Add a config option to enable the watchdog driver from probe
Reduce the default timeout to 30 seconds
Read the reset reason and print a messge if the last reboot was
due to watchdog reset
Change-Id: I7500ef236089b06ffcff3d8e7d86a5b9060b59cb
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
add a driver for the hardware watchdog timer embedded in NVIDIA
Tegra SoCs
Change-Id: I45bc829f26f350143d5a07e1f4ddc46d24f3a54c
Signed-off-by: Gary King <gking@nvidia.com>
The newly added WATCHDOG_CORE option is a bool, but the help text suggests
it can be built as a module. Fix it up.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
The WatchDog Timer Driver Core is a framework
that contains the common code for all watchdog-driver's.
It also introduces a watchdog device structure and the
operations that go with it.
This is the introduction of this framework. This part
supports the minimal watchdog userspace API (or with
other words: the functionality to use /dev/watchdog's
open, release and write functionality as defined in
the simplest watchdog API). Extra functionality will
follow in the next set of patches.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores.
It takes watchdog timer configuration from device tree and it needs that its
parent has defined the property "clock-frecuency".
It is compatible with watchdog timer kernel API, so user apps like watchdogd
may talk with it.
Signed-off-by: Alejandro Cabrera <aldaya@gmail.com>
The i.MX architecture provides IMX_HAVE_PLATFORM_* macros to signal
that a selected SoC supports a certain hardware. Use them instead of
depending on ARCH_* directly.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: linux-watchdog@vger.kernel.org
The Synopsys DesignWare watchdog is found in several ARM based systems
and provides a choice of 16 timeout periods depending on the clock
input. The watchdog cannot be disabled once started.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
hpwdt is a PCI driver so it should depend on PCI.
Fixes these build errors:
drivers/watchdog/hpwdt.c:762: error: implicit declaration of function 'pci_iomap'
drivers/watchdog/hpwdt.c:762: warning: assignment makes pointer from integer without a cast
drivers/watchdog/hpwdt.c:797: error: implicit declaration of function 'pci_iounmap'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Thomas Mingarelli <thomas.mingarelli@hp.com>
Remove Kconfig regression caused by commit
a4616153deae053b29a2b7dd9ec4b2a225accfc5 "watchdog: hpwdt: build hpwdt as
module by default with NMI_DECODING enabled"
With the above change applied, hpwdt will be enabled unconditionally by just
entering the Watchdog subscreen in menuconfig. Since this driver is not
essential to boot any box it should remain disabled until it gets manually
enabled, just like all other drivers.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Cc: Tony Camuso <tcamuso@redhat.com>
Trying to build the Intel SCU Watchdog fails for me with gcc 4.6.0 -
$ gcc --version | head -n 1
gcc (GCC) 4.6.0 20110513 (prerelease)
like this :
CC drivers/watchdog/intel_scu_watchdog.o
In file included from drivers/watchdog/intel_scu_watchdog.c:49:0:
/home/jj/src/linux-2.6/arch/x86/include/asm/apb_timer.h: In function ‘apbt_time_init’:
/home/jj/src/linux-2.6/arch/x86/include/asm/apb_timer.h:65:42: warning: ‘return’ with a value, in function returning void [enabled by default]
drivers/watchdog/intel_scu_watchdog.c: In function ‘intel_scu_watchdog_init’:
drivers/watchdog/intel_scu_watchdog.c:468:2: error: implicit declaration of function ‘sfi_get_mtmr’ [-Werror=implicit-function-declaration]
drivers/watchdog/intel_scu_watchdog.c:468:32: warning: assignment makes pointer from integer without a cast [enabled by default]
cc1: some warnings being treated as errors
make[1]: *** [drivers/watchdog/intel_scu_watchdog.o] Error 1
make: *** [drivers/watchdog/intel_scu_watchdog.o] Error 2
Additionally, linux/types.h is needlessly being included twice in
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
This patch adds the driver for the watchdog found inside the Lantiq SoC family.
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2327/
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: booke_wdt: clean up status messages
watchdog: cleanup spaces before tabs
watchdog: convert to DEFINE_PCI_DEVICE_TABLE
watchdog: Xen watchdog driver
watchdog: Intel SCU Watchdog Timer Driver for Moorestown and Medfield platforms.
watchdog: jz4740_wdt - fix magic character checking
watchdog: add JZ4740 watchdog driver
watchdog: it87_wdt: Add support for IT8721F watchdog
watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled
watchdog: hpwdt: Fix a couple of typos
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
While the hypervisor change adding SCHEDOP_watchdog support included a
daemon to make use of the new functionality, having a kernel driver
for /dev/watchdog so that user space code doesn't need to distinguish
non-Xen and Xen seems to be preferable.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
This submission includes:
- Fix to intel_scu_write() to start watchdog timer the on the
first write, and refresh on subsequent writes.
This enables Open, write, write, ... usage model.
- Moves boot parameter checks from intel_scu_open() to
intel_scu_watchdog_init(), so driver init will fail if these
parameters are out of bounds.
- Adds check for whether process waiting in wait_event_interruptible()
received a signal while it was waiting.
- Other small error handling changes.
Removed the read() method for now as that wass a non-standard behaviour.
Signed-off-by: Donald Johnson <donald.k.johnson@intel.com>
Signed-off-by: Shuduo Sang <shuduo.sang@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Adds support for the hardware watchdog found in Ingenic's jz4740
System-on-Chip.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
This patch adds support for a watchdog in IT8721F Super IO
chip to it87_wdt driver.
This new chips differ from the older IT87xxxF chips
in the following ways:
* WDT_GAMEPORT is not in IT8721F.
* WDT_PWROK is not in IT8721F.
Signed-off-by: Haruo Tomita <haruo.tomita@toshiba.co.jp>
Builds the hpwdt driver as a module by default.
If the hardware is present, the module will be loaded.
Also, if hpwdt is loaded, it will decode NMIs by default.
This has been made possible by he patches to hpwdt made by Dann Frazier
as well as related patches submitted by Don Zickus.
hpwdt only loads on hp ProLiant x86 32-bit and 64-bit platforms.
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
Fix some typos.
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
All m548x files were renamed to m54xx, except m548x_wdt.c. Fix that.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
into sh-latest
Add watchdog driver for MCF548x.
This patch adds a driver for the built-in hardware watchdog device
of the Atheros AR71XX/AR724X/AR913X SoCs.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
This driver adds support for /dev/watchdog for boards using either the MCP51 or
MCP55 chipsets. These are also known as the nForce 430 and nForce 550. This
driver is likely to work on other chipsets as well, though those are the only
two that have been tested.
Signed-off-by: Mike Waychison <mikew@google.com>
This driver adds /dev/watchdog support for the AMD sp5100 aka SB7x0 chipsets.
It follows the same conventions found in other /dev/watchdog drivers.
Signed-off-by: Priyanka Gupta <priyankag@google.com>
Update Kconfig with the additional Fintek hardware that we support.
Signed-off-by: Lutz Ballaschke <vegan.grindcore@googlemail.com>
Acked-by: Giel van Schijndel <me@mortis.eu>
The following adds watchdog support for the Winbond W83627DHG chip.
I have tested it on a PQ7-M102XL (Intel Atom) board.
Signed-off-by: Benny Lønstrup Ammitzbøll <benny@ammitzboell-consult.dk>
On some motherboards the it8712f watchdog does not work unless
the game port was enabled. see Bug 13140. We therefor add a note
to Kconfig.
This patch adds support for the Broadcom BCM63xx SoC built-in watchdog, it
uses one of the BCM63xx hardware timer id.
Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Giel van Schijndel <me@mortis.eu>
This patch adds support for watchdogs with 8b timers, like ones in
IT8702F and older revisions of IT8712F Super IO chip, to it87_wdt
driver. This patch should be used after the patch
'it87_wdt: Add support for IT8720F watchdog'.
Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org>
This simple patch adds support for a watchdog in IT8720F Super IO chip
to it87_wdt driver.
The PowerPC Book-E watchdog driver (booke_wdt.c) defines a default timeout
value in the code based on whether it's a Freescale Book-E part of not.
Instead of having hard-coded values in the driver, make it a Kconfig
option.
As newer chips gets faster, the current default values become less
appropriate, since the timeout sometimes occurs before the kernel finishes
booting. Making the value a Kconfig option allows BSPs to configure a new
value without requiring the wdt_period command-line parameter to be set.
Register the __init and __exit functions in the PowerPC Book-E Watchdog
driver as module entry/exit functions, and modify the Kconfig entry.
Add a .release method for the PowerPC Book-E Watchdog driver, so that the
watchdog is disabled when the driver is closed.
Loosely based on original code from Jiang Yutang <b14898@freescale.com>.
The NXP LPC32XX processor use the same watchdog as the Philips
PNX4008 processor.
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
hpwdt is quite functional without the NMI decoding feature.
This change lets users disable the NMI portion at compile-time
via the new HPWDT_NMI_DECODING config option.
Signed-off-by: dann frazier <dannf@hp.com>
Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com>
This driver supports both iLO2 and iLO3, but our user-visible strings
currently only reference iLO2. Let's just call it "iLO2+" to avoid having
to update strings for each iLO generation. This driver doesn't support
iLO ASICs prior to iLO2, but that is sufficiently explained in Kconfig.
Technical Reference Manual can be found at:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0270b/DDI0270.pdf
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Add a new watchdog driver for the Fintek F71808E and F71882FG Super I/O
controllers.
The OCTEON is a MIPS64 based SOC family with an on chip watchdog unit.
The driver is split into two source files one for the C code and one
for assembly. Assembly is needed to handle the NMI and then print the
machine state before the reboot is triggered.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Marc Zyngier <maz@misterjones.org>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
To: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org,
Patchwork: https://patchwork.linux-mips.org/patch/1503/
create mode 100644 drivers/watchdog/octeon-wdt-main.c
create mode 100644 drivers/watchdog/octeon-wdt-nmi.S
processors.
This is the driver for the hardware watchdog on the Freescale IMX2 and later processors.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Juergen Beisert <jbe@pengutronix.de>
This patch adds HAVE_S3C2410_WATCHDOG to control inclusion of watchdog driver
for Samsung SoCs. This option will help to include the driver only for the
necessary machines and not for all for any given arch.
Signed-off-by: Banajit Goswami <banajit.g@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The wdt mmaping thing was a special-cased hack that nothing in the wild
depends on, so just kill it off. While at it, sanitize the superfluous
comments in preparation for a driver rewrite and overhauled interface.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
This fixes the build failures seen when building mpcore_wdt and it
also removes the nonexistent ARM_MPCORE_PLATFORM dependency, instead
make it dependent on HAVE_ARM_TWD.
Also this fixes spinlock usage appropriately.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Correct fix for the "ioremap() causes build failure on S390" should have been
a dependancy on HAS_IOMEM. So we add this dependancy also (and leave the driver
in the ARM section for now).
This patch allows Watchdog timer to be selected for OMAP4 by fixing
Kconfig entry
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Use of ioremap() causes build failure on S390.
Restrict the driver to ARM until another architecture comes along
and enables the driver for its own use.
Signed-off-by: Marc Zyngier <maz@misterjones.org>
This patch corrects author and copyright notices following the split-up of
the GE Fanuc joint venture.
Signed-off-by: Martyn Welch <martyn.welch@ge.com>
This driver adds support for the max63{69,70,71,72,73,74} family of
watchdog timer chips.
It has been tested on an Arcom Zeus (max6369).
