[ Upstream commit 6a8aae68c87349dbbcd46eac380bc43cdb98a13b ]
If the msix_affinity_masks is alloced failed, then we'll
try to free some resources in vp_free_vectors() that may
access it directly.
We met the following stack in our production:
[ 29.296767] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 29.311151] IP: [<ffffffffc04fe35a>] vp_free_vectors+0x6a/0x150 [virtio_pci]
[ 29.324787] PGD 0
[ 29.333224] Oops: 0000 [#1] SMP
[ 29.425175] RIP: 0010:[<ffffffffc04fe35a>] [<ffffffffc04fe35a>] vp_free_vectors+0x6a/0x150 [virtio_pci]
[ 29.441405] RSP: 0018:ffff9a55c2dcfa10 EFLAGS: 00010206
[ 29.453491] RAX: 0000000000000000 RBX: ffff9a55c322c400 RCX: 0000000000000000
[ 29.467488] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff9a55c322c400
[ 29.481461] RBP: ffff9a55c2dcfa20 R08: 0000000000000000 R09: ffffc1b6806ff020
[ 29.495427] R10: 0000000000000e95 R11: 0000000000aaaaaa R12: 0000000000000000
[ 29.509414] R13: 0000000000010000 R14: ffff9a55bd2d9e98 R15: ffff9a55c322c400
[ 29.523407] FS: 00007fdcba69f8c0(0000) GS:ffff9a55c2840000(0000) knlGS:0000000000000000
[ 29.538472] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 29.551621] CR2: 0000000000000000 CR3: 000000003ce52000 CR4: 00000000003607a0
[ 29.565886] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 29.580055] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 29.594122] Call Trace:
[ 29.603446] [<ffffffffc04fe8a2>] vp_request_msix_vectors+0xe2/0x260 [virtio_pci]
[ 29.618017] [<ffffffffc04fedc5>] vp_try_to_find_vqs+0x95/0x3b0 [virtio_pci]
[ 29.632152] [<ffffffffc04ff117>] vp_find_vqs+0x37/0xb0 [virtio_pci]
[ 29.645582] [<ffffffffc057bf63>] init_vq+0x153/0x260 [virtio_blk]
[ 29.658831] [<ffffffffc057c1e8>] virtblk_probe+0xe8/0x87f [virtio_blk]
Cc: Gonglei <arei.gonglei@huawei.com>
Signed-off-by: Longpeng <longpeng2@huawei.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Gonglei <arei.gonglei@huawei.com>
commit cf94db21905333e610e479688add629397a4b384 upstream.
vring_create_virtqueue() allows the caller to specify via the
may_reduce_num parameter whether the vring code is allowed to
allocate a smaller ring than specified.
However, the split ring allocation code tries to allocate a
smaller ring on allocation failure regardless of what the
caller specified. This may cause trouble for e.g. virtio-pci
in legacy mode, which does not support ring resizing. (The
packed ring code does not resize in any case.)
Let's fix this by bailing out immediately in the split ring code
if the requested size cannot be allocated and may_reduce_num has
not been specified.
While at it, fix a typo in the usage instructions.
Fixes: 2a2d1382fe9d ("virtio: Add improved queue allocation API")
Cc: stable@vger.kernel.org # v4.6+
Signed-off-by: Cornelia Huck <cohuck@redhat.com>
Reviewed-by: Halil Pasic <pasic@linux.ibm.com>
Reviewed-by: Jens Freimann <jfreimann@redhat.com>
Pull virtio updates from Michael Tsirkin:
"virtio, vhost: fixes, tweaks
No new features but a bunch of tweaks such as switching balloon from
oom notifier to shrinker"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
vhost/scsi: increase VHOST_SCSI_PREALLOC_PROT_SGLS to 2048
vhost: allow vhost-scsi driver to be built-in
virtio: pci-legacy: Validate queue pfn
virtio: mmio-v1: Validate queue PFN
virtio_balloon: replace oom notifier with shrinker
virtio-balloon: kzalloc the vb struct
virtio-balloon: remove BUG() in init_vqs
Legacy PCI over virtio uses a 32bit PFN for the queue. If the
queue pfn is too large to fit in 32bits, which we could hit on
arm64 systems with 52bit physical addresses (even with 64K page
size), we simply miss out a proper link to the other side of
the queue.
Add a check to validate the PFN, rather than silently breaking
the devices.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <cdall@kernel.org>
Cc: Peter Maydel <peter.maydell@linaro.org>
Cc: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
virtio-mmio with virtio-v1 uses a 32bit PFN for the queue.
If the queue pfn is too large to fit in 32bits, which
we could hit on arm64 systems with 52bit physical addresses
(even with 64K page size), we simply miss out a proper link
to the other side of the queue.
the devices.
The OOM notifier is getting deprecated to use for the reasons:
- As a callout from the oom context, it is too subtle and easy to
generate bugs and corner cases which are hard to track;
- It is called too late (after the reclaiming has been performed).
Drivers with large amuont of reclaimable memory is expected to
release them at an early stage of memory pressure;
- The notifier callback isn't aware of oom contrains;
Link: https://lkml.org/lkml/2018/7/12/314
This patch replaces the virtio-balloon oom notifier with a shrinker
to release balloon pages on memory pressure. The balloon pages are
given back to mm adaptively by returning the number of pages that the
reclaimer is asking for (i.e. sc->nr_to_scan).
Currently the max possible value of sc->nr_to_scan passed to the balloon
shrinker is SHRINK_BATCH, which is 128. This is smaller than the
limitation that only VIRTIO_BALLOON_ARRAY_PFNS_MAX (256) pages can be
returned via one invocation of leak_balloon. But this patch still
considers the case that SHRINK_BATCH or shrinker->batch could be changed
to a value larger than VIRTIO_BALLOON_ARRAY_PFNS_MAX, which will need to
do multiple invocations of leak_balloon.
Historically, the feature VIRTIO_BALLOON_F_DEFLATE_ON_OOM has been used
to release balloon pages on OOM. We continue to use this feature bit for
the shrinker, so the shrinker is only registered when this feature bit
has been negotiated with host.
Signed-off-by: Wei Wang <wei.w.wang@intel.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Zero all the vb fields at alloaction, so that we don't need to
zero-initialize each field one by one later.
It's a bit overkill to use BUG when failing to add an entry to the
stats_vq in init_vqs. So remove it and just return the error to the
caller to bail out nicely.
Make vp_set_vq_affinity() take a cpumask instead of taking a single CPU.
If there are fewer queues than cores, queue affinity should be able to
map to multiple cores.
Link: https://patchwork.ozlabs.org/patch/948149/
Suggested-by: Willem de Bruijn <willemb@google.com>
Signed-off-by: Caleb Raitto <caraitto@google.com>
Acked-by: Gonglei <arei.gonglei@huawei.com>
Kernel panic when with high memory pressure, calltrace looks like,
PID: 21439 TASK: ffff881be3afedd0 CPU: 16 COMMAND: "java"
#0 [ffff881ec7ed7630] machine_kexec at ffffffff81059beb
#1 [ffff881ec7ed7690] __crash_kexec at ffffffff81105942
#2 [ffff881ec7ed7760] crash_kexec at ffffffff81105a30
#3 [ffff881ec7ed7778] oops_end at ffffffff816902c8
#4 [ffff881ec7ed77a0] no_context at ffffffff8167ff46
#5 [ffff881ec7ed77f0] __bad_area_nosemaphore at ffffffff8167ffdc
#6 [ffff881ec7ed7838] __node_set at ffffffff81680300
#7 [ffff881ec7ed7860] __do_page_fault at ffffffff8169320f
#8 [ffff881ec7ed78c0] do_page_fault at ffffffff816932b5
#9 [ffff881ec7ed78f0] page_fault at ffffffff8168f4c8
[exception RIP: _raw_spin_lock_irqsave+47]
RIP: ffffffff8168edef RSP: ffff881ec7ed79a8 RFLAGS: 00010046
RAX: 0000000000000246 RBX: ffffea0019740d00 RCX: ffff881ec7ed7fd8
RDX: 0000000000020000 RSI: 0000000000000016 RDI: 0000000000000008
RBP: ffff881ec7ed79a8 R8: 0000000000000246 R9: 000000000001a098
R10: ffff88107ffda000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000008 R14: ffff881ec7ed7a80 R15: ffff881be3afedd0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
It happens in the pagefault and results in double pagefault
during compacting pages when memory allocation fails.
Analysed the vmcore, the page leads to second pagefault is corrupted
with _mapcount=-256, but private=0.
It's caused by the race between migration and ballooning, and lock
missing in virtballoon_migratepage() of virtio_balloon driver.
This patch fix the bug.
Fixes: e22504296d4f64f ("virtio_balloon: introduce migration primitives to balloon pages")
Signed-off-by: Jiang Biao <jiang.biao2@zte.com.cn>
Signed-off-by: Huang Chong <huang.chong@zte.com.cn>
"virtio, vhost: features, fixes
- PCI virtual function support for virtio
- DMA barriers for virtio strong barriers
- bugfixes"
virtio: update the comments for transport features
virtio_pci: support enabling VFs
vhost: fix info leak due to uninitialized memory
virtio_ring: switch to dma_XX barriers for rpmsg
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
There is a new feature bit allocated in virtio spec to
support SR-IOV (Single Root I/O Virtualization):
https://github.com/oasis-tcs/virtio-spec/issues/11
This patch enables the support for this feature bit in
virtio driver.
Signed-off-by: Tiwei Bie <tiwei.bie@intel.com>
Pull virtio update from Michael Tsirkin:
"This adds reporting hugepage stats to virtio-balloon"
virtio_balloon: export hugetlb page allocation counts
Export the number of successful and failed hugetlb page
allocations via the virtio balloon driver. These 2 counts
come directly from the vm_events HTLB_BUDDY_PGALLOC and
HTLB_BUDDY_PGALLOC_FAIL.
Signed-off-by: Jonathan Helman <jonathan.helman@oracle.com>
Reviewed-by: Jason Wang <jasowang@redhat.com>
Currently <linux/slab.h> #includes <linux/kmemleak.h> for no obvious
reason. It looks like it's only a convenience, so remove kmemleak.h
from slab.h and add <linux/kmemleak.h> to any users of kmemleak_* that
don't already #include it. Also remove <linux/kmemleak.h> from source
files that do not use it.
This is tested on i386 allmodconfig and x86_64 allmodconfig. It would
be good to run it through the 0day bot for other $ARCHes. I have
neither the horsepower nor the storage space for the other $ARCHes.
Update: This patch has been extensively build-tested by both the 0day
bot & kisskb/ozlabs build farms. Both of them reported 2 build failures
for which patches are included here (in v2).
[ slab.h is the second most used header file after module.h; kernel.h is
right there with slab.h. There could be some minor error in the
counting due to some #includes having comments after them and I didn't
combine all of those. ]
[akpm@linux-foundation.org: security/keys/big_key.c needs vmalloc.h, per sfr]
Link: http://lkml.kernel.org/r/e4309f98-3749-93e1-4bb7-d9501a39d015@infradead.org
Link: http://kisskb.ellerman.id.au/kisskb/head/13396/
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Reported-by: Michael Ellerman <mpe@ellerman.id.au> [2 build failures]
Reported-by: Fengguang Wu <fengguang.wu@intel.com> [2 build failures]
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Wei Yongjun <weiyongjun1@huawei.com>
Cc: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: John Johansen <john.johansen@canonical.com>
The vq->vq.num_free hasn't been changed when error happens,
so it shouldn't be changed when handling the error.
Fixes: 780bc7903a32 ("virtio_ring: Support DMA APIs")
As mentioned at drivers/base/core.c:
* NOTE: _Never_ directly free @dev after calling this function, even
* if it returned an error! Always use put_device() to give up the
* reference initialized in this function instead.
so we don't free vp_dev until vp_dev->vdev.dev.release be called.
Signed-off-by: weiping zhang <zhangweiping@didichuxing.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
In order to make caller do a simple cleanup, we split device_register
into device_initialize and device_add. device_initialize always succeeds,
so the caller can always use put_device when register_virtio_device faild.
Suggested-by: Cornelia Huck <cohuck@redhat.com>
No need to get into the submenu to disable all VIRTIO-related
config entries.
This makes it easier to disable all VIRTIO config options
without entering the submenu. It will also enable one
to see that en/dis-abled state from the outside menu.
This is only intended to change menuconfig UI, not change
the config dependencies.
Signed-off-by: Vincent Legoll <vincent.legoll@gmail.com>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
of_device_ids are not supposed to change at runtime. All functions
working with of_device_ids provided by <linux/of.h> work with const
of_device_ids. So mark the non-const structs as const.
File size before:
3647 608 0 4255 109f drivers/virtio/virtio_mmio.o
File size after constify virtio_mmio_match.
4063 192 0 4255 109f drivers/virtio/virtio_mmio.o
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Fix ptr_ret.cocci warnings:
drivers/virtio/virtio_mmio.c:653:1-3: WARNING: PTR_ERR_OR_ZERO can be used
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
Signed-off-by: Vasyl Gomonovych <gomonovych@gmail.com>
Add a new field VIRTIO_BALLOON_S_CACHES to virtio_balloon memory
statistics protocol. The value represents all disk/file caches.
In this case it corresponds to the sum of values
Buffers+Cached+SwapCached from /proc/meminfo.
Signed-off-by: Tomáš Golembiovský <tgolembi@redhat.com>
Recent rework of the virtio_mmio probe/remove paths balanced a
devm_ioremap() with an iounmap() rather than its devm variant. This ends
up corrupting the devm datastructures, and results in the following
boot-time splat on arm64 under QEMU 2.9.0:
[ 3.450397] ------------[ cut here ]------------
[ 3.453822] Trying to vfree() nonexistent vm area (00000000c05b4844)
[ 3.460534] WARNING: CPU: 1 PID: 1 at mm/vmalloc.c:1525 __vunmap+0x1b8/0x220
[ 3.475898] Kernel panic - not syncing: panic_on_warn set ...
[ 3.475898]
[ 3.493933] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.15.0-rc3 #1
[ 3.513109] Hardware name: linux,dummy-virt (DT)
[ 3.525382] Call trace:
[ 3.531683] dump_backtrace+0x0/0x368
[ 3.543921] show_stack+0x20/0x30
[ 3.547767] dump_stack+0x108/0x164
[ 3.559584] panic+0x25c/0x51c
[ 3.569184] __warn+0x29c/0x31c
[ 3.576023] report_bug+0x1d4/0x290
[ 3.586069] bug_handler.part.2+0x40/0x100
[ 3.597820] bug_handler+0x4c/0x88
[ 3.608400] brk_handler+0x11c/0x218
[ 3.613430] do_debug_exception+0xe8/0x318
[ 3.627370] el1_dbg+0x18/0x78
[ 3.634037] __vunmap+0x1b8/0x220
[ 3.648747] vunmap+0x6c/0xc0
[ 3.653864] __iounmap+0x44/0x58
[ 3.659771] devm_ioremap_release+0x34/0x68
[ 3.672983] release_nodes+0x404/0x880
[ 3.683543] devres_release_all+0x6c/0xe8
[ 3.695692] driver_probe_device+0x250/0x828
[ 3.706187] __driver_attach+0x190/0x210
[ 3.717645] bus_for_each_dev+0x14c/0x1f0
[ 3.728633] driver_attach+0x48/0x78
[ 3.740249] bus_add_driver+0x26c/0x5b8
[ 3.752248] driver_register+0x16c/0x398
[ 3.757211] __platform_driver_register+0xd8/0x128
[ 3.770860] virtio_mmio_init+0x1c/0x24
[ 3.782671] do_one_initcall+0xe0/0x398
[ 3.791890] kernel_init_freeable+0x594/0x660
[ 3.798514] kernel_init+0x18/0x190
[ 3.810220] ret_from_fork+0x10/0x18
To fix this, we can simply rip out the explicit cleanup that the devm
infrastructure will do for us when our probe function returns an error
code, or when our remove function returns.
We only need to ensure that we call put_device() if a call to
register_virtio_device() fails in the probe path.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Fixes: 7eb781b1bbb7136f ("virtio_mmio: add cleanup for virtio_mmio_probe")
Fixes: 25f32223bce5c580 ("virtio_mmio: add cleanup for virtio_mmio_remove")
Cc: Cornelia Huck <cohuck@redhat.com>
Cc: weiping zhang <zhangweiping@didichuxing.com>
Cc: virtualization@lists.linux-foundation.org
cleanup all resource allocated by virtio_mmio_probe.
so we don't free vm_dev until vm_dev.dev.release be called.
commit c7cdff0e8647 ("virtio_balloon: fix deadlock on OOM")
changed code to increment vb->num_pfns before call to
set_page_pfns(), which used to happen only after.
This patch fixes boot hang for me on ppc64le KVM guests.
Fixes: c7cdff0e8647 ("virtio_balloon: fix deadlock on OOM")
Cc: Michal Hocko <mhocko@suse.com>
Cc: Wei Wang <wei.w.wang@intel.com>
Signed-off-by: Jan Stancek <jstancek@redhat.com>
index can be reused by other virtio device.
fill_balloon doing memory allocations under balloon_lock
can cause a deadlock when leak_balloon is called from
virtballoon_oom_notify and tries to take same lock.
To fix, split page allocation and enqueue and do allocations outside the lock.
Here's a detailed analysis of the deadlock by Tetsuo Handa:
In leak_balloon(), mutex_lock(&vb->balloon_lock) is called in order to
serialize against fill_balloon(). But in fill_balloon(),
alloc_page(GFP_HIGHUSER[_MOVABLE] | __GFP_NOMEMALLOC | __GFP_NORETRY) is
called with vb->balloon_lock mutex held. Since GFP_HIGHUSER[_MOVABLE]
implies __GFP_DIRECT_RECLAIM | __GFP_IO | __GFP_FS, despite __GFP_NORETRY
is specified, this allocation attempt might indirectly depend on somebody
else's __GFP_DIRECT_RECLAIM memory allocation. And such indirect
__GFP_DIRECT_RECLAIM memory allocation might call leak_balloon() via
virtballoon_oom_notify() via blocking_notifier_call_chain() callback via
out_of_memory() when it reached __alloc_pages_may_oom() and held oom_lock
mutex. Since vb->balloon_lock mutex is already held by fill_balloon(), it
will cause OOM lockup.
Thread1 Thread2
fill_balloon()
takes a balloon_lock
balloon_page_enqueue()
alloc_page(GFP_HIGHUSER_MOVABLE)
direct reclaim (__GFP_FS context) takes a fs lock
waits for that fs lock alloc_page(GFP_NOFS)
takes the oom_lock
out_of_memory()
leak_balloon()
tries to take that balloon_lock and deadlocks
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull SCSI updates from James Bottomley:
"This is mostly updates of the usual suspects: lpfc, qla2xxx, hisi_sas,
megaraid_sas, zfcp and a host of minor updates.
The major driver change here is the elimination of the block based
cciss driver in favour of the SCSI based hpsa driver (which now drives
all the legacy cases cciss used to be required for). Plus a reset
handler clean up and the redo of the SAS SMP handler to use bsg lib"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (279 commits)
scsi: scsi-mq: Always unprepare before requeuing a request
scsi: Show .retries and .jiffies_at_alloc in debugfs
scsi: Improve requeuing behavior
scsi: Call scsi_initialize_rq() for filesystem requests
scsi: qla2xxx: Reset the logo flag, after target re-login.
scsi: qla2xxx: Fix slow mem alloc behind lock
scsi: qla2xxx: Clear fc4f_nvme flag
scsi: qla2xxx: add missing includes for qla_isr
scsi: qla2xxx: Fix an integer overflow in sysfs code
scsi: aacraid: report -ENOMEM to upper layer from aac_convert_sgraw2()
scsi: aacraid: get rid of one level of indentation
scsi: aacraid: fix indentation errors
scsi: storvsc: fix memory leak on ring buffer busy
scsi: scsi_transport_sas: switch to bsg-lib for SMP passthrough
scsi: smartpqi: remove the smp_handler stub
scsi: hpsa: remove the smp_handler stub
scsi: bsg-lib: pass the release callback through bsg_setup_queue
scsi: Rework handling of scsi_device.vpd_pg8[03]
scsi: Rework the code for caching Vital Product Data (VPD)
scsi: rcu: Introduce rcu_swap_protected()
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
Pull x86 asm updates from Ingo Molnar:
- Introduce the ORC unwinder, which can be enabled via
CONFIG_ORC_UNWINDER=y.
The ORC unwinder is a lightweight, Linux kernel specific debuginfo
implementation, which aims to be DWARF done right for unwinding.
Objtool is used to generate the ORC unwinder tables during build, so
the data format is flexible and kernel internal: there's no
dependency on debuginfo created by an external toolchain.
The ORC unwinder is almost two orders of magnitude faster than the
(out of tree) DWARF unwinder - which is important for perf call graph
profiling. It is also significantly simpler and is coded defensively:
there has not been a single ORC related kernel crash so far, even
with early versions. (knock on wood!)
But the main advantage is that enabling the ORC unwinder allows
CONFIG_FRAME_POINTERS to be turned off - which speeds up the kernel
measurably:
With frame pointers disabled, GCC does not have to add frame pointer
instrumentation code to every function in the kernel. The kernel's
.text size decreases by about 3.2%, resulting in better cache
utilization and fewer instructions executed, resulting in a broad
kernel-wide speedup. Average speedup of system calls should be
roughly in the 1-3% range - measurements by Mel Gorman [1] have shown
a speedup of 5-10% for some function execution intense workloads.
The main cost of the unwinder is that the unwinder data has to be
stored in RAM: the memory cost is 2-4MB of RAM, depending on kernel
config - which is a modest cost on modern x86 systems.
Given how young the ORC unwinder code is it's not enabled by default
- but given the performance advantages the plan is to eventually make
it the default unwinder on x86.
See Documentation/x86/orc-unwinder.txt for more details.
- Remove lguest support: its intended role was that of a temporary
proof of concept for virtualization, plus its removal will enable the
reduction (removal) of the paravirt API as well, so Rusty agreed to
its removal. (Juergen Gross)
- Clean up and fix FSGS related functionality (Andy Lutomirski)
- Clean up IO access APIs (Andy Shevchenko)
- Enhance the symbol namespace (Jiri Slaby)
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (47 commits)
objtool: Handle GCC stack pointer adjustment bug
x86/entry/64: Use ENTRY() instead of ALIGN+GLOBAL for stub32_clone()
x86/fpu/math-emu: Add ENDPROC to functions
x86/boot/64: Extract efi_pe_entry() from startup_64()
x86/boot/32: Extract efi_pe_entry() from startup_32()
x86/lguest: Remove lguest support
x86/paravirt/xen: Remove xen_patch()
objtool: Fix objtool fallthrough detection with function padding
x86/xen/64: Fix the reported SS and CS in SYSCALL
objtool: Track DRAP separately from callee-saved registers
objtool: Fix validate_branch() return codes
x86: Clarify/fix no-op barriers for text_poke_bp()
x86/switch_to/64: Rewrite FS/GS switching yet again to fix AMD CPUs
selftests/x86/fsgsbase: Test selectors 1, 2, and 3
x86/fsgsbase/64: Report FSBASE and GSBASE correctly in core dumps
x86/fsgsbase/64: Fully initialize FS and GS state in start_thread_common
x86/asm: Fix UNWIND_HINT_REGS macro for older binutils
x86/asm/32: Fix regs_get_register() on segment registers
x86/xen/64: Rearrange the SYSCALL entries
x86/asm/32: Remove a bunch of '& 0xffff' from pt_regs segment reads
Three cases of simple overlapping changes.
Commit 0b0f9dc5 ("Revert "virtio_pci: use shared interrupts for
virtqueues"") removed the adjustment of the pre_vectors for the virtio
MSI-X vector allocation which was added in commit fb5e31d9 ("virtio:
allow drivers to request IRQ affinity when creating VQs"). This will
lead to an incorrect assignment of MSI-X vectors, and potential
deadlocks when offlining cpus.
Fixes: 0b0f9dc5 ("Revert "virtio_pci: use shared interrupts for virtqueues")
Reported-by: YASUAKI ISHIMATSU <yasu.isimatu@gmail.com>
If using indirect descriptors, you can make the total_sg as large as you
want. If not, BUG is too serious because the function later returns
-ENOSPC.
Signed-off-by: Richard W.M. Jones <rjones@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Lguest seems to be rather unused these days. It has seen only patches
ensuring it still builds the last two years and its official state is
"Odd Fixes".
Remove it in order to be able to clean up the paravirt code.
Signed-off-by: Juergen Gross <jgross@suse.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: boris.ostrovsky@oracle.com
Cc: lguest@lists.ozlabs.org
Cc: rusty@rustcorp.com.au
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/20170816173157.8633-3-jgross@suse.com
Two minor conflicts in virtio_net driver (bug fix overlapping addition
of a helper) and MAINTAINERS (new driver edit overlapping revamp of
PHY entry).
Clean up the comment format.
This patch saves the deflated pages to a list, instead of the PFN array.
Accordingly, the balloon_pfn_to_page() function is removed.
Signed-off-by: Liang Li <liang.z.li@intel.com>
Allow zero to be store as a ctx, with this we could store e.g zero
value which could be meaningful for the case of storing headroom
through ctx.
Signed-off-by: Jason Wang <jasowang@redhat.com>
virtio balloon bypasses the DMA API entirely so does not support the
VIOMMU right now. It's not clear we need that support, for now let's
just make sure we don't pretend to support it.
Fixes: 1a937693993f ("virtio: new feature to detect IOMMU device quirk")
Acked-by: Jason Wang <jasowang@redhat.com>
Allow extra context per descriptor. To avoid slow down for data path,
this disables use of indirect descriptors for this vq.
Allows maintaining extra context per vq. For ease of use, passing in
NULL is legal and disables the feature for all vqs.
Includes fixes by Christian for s390, acked by Cornelia.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
We are going to add more parameters to find_vqs, let's wrap the call so
we don't need to tweak all drivers every time.
virtio-pci registers a per-vq affinity hint when using MSIX,
but fails to remove it when freeing the interrupt, resulting
in this type of splat:
[ 31.111202] WARNING: CPU: 0 PID: 2823 at kernel/irq/manage.c:1503 __free_irq+0x2c4/0x2c8
[ 31.114689] Modules linked in:
[ 31.116101] CPU: 0 PID: 2823 Comm: kexec Not tainted 4.10.0+ #6941
[ 31.118911] Hardware name: Generic DT based system
[ 31.121319] [<c022fb78>] (unwind_backtrace) from [<c0229d8c>] (show_stack+0x18/0x1c)
[ 31.125017] [<c0229d8c>] (show_stack) from [<c05192f4>] (dump_stack+0x84/0x98)
[ 31.128427] [<c05192f4>] (dump_stack) from [<c023d940>] (__warn+0xf4/0x10c)
[ 31.131910] [<c023d940>] (__warn) from [<c023da20>] (warn_slowpath_null+0x28/0x30)
[ 31.135543] [<c023da20>] (warn_slowpath_null) from [<c0290238>] (__free_irq+0x2c4/0x2c8)
[ 31.139355] [<c0290238>] (__free_irq) from [<c02902d0>] (free_irq+0x44/0x78)
[ 31.142909] [<c02902d0>] (free_irq) from [<c059d3a8>] (vp_del_vqs+0x68/0x1c0)
[ 31.146299] [<c059d3a8>] (vp_del_vqs) from [<c056ca4c>] (pci_device_shutdown+0x3c/0x78)
The obvious fix is to drop the affinity hint before freeing the
interrupt.
This reverts commit 5c34d002dcc7a6dd665a19d098b4f4cd5501ba1a.
drivers/virtio/virtio_pci_common.c
The cleanup seems to be one of the changes that broke
hybernation for some users. We are still not sure why
but revert helps.
This reverts the cleanup changes but keeps the affinity support.
Tested-by: Mike Galbraith <efault@gmx.de>
This reverts commit 07ec51480b5eb1233f8c1b0f5d7a7c8d1247c507.
Unfortunately the idea does not work with threadirqs
as more than 32 queues can then map to a single interrupts.
Further, the cleanup seems to be one of the changes that broke
but revert helps.
This reverts commit 53a020c661741f3b87ad3ac6fa545088aaebac9b.
but revert helps.
