path: root/drivers/watchdog/at91rm9200_wdt.c
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-18[WATCHDOG] Some more general cleanupWim Van Sebroeck
Clean-up the watchdog drivers so that checkpatch.pl get's happy... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] at91rm9200_wdt.c: move probe function to .devinit.textUwe Kleine-König
A pointer to at91wdt_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ilpo Jarvinen <ilpo.jarvinen@helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-02-14[ARM] 5390/1: AT91: Watchdog fixesAndrew Victor
The recently merged AT91SAM9 watchdog driver uses the AT91SAM9X_WATCHDOG config variable, whereas the original version of the driver (and the platform support code) used AT91SAM9_WATCHDOG. This causes the watchdog platform_device to never be registered, and therefore the driver not to be initialized. This patch: - updates the platform support code to use AT91SAM9X_WATCHDOG. - includes <linux/io.h> to fix compile error (same fix as was applied to at91rm9200_wdt.c) - fixes comment regarding watchdog clock-rates in at91rm9200. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-24[ARM] 5370/1: at91: fix rm9200 watchdogJean-Christop PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-26[WATCHDOG] at91rm9200_wdt.c: fix misleading indentationIlpo Jarvinen
Signed-off-by: Ilpo Jarvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-10[WATCHDOG] fix watchdog/at91rm9200_wdt.c compilationAdrian Bunk
This patch fixes the following compile error: <-- snip --> ... CC drivers/watchdog/at91rm9200_wdt.o at91rm9200_wdt.c:188: error: 'at91_wdt_ioctl' undeclared here (not in a make[3]: *** [drivers/watchdog/at91rm9200_wdt.o] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-08Merge Linus' latest into masterRussell King
Conflicts: drivers/watchdog/at91rm9200_wdt.c drivers/watchdog/davinci_wdt.c drivers/watchdog/ep93xx_wdt.c drivers/watchdog/ixp2000_wdt.c drivers/watchdog/ixp4xx_wdt.c drivers/watchdog/ks8695_wdt.c drivers/watchdog/omap_wdt.c drivers/watchdog/pnx4008_wdt.c drivers/watchdog/sa1100_wdt.c drivers/watchdog/wdt285.c
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-27[WATCHDOG 06/57] at91: watchdog to unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-04-11watchdog: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable watchdog drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers; registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
