path: root/drivers/watchdog/shwdt.c
2011-08-02watchdog: shwdt: fix usage of mod_timerDavid Engraf
Fix the usage of mod_timer() and make the driver usable. mod_timer() must be called with an absolute timeout in jiffies. The old implementation used a relative timeout thus the hardware watchdog was never triggered. Signed-off-by: David Engraf <david.engraf@sysgo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Wim Van sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org>
2011-01-26Merge branches 'sh/wdt', 'sh/pci-express-async' and 'common/serial-rework' ↵Paul Mundt
into sh-latest
2010-05-25watchdog: shwdt: driver model conversion.Paul Mundt
This is a long overdue driver model conversion for the shwdt watchdog driver. This is the initial conversion, more incremental changes to follow. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-25watchdog: fix several MODULE_PARM_DESC stringsRandy Dunlap
Fix MODULE_PARM_DESC() strings in several watchdog drivers. Some are simple as add a parenthesis. Others are problems from __stringify() being used on a variable name instead of a macro name, so the variable name is produced in the string instead of its build-time value. In these cases, create a macro for the value so that the module param description string is useful. Only pc87413_wdt has been built (due to toolchains). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: shwdt: Kill off mmap stub and superfluous comments.Paul Mundt
The wdt mmaping thing was a special-cased hack that nothing in the wild depends on, so just kill it off. While at it, sanitize the superfluous comments in preparation for a driver rewrite and overhauled interface. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-18[WATCHDOG] Some more general cleanupWim Van Sebroeck
Clean-up the watchdog drivers so that checkpatch.pl get's happy... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-10[WATCHDOG] fix watchdog/shwdt.c compilationAdrian Bunk
This patch fixes the following compile errors caused by commit 70b814ec1a484279a51bf9f7193551b996627247 ([WATCHDOG 45/57] shwdt: coding style, cleanup, switch to unlocked_io): <-- snip --> ... CC drivers/watchdog/shwdt.o shwdt.c:64: error: 'WTCSR_CKS_4096' undeclared here (not in a function) shwdt.c: In function 'sh_wdt_start': shwdt.c:92: error: 'wdt_lock' undeclared (first use in this function) shwdt.c:92: error: (Each undeclared identifier is reported only once shwdt.c:92: error: for each function it appears in.) shwdt.c:97: error: implicit declaration of function 'sh_wdt_read_csr' shwdt.c:98: error: 'WTCSR_WT' undeclared (first use in this function) shwdt.c:99: error: implicit declaration of function 'sh_wdt_write_csr' shwdt.c:101: error: implicit declaration of function 'sh_wdt_write_cnt' shwdt.c:112: error: 'WTCSR_TME' undeclared (first use in this function) shwdt.c:113: error: 'WTCSR_RSTS' undeclared (first use in this function) shwdt.c: In function 'sh_wdt_stop': shwdt.c:142: error: 'wdt_lock' undeclared (first use in this function) shwdt.c:147: error: 'WTCSR_TME' undeclared (first use in this function) shwdt.c: In function 'sh_wdt_keepalive': shwdt.c:160: error: 'wdt_lock' undeclared (first use in this function) shwdt.c: In function 'sh_wdt_set_heartbeat': shwdt.c:176: error: 'wdt_lock' undeclared (first use in this function) shwdt.c: In function 'sh_wdt_ping': shwdt.c:192: error: 'wdt_lock' undeclared (first use in this function) shwdt.c:197: error: 'WTCSR_IOVF' undeclared (first use in this function) shwdt.c: At top level: shwdt.c:417: error: conflicting type qualifiers for 'sh_wdt_info' shwdt.c:71: error: previous declaration of 'sh_wdt_info' was here make[3]: *** [drivers/watchdog/shwdt.o] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-06-21[WATCHDOG 45/57] shwdt: coding style, cleanup, switch to unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-03-06[WATCHDOG] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-02-03drivers/watchdog/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
