path: root/drivers/watchdog/dw_wdt.c
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-01-27watchdog: dw_wdt.c: use devm_request_and_ioremapJulia Lawall
Reimplement a call to devm_request_mem_region followed by a call to ioremap or ioremap_nocache by a call to devm_request_and_ioremap. The semantic patch that makes this transformation is as follows: (http://coccinelle.lip6.fr/) // <smpl> @nm@ expression myname; identifier i; @@ struct platform_driver i = { .driver = { .name = myname } }; @@ expression dev,res,size; expression nm.myname; @@ -if (!devm_request_mem_region(dev, res->start, size, - \(res->name\|dev_name(dev)\|myname\))) { - ... - return ...; -} ... when != res->start ( -devm_ioremap(dev,res->start,size) +devm_request_and_ioremap(dev,res) | -devm_ioremap_nocache(dev,res->start,size) +devm_request_and_ioremap(dev,res) ) ... when any when != res->start // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-01-06watchdog: convert drivers/watchdog/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/watchdog/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Nicolas Thill <nico@openwrt.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Cercueil <paul@crapouillou.net> Cc: Marc Zyngier <maz@misterjones.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alejandro Cabrera <aldaya@gmail.com> Cc: "George G. Davis" <gdavis@mvista.com> Cc: Sylver Bruneau <sylver.bruneau@googlemail.com> Cc: Vitaly Wool <vital@embeddedalley.com> Cc: Mika Westerberg <mika.westerberg@iki.fi> Cc: Timo Kokkonen <timo.t.kokkonen@nokia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: add support for the Synopsys DesignWare WDTJamie Iles
The Synopsys DesignWare watchdog is found in several ARM based systems and provides a choice of 16 timeout periods depending on the clock input. The watchdog cannot be disabled once started. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
