Linux 4.1.43
* tag 'v4.1.43': (182 commits)
Linux 4.1.43
HID: core: prevent out-of-bound readings
ipvs: SNAT packet replies only for NATed connections
Revert "dmaengine: ep93xx: Don't drain the transfers in terminate_all()"
staging: comedi: ni_mio_common: fix E series ni_ai_insn_read() data
kvm: vmx: Do not disable intercepts for BNDCFGS
tracing: Use SOFTIRQ_OFFSET for softirq dectection for more accurate results
PM / QoS: return -EINVAL for bogus strings
sched/topology: Optimize build_group_mask()
sched/topology: Fix overlapping sched_group_mask
crypto: caam - fix signals handling
crypto: atmel - only treat EBUSY as transient if backlog
crypto: talitos - Extend max key length for SHA384/512-HMAC and AEAD
Add "shutdown" to "struct class".
mnt: Make propagate_umount less slow for overlapping mount propagation trees
mnt: In propgate_umount handle visiting mounts in any order
mnt: In umount propagation reparent in a separate pass
vt: fix unchecked __put_user() in tioclinux ioctls
exec: Limit arg stack to at most 75% of _STK_LIM
s390: reduce ELF_ET_DYN_BASE
[ Upstream commit fedf266f9955d9a019643cde199a2fd9a0259f6f ]
The bcm_kona_wdt_set_resolution_reg() call takes the spinlock, so
initialize it earlier. Fixes a warning at boot with lock debugging
enabled.
Fixes: 6adb730dc208 ("watchdog: bcm281xx: Watchdog Driver")
Signed-off-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 46c319b848268dab3f0e7c4a5b6e9146d3bca8a4 ]
Make sure to check the number of endpoints to avoid dereferencing a
NULL-pointer should a malicious device lack endpoints.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit 10e7ac22cdd4d211cef99afcb9371b70cb175be6 ]
Calling return copy_to_user(...) in an ioctl will not do the right thing
if there's a pagefault: copy_to_user returns the number of bytes not
copied in this case.
Fix up watchdog/rc32434_wdt to do
return copy_to_user(...)) ? -EFAULT : 0;
instead.
Cc: stable@vger.kernel.org
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Correct wdog->timeout after set_timeout(), otherwise, the WDIOC_GETTIMEOUT
will return the default value '60s' always, correct it and also for the new
wdog->pretimeout.
Signed-off-by: Robin Gong <b38343@freescale.com>
The pre-timeout interrupt will be triggered before watchdog timeout happen.
So add interface in imx2_wdt driver.
Since the watchdog common framework centrialize the IOCTL interfaces of device
driver now, the SETPRETIMEOUT and GETPRETIMEOUT need to be added in common code
Most of i.mx6 and i.mx7 board need to support WDOG_B reboot to workaroud some
issues such as ldo-bypass, QSPI-NOR boot issue. Please enable 'fsl,wdog_b'
property if you want to use WDOG_B reboot(trigger PMIC reboot).
commit 0919e4445190da18496d31aac08b90828a47d45f upstream.
Commit f2147de33470 ("watchdog: sunxi: support parameterized compatible
strings") introduced a regression in sunxi_wdt_start(), by which
the system reset function of the watchdog is not enabled upon
starting the watchdog. As a result, the system is not reset when the
watchdog expires. Fix it.
Fixes: f2147de33470 ("watchdog: sunxi: support parameterized compatible strings")
Signed-off-by: Francesco Lavra <francescolavra.fl@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit 530c11d432727c697629ad5f9d00ee8e2864d453 upstream.
The omap watchdog has the annoying behaviour that writes to most
registers don't have any effect when the watchdog is already running.
Quoting the AM335x reference manual:
To modify the timer counter value (the WDT_WCRR register),
prescaler ratio (the WDT_WCLR[4:2] PTV bit field), delay
configuration value (the WDT_WDLY[31:0] DLY_VALUE bit field), or
the load value (the WDT_WLDR[31:0] TIMER_LOAD bit field), the
watchdog timer must be disabled by using the start/stop sequence
(the WDT_WSPR register).
Currently the timer is stopped in the .probe callback but still there
are possibilities that yield to a situation where omap_wdt_start is
entered with the timer running (e.g. when /dev/watchdog is closed
without stopping and then reopened). In such a case programming the
timeout silently fails!
To circumvent this stop the timer before reprogramming.
Assuming one of the first things the watchdog user does is setting the
timeout explicitly nothing too bad should happen because this explicit
setting works fine.
Fixes: 7768a13c252a ("[PATCH] OMAP: Add Watchdog driver support")
Pull watchdog updates from Wim Van Sebroeck:
"This contains following changes:
- Octeon: convert to watchdog-API and apply some fixes
- Cadence wdt: remove dependency on ARCH
- add DT bindings for qcom + msm
- bcm281xx: Remove use of seq_printf return value
- stmp3xxx_rtc_wdt + pnx4008_wdt: fix broken email addresses"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: stmp3xxx_rtc_wdt: fix broken email address
watchdog: pnx4008_wdt: fix broken email address
watchdog: octeon: use fixed length string for register names
watchdog: octeon: fix some trivial coding style issues
watchdog: octeon: convert to WATCHDOG_CORE API
watchdog: cadence: Remove Kconfig dependency on ARCH
ARM: msm: add watchdog entries to DT timer binding doc
ARM: qcom: add description of KPSS WDT for IPQ8064
watchdog: qcom: use timer devicetree binding
watchdog: bcm281xx: Remove use of seq_printf return value
Pull ARM SoC driver updates from Olof Johansson:
"Driver updates for v4.1. Some of these are for drivers/soc, where we
find more and more SoC-specific drivers these days. Some are for
other driver subsystems where we have received acks from the
appropriate maintainers.
The larger parts of this branch are:
- MediaTek support for their PMIC wrapper interface, a high-level
interface for talking to the system PMIC over a dedicated I2C
interface.
- Qualcomm SCM driver has been moved to drivers/firmware. It's used
for CPU up/down and needs to be in a shared location for arm/arm64
common code.
- cleanup of ARM-CCI PMU code.
- another set of cleanusp to the OMAP GPMC code"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
soc/mediatek: Remove unused variables
clocksource: atmel-st: select MFD_SYSCON
soc: mediatek: Add PMIC wrapper for MT8135 and MT8173 SoCs
arm-cci: Fix CCI PMU event validation
arm-cci: Split the code for PMU vs driver support
arm-cci: Get rid of secure transactions for PMU driver
arm-cci: Abstract the CCI400 PMU specific definitions
arm-cci: Rearrange code for splitting PMU vs driver code
drivers: cci: reject groups spanning multiple HW PMUs
ARM: at91: remove useless include
clocksource: atmel-st: remove mach/hardware dependency
clocksource: atmel-st: use syscon/regmap
ARM: at91: time: move the system timer driver to drivers/clocksource
ARM: at91: properly initialize timer
ARM: at91: at91rm9200: remove deprecated arm_pm_restart
watchdog: at91rm9200: implement restart handler
watchdog: at91rm9200: use the system timer syscon
mfd: syscon: Add atmel system timer registers definition
ARM: at91/dt: declare atmel,at91rm9200-st as a syscon
soc: qcom: gsbi: Add support for ADM CRCI muxing
My Pengutronix address is not valid anymore, redirect people to the Pengutronix
kernel team.
Reported-by: Harald Geyer <harald@ccbib.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Robert Schwebel <r.schwebel@pengutronix.de>
kernel team.
Use fixed length string for register names. This saves 416 bytes
in text size.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Fix some trivial coding style issues to reduce noise from static analyzers.
Convert OCTEON watchdog to WATCHDOG_CORE API. This enables support
for multiple watchdogs on OCTEON boards.
Remove Kconfig dependency and enable driver for
all ARCHs.
MSM watchdog configuration happens in the same register block as the
timer, so we'll use the same binding as the existing timer.
The qcom-wdt will now be probed when devicetree has an entry compatible
with "qcom,kpss-timer" or "qcom-scss-timer".
Signed-off-by: Mathieu Olivari <mathieu@codeaurora.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
Acked-by: Guenter Roeck <linux~roeck-us.net>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"The major change in this merge is the removal of the support for
31-bit kernels. Naturally 31-bit user space will continue to work via
the compat layer.
And then some cleanup, some improvements and bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (23 commits)
s390/smp: wait until secondaries are active & online
s390/hibernate: fix save and restore of kernel text section
s390/cacheinfo: add missing facility check
s390/syscalls: simplify syscall_get_arch()
s390/irq: enforce correct irqclass_sub_desc array size
s390: remove "64" suffix from mem64.S and swsusp_asm64.S
s390/ipl: cleanup macro usage
s390/ipl: cleanup shutdown_action attributes
s390/ipl: cleanup bin attr usage
s390/uprobes: fix address space annotation
s390: add missing arch_release_task_struct() declaration
s390: make couple of functions and variables static
s390/maccess: improve s390_kernel_write()
s390/maccess: remove potentially broken probe_kernel_write()
s390/watchdog: support for KVM hypervisors and delete pr_info messages
s390/watchdog: enable KEEPALIVE for /dev/watchdog
s390/dasd: remove setting of scheduler from driver
s390/traps: panic() instead of die() on translation exception
s390: remove test_facility(2) (== z/Architecture mode active) checks
s390/cmpxchg: simplify cmpxchg_double
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into next/drivers
Merge "arm-cci PMU updates for 4.1" from Will Deacon:
CCI-400 PMU updates
This series reworks some of the CCI-400 PMU code so that it can be used
on both ARM and ARM64-based systems, without the need to boot in secure
mode on the latter. This paves the way for CCI-500 support in future.
* tag 'arm-perf-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux:
+ Linux 4.0-rc4
If the target sleep state of the system is not an ACPI sleep state
(S1, S2 or S3), the TCO watchdog needs to be stopped during system
suspend, because it may not be possible to ping it any more after
timekeeping has been suspended (suspend-to-idle does that for
one example).
For this reason, provide ->suspend_noirq and ->resume_noirq
callbacks for the iTCO watchdog driver and use them to stop
and restart the watchdog during system suspend and resume,
respectively, if the system is not going to enter an ACPI
sleep state (in which case the watchdog will be stopped
by the platform firmware before the state is entered).
Reported-and-tested-by: Borun Fu <borun.fu@intel.com>
The IMG PDC watchdog driver heartbeat module parameter has no default so
it is initialised to zero. This results in the following warning during
probe:
imgpdc-wdt 2006000.wdt: Initial timeout out of range! setting max timeout
The module parameter description implies that the default value should
be PDC_WDT_DEF_TIMEOUT, which isn't yet used, so initialise it to that.
Also tweak the heartbeat module parameter description for consistency.
Fixes: 93937669e9b5 ("watchdog: ImgTec PDC Watchdog Timer Driver")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Cc: Naidu Tellapati <Naidu.Tellapati@imgtec.com>
Cc: Jude Abraham <Jude.Abraham@imgtec.com>
Cc: linux-watchdog@vger.kernel.org
The IMG PDC watchdog probe function calls pdc_wdt_stop() prior to
watchdog_set_drvdata(), causing a NULL pointer dereference when
pdc_wdt_stop() retrieves the struct pdc_wdt_dev pointer using
watchdog_get_drvdata() and reads the register base address through it.
Fix by moving the watchdog_set_drvdata() call earlier, to where various
other pdc_wdt->wdt_dev fields are initialised.
"ret" should be signed for the error handling to work correctly. This
doesn't matter much in real life since mtk_wdt_set_timeout() always
succeeds.
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
This patch extends the diag288 watchdog driver to be able to deal with KVM
hypervisors. Only z/VM needs special handling, we can use the same interface
as on LPAR. Remove all pr_info output to avoid misconception. Because there
is no value in these messages and only the pr_err messages make sense.
Signed-off-by: Xu Wang <gesaint@linux.vnet.ibm.com>
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
There's no reason why we wouldn't want to be able to send a keep alive
message to /dev/watchdog (feed dog) for the s390 diag288 watchdog, so
let's enable the WDIOF_KEEPALIVEPING option.
Restarting the at91rm9200 is done through programming the watchdog and waiting
for it to reset.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Use a syscon regmap to access the system timer registers.
Also, rename the driver atmel_st_watchdog to stop conflicting with
at91sam9_wdt.c
The watchdog interrupt (only used when activating software watchdog)
shouldn't be suspended when entering suspend mode, because it is shared
with a timer device (which request the line with IRQF_NO_SUSPEND) and once
the watchdog "Mode Register" has been written, it cannot be changed (which
means we cannot disable the watchdog interrupt when entering suspend).
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
BCM5301X (ARCH_BCM_5301X) is a new Broadcom architecture using the same
SoC bus driver (bcma) as BCM47XX but based on ARM instead of MIPS.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Add DT support to the jz4740 driver. Simple of_match_ptr. No other
modification for probe needed
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
The dw_wdt_set_top() function takes in a value in seconds. In
dw_wdt_open() we were calling it with a value that's supposed to
represent the maximum value programmed into the "top" register with a
comment saying that we were trying to set the watchdog to its maximum
value. Instead we ended up setting the watchdog to ~15 seconds.
Let's fix this. However, setting things to the "max" gives me an 86
second watchdog in the system I'm looking at. 86 seconds feels a
little too long. We'll explicitly choose 30 seconds as a more
reasonable value.
NOTE: Ideally this driver should be transitioned to be a real watchdog
driver. Then we could use "watchdog_init_timeout" and let the timeout
be specified in a number of ways (device tree, module parameter, etc).
This patch should be considered a bit of a stopgap solution.
Signed-off-by: Doug Anderson <dianders@chromium.org>
On some dw_wdt implementations the "top" register may be initted to 0
at bootup. In such a case, each "pat" of the watchdog will reset the
timer to 0xffff. That's pretty short.
The input clock of the wdt can be any of a wide range of values. On
an rk3288 system, I've seen the wdt clock be 24.75 MHz. That means
each tick is ~40ns and we'll count to 0xffff in ~2.6ms.
Because of the above two facts, it's a really good idea to pat the
watchdog after initting the "top" register properly and before
enabling the watchdog. If you don't then there's no way we'll get the
next heartbeat in time.
Jisheng Zhang fixed this problem on some dw_wdt versions by using the
TOP_INIT feature. However, the dw_wdt on rk3288 doesn't have TOP_INIT
so it's a good idea to also pat the watchdog manually.
The watchdog functionality in both chips is almost identical to NCT6779.
Just like in case of other watchdog drivers, use the new kernel core
API to provide restart support.
On some chips, like the TPS386000, the trigger cannot be disabled
and the CPU must keep toggling the line at all times. Add a switch
"always_running" to keep toggling the GPIO line regardless of the
state of the soft part of the watchdog. The "armed" member keeps
track of whether a timeout must also cause a reset.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Register a restart handler for the da9063 watchdog. System restart is
triggered by sending the shutdown command to the PMIC.
As more-suitable restart handlers may exist, the priority of the
watchdog restart handler is set to 128.
The actual restart method was inspired by a platform-specific patch from
the BSP by Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Steve Twiss <stwiss.opensource@diasemi.com>
This patch adds a driver for the Mediatek SoC integrated
watchdog. This driver supports watchdog and software reset
for mt65xx and mt81xx SoCs.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Tested-by: Eddie Huang <eddie.huang@mediatek.com>
This allows testing the watchdog easily with distros just by
doing pkill -9 watchdog.
Reported-by: Thomas Dziedzic <gostrc@gmail.com>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Replace device_reset() with devm_reset_control_get() + reset_control_deassert().
Make use of watchdog_init_timeout() instead of setting the timeout manually.
Signed-off-by: John Crispin <blogic@openwrt.org>
allow_kdump was enabled as default since following commit.
commit a089361cf5f1d6a5295aa5385238bd044998e1e9,
watchdog: hpwdt: Unregister NMI events on exit.
But the initialization message was not modified.
So it still shows
HP Watchdog Timer Driver: NMI decoding initialized,
allow kernel dump: ON (default = 0/OFF) <=
This "default = 0/OFF" message may confuse users.
Fix it as "default = 1/ON".
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
IT8783 watchdog works as in IT872x
Tested on Adlink cPCI-6520 boards
Signed-off-by: Paolo Teti <paolo.teti@gmail.com>
The regmap_config struct may be const because it is not modified by the
driver and regmap_init() accepts pointer to const. Make struct
watchdog_ops const as well.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
This commit adds support for ImgTec PowerDown Controller Watchdog Timer.
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Signed-off-by: Naidu Tellapati <Naidu.Tellapati@imgtec.com>
Signed-off-by: Jude Abraham <Jude.Abraham@imgtec.com>
[ezequiel: Minor style fixes]
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
This platform_driver does not need to set an owner, it will be populated by the
driver core.
