commit 97d2a10d5804d585ab0b58efbd710948401b886a upstream.
1. address has to be page aligned.
2. set_memory_x uses page size argument, not size.
Bug causes with following commit:
commit da28179b4e90dda56912ee825c7eaa62fc103797
Author: Mingarelli, Thomas <Thomas.Mingarelli@hp.com>
Date: Mon Nov 7 10:59:00 2011 +0100
watchdog: hpwdt: Changes to handle NX secure bit in 32bit path
commit e67d668e147c3b4fec638c9e0ace04319f5ceccd upstream.
This patch makes use of the set_memory_x() kernel API in order
to make necessary BIOS calls to source NMIs.
Signed-off-by: Maxim Uvarov <maxim.uvarov@oracle.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
This is needed for SLES11 SP2 and the latest upstream kernel as it appears
the NX Execute Disable has grown in its control.
Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com>
Signed-off by: Wim Van Sebroeck <wim@iguana.be>
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables.
hpwdt_init_nmi_decoding() is called in hpwdt_init_one error handling,
thus remove the __devexit annotation of hpwdt_exit_nmi_decoding().
This patch fixes below warning:
WARNING: drivers/watchdog/hpwdt.o(.devinit.text+0x36f): Section mismatch in reference from the function hpwdt_init_one() to the function .devexit.text:hpwdt_exit_nmi_decoding()
The function __devinit hpwdt_init_one() references
a function __devexit hpwdt_exit_nmi_decoding().
This is often seen when error handling in the init function
uses functionality in the exit path.
The fix is often to remove the __devexit annotation of
hpwdt_exit_nmi_decoding() so it may be used outside an exit section.
Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com>
They are a handful of places in the code that register a die_notifier
as a catch all in case no claims the NMI. Unfortunately, they trigger
on events like DIE_NMI and DIE_NMI_IPI, which depending on when they
registered may collide with other handlers that have the ability to
determine if the NMI is theirs or not.
The function unknown_nmi_error() makes one last effort to walk the
die_chain when no one else has claimed the NMI before spitting out
messages that the NMI is unknown.
This is a better spot for these devices to execute any code without
colliding with the other handlers.
The two drivers modified are only compiled on x86 arches I believe, so
they shouldn't be affected by other arches that may not have
DIE_NMIUNKNOWN defined.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: openipmi-developer@lists.sourceforge.net
Cc: dann frazier <dannf@hp.com>
LKML-Reference: <1294348732-15030-3-git-send-email-dzickus@redhat.com>
CONFIG_HARDLOCKUP_DETECTOR
The x86 arch has shifted its use of the nmi_watchdog from a
local implementation to the global one provide by
kernel/watchdog.c. This shift has caused a whole bunch of
compile problems under different config options. I attempt to
simplify things with the patch below.
In order to simplify things, I had to come to terms with the
meaning of two terms ARCH_HAS_NMI_WATCHDOG and
CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing,
the former on a local level and the latter on a global level.
With the old x86 nmi watchdog gone, there is no need to rely on
defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't
make sense any more. x86 will now use the global
implementation.
The changes below do a few things. First it changes the few
places that relied on ARCH_HAS_NMI_WATCHDOG to use
CONFIG_X86_LOCAL_APIC (the former was an alias for the latter
anyway, so nothing unusual here). Those pieces of code were
relying more on local apic functionality the nmi watchdog
functionality, so the change should make sense.
Second, I removed the x86 implementation of
touch_nmi_watchdog(). It isn't need now, instead x86 will rely
on kernel/watchdog.c's implementation.
Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from
x86. And tweaked the include/linux/nmi.h file to tell users to
look for an externally defined touch_nmi_watchdog in the case of
ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This
changes removes some of the ugliness in that file.
Finally, I added a Kconfig dependency for
CONFIG_HARDLOCKUP_DETECTOR that said you can't have
ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can
only have one nmi_watchdog.
Tested with
ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken
configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig,
(various broken configs)
Hopefully, after this patch I won't get any more compile broken
emails. :-)
v3:
changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function
prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set.
Cc: fweisbec@gmail.com
LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com>
Now that the bulk of the old nmi_watchdog is gone, remove all
the stub variables and hooks associated with it.
This touches lots of files mainly because of how the io_apic
nmi_watchdog was implemented. Now that the io_apic nmi_watchdog
is forever gone, remove all its fingers.
Most of this code was not being exercised by virtue of
nmi_watchdog != NMI_IO_APIC, so there shouldn't be anything to
risky here.
Cc: gorcunov@openvz.org
LKML-Reference: <1289578944-28564-3-git-send-email-dzickus@redhat.com>
hpwdt is quite functional without the NMI decoding feature.
This change lets users disable the NMI portion at compile-time
via the new HPWDT_NMI_DECODING config option.
Signed-off-by: dann frazier <dannf@hp.com>
Move NMI-decoding initialisation and exit code to seperate functions so that
we can ifdef-out parts of it in the future.
Also, this is for a device, so let's use dev_info instead of printk.
The term "decoding" more clearly explains what hpwdt is doing. It isn't
just finding the source of the interrupt, but rather aids in decoding what
the interrupt means.
Reorganize this function to remove excess indentation and highlight
the single return code. (No functional change).
Let applications check the amount of time left before the watchdog will fire.
The hpwdt timer is a 16 bit value with 128ms resolution.
Let applications use this entire range.
Define a macro to convert from seconds to timer ticks.
The 32-bit assembly is guarded by an #ifndef CONFIG_X86_64. Kconfig prevents
us from building this driver on !X86, so that happens to suffice - but we
should really lock it down to #ifdef CONFIG_X86_32.
This driver supports both iLO2 and iLO3, but our user-visible strings
currently only reference iLO2. Let's just call it "iLO2+" to avoid having
to update strings for each iLO generation. This driver doesn't support
iLO ASICs prior to iLO2, but that is sufficiently explained in Kconfig.
* Group together includes specific to NMI sourcing
* Group defines only used by NMI sourcing together
* Group declarations specific to NMI sourcing together
This gives a clean seperation of watchdog specific items and
NMI sourcing specific items (which is needed for making it
possible to build hpwdt without the NMI functionality).
Reorganization only.
* remove unnecessary includes
* We use a spinlock, but lacked the include
* We need bitops.h for test_and_set_bit/clear_bit
Use %p instead of %08x in printk().
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] hpwdt - fix lower timeout limit
[WATCHDOG] iTCO_wdt: TCO Watchdog patch for additional Intel Cougar Point DeviceIDs
[WATCHDOG] doc: Fix use of WDIOC_SETOPTIONS ioctl.
[WATCHDOG] doc: watchdog simple example: don't fail on fsync()
[WATCHDOG] set max63xx driver as ARM only
[WATCHDOG] powerpc: pika_wdt ident cannot be const
[Novell Bug 581103] HP Watchdog driver has arbitrary (wrong) timeout limits.
Fix the lower timeout limit to a more appropriate value.
Signed-off-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com>
Cc: stable <stable@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
make the watchdog_info struct const where possible.
Add a priority option so that the user can choose if we do the NMI
first or last.
Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com>
Add NMI sourcing functionality (Can only be active if nmi_watchdog is
inactive).
At the moment, dmi_walk() lacks flexibility, users can't pass data to
the callback function. Add a pointer for private data to make this
function more flexible.
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Roland Dreier <rolandd@cisco.com>
Some more cleaning-up of the watchdog drivers.
Fix following warnings:
WARNING: struct file_operations should normally be const
Add the PCI-ID for the upcoming new BMC controller for HP hardware.
When the "hpwdt" module is loaded (even if the /dev/watchdog device is not
opened), then kdump does not work. The panic kernel either does not start at
all or crash in various places.
The problem is that hpwdt_pretimeout is registered with register_die_notifier()
with the highest possible priority. Because it returns NOTIFY_STOP, the
crash_nmi_callback which is also registered with register_die_notifier()
is never executed. This causes the shutdown of other CPUs to fail.
Reverting the order is no option: The crash_nmi_callback executes HLT
and so never returns normally. Because of that, it must be executed as
last notifier, which currently is done.
So, that patch returns NOTIFY_OK to keep the crash_nmi_callback executed.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: Vivek Goyal <vgoyal@redhat.com>
The address provided by the SMBIOS/DMI CRU information is mapped via
ioremap() in the virtual address space. However, since the address is
executed (i.e. call'd), we need to set that pages as executable.
Without that, I get following oops on a HP ProLiant DL385 G2
machine with BIOS from 05/29/2008 when I trigger crashdump:
BUG: unable to handle kernel paging request at ffffc20011090c00
IP: [<ffffc20011090c00>] 0xffffc20011090c00
PGD 12f813067 PUD 7fe6a067 PMD 7effe067 PTE 80000000fffd3173
Oops: 0011 [1] SMP
last sysfs file: /sys/devices/system/cpu/cpu3/cache/index2/shared_cpu_map
CPU 1
Modules linked in: autofs4 ipv6 af_packet cpufreq_conservative cpufreq_userspace
cpufreq_powersave powernow_k8 fuse loop dm_mod rtc_cmos ipmi_si sg rtc_core i2c
_piix4 ipmi_msghandler bnx2 sr_mod container button i2c_core hpilo joydev pcspkr
rtc_lib shpchp hpwdt cdrom pci_hotplug usbhid hid ff_memless ohci_hcd ehci_hcd
uhci_hcd usbcore edd ext3 mbcache jbd fan ide_pci_generic serverworks ide_core p
ata_serverworks pata_acpi cciss ata_generic libata scsi_mod dock thermal process
or thermal_sys hwmon
Supported: Yes
Pid: 0, comm: swapper Not tainted 2.6.27.5-HEAD_20081111100657-default #1
RIP: 0010:[<ffffc20011090c00>] [<ffffc20011090c00>] 0xffffc20011090c00
RSP: 0018:ffff88012f6f9e68 EFLAGS: 00010046
RAX: 0000000000000d02 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88012f6f9e98 R08: 666666666666660a R09: ffffffffa1006fc0
R10: 0000000000000000 R11: ffff88012f6f3ea8 R12: ffffc20011090c00
R13: ffff88012f6f9ee8 R14: 000000000000000e R15: 0000000000000000
FS: 00007ff70b29a6f0(0000) GS:ffff88012f6512c0(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: ffffc20011090c00 CR3: 0000000000201000 CR4: 00000000000006e0
Process swapper (pid: 0, threadinfo ffff88012f6f2000, task ffff88007fa8a1c0)
Stack: ffffffffa0f8502b 0000000000000002 ffffffff80738d50 0000000000000000
0000000000000046 0000000000000046 00000000fffffffe ffffffffa0f852ec
0000000000000000 ffffffff804ad9a6 0000000000000000 0000000000000000
Call Trace:
Inexact backtrace:
<NMI> [<ffffffffa0f8502b>] ? asminline_call+0x2b/0x55 [hpwdt]
[<ffffffffa0f852ec>] hpwdt_pretimeout+0x3c/0xa0 [hpwdt]
[<ffffffff804ad9a6>] ? notifier_call_chain+0x29/0x4c
[<ffffffff802587e4>] ? notify_die+0x2d/0x32
[<ffffffff804abbdc>] ? default_do_nmi+0x53/0x1d9
[<ffffffff804abd90>] ? do_nmi+0x2e/0x43
[<ffffffff804ab552>] ? nmi+0xa2/0xd0
[<ffffffff80221ef9>] ? native_safe_halt+0x2/0x3
<<EOE>> [<ffffffff8021345d>] ? default_idle+0x38/0x54
[<ffffffff8021359a>] ? c1e_idle+0x118/0x11c
[<ffffffff8020b3b5>] ? cpu_idle+0xa9/0xf1
Code: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff <55> 50 e8 00 00 00 00 58 48 2d 07 10 40 00 48 8b e8 58 e9 68 02
RIP [<ffffc20011090c00>] 0xffffc20011090c00
RSP <ffff88012f6f9e68>
Kernel panic - not syncing: Fatal exception
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Cc: Alan Cox <alan@redhat.com>
add kdebug support for the hpwdt.c driver.
More coding style clean-up's.
The last clean-up created 2 times the same include. delete the doubles.
Merge branch 'alan' of ../linux-2.6-watchdog-mm
Fixed Conflicts in the following files:
drivers/watchdog/booke_wdt.c
drivers/watchdog/mpc5200_wdt.c
drivers/watchdog/sc1200wdt.c
Signed-off-by: Alan Cox <alan@redhat.com>
Static (read: global) is potential problem. Two threads can corrupt each
other's interrupt status, better avoid this.
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Thomas Mingarelli <thomas.mingarelli@hp.com>
The inline assembly in drivers/watchdog/hpwdt.c was incredibly broken,
and included all the function prologue and epilogue stuff, even though
it was itself then inside a C function where the compiler would add its
own prologue and epilogue on top of it all.
This then just _happened_ to work if you had exactly the right compiler
version and exactly the right compiler flags, so that gcc just happened
to not create any prologue at all (the gcc-generated epilogue wouldn't
matter, since it would never be reached).
But the more proper way to fix it is to simply not do this. Move the
inline asm to the top level, with no surrounding function at all (the
better alternative would be to remove the prologue and make it actually
use proper description of the arguments to the inline asm, but that's a
bigger change than the one I'm willing to make right now).
Tested-by: S.Çağlar Onur <caglar@pardus.org.tr>
The old setup works better.
The driver needs the asmlinkage tag and the CFLAGS line in the Makefile.
Without it the driver doesn't work.
clean-up includes
I need to just return in case it's not my NMI so someone else can take a look
at it (and reset die_nmi_called to 0 in case I actually do get one that's mine
to handle).
This patch makes the needlessly global asminline_call() static and
removes the not required "asmlinkage".
Signed-off-by: Adrian Bunk <bunk@kernel.org>
We can simplify the code by deleting all of the duplicated DMI table
walking code and using the kernel's existing dmi_walk() interface to
find the DMI entry the driver is looking for.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The return value of smbios_scan_machine() is never used, and when it
succeeds it doesn't return anything, so just make it void. This fixes:
drivers/watchdog/hpwdt.c: In function 'smbios_scan_machine':
drivers/watchdog/hpwdt.c:562: warning: control reaches end of non-void function
On my HP DL380 G5 system running a 64-bit kernel, loading the hpwdt
driver causes a crash because the driver attempts to ioremap an
invalid physical address. This is because the driver has an incorrect
definition of the SMBIOS table entry point structure: the table
address is only a 32-bit quantity, and making it a u64 means that the
high-order 32 bits end up containing garbage.
Correcting the structure definition fixes the driver so that it loads
without any problems on my system.
Hp is providing a Hardware WatchDog Timer driver that will only work with the
specific HW Timer located in the HP ProLiant iLO 2 ASIC. The iLO 2 HW Timer
will generate a Non-maskable Interrupt (NMI) 9 seconds before physically
resetting the server, by removing power, so that the event can be logged to
the HP Integrated Management Log (IML), a Non-Volatile Random Access Memory
(NVRAM). The logging of the event is performed using the HP ProLiant ROM via
an Industry Standard access known as a BIOS Service Directory Entry.
