path: root/drivers/watchdog/iTCO_wdt.c
2018-10-02watchdog: iTCO_wdt: Remove unused hooksJean Delvare
As the only user of iTCO_vendor_pre_keepalive and iTCO_vendor_pre_set_heartbeat has just been removed, we can delete these 2 hooks. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Martin Wilck <mwilck@suse.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
2017-09-09watchdog: Revert "iTCO_wdt: all versions count down twice"Wim Van Sebroeck
This reverts commit 1fccb73011ea8a5fa0c6d357c33fa29c695139ea. Reported as Bug 196509 - iTCO_wdt regression reboot before timeout expire Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2017-05-19iTCO_wdt: all versions count down twicePaolo Bonzini
The ICH9 is listed as having TCO v2, and indeed the behavior in the datasheet corresponds to v2 (for example the NO_REBOOT flag is accessible via the 16KiB-aligned Root Complex Base Address). However, the TCO counts twice just like in v1; the documentation of the SECOND_TO_STS bit says: "ICH9 sets this bit to 1 to indicate that the TIMEOUT bit had been (or is currently) set and a second timeout occurred before the TCO_RLD register was written. If this bit is set and the NO_REBOOT config bit is 0, then the ICH9 will reboot the system after the second timeout. The same can be found in the BayTrail (Atom E3800) datasheet, and even HOWTOs around the Internet say that it will reboot after _twice_ the specified heartbeat. I did not find the Apollo Lake datasheet, but because v4/v5 has a SECOND_TO_STS bit just like the previous version I'm enabling this for Apollo Lake as well. Cc: linux-watchdog@vger.kernel.org Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2017-04-28watchdog: iTCO_wdt: Add PMC specific noreboot update apiKuppuswamy Sathyanarayanan
In some SoCs, setting noreboot bit needs modification to PMC GC registers. But not all PMC drivers allow other drivers to memory map their GC region. This could create mem request conflict in watchdog driver. So this patch adds facility to allow PMC drivers to pass noreboot update function to watchdog drivers via platform data. Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-04-28watchdog: iTCO_wdt: cleanup set/unset no_reboot_bit functionsKuppuswamy Sathyanarayanan
iTCO_wdt no_reboot_bit set/unset functions has lot of common code between them. So merging these two functions into a single update function would remove these unnecessary code duplications. This patch fixes this issue by creating a no_reboot_bit update function to handle both set/unset functions. Also checking for iTCO version every time you make no_reboot_bit set/unset call is inefficient and makes the code look complex. This can be improved by performing this check once during device probe and selecting the appropriate no_reboot_bit update function. This patch fixes this issue by splitting the update function into multiple helper functions. Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-02-24watchdog: iTCO_wdt: Replace shutdown function with call to ↵Guenter Roeck
watchdog_stop_on_reboot The shutdown function calls the stop function. Call watchdog_stop_on_reboot() from probe instead. The conversion was done automatically with coccinelle using the following semantic patches. The semantic patches and the scripts used to generate this commit log are available at https://github.com/groeck/coccinelle-patches - Replace shutdown function with call to watchdog_stop_on_reboot() Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2017-02-24watchdog: iTCO_wdt: Simplify module init functionGuenter Roeck
The 'ret' variable in iTCO_wdt_init_module() does not add any value; drop it. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2017-02-24watchdog: iTCO_wdt: Use pdev for platform device and pci_dev for pci deviceGuenter Roeck
Use pdev for struct platform_device, pci_dev for struct pci_dev, and dev for struct device variables to improve consistency. Remove 'struct platform_device *dev;' from struct iTCO_wdt_private since it was unused. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2017-02-24watchdog: iTCO_wdt: Use device managed resourcesGuenter Roeck
Using device managed resources simplifies error handling and cleanup, and to reduce the likelyhood of errors. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2017-02-24watchdog: iTCO_wdt: Use allocated data structuresGuenter Roeck
Allocate private data and the watchdog device to avoid having to clear it on remove and to enable subsequent simplifications. Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-24watchdog: iTCO_wdt: constify iTCO_wdt_pm structureJulia Lawall
iTCO_wdt_pm, of type struct dev_pm_ops, is never modified, so declare it as const. Done with the help of Coccinelle. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-07-17watchdog: iTCO-wdt: handle 5th variation for Apollo LakeYong, Jonathan
The Apollo Lake Watchdog has the no_reboot flag in the 4th bit. Signed-off-by: Yong, Jonathan <jonathan.yong@intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-08-11watchdog: iTCO_wdt: Add support for TCO on Intel SunrisepointMatt Fleming
The revision of the watchdog hardware in Sunrisepoint necessitates a new "version" inside the TCO watchdog driver because some of the register layouts have changed. Also update the Kconfig entry to select both the LPC and SMBus drivers since the TCO device is on the SMBus in Sunrisepoint. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-08-11mfd: watchdog: iTCO_wdt: Expose watchdog properties using platform dataMatt Fleming
Intel Sunrisepoint (Skylake PCH) has the iTCO watchdog accessible across the SMBus, unlike previous generations of PCH/ICH where it was on the LPC bus. Because it's on the SMBus, it doesn't make sense to pass around a 'struct lpc_ich_info', and leaking the type of bus into the iTCO watchdog driver is kind of backwards anyway. This change introduces a new 'struct itco_wdt_platform_data' for use inside the iTCO watchdog driver and by the upcoming Intel Sunrisepoint code, which neatly avoids having to include lpc_ich headers in the i801 i2c driver. This change is overdue because lpc_ich_info has already found its way into other TCO watchdog users, notably the intel_pmc_ipc driver where the watchdog actually isn't on the LPC bus as far as I can see. A simple translation layer is provided for converting from the existing 'struct lpc_ich_info' inside the lpc_ich mfd driver. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Acked-by: Darren Hart <dvhart@linux.intel.com> [drivers/x86 refactoring] Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-04-03PM / watchdog: iTCO: stop watchdog during system suspendRafael J. Wysocki
If the target sleep state of the system is not an ACPI sleep state (S1, S2 or S3), the TCO watchdog needs to be stopped during system suspend, because it may not be possible to ping it any more after timekeeping has been suspended (suspend-to-idle does that for one example). For this reason, provide ->suspend_noirq and ->resume_noirq callbacks for the iTCO watchdog driver and use them to stop and restart the watchdog during system suspend and resume, respectively, if the system is not going to enter an ACPI sleep state (in which case the watchdog will be stopped by the platform firmware before the state is entered). Reported-and-tested-by: Borun Fu <borun.fu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2014-10-20watchdog: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-07Merge tag 'mfd-for-linus-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - Use of managed resources - omap, twl4030, ti_am335x_tscadc - Advanced error handling - omap - Rework clk management - omap - Device Tree (re-)work - tc3589x, pm8921, da9055, sec - IRC management overhaul and !BROKEN - pm8921 - Convert to regmap - ssbi, pm8921 - Use simple power-management ops - ucb1x00 - Include file clean-up - adp5520, cs5535, janz, lpc_ich, - lpc_sch, max14577, mcp-sa11x0, pcf50633-adc, rc5t583, rdc321x-southbridge, retu, smsc-ece1099, ti-ssp, ti_am335x_tscadc, tps65912, vexpress-config, wm8350, ywm8350 - Various bug fixes across the subsystem - NULL/invalid pointer dereference prevention - Resource leak mitigation, - Variable used initialised - Staticise various containers - Enforce return value checks New drivers/supported devices: - Add support for s2mps14 and s2mpa01 to sec - Add support for da9063 (v5) to da9063 - Add support for atom-c2000 to gpio-ich - Add support for come-{mbt10,cbt6,chl6} to kempld - Add support for da9053 to da9052 - Add support for itco-wdt (v3) and baytrail to lpc_ich - Add new drivers for tps65218, rtsx_usb, bcm590xx (Re-)moved drivers: - twl4030 ==> drivers/iio - ti-ssp ==> /dev/null" * tag 'mfd-for-linus-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (103 commits) mfd: wm5110: Correct default for HEADPHONE_DETECT_1 mfd: arizona: Correct small errors in the DT binding documentation mfd: arizona: Mark DSP clocking register as volatile mfd: devicetree: bindings: Add pm8xxx RTC description mfd: kempld-core: Fix potential hang-up during boot mfd: sec-core: Fix uninitialized 'regmap_rtc' on S2MPA01 mfd: tps65910: Fix regmap_irq_chip_data leak on mfd_add_devices fail mfd: tps65910: Fix possible invalid pointer dereference on regmap_add_irq_chip fail mfd: sec-core: Fix I2C dummy device resource leak on probe failure mfd: sec-core: Add of_compatible strings for clock MFD cells mfd: Remove obsolete ti-ssp driver Documentation: mfd: s2mps11: Describe S5M8767 and S2MPS14 clocks mfd: bcm590xx: Fix type argument for module device table mfd: lpc_ich: Add support for Intel Bay Trail SoC mfd: lpc_ich: Add support for NM10 GPIO mfd: lpc_ich: Change Avoton to iTCO v3 watchdog: iTCO_wdt: Add support for v3 silicon mfd: lpc_ich: Add support for iTCO v3 mfd: lpc_ich: Remove lpc_ich_cfg struct use mfd: lpc_ich: Only configure watchdog or GPIO when present ...
2014-03-31watchdog: iTCO_wdt: Fix the parent deviceJean Delvare
The watchdog's parent is iTCO_wdt (the platform device) not lpc_ich (the PCI device.) Setting the parent right makes it much easier for the user to figure out which driver/module is handling the watchdog device node. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-03-31watchdog: fix checkpatch warnings and errorJingoo Han
Fix the following checkpatch warnings and error: WARNING: quoted string split across lines WARNING: braces {} are not necessary for single statement blocks WARNING: __initdata should be placed after ibmasr_id_table[] WARNING: please, no space before tabs ERROR: do not initialise statics to 0 or NULL Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-03-19watchdog: iTCO_wdt: Add support for v3 siliconPeter Tyser
Some new Atom's, eg Avoton and Bay Trail, have slightly different iTCO functionality: - The watchdog timer ticks at 1 second instead of .6 seconds - Some 8 and 16-bit registers were combined into 32-bit registers - Some registers were removed (DAT_IN, DAT_OUT, MESSAGE) - The BOOT_STS field in TCO_STS was removed - The NO_REBOOT bit is in the PMC area instead of GCS Update the driver to support the above changes and bump the version to 1.11. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Rajat Jain <rajatjain@juniper.net> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-11-17watchdog: Get rid of MODULE_ALIAS_MISCDEV statementsJean Delvare
I just can't find any value in MODULE_ALIAS_MISCDEV(WATCHDOG_MINOR) and MODULE_ALIAS_MISCDEV(TEMP_MINOR) statements. Either the device is enumerated and the driver already has a module alias (e.g. PCI, USB etc.) that will get the right driver loaded automatically. Or the device is not enumerated and loading its driver will lead to more or less intrusive hardware poking. Such hardware poking should be limited to a bare minimum, so the user should really decide which drivers should be tried and in what order. Trying them all in arbitrary order can't do any good. On top of that, loading that many drivers at once bloats the kernel log. Also many drivers will stay loaded afterward, bloating the output of "lsmod" and wasting memory. Some modules (cs5535_mfgpt which gets loaded as a dependency) can't even be unloaded! If defining char-major-10-130 is needed then it should happen in user-space. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Zwane Mwaikambo <zwane@arm.linux.org.uk> Cc: Jim Cromie <jim.cromie@gmail.com>
2013-11-17watchdog: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-11-28watchdog: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-16mfd: lpc_ich: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
This patch adds the Watchdog Timer Device IDs for the Intel Lynx Point-LP PCH. The Device IDs are defined in drivers/mfd/lpc_ich.c Signed-off-by: James Ralston <james.d.ralston@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-23watchdog: iTCO_wdt.c: convert to watchdog coreWim Van Sebroeck
This patch converts the iTCO_wdt watchdog driver to use the generic watchdog framework. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-06-28watchdog: iTCO_wdt: add platform driver module aliasJan Beulich
The recent conversion of iTCO_wdt resulted in the driver no longer getting loaded automatically, since it no longer has a MODULE_DEVICE_TABLE() included. As the lpc_ich driver now creates a platform device, auto-loading can easily be done by having a respective module alias in place. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Aaron Sierra <asierra@xes-inc.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-05-30watchdog: iTCO_wdt.c: fix printk format warningsRandy Dunlap
Fix printk format warnings: drivers/watchdog/iTCO_wdt.c:577:3: warning: format '%04llx' expects type 'long long unsigned int', but argument 2 has type 'resource_size_t' drivers/watchdog/iTCO_wdt.c:594:3: warning: format '%04llx' expects type 'long long unsigned int', but argument 2 has type 'resource_size_t' drivers/watchdog/iTCO_wdt.c:600:2: warning: format '%04llx' expects type 'long long unsigned int', but argument 4 has type 'resource_size_t' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-05-09watchdog: Convert iTCO_wdt driver to mfd modelAaron Sierra
This patch converts the iTCO_wdt driver to use the multi-function device driver model. It uses resources discovered by the lpc_ich driver, so that it no longer does its own PCI scanning. Signed-off-by: Aaron Sierra <asierra@xes-inc.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-01-27watchdog: iTCO_wdt: add Intel Lynx Point DeviceIDsSeth Heasley
This patch adds the TCO Watchdog DeviceIDs for the Intel Lynx Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-12-27watchdog: iTCO_wdt.c - problems with newer hardware due to SMI clearing (part 2)Wim Van Sebroeck
Redhat Bugzilla: Bug 727875 - TCO_EN bit is disabled by TCO driver The previous patch breaks reset watchdog behaviour on the older hardware. It is therefor better to make sure that the behaviour for older hardware (<=ICH5 or 6300ESB) is preserved and that the behaviour for newer hardware is changed. We therefor use the iTCO_version to see if we need the clearing of the SMI_TCO_EN bit in the SMI_EN register. So the new behaviour becomes: turn_SMI_watchdog_clear_off=0 -> Do not turn off SMI clearing watchdog. turn_SMI_watchdog_clear_off=1 -> Turn off SMI clearing watchdog when iTCO_version=1 (ICHO till ICH5 + 6300ESB only) turn_SMI_watchdog_clear_off=2 -> Turn off SMI clearing watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-11-05watchdog: iTCO_wdt.c - problems with newer hardware due to SMI clearingWim Van Sebroeck
Redhat Bugzilla: Bug 727875 - TCO_EN bit is disabled by TCO driver Jiri Slaby: 28d41f53f broke temperature sensors on a ICH10 chipset The iTCO_wdt driver disables the SMI. This breaks good working of newer hardware. The disabling of the SMI by the TCO logic dates back from the i810-tco driver from Nils Faerber (around 28 July 2000). The reason for this was that some BIOSes install handlers reset or disable the watchdog timer instead of resetting the system. The trick to fix this was to disable the SMI (by clearing the SMI_TCO_EN bit of the SMI_EN register) to prevent this from happening. This however has strange effects on newer hardware. So we are in a situation that a fix for broken old hardware affects newer hardware. The correct solution is to make this fix an option (with the new module parameter: turn_SMI_watchdog_clear_off) so that the default behaviour is the unfixed version. the next patch will be to move this in the start and stop functions of the driver and to add a new module parameter for the global_smi_en bit and to get rid of the vendor_support code. This fix can have an effect on old (typical ICH & ICH2 chipsets) motherboards that have a broken BIOS implementation concerning TCO logic. In these case the module parameter turn_SMI_watchdog_clear_off=1 will need to be added. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: remove empty pm-functionsWolfram Sang
While checking what watchdog drivers usually do in suspend/resume to spot common behaviour for the watchdog framework, I found these drivers which do nothing but add some cruft. Remove it, it is superfluous. New approaches should probably be done with pm_ops anyway. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: iTCO_wdt: clean-up PCI device ID'sWim Van Sebroeck
Clean up of the iTCO_wdt PCI device ID's. Own macro is replaced by the PCI_VDEVICE macro. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-04-26watchdog: iTCO_wdt: TCO Watchdog patch for Intel Panther Point PCHSeth Heasley
This patch adds the TCO Watchdog DeviceIDs for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: cleanup spaces before tabsWim Van Sebroeck
cleanup spaces before tabs in drivers/watchdog/ Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: convert to DEFINE_PCI_DEVICE_TABLEWim Van Sebroeck
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-01-12watchdog: iTCO_wdt: TCO Watchdog patch for Intel DH89xxCC PCHSeth Heasley
This patch adds the DeviceIDs for TCO Watchdog on the Intel DH89xxCC PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-01-12watchdog: iTCO_wdt: TCO Watchdog patch for Intel NM10 DeviceIDsWim Van Sebroeck
This patch adds the Intel NM10 DeviceIDs for iTCO Watchdog. Reported-by: Dan Weinlader <dan@weinlader.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-12-02watchdog: iTCO_wdt: TCO Watchdog patch for Intel Patsburg PCHSeth Heasley
This patch adds an additional LPC Controller DeviceID for the Intel Patsburg PCH for TCO Watchdog. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-28watchdog: iTCO_wdt.c: remove extra pci_dev_put()'s from init codePrarit Bhargava
The iTCO_wdt driver erroneously releases the pci_dev, and causes PCI hotremove to fail because of an incorrect usage count. The probe for this driver does a for_each_pci_dev() which gets a reference for a pci_dev when iTCO_wdt_init() is successful. The for_each_pci_dev() loop puts a reference for a pci_dev when iTCO_wdt_init() fails, so the iTCO_wdt_init() does not need to do any pci_dev_put()'s. The only pci_dev_put() that is required is in the iTCO_wdt_cleanup() function. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-28watchdog: iTCO_wdt: Cleanup warning messagesPrarit Bhargava
The current iTCO_wdt driver warnings are confusing. Currently when the device driver returns an error the console contains: iTCO_vendor_support: vendor-support=0 iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05 iTCO_wdt: failed to reset NO_REBOOT flag, reboot disabled by hardware iTCO_wdt: No card detected After the patch, iTCO_vendor_support: vendor-support=0 iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05 iTCO_wdt: failed to reset NO_REBOOT flag, device disabled by hardware/BIOS Clean this up and use the word "device" to describe the device. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-28watchdog: iTCO_wdt: TCO Watchdog patch for Intel Patsburg DeviceIDsSeth Heasley
This patch adds the Intel Patsburg (PCH) DeviceIDs for iTCO Watchdog. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25iTCO_wdt: fix TCO V1 timeout values and limitsPádraig Brady
For TCO V1 devices the programmed timeout was twice too long because the fact that the TCO V1 timer needs to count down twice before triggering the watchdog, wasn't accounted for. Also the timeout values in the module description and error message were clarified. And the _STS registers are 16 bit instead of 8 bit. Signed-off-by: Pádraig Brady <P@draigBrady.com> Tested-by: Simon Kagstrom <simon.kagstrom@netinsight.se> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-06[WATCHDOG] iTCO_wdt: TCO Watchdog patch for additional Intel Cougar Point ↵Seth Heasley
DeviceIDs This patch adds the Intel Cougar Point PCH LPC Controller DeviceIDs for iTCO Watchdog. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] iTCO_wdt: clean up probe(), modify err msgNaga Chumbalkar
It's possible that the platform is not allowing reboot via TCO timer expiration. Also, differentiate between not finding a chipset that has TCO, and the case where TCO is present but the driver fails to initialize for some reason. Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
