddd4fb516fc399cba
Reviewed-on: http://git-master/r/119667
Invalidate the FDC before submitting the context
save pushbuffer to ensure cache coherency across
both GPU cores.
Bug 1020291
Reviewed-on: http://git-master/r/121945
(cherry picked from commit cef956d07ec717f4714f5101805bbe2f0f149e71)
Change-Id: I43ffee6a77122b4f2fe17f063dc6756c501e59c7
Reviewed-on: http://git-master/r/122323
Tested-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Locking in nvhdcp was set up in such a way that we couldn't
change the state of the HDMI plug while negotiating the HDCP connection.
Another lock was added that is only taken when the state of the plug or
hdcp session are changed. This enables correct failure if the plug is removed
during negotiation.
Bug 1024031
Reviewed-on: http://git-master/r/120546
(cherry picked from commit 51f746421b73f8f378bd7908b35fd6c79687e239)
Change-Id: Id9a9b09f2cd03a1b51e7334391f35fc076a1e1dd
Reviewed-on: http://git-master/r/121399
In case tegra_dc_init fails, this change will prevent unbalanced call
to dc->out_ops->disable().
Also mark tegra_dc_io_end in case tegra_dc_controller_enable
fails, this is required to not stop device from going into suspend mode.
Bug 1003874
Change-Id: I5af6b46fc50e1ae8e54f9f4eb8540d751364fed7
Signed-off-by: Gaurav Batra <gbatra@nvidia.com>
Reviewed-on: http://git-master/r/120108
- replace the usage of strncmp with strcmp in
nvhost_bus_match()
- strncmp was needed when we had device name as
<name.ip-version>. but now the device name is <name>
which matches with the driver name.
- multiple devices get bind with the same driver using
id_table which uses .version field as an index in id_table
Change-Id: If0b6f0ee18626d5e7ff801b8515ef5168069c3f2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/117953
Reviewed-by: Ken Adams <kadams@nvidia.com>
- Add compilation flag to treat warning as error
bug 949219
Change-Id: Ib183b75f73df1a141f1dfdbc330369da838b24b9
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118086
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
change printk to trace_printk
Bug 995270
Change-Id: I71caadb76f6101f377e44ad3f3dc24ede0a099d5
Signed-off-by: Jay Cheng <jacheng@nvidia.com>
nvmap_ioctl_pinop kmalloc's a temporary buffer, whose length is directly
given by ioctl parameter from usermode. The total size of the buffer
is not checked for overflow, which will cause a kernel panic with some
inputs.
Also, a sizeof() is applied to wrong type when calculating the amount
of bytes to copy from userspace.
nvmap_map_into_caller_ptr attempts to validate that the memory range
to be mapped is correct, but integer overflow can cause the check to
fail. This will lead to mapping wrong pages from the allocated
handle later on, when the page fault handler gets called.
Bug 1025502
Change-Id: I71a09c40c209dba9c5b37c3912e92a81e6f87e80
Fixing host transmission with HS enabled.
Bug 999141
Change-Id: I9dcc5282971830865dacf16dbbbebf4096aeb00e
Signed-off-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-on: http://git-master/r/118315
enable using frame rate information in 3d frequency scaling by default
Bug 991589
Change-Id: I410c86e3a56ddf00610133333dd518b4f46aa9ec
Reviewed-on: http://git-master/r/116867
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
adding support for using a throughput hint given by the tegra-gfx misc
device in the 3d scaling code. If throughput hint usage is enabled and
the latest throughput hint is recent enough (less than 1 second old),
the throughput hint is used to control 3d frequency scaling. Otherwise
the existing idle time percentage estimate is used.
Bug 991589
Change-Id: I68893e5ce7ef922b95ce5f5b3664eb8e1fdd4027
Reviewed-on: http://git-master/r/116866
Creates a miscdev at /dev/tegra-throughput which gl will use to set a
target frame rate. In addition it receives notifications from dc on
flip events. On each notification the percentage ratio of the actual
frame time to the target frame time is calculated. In subsequent
changes this ratio will be reported to other modules as a throughput
hint.
Bug 991589
Change-Id: Ieaa2b2755b63d2d071de31e3ef819d4c3b51a956
Reviewed-on: http://git-master/r/116865
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
page list array size greater than PAGE_SIZE should use vmalloc.
Change-Id: Ic03668ba7ff716bfb3cc08aaef5f86214ee0a9df
Reviewed-on: http://git-master/r/116875
Reviewed-by: Alex Waterman <alexw@nvidia.com>
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
(cherry picked from commit ddacaacd2a9fff10187e026eaa0d898694eeb95f)
Reviewed-on: http://git-master/r/118194
NVMAP_CONVERT_CARVEOUT_TO_IOVMM is only available for IOMMU less SoCs.
This was introduced by:
commit b8b0b4c42fc77d94b8deadaa46f795784f3bbb5e
video: tegra: nvmap: Make IOMMU/IOVMM selectable in Kconfig
Bug 1017112
Change-Id: I2a6f101b15085ece600f77690bc77adc042eb29f
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/117976
Tested-by: Meghana Kankarej <mkankarej@nvidia.com>
The one shot thread will clock gate the modules periodically. This will ensure
relevant paths in dc driver have an active dc clock and dsi host.
Bug 1013172
Change-Id: Ibb505e35044f31405c06cb9fa0d6fdf78aafd4a6
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/117137
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
- host1x_save_context() explicitly updated the ref count on context
- with the re-factoring of nvhost_job code, nvhost_job_alloc()
takes a ref count on context
- this caused the explicit ref count in host1x_save_context()
redundant and lead to memory leak. hence remove it
Bug 1015924
Change-Id: Id18c74412e8659b60288700972690d1b895de4c1
Reviewed-on: http://git-master/r/116409
(cherry picked from commit c98d0cfbbdacdda8e540b5d9e0d513e279b3b2f5)
Reviewed-on: http://git-master/r/117326
This was accidently reverted to be set to max with commit 9774bbe31a.
With 2d clock at max, there is a hit on video power numbers.
Change-Id: Iaf73c6f7800d56229d35fb6a2b00f61d460e986d
Reviewed-on: http://git-master/r/117589
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Send host commands to panel during vertical blanking
of a frame. Implementation is generic enough to
handle both long and short packets.
Bug 1009863
Change-Id: I9a80641df2d8b67eb3649d220c028543b246a5f3
Reviewed-on: http://git-master/r/114990
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Ported Peter's original change 86413 to main.
board-p1852-panel.c:
Add support for primary and secondary LVDS displays, and secondary HDMI display.
board-p1852-pinmux.c:
Add configuration for HDMI and LVDS
board-p1852.c:
board-p1852.h:
Support for determining which p1852 sku is in use
hdmi.c:If no edid retrieved, but there's a hardwired mode, enable it
(used to support HDMI->LVDS output on p1852 sku 2)
devices.c:added secondary display data.
Bug 977859
Bug 994011
Change-Id: Ide8fb6bf7dd873b1d50269fb98d7c1687e4d9073
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/100438
This patch allows nvmap to use the standard IOMMU API as its backend
engine instead of the legacy tegra IOVMM by Kconfig.
Enable TEGRA_IOMMU_{GART,SMMU} under IOMMU in config, and it
automatically disables IOVMM, instead.
Change-Id: I71112ef8072591aac4a93075623ca31c8851a960
Reviewed-on: http://git-master/r/114217
Without the CONFIG_SWITCH enabled, there are multiple unused
variable warnings that get treated as error.
bug 949219
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I39512367fa4bbd3b00a435d0d7a31cfede9e712f
Reviewed-on: http://git-master/r/115428
Use the right number of parameters for tegra_dc_calc_fresh() when called from
print_mode(). This code is only used for debug.
Change-Id: I4d0bb8b1700f670644057039fe8d0bc315b27c1d
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/115485
After making pclk output ahead of LVDS_SHDN# , data output is later than
panel ready then caused partial black screen. Force triggered data output to
get it fixed.
Bug 972377
Bug 976081
Bug 1001434
Change-Id: Icd455d7439f622e46295158a5435286c521526aa
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/113164
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
This is similar to commit a62be5b5595ad86411ced81bceeb3d6a693426d2
pushed for rel-14 branch.
Bug 1004341
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/111227
(cherry-picked from fbfce3106da8dad18948103c812bdd9d45ffdd06)
Change-Id: Ib459094fd6499b3cc63bc534bf36e57dc98ce62b
Reviewed-on: http://git-master/r/114584
Allows overidding the default disp mode without having to recompile
the kernel. Boot args can be specified in the following format:
disp_params=<rgb|hdmi|dsi>:pclk,h_active,v_active,h_ref_to_sync,
v_ref_to_sync,h_sync_width,v_sync_width,h_back_porch,v_back_porch,
h_front_porch,v_front_porch;<rgb|hdmi|dsi>:pclk,h_active,...
Bug 969088
Change-Id: Id0acf608de145493f6749d5b799d4bbb8162ba72
Signed-off-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-on: http://git-master/r/104604
- Adding flag to treat warning as error.
- Handled warning of unused function.
bug 949219
Change-Id: Ic6edfc28bae95b8395cbd51e80f14aa4aa663f61
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/114624
Introduce IOMMU backend functions which use DMA API familiy
internally. Replace tegra_iovmm_*() API with arm_iommu_*iova*() and
dma_(un)map_page_(at)().
Change-Id: I0b014926ffedc12bf8f868b163982c6082d050b6
Reviewed-on: http://git-master/r/114216
Allow tegra_iovmm_alloc_client() to take struct device * instead of
const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to
support IOVMM and IOMMU simultaneously.
Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb
Reviewed-on: http://git-master/r/114215
This change is for programming VI and EPP through ISP channel
to support RGB input and dual video capturing.
1. Added syncpt in the ISP channel to submit the channel.
2. Added epp clock to use VI2EPP for RGB capture.
Note: To use this channel, EPP should be free from 2D.
Bug 988546
Change-Id: I17fe278c9325aac2ea1e29cbaf50c8a4499d8551
Signed-off-by: Songhee Baek <sbaek@nvidia.com>
Reviewed-on: http://git-master/r/113965
- Handled warning of, possible use of uninitialized variable and unused
function.
bug 949219
Change-Id: I0d7d345e66774f08e52a12e653a5e7aa6a7a8591
Reviewed-on: http://git-master/r/113905
- Handled warning of unused label.
bug 949219
Change-Id: I72e22063b199562c4a4c065419c1656e3e8ff7ff
Reviewed-on: http://git-master/r/113880
Freeze vblank worker while suspending by adding the work into
system freezewq. This eliminates a kernel panic caused by nvsd
reading brightness valuesfrom display while clock gated.
Bug 1006180
Bug 1003969
Bug 1003730
Change-Id: Ice9bfb18e5c826ae063c2b901421b1047ff9d2f0
Signed-off-by: Mark Zhang <markz@nvidia.com>
Reviewed-on: http://git-master/r/112880
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
- Gpio freeing function does disabling job.
- If backlight pin is an sfio, we have to claim the gpio. So that we can use
the gpio api's to configure it as sfio.
bug 984440
bug 858120
Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b
Reviewed-on: http://git-master/r/109564
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Reviewed-on: http://git-master/r/111371
Send specified DC frames to 720p panel during power up/down sequencing.
Bug 997484.
Change-Id: I3927e98322ec93f68cabf635c71485b64750d7f9
Reviewed-on: http://git-master/r/109917
(cherry picked from commit e1d10bc056031fbc2f68101978d76317c44fc7af)
Reviewed-on: http://git-master/r/111944
Force serialization of 2D jobs by inserting a host wait for previous
maximum at the beginning of the job.
Bug 1002293
Change-Id: I667ad4565cc32186ea7ccf16845c68d1b1bbdf78
Reviewed-on: http://git-master/r/111475
Reviewed-by: Daniel Parker <dparker@nvidia.com>
Reviewed-by: Francis Hart <fhart@nvidia.com>
- Grouping variables around bitwise operators for safe operation.
bug 949219
Change-Id: I8edf7fb241eb79ac07b63ab856d206fc453308f1
Reviewed-on: http://git-master/r/109577
This patch removes the possibility to disable the second GPU of T30
using a fuse.
Change-Id: I73cd4b7bd52035322e5fc1b040ffeda6d600a90e
Reviewed-on: http://git-master/r/109434
Change-Id: I6584c856356d6be123a66731bde414e4925ffe07
Reviewed-on: http://git-master/r/111184
We support 3 different aggressiveness levels of disabling DSI runtime.
The larger the aggressive level is, the higher DSI power we can save.
Bug 936337
Change-Id: Idadcb49b364e29ddd0a05dde1c6d3dfda6cd493e
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/106361
