path: root/drivers/watchdog/it8712f_wdt.c
2011-07-26watchdog: it8712f_wdt.c: improve includesWim Van Sebroeck
remove unneeded pci.h include. and include ioport.h to avoid build errors for the region functions. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: Use "request_muxed_region" in it87 watchdog driversNat Gurumoorthy
Changes the it87 watchdog drivers to use "request_muxed_region". Serialize access to the hardware by using "request_muxed_region" macro defined by Alan Cox. Call to this macro will hold off the requestor if the resource is currently busy. The use of the above macro makes it possible to get rid of spinlocks in it8712f_wdt.c and it87_wdt.c watchdog drivers. This also greatly simplifies the implementation of it87_wdt.c driver. "superio_enter" will return an error if call to "request_muxed_region" fails. Rest of the code change is to ripple an error return from superio_enter to the top level. Signed-off-by: Nat Gurumoorthy <natg@google.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: cleanup spaces before tabsWim Van Sebroeck
cleanup spaces before tabs in drivers/watchdog/ Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-28watchdog: it8712f_wdt: Add module parameter for alternative reset sourcesTimo Juhani Lindfors
On iEi PCISA-9652-R10 (BIOS version 1.5) single board computer reads from the game port do not seem to reset the watchdog timer. This patch adds a module parameter wdt_config_reg to specify alternative reset sources. At least WDT_RESET_KBD has been tested, even just running while true; do setleds -L +scroll sleep 1 setleds -L -scroll sleep 1 done is enough to keep the watchdog happy. Signed-off-by: Timo Juhani Lindfors <timo.lindfors@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-28 watchdog: it8712f_wdt: Add comments for config/control register namesTimo Juhani Lindfors
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-18[WATCHDOG] Correct WDIOF_MAGICCLOSE flagWim Van Sebroeck
Make sure that when the WDIOF_MAGICCLOSE flag is set we also support the magic-close feature... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-04it8712f_wdt: Locking and coding styleAlan Cox
Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-06[WATCHDOG] it8712f_wdt Zero MSB timeout byte when disabling watchdogAndrew Paprocki
I noticed this while testing the latest code. I'm not sure if it is required, but the normal (or LSB) timeout value is set to zero, so the MSB should be as well to stay consistent. If the chip revision is >= 8, set MSB of the 16-bit timeout value to zero when disabling the watchdog in it8712f_wdt_disable(). Signed-off-by: Andrew Paprocki <andrew@ishiboo.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-04-01[WATCHDOG] Fix it8712f_wdt.c wrong byte order accessing WDT_TIMEOUTOliver Schuster
This patch corrects an error in the driver it8712f_wdt. You cannot set the 16-bit WDT_TIMEOUT access as a 16-bit outw, because the byte ordering will be wrong. So just do the high 8 bits as a separate access. Signed-off-by: Oliver Schuster <olivers137@aol.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-06[WATCHDOG] it8712f_wdt support for 16-bit timeout values, WDIOC_GETSTATUSAndrew Paprocki
This patch adds support for 16-bit watchdog timeout values which are available in chip revisions >= 0x08. Values <= 65535 are seconds precision, otherwise minutes precision is used up to a maximum value of 3932100. Added implementation for WDIOC_GETSTATUS which checks the WDT status bit in the WDT control register. Signed-off-by: Andrew Paprocki <andrew@ishiboo.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-01-25[WATCHDOG] constify function pointer tablesJan Engelhardt
"static struct file_operations" should be "static const struct file_operations". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-11-19[WATCHDOG] IT8212F watchdog driverJorge Boncompte [DTI2]
This patch adds support for the ITE Tech Inc. IT8712F EC-LPC Super I/O chipset found on many Pentium III and AMD motherboards. Developed using code from other watchdog drivers and the datasheet on ITE Tech homepage. Signed-off-by: Jorge Boncompte <jorge@dti2.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
