Convert off-by-1 r->end - r->start to resource_size(r)
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Since 1c48a5c93da6313 (dt: Eliminate of_platform_{,un}register_driver)
mpc8xxx_wdt no longer builds as it tries to refer to a 'match' variable
rather than ofdev->dev.of_match that it checks just before.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
reboot on timer expiry
This is needed for determining the reason for failure when a softdog
timeout occurs.
We use softdog to watch for critical application failures and at the
minimum a snapshot of the system would help to determine the cause. In
such a scenario the application could fail but there isn't a softlockup as
such, hence the detect softlockup feature does not help.
The patch adds a module parameter soft_panic which when set to 1 causes
softdog to invoke panic instead of reboot when the softdog timer expires.
By invoking panic we execute kdump if it is configured and the vmcore
generated by kdump should provide atleast a minimal idea of the reason for
failure.
Based on an original patch by Ken Sugawara <sugaken.r3@gmail.com>
Signed-off-by: Anithra P J <anithra@linux.vnet.ibm.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Fix section mismatch warning:
Mark the called nv_tco_getdevice() as __devinit, just like its caller.
WARNING: drivers/watchdog/nv_tco.o(.devinit.text+0x16): Section mismatch in reference from the function nv_tco_init() to the function .init.text:nv_tco_getdevice()
The function __devinit nv_tco_init() references
a function __init nv_tco_getdevice().
If nv_tco_getdevice is only used by nv_tco_init then
annotate nv_tco_getdevice with a matching annotation.
Stefano found SP5100 TCO watchdog driver using wrong address.
[ 9.148536] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01
[ 9.148628] DEBUG __ioremap_caller WARNING address=b8fe00 size=8 valid=1 reserved=1
and e820 said that range is RAM.
We should check if we can use that reading out. BIOS could just program wrong address there.
Reported-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by:Yinghai Lu <yinghai@kernel.org>
Acked-by: Mike Waychison <mikew@google.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: stable <stable@kernel.org>
Request_mem_region should be used with release_mem_region, not
release_resource.
In pnx4008_wdt.c, a missing clk_put is added as well.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E;
*x = request_mem_region(...)
... when != release_mem_region(x)
when != x = E
* release_resource(x);
// </smpl>
release_region/release_mem_region
release_resource.
The semantic match that finds this problem is as follows:
// <smpl>
expression x,E;
when != x = E
// </smpl>
Use mfd_data for passing information from mfd drivers to soc
clients. The mfd_cell's driver_data field is being phased out.
Clients that were using driver_data now access .mfd_data
via mfd_get_data().
Signed-off-by: Andres Salomon <dilinger@queued.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
master.kernel.org:/home/rmk/linux-2.6-arm
* 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6647/1: add Versatile Express defconfig
ARM: 6644/1: mach-ux500: update the U8500 defconfig
* 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6764/1: pl011: factor out FIFO to TTY code
ARM: 6763/1: pl011: add optional RX DMA to PL011 v2
ARM: 6758/1: amba: support pm ops
ARM: amba: make amba_driver id_table const
ARM: amba: make internal ID table handling const
ARM: amba: make probe() functions take const id tables
ARM: 6662/1: amba: make amba_bustype non-static
ARM: mmci: add dmaengine-based DMA support
ARM: mmci: no need for separate host->data_xfered
ARM: mmci: avoid unnecessary switch to data available PIO interrupts
ARM: mmci: no need to call flush_dcache_page() with sg_miter API
ARM: mmci: avoid reporting too many completed bytes on fifo overrun
ALSA: AACI: make fifo variables more explanitory
ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period
ALSA: AACI: use snd_pcm_lib_period_bytes()
ALSA: AACI: clean up AACI announcement printk
ALSA: AACI: fix channel mask selection
ALSA: AACI: fix number of channels for record
ALSA: AACI: fix multiple IRQ claiming
* 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm:
VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var()
VIDEO: cyberpro: remove useless function extreg pointers
VIDEO: cyberpro: update handling of device structures
VIDEO: cyberpro: add support for video capture I2C
VIDEO: cyberpro: make 'reg_b0_lock' always present
VIDEO: cyberpro: add I2C support
VIDEO: cyberpro: select lowest multipler/divisor for PLL
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
watchdog: booke_wdt: clean up status messages
watchdog: cleanup spaces before tabs
watchdog: convert to DEFINE_PCI_DEVICE_TABLE
watchdog: Xen watchdog driver
watchdog: Intel SCU Watchdog Timer Driver for Moorestown and Medfield platforms.
watchdog: jz4740_wdt - fix magic character checking
watchdog: add JZ4740 watchdog driver
watchdog: it87_wdt: Add support for IT8721F watchdog
watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled
watchdog: hpwdt: Fix a couple of typos
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
Improve the status messages that are displayed during some operations of the
PowerPC watchdog timer driver. When the watchdog is enabled, the timeout is
displayed as a number of seconds, instead of an obscure "period". The "period"
is the position of a bit in a 64-bit timer register. The higher the value,
the quicker the watchdog timeout occurs. Some people chose a high "period"
value for the timer and get confused as to why the board resets within a
few seconds.
Messages displayed during open and close are now debug messages, so that they
don't clutter the console by default. Finally, printk() is replaced with the
pr_xxx() equivalent.
cleanup spaces before tabs in drivers/watchdog/
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables.
While the hypervisor change adding SCHEDOP_watchdog support included a
daemon to make use of the new functionality, having a kernel driver
for /dev/watchdog so that user space code doesn't need to distinguish
non-Xen and Xen seems to be preferable.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
This submission includes:
- Fix to intel_scu_write() to start watchdog timer the on the
first write, and refresh on subsequent writes.
This enables Open, write, write, ... usage model.
- Moves boot parameter checks from intel_scu_open() to
intel_scu_watchdog_init(), so driver init will fail if these
parameters are out of bounds.
- Adds check for whether process waiting in wait_event_interruptible()
received a signal while it was waiting.
- Other small error handling changes.
Removed the read() method for now as that wass a non-standard behaviour.
Signed-off-by: Donald Johnson <donald.k.johnson@intel.com>
Signed-off-by: Shuduo Sang <shuduo.sang@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
When writing to /dev/watchdog all characters should be checked
for the magic character 'V'.
Adds support for the hardware watchdog found in Ingenic's jz4740
System-on-Chip.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
This patch adds support for a watchdog in IT8721F Super IO
chip to it87_wdt driver.
This new chips differ from the older IT87xxxF chips
in the following ways:
* WDT_GAMEPORT is not in IT8721F.
* WDT_PWROK is not in IT8721F.
Signed-off-by: Haruo Tomita <haruo.tomita@toshiba.co.jp>
Builds the hpwdt driver as a module by default.
If the hardware is present, the module will be loaded.
Also, if hpwdt is loaded, it will decode NMIs by default.
This has been made possible by he patches to hpwdt made by Dann Frazier
as well as related patches submitted by Don Zickus.
hpwdt only loads on hp ProLiant x86 32-bit and 64-bit platforms.
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
Fix some typos.
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
hpwdt_init_nmi_decoding() is called in hpwdt_init_one error handling,
thus remove the __devexit annotation of hpwdt_exit_nmi_decoding().
This patch fixes below warning:
WARNING: drivers/watchdog/hpwdt.o(.devinit.text+0x36f): Section mismatch in reference from the function hpwdt_init_one() to the function .devexit.text:hpwdt_exit_nmi_decoding()
The function __devinit hpwdt_init_one() references
a function __devexit hpwdt_exit_nmi_decoding().
This is often seen when error handling in the init function
uses functionality in the exit path.
The fix is often to remove the __devexit annotation of
hpwdt_exit_nmi_decoding() so it may be used outside an exit section.
Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com>
outb_p(c || 0x01, WDT_EFDR); -> || should be |
Reported-By: Toralf Förster <toralf.foerster@gmx.de>
"==" has higher precedence than "&". Since
if (sch311x_sio_inb(sio_config_port, 0x30) & (0x01 == 0)) is always
false the message is never printed.
if (sch311x_sio_inb(sio_config_port, 0x30) && 0x01 == 0) -> && should be &
cppcheck-1.47 reports:
[drivers/watchdog/cpwd.c:650]: (error) Buffer access out-of-bounds: p.devs
The source code is
for (i = 0; i < 4; i++) {
misc_deregister(&p->devs[i].misc);
where devs is defined as WD_NUMDEVS big and WD_NUMDEVS is equal to 3.
So the 4 should be a 3 or WD_NUMDEVS.
Reported-By: David Binderman
The omap_wdt should only be in full active state when the
registers are being accessed. Otherwise the device can be
on lower power mode.
This patch is based on a patch created by Kalle Jokiniemi:
https://patchwork.kernel.org/patch/618231/
which is itself based on a patch created by Atal
Shargorodsky: http://lkml.org/lkml/2009/3/10/266.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@nokia.com>
Tested-by: Kalle Jokiniemi <kalle.jokiniemi@nokia.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Kevin Hilman <khilman@ti.com>
Some systems don't provide DMI_BOARD_NAME in their DMI tables. Avoid
crash in such situations in fitpc2_wdt_init.
The fix is to check if the dmi_get_system_info return value is NULL.
The oops:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81253ae6>] strstr+0x26/0xa0
PGD 3966e067 PUD 39605067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map
CPU 1
Modules linked in: ...
Pid: 1748, comm: modprobe Not tainted 2.6.37-22-default #1 /Bochs
RIP: 0010:[<ffffffff81253ae6>] [<ffffffff81253ae6>] strstr+0x26/0xa0
RSP: 0018:ffff88003ad73f18 EFLAGS: 00010206
RAX: 0000000000000000 RBX: 00000000ffffffed RCX: 00000000ffffffff
RDX: ffffffffa003f4cc RSI: ffffffffa003f4c2 RDI: 0000000000000000
CR2: 0000000000000000 CR3: 000000003b7ac000 CR4: 00000000000006e0
Process modprobe (pid: 1748, threadinfo ffff88003ad72000, task ffff88002e6365c0)
Stack: ...
Call Trace:
[<ffffffffa004201f>] fitpc2_wdt_init+0x1f/0x13c [sbc_fitpc2_wdt]
[<ffffffff810002da>] do_one_initcall+0x3a/0x170
Code: f3 c3 0f 1f 00 80 3e 00 53 48 89 f8 74 1b 48 89 f2 0f 1f 40 00 48 83 c2 01 80 3a 00 75 f7 49 89 d0 48 89 f8 49 29 f0 75 02 5b c3 <80> 3f 00 74 0e 0f 1f 44 00 00 48 83 c0 01 80 38 00 75 f7 49 89
Final step to eliminate of_platform_bus_type. They're all just
platform drivers now.
v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell)
Make Primecell driver probe functions take a const pointer to their
ID tables. Drivers should never modify their ID tables in their
probe handler.
All m548x files were renamed to m54xx, except m548x_wdt.c. Fix that.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
m548x headers were renamed to m54xx, but m548x_wdt.c still uses the
old names. Fix that.
into sh-latest
Add watchdog driver for MCF548x.
This patch adds a driver for the built-in hardware watchdog device
of the Atheros AR71XX/AR724X/AR913X SoCs.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
This driver adds support for /dev/watchdog for boards using either the MCP51 or
MCP55 chipsets. These are also known as the nForce 430 and nForce 550. This
driver is likely to work on other chipsets as well, though those are the only
two that have been tested.
Signed-off-by: Mike Waychison <mikew@google.com>
This driver adds /dev/watchdog support for the AMD sp5100 aka SB7x0 chipsets.
It follows the same conventions found in other /dev/watchdog drivers.
Signed-off-by: Priyanka Gupta <priyankag@google.com>
Update Kconfig with the additional Fintek hardware that we support.
Signed-off-by: Lutz Ballaschke <vegan.grindcore@googlemail.com>
Acked-by: Giel van Schijndel <me@mortis.eu>
This patch adds the DeviceIDs for TCO Watchdog on the Intel DH89xxCC PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
This patch adds the Intel NM10 DeviceIDs for iTCO Watchdog.
Reported-by: Dan Weinlader <dan@weinlader.org>
ks8695_wdt needs KS8695_CLOCK_RATE, which is defined in
mach/hardware.h, which is pulled in by the include of mach/timex.h,
but the latter is going away, so just include mach/hardware.h
directly.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
When the watchdog period is changed, it needs to be propagated to all cores
in addition to the core that performed the change.
Signed-off-by: Randy Vinson <rvinson@mvista.com>
Normally, the watchdog is disabled when dev/watchdog is closed, but if
CONFIG_WATCHDOG_NOWAYOUT is defined, then it means that the watchdog should
remain enabled. So we should disable it only if CONFIG_WATCHDOG_NOWAYOUT is
not defined.
Also ensure that /dev/watchdog is only opened by one process at a time. That
way, a second process can't accidentally disable the watchdog while the first
process has it open. There shouldn't be any need for more than one process to
open /dev/watchdog anyway.
Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Annotate alim7101_pci_tbl as '__used' to fix following warning:
CC drivers/watchdog/alim7101_wdt.o
drivers/watchdog/alim7101_wdt.c:433: warning: ‘alim7101_pci_tbl’ defined but not used
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Annotate ali_pci_tbl as '__used' to fix following warning:
CC drivers/watchdog/alim1535_wdt.o
drivers/watchdog/alim1535_wdt.c:304: warning: ‘ali_pci_tbl’ defined but not used
