path: root/drivers/watchdog/w83697hf_wdt.c
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-18[WATCHDOG] Some more general cleanupWim Van Sebroeck
Clean-up the watchdog drivers so that checkpatch.pl get's happy... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-06-21[WATCHDOG 50/57] w83697hf_wdt: cleanup, coding style and switch to ↵Alan Cox
unlocked_ioctl Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Add w83697h_wdt early_disable optionSamuel Tardieu
Pádraig Brady requested the possibility of not disabling the watchdog at module load time or kernel boot time if it had been previously enabled in the bios. It may help rebooting the machine if it freezes before the userland daemon kicks in. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Cc: Pádraig Brady <P@draigBrady.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Make w83697h_wdt timeout option string similar to othersSamuel Tardieu
Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Make w83697h_wdt void-like functions voidSamuel Tardieu
Some non-exported functions always returned 0. Mark them void instead. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-01-18[WATCHDOG] Revert "Stop looking for device as soon as one is found"Wim Van Sebroeck
This reverts commit 3ff6eb4a2fe5757cbe7c5d57c8eb60ab0775f2f0. the !found check in the for loop allready made sure that only one device was found. Signed-Off-By: Pádraig Brady <P@draigBrady.com> Signed-Off-By: Wim Van Sebroeck <wim@iguana.be>
2007-11-19[WATCHDOG] Stop looking for device as soon as one is foundSamuel Tardieu
If no address is given for the W83697HF/HG watchdog IO port, stop looping through possible locations when a watchdog device has been found. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-11-02[WATCHDOG] spin_lock_init() fixesAlexey Dobriyan
Some watchdog drivers initialize global spinlocks in module's init function which is tolerable, but some do it in PCI probe function. So, switch to static initialization to fix theoretical bugs and, more importantly, stop giving people bad examples. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
