path: root/drivers/watchdog
2013-01-02watchdog: twl4030_wdt: add DT supportAaro Koskinen
Add DT support for twl4030_wdt. This is needed to get twl4030_wdt to probe when booting with DT. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-01-02watchdog: omap_wdt: eliminate unused variable and a compiler warningAaro Koskinen
We forgot to delete this in the commit 4f4753d9 (watchdog: omap_wdt: convert to devm_ functions), and as a result the following compilation warning was introduced: drivers/watchdog/omap_wdt.c: In function 'omap_wdt_remove': drivers/watchdog/omap_wdt.c:299:19: warning: unused variable 'res' [-Wunused-variable] Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Reviewed-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-01-02watchdog: da9055: Don't update wdt_dev->timeout in da9055_wdt_set_timeout ↵Axel Lin
error path Otherwise, WDIOC_GETTIMEOUT returns wrong value if set_timeout fails. This patch also removes unnecessary ret variable in da9055_wdt_ping function. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-01-02watchdog: da9055: Fix invalid free of devm_ allocated dataAxel Lin
It is not required to free devm_ allocated data. Since kref_put needs a valid release function, da9055_wdt_release_resources() is not deleted. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: Orion: Fix possible null-deference in orion_wdt_probeJason Gunthorpe
If the DT does not include a regs parameter then the null res would be dereferenced. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: sp5100_tco: Add SB8x0 chipset supportTakahisa Tanaka
The current sp5100_tco driver only supports SP5100/SB7x0 chipset, doesn't support SB8x0 chipset, because current sp5100_tco driver doesn't know that the offset address for watchdog timer was changed from SB8x0 chipset. The offset address of SP5100 and SB7x0 chipsets are as follows, quote from the AMD SB700/710/750 Register Reference Guide (Page 164) and the AMD SP5100 Register Reference Guide (Page 166). WatchDogTimerControl 69h WatchDogTimerBase0 6Ch WatchDogTimerBase1 6Dh WatchDogTimerBase2 6Eh WatchDogTimerBase3 6Fh In contrast, the offset address of SB8x0 chipset is as follows, quote from AMD SB800-Series Southbridges Register Reference Guide (Page 147). WatchDogTimerEn 48h WatchDogTimerConfig 4Ch So, In the case of SB8x0 chipset, sp5100_tco reads meaningless MMIO address (for example, 0xbafe00) from wrong offset address, and the following message is logged. SP5100 TCO timer: mmio address 0xbafe00 already in use With this patch, sp5100_tco driver supports SB8x0 chipset, and can avoid iomem resource conflict. The processing of this patch is as follows. Step 1) Attempt to get the watchdog base address from indirect I/O (0xCD6 and 0xCD7). - Go to the step 7 if obtained address hasn't conflicted with other resource. But, currently, the address (0xfec000f0) conflicts with the IOAPIC MMIO address, and the following message is logged. SP5100 TCO timer: mmio address 0xfec000f0 already in use 0xfec000f0 is recommended by AMD BIOS Developer's Guide. So, go to the next step. Step 2) Attempt to get the SBResource_MMIO base address from AcpiMmioEN (for SB8x0, PM_Reg:24h) or SBResource_MMIO (SP5100/SB7x0, PCI_Reg:9Ch) register. - Go to the step 7 if these register has enabled by BIOS, and obtained address hasn't conflicted with other resource. - If above condition isn't true, go to the next step. Step 3) Attempt to get the free MMIO address from allocate_resource(). - Go to the step 7 if these register has enabled by BIOS, and obtained address hasn't conflicted with other resource. - Driver initialization has failed if obtained address has conflicted with other resource, and no 'force_addr' parameter is specified. Step 4) Use the specified address If 'force_addr' parameter is specified. - allocate_resource() function may fail, when the PCI bridge device occupies iomem resource from 0xf0000000 to 0xffffffff. To handle such a case, I added 'force_addr' parameter to sp5100_tco driver. With 'force_addr' parameter, sp5100_tco driver directly can assign MMIO address for watchdog timer from free iomem region. Note that It's dangerous to specify wrong address in the 'force_addr' parameter. Example of force_addr parameter use # cat /proc/iomem ...snip... fec00000-fec003ff : IOAPIC 0 <--- free MMIO region fec10000-fec1001f : pnp 00:0b fec20000-fec203ff : IOAPIC 1 ...snip... # cat /etc/modprobe.d/sp5100_tco.conf options sp5100_tco force_addr=0xfec00800 # modprobe sp5100_tco # cat /proc/iomem ...snip... fec00000-fec003ff : IOAPIC 0 fec00800-fec00807 : SP5100 TCO <--- watchdog timer MMIO address fec10000-fec1001f : pnp 00:0b fec20000-fec203ff : IOAPIC 1 ...snip... # - Driver initialization has failed if specified address has conflicted with other resource. Step 5) Disable the watchdog timer - To rewrite the watchdog timer register of the chipset, absolutely guarantee that the watchdog timer is disabled. Step 6) Re-program the watchdog timer MMIO address to chipset. - Re-program the obtained MMIO address in Step 3 or Step 4 to chipset via indirect I/O (0xCD6 and 0xCD7). Step 7) Enable and setup the watchdog timer This patch has worked fine on my test environment (ASUS M4A89GTD-PRO/USB3 and DL165G7). therefore I believe that it's no problem to re-program the MMIO address for watchdog timer to chipset during disabled watchdog. However, I'm not sure about it, because I don't know much about chipset programming. So, any comments will be welcome. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43176 Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Tested-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Takahisa Tanaka <mc74hc00@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: davinci_wdt: add OF supportMurali Karicheri
This adds OF support for davinci_wdt driver. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: da9052: Fix invalid free of devm_ allocated dataTushar Behera
It is not required to free devm_ allocated data. Since kref_put needs a valid release function, da9052_wdt_release_resources() is not deleted. Fixes following warning. drivers/watchdog/da9052_wdt.c:59:1-6: WARNING: invalid free of devm_ allocated data Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to ↵Peter Ujfalusi
TWL_MODULE_PM_RECEIVER To facilitate upcoming cleanup in twl stack. No functional changes. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>(Joe Perches
dev_<level> calls take less code than dev_printk(KERN_<LEVEL> and reducing object size is good. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: DA9055 Watchdog driverAshish Jangam
This is the Watchdog patch for the DA9055 PMIC. This patch has got dependency on the DA9055 MFD core. This patch is functionally tested on SMDK6410 Signed-off-by: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: omap_wdt: eliminate gotoAaro Koskinen
Eliminate a goto to simplify the code. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: omap_wdt: delete redundant platform_set_drvdata() callsAaro Koskinen
It's not needed to manually reset the driver data. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: omap_wdt: convert to devm_ functionsAaro Koskinen
Use devm_kzalloc(), devm_request_mem_region() ande devm_ioremap() to simplify the code. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: omap_wdt: convert to new watchdog coreAaro Koskinen
Convert omap_wdt to new watchdog core. On OMAP boards, there are usually multiple watchdogs. Since the new watchdog core supports multiple watchdogs, all watchdog drivers used on OMAP should be converted. The legacy watchdog device node is still created, so this should not break existing users. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Tested-by: Jarkko Nikula <jarkko.nikula@jollamobile.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepareThomas Abraham
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare calls as required by common clock framework. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: imx2_wdt: Select the driver via ARCH_MXCFabio Estevam
With device tree support in place, we should not use IMX_HAVE_PLATFORM_IMX2_WDT as a dependency for selecting the imx2_wdt driver. Use ARCH_MXC symbol instead, so that the driver can be even selected by a device-tree only SoC, such as i.MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: cpu5wdt.c: add missing del_timer calldevendra.aaru
We do a setup_timer at init stage of the module, but we didn't de-activate the time using del_timer. Signed-off-by: devendra.aaru <devendra.aaru@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: hpwdt.c: Increase version stringTom Mingarelli
Changing the version of the driver for all the latest patches being applied for kdump fixes. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: Convert twl4030_wdt to watchdog coreJarkko Nikula
Convert the twl4030_wdt watchdog driver to watchdog core. While at there use devm_kzalloc and set the default timeout in order to be able test this driver with a simple shell script. Signed-off-by: Jarkko Nikula <jarkko.nikula@jollamobile.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19davinci_wdt: preparation for switch to common clock frameworkKaricheri, Muralidharan
As a first step towards migrating davinci platforms to use common clock framework, replace all instances of clk_enable() with clk_prepare_enable() and clk_disable() with clk_disable_unprepare(). Until the platform is switched to use the CONFIG_HAVE_CLK_PREPARE Kconfig variable, this just adds a might_sleep() call and would work without any issues. This will make it easy later to switch to common clk based implementation of clk driver from DaVinci specific driver. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: sp805_wdt.c: use clk_prepare_enable and clk_disable_unprepareJulia Lawall
Clk_prepare_enable and clk_disable_unprepare combine clk_prepare and clk_enable, and clk_disable and clk_unprepare. They make the code more concise, and ensure that clk_unprepare is called when clk_enable fails. A simplified version of the semantic patch that introduces calls to these functions is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e; @@ - clk_prepare(e); - clk_enable(e); + clk_prepare_enable(e); @@ expression e; @@ - clk_disable(e); - clk_unprepare(e); + clk_disable_unprepare(e); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-19watchdog: ath79_wdt: convert to use module_platform_driverGabor Juhos
This makes the code a bit smaller by getting rid of some boilerplate code. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13Merge tag 'pm-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC power management and clock changes from Olof Johansson: "This branch contains a largeish set of updates of power management and clock setup. The bulk of it is for OMAP/AM33xx platforms, but also a few around hotplug/suspend/resume on Exynos. It includes a split-up of some of the OMAP clock data into separate files which adds to the diffstat, but gross delta is fairly reasonable." * tag 'pm-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: OMAP: Move plat-omap/dma-omap.h to include/linux/omap-dma.h ASoC: OMAP: mcbsp fixes for enabling ARM multiplatform support watchdog: OMAP: fixup for ARM multiplatform support ARM: EXYNOS: Add flush_cache_all in suspend finisher ARM: EXYNOS: Remove scu_enable from cpuidle ARM: EXYNOS: Fix soft reboot hang after suspend/resume ARM: EXYNOS: Add support for rtc wakeup ARM: EXYNOS: fix the hotplug for Cortex-A15 ARM: OMAP2+: omap_device: Correct resource handling for DT boot ARM: OMAP2+: hwmod: Add possibility to count hwmod resources based on type ARM: OMAP2+: hwmod: Add support for per hwmod/module context lost count ARM: OMAP2+: PRM: initialize some PRM functions early ARM: OMAP2+: voltage: fixup oscillator handling when CONFIG_PM=n ARM: OMAP4: USB: power down MUSB PHY during boot ARM: OMAP2+: clock: Cleanup !CONFIG_COMMON_CLK parts ARM: OMAP2xxx: clock: drop obsolete clock data ARM: OMAP2: clock: Cleanup !CONFIG_COMMON_CLK parts ARM: OMAP3+: DPLL: drop !CONFIG_COMMON_CLK sections ARM: AM33xx: clock: drop obsolete clock data ARM: OMAP3xxx: clk: drop obsolete clock data ...
2012-12-13Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree conversions and enablement from Olof Johansson: "Continued device tree conversion and enablement across a number of platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other smaller series as well. ux500 has seen continued conversion for platforms. Several platforms have seen pinctrl-via-devicetree conversions for simpler multiplatform. Tegra is adding data for new devices/drivers, and Exynos has a bunch of new bindings and devices added as well. So, pretty much the same progression in the right direction as the last few releases." Fix up conflicts as per Olof. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits) ARM: ux500: Rename dbx500 cpufreq code to be more generic ARM: dts: add missing ux500 device trees ARM: ux500: Stop registering the PCM driver from platform code ARM: ux500: Move board specific GPIO info out to subordinate DTS files ARM: ux500: Disable the MMCI gpio-regulator by default ARM: Kirkwood: remove kirkwood_ehci_init() from new boards ARM: Kirkwood: Add support LED of OpenBlocks A6 ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6 ARM: kirkwood: Add NAND partiton map for OpenBlocks A6 ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6 ARM: kirkwood: Add support DT of second I2C bus ARM: kirkwood: Convert mplcec4 board to pinctrl ARM: Kirkwood: Convert km_kirkwood to pinctrl ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl ARM: Kirkwood: Convert IX2-200 to pinctrl. ARM: Kirkwood: Convert lsxl boards to pinctrl. ARM: Kirkwood: Convert ib62x0 to pinctrl. ARM: Kirkwood: Convert GoFlex Net to pinctrl. ARM: Kirkwood: Convert dreamplug to pinctrl. ARM: Kirkwood: Convert dockstar to pinctrl. ...
2012-12-12Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups on various subarchitectures from Olof Johansson: "Cleanup patches for various ARM platforms and some of their associated drivers. There's also a branch in here that enables Freescale i.MX to be part of the multiplatform support -- the first "big" SoC that is moved over (more multiplatform work comes in a separate branch later during the merge window)." Conflicts fixed as per Olof, including a silent semantic one in arch/arm/mach-omap2/board-generic.c (omap_prcm_restart() was renamed to omap3xxx_restart(), and a new user of the old name was added). * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (189 commits) ARM: omap: fix typo on timer cleanup ARM: EXYNOS: Remove unused regs-mem.h file ARM: EXYNOS: Remove unused non-dt support for dwmci controller ARM: Kirkwood: Use hw_pci.ops instead of hw_pci.scan ARM: OMAP3: cm-t3517: use GPTIMER for system clock ARM: OMAP2+: timer: remove CONFIG_OMAP_32K_TIMER ARM: SAMSUNG: use devm_ functions for ADC driver ARM: EXYNOS: no duplicate mask/unmask in eint0_15 ARM: S3C24XX: SPI clock channel setup is fixed for S3C2443 ARM: EXYNOS: Remove i2c0 resource information and setting of device names ARM: Kirkwood: checkpatch cleanups ARM: Kirkwood: Fix sparse warnings. ARM: Kirkwood: Remove unused includes ARM: kirkwood: cleanup lsxl board includes ARM: integrator: use BUG_ON where possible ARM: integrator: push down SC dependencies ARM: integrator: delete static UART1 mapping ARM: integrator: delete SC mapping on the CP ARM: integrator: remove static CP syscon mapping ARM: integrator: remove static AP syscon mapping ...
2012-12-12Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Here's the updates for ARM for this merge window, which cover quite a variety of areas. There's a bunch of patch series from Will tackling various bugs like the PROT_NONE handling, ASID allocation, cluster boot protocol and ASID TLB tagging updates. We move to a build-time sorted exception table rather than doing the sorting at run-time, add support for the secure computing filter, and some updates to the perf code. We also have sorted out the placement of some headers, fixed some build warnings, fixed some hotplug problems with the per-cpu TWD code." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (73 commits) ARM: 7594/1: Add .smp entry for REALVIEW_EB ARM: 7599/1: head: Remove boot-time HYP mode check for v5 and below ARM: 7598/1: net: bpf_jit_32: fix sp-relative load/stores offsets. ARM: 7595/1: syscall: rework ordering in syscall_trace_exit ARM: 7596/1: mmci: replace readsl/writesl with ioread32_rep/iowrite32_rep ARM: 7597/1: net: bpf_jit_32: fix kzalloc gfp/size mismatch. ARM: 7593/1: nommu: do not enable DCACHE_WORD_ACCESS when !CONFIG_MMU ARM: 7592/1: nommu: prevent generation of kernel unaligned memory accesses ARM: 7591/1: nommu: Enable the strict alignment (CR_A) bit only if ARCH < v6 ARM: 7590/1: /proc/interrupts: limit the display of IPIs to online CPUs only ARM: 7587/1: implement optimized percpu variable access ARM: 7589/1: integrator: pass the lm resource to amba ARM: 7588/1: amba: create a resource parent registrator ARM: 7582/2: rename kvm_seq to vmalloc_seq so to avoid confusion with KVM ARM: 7585/1: kernel: fix nr_cpu_ids check in DT logical map init ARM: 7584/1: perf: fix link error when CONFIG_HW_PERF_EVENTS is not selected ARM: gic: use a private mapping for CPU target interfaces ARM: kernel: add logical mappings look-up ARM: kernel: add cpu logical map DT init in setup_arch ARM: kernel: add device tree init map function ...
2012-11-30Merge tag 'tags/omap-for-v3.8/cleanup-multiplatform-no-clock-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/pm2 From Tony Lindgren: Remaining patches to allow omap2+ to build with multiplatform enabled. Unfortunately the DMA header patch had to be redone to avoid adding new multiplatform specific include paths, the other patches are just trivial compile fixes. Note that this does not yet contain the necessary Kconfig changes as we are still waiting for some drivers to get fixed up first. * tag 'tags/omap-for-v3.8/cleanup-multiplatform-no-clock-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP: Move plat-omap/dma-omap.h to include/linux/omap-dma.h ASoC: OMAP: mcbsp fixes for enabling ARM multiplatform support watchdog: OMAP: fixup for ARM multiplatform support Conflicts due to surrounding changes in: arch/arm/mach-omap2/omap_hwmod_2420_data.c arch/arm/mach-omap2/omap_hwmod_2430_data.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-30watchdog: OMAP: fixup for ARM multiplatform supportTony Lindgren
Recent changes to the omap_wdt.c removed the dependencies to the core omap code, but forgot to remove mach/hardware.h. We cannot include any plat headers with multiplatform support enabled. cc: Wim Van Sebroeck <wim@iguana.be> cc: linux-watchdog@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-11-28watchdog: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-20Merge tag 'at91-for-next-dt' of git://github.com/at91linux/linux-at91 into ↵Olof Johansson
next/dt From Nicolas Ferre: More DT material for AT91: - conversion of watchdog to DT - usart definition for evk-pro3 board * tag 'at91-for-next-dt' of git://github.com/at91linux/linux-at91: ARM: at91/dts: evk-pro3: enable watchdog ARM: at91/dts: add at91sam9_wdt driver to at91sam926x, at91sam9g45 watchdog: at91sam9_wdt: add device tree support ARM: at91: dt: evk-pro3: enable uart0 and uart2
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-16Merge tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6 into next/dtArnd Bergmann
From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX dt updates for 3.8 * tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6: Add device tree file for the armadeus apf27 ARM i.MX: Add Ka-Ro TX25 devicetree ARM i.MX25: Add devicetree ARM i.MX25: Add devicetree support ARM i.MX25: Add missing clock gates Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-16watchdog: at91sam9_wdt: add device tree supportFabio Porcedda
Tested on an at91sam9260 board (evk-pro3) Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-15Merge tag 'omap-for-v3.8/cleanup-prcm-part2-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren <tony@atomide.com>: More PRCM cleanups via Paul Walmsley <paul@pwsan.com>: Second set of OMAP PRCM cleanups for 3.8. These patches remove the use of omap_prcm_get_reset_sources() from the OMAP watchdog driver, and remove mach-omap2/prcm.c and plat-omap/include/plat/prcm.h. Basic test logs for this branch on top of Tony's cleanup-prcm branch at commit 7fc54fd3084457c7f11b9e2e1e3fcd19a3badc33 are here: http://www.pwsan.com/omap/testlogs/prcm_cleanup_b_3.8/20121108151646/ However, cleanup-prcm at 7fc54fd3 does not include some fixes that are needed for a successful test. With several reverts, fixes, and workarounds applied, the following test logs were obtained: http://www.pwsan.com/omap/testlogs/TEST_prcm_cleanup_b_3.8/20121108151930/ which indicate that the series tests cleanly. This second pull request updates one of the patches which broke with rmk's allnoconfigs, and also updates the tag description to indicate that 7fc54fd3 is building cleanly here. * tag 'omap-for-v3.8/cleanup-prcm-part2-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (27 commits) ARM: OMAP2: Fix compillation error in cm_common ARM: OMAP2+: PRCM: remove obsolete prcm.[ch] ARM: OMAP2+: hwmod: call to _omap4_disable_module() should use the SoC-specific call ARM: OMAP2+: PRCM: consolidate PRCM-related timeout macros ARM: OMAP2+: PRCM: split and relocate the PRM/CM globals setup ARM: OMAP2+: PRCM: remove omap2_cm_wait_idlest() ARM: OMAP2+: CM/clock: convert _omap2_module_wait_ready() to use SoC-independent CM functions ARM: OMAP2xxx: APLL/CM: convert to use omap2_cm_wait_module_ready() ARM: OMAP2+: board files: use SoC-specific system restart functions ARM: OMAP2+: PRCM: create SoC-specific chip restart functions ARM: OMAP2xxx: clock: move virt_prcm_set code into clkt2xxx_virt_prcm_set.c ARM: OMAP2xxx: clock: remove global 'dclk' variable ARM: OMAP2/3: PRM: add SoC reset functions (using the CORE DPLL method) ARM: OMAP2+: common: remove mach-omap2/common.c globals and map_common_io code ARM: OMAP2+: PRCM: remove omap_prcm_get_reset_sources() watchdog: OMAP: use standard GETBOOTSTATUS interface; use platform_data fn ptr ARM: OMAP2+: WDT: move init; add read_reset_sources pdata function pointer ARM: OMAP1: CGRM: fix omap1_get_reset_sources() return type ARM: OMAP2+: PRM: create PRM reset source API for the watchdog timer driver ARM: OMAP1: create read_reset_sources() function (for initial use by watchdog) ... Conflicts: arch/arm/mach-omap2/cm33xx.c arch/arm/mach-omap2/io.c arch/arm/mach-omap2/prm_common.c Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-08watchdog: OMAP: use standard GETBOOTSTATUS interface; use platform_data fn ptrPaul Walmsley
Previously the OMAP watchdog driver used a non-standard way to report the chip reset source via the GETBOOTSTATUS ioctl. This patch converts the driver to use the standard WDIOF_* flags for this purpose. This patch may break existing userspace code that uses the existing non-standard data format returned by the OMAP watchdog driver's GETBOOTSTATUS ioctl. To fetch detailed reset source information, userspace code will need to retrieve it directly from the CGRM or PRM drivers when those are completed. Previously, to fetch the reset source, the driver either read a register outside the watchdog IP block (OMAP1), or called a function exported directly from arch/arm/mach-omap2. Both approaches are broken. This patch also converts the driver to use a platform_data function pointer. This approach is temporary, and is due to the lack of drivers for the OMAP16xx+ Clock Generation and Reset Management IP block and the OMAP2+ Power and Reset Management IP block. Once drivers are available for those IP blocks, the watchdog driver can be converted to call exported functions from those drivers directly. At that point, the platform_data function pointer can be removed. In the short term, this patch is needed to allow the PRM code to be removed from arch/arm/mach-omap2 (it is being moved to a driver). This version integrates a fix from Jon Hunter <jon-hunter@ti.com> that avoids a NULL pointer dereference in a DT-only boot, and integrates a patch commit message fix from Felipe Balbi <balbi@ti.com>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Wim Van Sebroeck <wim@iguana.be> Acked-by: Wim Van Sebroeck <wim@iguana.be> [paul@pwsan.com: integrated pdata fix from Jon Hunter] Cc: Jon Hunter <jon-hunter@ti.com> [paul@pwsan.com: integrated changelog fix from Felipe Balbi] Cc: Felipe Balbi <balbi@ti.com>
2012-11-08WATCHDOG: fix build PM warningsRussell King
drivers/watchdog/sp805_wdt.c:288:12: warning: 'sp805_wdt_suspend' defined but not used drivers/watchdog/sp805_wdt.c:298:12: warning: 'sp805_wdt_resume' defined but not used This is caused by the wrong config symbol being used for these functions. Rather than fixing that, mark the functions with __maybe_unused Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-15watchdog: imx2_wdt: remove unneeded mach/hardware.h inclusionShawn Guo
The inclusion of mach/hardware.h is not used by the driver at all. Remove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org
2012-10-07Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu Pull m68knommu arch updates from Greg Ungerer: "Most of it is a cleanup of the ColdFire hardware header files. We have had a few occurrances of bugs caused by inconsistent definitions of peripheral addresses. These patches make them all consistent, and also clean out a bunch of old crap. Overall we remove about 1000 lines." * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (27 commits) m68knommu: fix inconsistent formating in ColdFire 5407 definitions m68knommu: fix inconsistent formating in ColdFire 5307 definitions m68knommu: fix inconsistent formating in ColdFire 527x definitions m68knommu: fix inconsistent formating in ColdFire 5272 definitions m68knommu: fix inconsistent formating in ColdFire 523x definitions m68knommu: clean up ColdFire 54xx General Timer definitions m68knommu: clean up Pin Assignment definitions for the 54xx ColdFire CPU m68knommu: fix multi-function pin setup for FEC module on ColdFire 523x m68knommu: move ColdFire slice timer address defiens to 54xx header m68knommu: use read/write IO access functions in ColdFire m532x setup code m68knommu: modify ColdFire 532x GPIO register definitions to be consistent m68knommu: remove a lot of unsed definitions for 532x ColdFire m68knommu: use definitions for the ColdFire 528x FEC multi-function pins m68knommu: remove address offsets relative to IPSBAR for ColdFire 527x m68knommu: remove unused ColdFire 5282 register definitions m68knommu: fix wrong register offsets used for ColdFire 5272 multi-function pins m68knommu: make ColdFire 5249 MBAR2 register definitions absolute addresses m68knommu: make remaining ColdFire 5272 register definitions absolute addresses m68knommu: make ColdFire Park and Assignment register definitions absolute addresses m68knommu: make ColdFire Chip Select register definitions absolute addresses ...
2012-10-05Merge tag 'mfd-3.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: "MFD bits for the 3.7 merge window. As usual we have a few new drivers: - TI LP8788 - TI OMAP USB TLL - Maxim MAX8907 - SMSC ECE1099 - Dialog Semiconductor DA9055 - A simpler syscon driver that allow us to get rid of the anatop one. Drivers are also gradually getting Device Tree and IRQ domain support. The following drivers got DT support: - palmas, 88pm860x, tc3589x and twl4030-audio And those ones now use the IRQ domain APIs: - 88pm860x, tc3589x, db8500_prcmu Also some other interesting changes: - Intel's ICH LPC now supports Lynx Point - TI's twl4030-audio added a GPO child - tps6527 enabled its backlight subdevice - The twl6030 pwm driver moved to the new PWM subsystem And finally a bunch of cleanup and casual fixes for mc13xxx, 88pm860x, palmas, ab8500, wm8994, wm5110, max8907 and the tps65xxx family." Fix up various annoying conflicts: the DT and IRQ domain support came in twice and was already in 3.6. And then it was apparently rebased. Guys, DON'T REBASE! * tag 'mfd-3.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (89 commits) ARM: dts: Enable 88pm860x pmic mfd: 88pm860x: Move gpadc init into touch mfd: 88pm860x: Device tree support mfd: 88pm860x: Use irqdomain mfd: smsc: Add support for smsc gpio io/keypad driver backlight: tps65217_bl: Add missing platform_set_drvdata in tps65217_bl_probe mfd: DA9055 core driver mfd: tps65910: Add alarm interrupt of TPS65910 RTC to mfd device list mfd: wm5110: Add register patches for revision B mfd: wm5110: Disable control interface error report for WM5110 rev B mfd: max8907: Remove regulator-compatible from DT docs backlight: Add TPS65217 WLED driver mfd: Add backlight as subdevice to the tps65217 mfd: Provide the PRCMU with its own IRQ domain mfd: Fix max8907 sparse warning mfd: Add lp8788 mfd driver mfd: dbx500: Provide a more accurate smp_twd clock mfd: rc5t583: Fix warning messages regulator: palmas: Add DT support mfd: palmas: Change regulator defns to better suite DT ...
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-10-01Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM soc bug fixes from Olof Johansson: "These were submitted as bug fixes before v3.6 but not considered important enough to be included in it. Some of them cross over to cleanup territory as well, and aren't strictly bugfixes." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: nomadik: remove NAND_NO_READRDY use ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe() ARM: SAMSUNG: Add missing variable declaration in s3c64xx_spi1_set_platdata() ARM: S3C24XX: removes unnecessary semicolon ARM: S3C24xx: delete double assignment ARM: EXYNOS: fix address for EXYNOS4 MDMA1 ARM: EXYNOS: fixed SYSMMU setup definition to mate parameter name ARM: ep93xx: Move ts72xx.h out of include/mach ARM: ep93xx: use __iomem pointers for MMIO ARM: msm: Fix early debug uart mapping on some memory configs ARM: msm: io: Change the default static iomappings to be shared ARM: msm: io: Remove 7x30 iomap region from 7x00 ARM: msm: Remove call to missing FPGA init on 8660 ARM: OMAP4: wakeupgen: remove duplicate AUXCOREBOOT* read/write ARM: OMAP4: wakeupgen: Fix the typo in AUXCOREBOOT register save dma: tegra: make data used as *of_device_id.data const can: mpc5xxx_can: make data used as *of_device_id.data const macintosh/mediabay: make data used as *of_device_id.data const i2c/mpc: make data used as *of_device_id.data const mfd/da9052: make i2c_device_id array const ...
2012-09-27m68knommu: clean up ColdFire 54xx General Timer definitionsGreg Ungerer
Convert the ColdFire 54xx CPU General Timer register address definitions to include the MCF_MBAR peripheral region offset. This makes them consistent with all other 54xx address register definitions (in m54xxsim.h). The goal is to reduce different definitions used (some including offsets and others not) causing bugs when used incorrectly. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-09-16Merge tag 'omap-cleanup-sparseirq-for-v3.7' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Tony Lindgren: This branch contains changes needed to make omap2+ work properly with sparse IRQ. It also removes dependencies to mach/hardware.h. These help moving things towards ARM single zImage support. This branch is based on a commit in tty-next branch with omap-devel-gpmc-fixed-for-v3.7 and cleanup-omap-tags-for-v3.7 merged in to keep things compiling and sort out some merge conflicts. * tag 'omap-cleanup-sparseirq-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP1: Move SoC specific headers from plat to mach for omap1 ARM: OMAP2+ Move SoC specific headers to be local to mach-omap2 ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+ ARM: OMAP: Remove unused old gpio-switch.h ARM: OMAP1: Move plat/irqs.h to mach/irqs.h ARM: OMAP2+: Remove hardcoded IRQs and enable SPARSE_IRQ ARM: OMAP2+: Prepare for irqs.h removal W1: OMAP HDQ1W: Remove dependencies to mach/hardware.h Input: omap-keypad: Remove dependencies to mach includes ARM: OMAP: Move gpio.h to include/linux/platform_data ARM: OMAP2+: Remove hardcoded twl4030 gpio_base, irq_base and irq_end ARM: OMAP2+: Remove unused nand_irq for GPMC ARM: OMAP2+: Make INTCPS_NR_IRQS local for mach-omap2/irq.c ARM: OMAP1: Define OMAP1_INT_I2C locally ARM: OMAP1: Move define of OMAP_LCD_DMA to dma.h
2012-09-16mfd: lpc_ich: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
This patch adds the Watchdog Timer Device IDs for the Intel Lynx Point-LP PCH. The Device IDs are defined in drivers/mfd/lpc_ich.c Signed-off-by: James Ralston <james.d.ralston@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
