[ Upstream commit c8a6a09c1c617402cc9254b2bc8da359a0347d75 ]
In ca91cx42_slave_get function, the value pointed by vme_base pointer is
set through:
*vme_base = ioread32(bridge->base + CA91CX42_VSI_BS[i]);
So it must be dereferenced to be used in calculation of pci_base:
*pci_base = (dma_addr_t)*vme_base + pci_offset;
This bug was caught thanks to the following gcc warning:
drivers/vme/bridges/vme_ca91cx42.c: In function ‘ca91cx42_slave_get’:
drivers/vme/bridges/vme_ca91cx42.c:467:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
*pci_base = (dma_addr_t)vme_base + pci_offset;
Signed-off-by: Augusto Mecking Caringi <augustocaringi@gmail.com>
Acked-By: Martyn Welch <martyn@welchs.me.uk>
Cc: stable <stable@vger.kernel.org>
The tsi148 driver is registering the slave images as supporting the "USER"
access modes and CR/CSR access mode rather than the master images as it
should.
Remove the incorrect case entries for these modes from the
tsi148_slave_set() function, stop registering slave_images as supporting
these modes and instead register master windows as supporting these modes.
Signed-off-by: Martyn Welch <martyn.welch@ge.com>
Acked-by: Dmitry Kalinkin <dmitry.kalinkin@gmail.com>
We also make sure that user won't be able to reconfigure the window while it is
mmap'ed.
Signed-off-by: Dmitry Kalinkin <dmitry.kalinkin@gmail.com>
Cc: Martyn Welch <martyn.welch@ge.com>
Cc: Igor Alekseev <igor.alekseev@itep.ru>
Replace a misspelled function name by %s and then __func__.
This is the get function, not the set function, as was indicated by the
string.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Remove the now unnecessary memset too.
Cc: Manohar Vanga <manohar.vanga@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
The CA91CX42_DCTL_VDW_M define is cut and pasted twice so we can delete
the second instance.
Save some characters by using to_pci_dev() instead of container_of().
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
Previously, tsi148_master_set() assumed the address contained in its
PCI bus resource represented the actual PCI bus address. This is a fine
assumption on some platforms. However, on platforms that don't use a
1:1 (CPU:PCI) mapping this results in the tsi148 driver configuring an
invalid master window translation.
This patch updates the vme_tsi148 driver to first convert the address
contained in the PCI bus resource into a PCI bus address before using
it.
[asierra: account for pcibios_resource_to_bus() prototype change]
Signed-off-by: Joe Schultz <jschultz@xes-inc.com>
This patch corrects a typo where "vme_base" was used instead of
"*vme_base". The typo resulted in an incorrect value being returned
to userspace (via vme_user).
It also removes the following compile warning on some platforms:
[asierra: commit title/log rewording]
We need the fixes here for future mei and other patches.
The ca91cx42 and tsi148 VME bridges use the width of reads and writes on the
PCI bus in part to control the width of the cycles on the VME bus. It is
important that we can control the width of cycles on the VME bus as some VME
hardware requires cycles of a specific width. The memcpy_toio() and
memcpy_fromio() functions do not provide sufficient control, so instead loop
using ioread functions.
Reported-by: Michael Kenney <mfkenney@gmail.com>
In order to ensure the correct width cycles on the VME bus, the VME bridge
drivers implement an algorithm to utilise the largest possible width reads and
writes whilst maintaining natural alignment constraints. The algorithm
currently looks at the start address rather than the current read/write address
when determining whether a 16-bit width cycle is required to get to 32-bit
alignment. This results in incorrect alignment,
Reported-by: Jim Strouth <james.strouth@ge.com>
Tested-by: Jim Strouth <james.strouth@ge.com>
Previously, VME bridge support was treated as any other driver (using
module_init() macro), but if VME bridge and vme_user (staging) drivers
were compiled into the kernel, then vme_user would attempt to register
itself before the VME core support had been loaded. This would result
in a kernel panic.
The load order of these built-in drivers is based on the order in which
drivers/staging/vme and driver/vme are compiled.
This patch changes the VME core driver to use the subsys_initcall()
macro which ensures that it is loaded before all other VME drivers
regardless of the order in which they are compiled.
Tested-by: Aaron Sierra <asierra@xes-inc.com>
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro
is not preferred.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Traditionally the "get" functions increment the reference count of the
object that is returned, which does not happen with vme_slot_get. The
function vme_slot_get returns the physical VME slot associated with a
particular struct vme_dev. Rename vme_slot_num to avoid any confusion.
The match function for vme_user is completely wrong. It will blindly bind
against the first VME slot on each bus (at this point that would be just the
first bus as the driver can only handle one bus).
The original intention (before some major subsystem changes) was that the
driver bind against the slot to which the bridge was attached in the VME
system and to the bus(es) provided via the "bus" module parameter.
To do this cleanly (i.e. without poking arround in the subsystems internal
stuctures) a functionality has been added to provide access to the bus
enumeration.
free_irq() expects the same device identity that was passed to
corresponding request_irq(), otherwise the IRQ is not freed.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Added missing __iomem annotation in order to fix the following
sparse warnings:
drivers/vme/boards/vme_vmivme7805.c:62:19: warning: incorrect type in assignment (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:62:19: expected void *static [toplevel] vmic_base
drivers/vme/boards/vme_vmivme7805.c:62:19: got void [noderef] <asn:2>*
drivers/vme/boards/vme_vmivme7805.c:70:9: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:70:9: expected void volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:70:9: got void *
drivers/vme/boards/vme_vmivme7805.c:73:16: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:73:16: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:73:16: got void *
drivers/vme/boards/vme_vmivme7805.c:75:9: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:75:9: expected void volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:75:9: got void *
drivers/vme/boards/vme_vmivme7805.c:78:16: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:78:16: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:78:16: got void *
drivers/vme/boards/vme_vmivme7805.c:85:9: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:85:9: expected void volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:85:9: got void *
drivers/vme/boards/vme_vmivme7805.c:99:17: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/boards/vme_vmivme7805.c:99:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/boards/vme_vmivme7805.c:99:17: got void *static [toplevel] vmic_base
sparse warnings:
drivers/vme/bridges/vme_ca91cx42.c:859:39: warning: incorrect type in initializer (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:859:39: expected void *addr
drivers/vme/bridges/vme_ca91cx42.c:859:39: got void [noderef] <asn:2>*
drivers/vme/bridges/vme_ca91cx42.c:878:30: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:878:30: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:878:30: got void *addr
drivers/vme/bridges/vme_ca91cx42.c:885:47: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:885:47: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:885:47: got void *
drivers/vme/bridges/vme_ca91cx42.c:889:48: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:889:48: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:889:48: got void *
drivers/vme/bridges/vme_ca91cx42.c:896:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:896:17: expected void const volatile [noderef] <asn:2>*<noident>
drivers/vme/bridges/vme_ca91cx42.c:896:17: got void *
drivers/vme/bridges/vme_ca91cx42.c:901:40: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:901:40: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:901:40: got void *
drivers/vme/bridges/vme_ca91cx42.c:905:39: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:905:39: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:905:39: got void *
drivers/vme/bridges/vme_ca91cx42.c:919:39: warning: incorrect type in initializer (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:919:39: expected void *addr
drivers/vme/bridges/vme_ca91cx42.c:919:39: got void [noderef] <asn:2>*
drivers/vme/bridges/vme_ca91cx42.c:932:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:932:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:932:17: got void *addr
drivers/vme/bridges/vme_ca91cx42.c:939:25: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:939:25: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:939:25: got void *
drivers/vme/bridges/vme_ca91cx42.c:943:25: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:943:25: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:943:25: got void *
drivers/vme/bridges/vme_ca91cx42.c:950:17: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:950:17: expected void volatile [noderef] <asn:2>*<noident>
drivers/vme/bridges/vme_ca91cx42.c:950:17: got void *
drivers/vme/bridges/vme_ca91cx42.c:955:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:955:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:955:17: got void *
drivers/vme/bridges/vme_ca91cx42.c:959:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_ca91cx42.c:959:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_ca91cx42.c:959:17: got void *
sparse warnings:
drivers/vme/bridges/vme_tsi148.c:1270:39: warning: incorrect type in initializer (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1270:39: expected void *addr
drivers/vme/bridges/vme_tsi148.c:1270:39: got void [noderef] <asn:2>*
drivers/vme/bridges/vme_tsi148.c:1287:30: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1287:30: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1287:30: got void *addr
drivers/vme/bridges/vme_tsi148.c:1294:47: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1294:47: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1294:47: got void *
drivers/vme/bridges/vme_tsi148.c:1298:48: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1298:48: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1298:48: got void *
drivers/vme/bridges/vme_tsi148.c:1305:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1305:17: expected void const volatile [noderef] <asn:2>*<noident>
drivers/vme/bridges/vme_tsi148.c:1305:17: got void *
drivers/vme/bridges/vme_tsi148.c:1310:40: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1310:40: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1310:40: got void *
drivers/vme/bridges/vme_tsi148.c:1314:39: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1314:39: expected void const volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1314:39: got void *
drivers/vme/bridges/vme_tsi148.c:1351:39: warning: incorrect type in initializer (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1351:39: expected void *addr
drivers/vme/bridges/vme_tsi148.c:1351:39: got void [noderef] <asn:2>*
drivers/vme/bridges/vme_tsi148.c:1369:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1369:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1369:17: got void *addr
drivers/vme/bridges/vme_tsi148.c:1376:25: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1376:25: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1376:25: got void *
drivers/vme/bridges/vme_tsi148.c:1380:25: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1380:25: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1380:25: got void *
drivers/vme/bridges/vme_tsi148.c:1387:17: warning: incorrect type in argument 1 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1387:17: expected void volatile [noderef] <asn:2>*<noident>
drivers/vme/bridges/vme_tsi148.c:1387:17: got void *
drivers/vme/bridges/vme_tsi148.c:1392:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1392:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1392:17: got void *
drivers/vme/bridges/vme_tsi148.c:1396:17: warning: incorrect type in argument 2 (different address spaces)
drivers/vme/bridges/vme_tsi148.c:1396:17: expected void volatile [noderef] <asn:2>*addr
drivers/vme/bridges/vme_tsi148.c:1396:17: got void *
Fix to return a negative error code in the tsi148_crcsr_init() error
handling case instead of 0, as done elsewhere in this function.
The tsi148 driver can be configured to reserve a window for internal
use (as part of the error checking routine). The intialisation of this
window currently configures a set of attributes that are never used
as these are only ever used by the VME core and this window is not
advertised to the core.
Remove configuration of these attributes.
The logic in the init routine for the TSI148 is inverted. It isn't switching
on the CR/CSR space when it should be and is reporting it's on when its not.
Correct the logic to do the right thing.
Reported-by: De Roo, Steven <steven.deroo@arcelormittal.com>
The TSI148 driver provides an optional mechanism for ensuring that errors
resulting from posted transfers are caught whilst still relevant. To do this
errors are stored in a link list. If bus errors are not checked, this list
would grow until available memory had been exhausted.
Only store the errors in a link list if error detection is switched on.
There is a memory leak in the function vme_dma_free(). The resource
structure allocated in vme_dma_request() needs to be free'd in
vme_dma_free().
put_device() must be called after device_register() fails,
since device_register() always initializes the refcount
on the device structure.
Signed-off-by: Emilio G. Cota <cota@braap.org>
Use the module_pci_driver() macro to make the code simpler
by eliminating module_init and module_exit calls.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Since we will be removing items off the list using list_del() we need
to use a safer version of the list_for_each() macro aptly named
list_for_each_safe(). We should use the safe macro if the loop
involves deletions of items.
The memcpy_fromio() and memcpy_toio() functions use the __memcpy() function,
at least on x86. This function carries out transfers smaller than 32 bits as
multiple 8 bit transfers, causing a single (aligned) 16 bit transfer to be
split into 2 8 bit transfers which may not be supported by the target VME
device.
The commit 53059aa05988761a738fa8bc082bbf3c5d4462d1 fixed this for the
ca91cx42, however this was not fixed for the tsi148 at the time. This patch
uses the same algorithm to fix the tsi148.
Reported-by: Daniel Lambert <daniel.lambert@clermont.in2p3.fr>
The documentation for the VME device driver API is currently in
drivers/vme/vme_api.txt, move this to Documentation/vme_api.txt
Signed-of-by: Martyn Welch <martyn.welch@ge.com>
Acked-by: Rob Landley <rob@landley.net>
Functions not referenced outside of a source file should be marked
static to prevent them from being exposed globally.
Quiets the sparse warnings:
warning: symbol 'ca91cx42_alloc_consistent' was not declared. Should it be static?
warning: symbol 'ca91cx42_free_consistent' was not declared. Should it be static?
Acked-by: Martyn Welch <martyn.welch@ge.com>
warning: symbol 'tsi148_alloc_consistent' was not declared. Should it be static?
warning: symbol 'tsi148_free_consistent' was not declared. Should it be static?
This moves the VME core, VME board drivers, and VME bridge drivers out
of the drivers/staging/vme/ area to drivers/vme/.
The VME device drivers have not moved out yet due to some API questions
they are still working through, that should happen soon, hopefully.
Cc: Manohar Vanga <manohar.vanga@cern.ch>
Cc: Vincent Bossier <vincent.bossier@gmail.com>
Cc: "Emilio G. Cota" <cota@braap.org>
