path: root/drivers/watchdog
2010-06-17watchdog: at32ap700x_wdt: register misc device last in probe() functionHans-Christian Egtvedt
This patch reworks the probe() function in the at32ap700x_wdt driver, this to make sure the miscdev is properly initialized and the driver is ready to be accessed. Reported-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Wim Van sebroeck <wim@iguana.be>
2010-06-13watchdog: [PATCH 3/3] imx2_wdt: fix section mismatchBaruch Siach
Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-06-07[PATCH 2/11] drivers/watchdog: Eliminate a NULL pointer dereferenceJulia Lawall
At the point of the call to dev_err, wm8350 is NULL. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression E,E1; identifier f; statement S1,S2,S3; @@ if ((E == NULL && ...) || ...) { ... when != if (...) S1 else S2 when != E = E1 * E->f ... when any return ...; } else S3 // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-06-02of/watchdog: gef_wdt.c: fix build breakageAnatolij Gustschin
Fixes build error caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-02watchdog: Fix build failure with OF changesMichael Guntsche
commit 61c7a080a5a061c976988fd4b844dfb468dda255 ( of: Always use 'struct device.of_node' to get device node pointer.) missed drivers/watchdog/mpc8xxx_wdt.c. This patch fixes it Signed-off-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-28mfd: Change rdc321x resources flags to IORESOURCE_IOFlorian Fainelli
The rdc321x southbridge PCI device has no MEM PCI resources that we could pass to mfd_add_devices. Since 33254dd5, mfd_add_device checks for the mem_base argument that we set to NULL. Changing the resources passed to our MFD cells from IORESOURCE_MEM to IORESOURCE_IO fixes that. Since we use those resources as offsets to the PCI configuration space base address of the southbridge device this is also more adequate. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28watchdog: Convert rdc321x_wdt to use southbridge pci deviceFlorian Fainelli
The RDC321x MFD southbridge driver will pass a reference to the southbridge PCI device which should be used by the watchdog driver for its operations. This patch converts the watchdog driver to use the pci_dev pointer and make use of the base register resource which is passed along with the platform device. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-25watchdog: Driver for the watchdog timer on Freescale IMX2 (and later) ↵Wolfram Sang
processors. This is the driver for the hardware watchdog on the Freescale IMX2 and later processors. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Juergen Beisert <jbe@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: s3c2410_wdt - Fix on handling of the request_mem_region failBanajit Goswami
If the request for wdt_mem region fails, this patch modifies the driver such that, it does not try to release the wdt_mem region on exit. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: s3c2410_wdt - Add extra option to include watchdog for Samsung SoCsBanajit Goswami
This patch adds HAVE_S3C2410_WATCHDOG to control inclusion of watchdog driver for Samsung SoCs. This option will help to include the driver only for the necessary machines and not for all for any given arch. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25iTCO_wdt: fix TCO V1 timeout values and limitsPádraig Brady
For TCO V1 devices the programmed timeout was twice too long because the fact that the TCO V1 timer needs to count down twice before triggering the watchdog, wasn't accounted for. Also the timeout values in the module description and error message were clarified. And the _STS registers are 16 bit instead of 8 bit. Signed-off-by: Pádraig Brady <P@draigBrady.com> Tested-by: Simon Kagstrom <simon.kagstrom@netinsight.se> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: twl4030_wdt: Disable watchdog during probingAmeya Palande
If we are not able to register then it is better to have watchdog in disabled state than noticing a system reboot. Signed-off-by: Ameya Palande <ameya.palande@nokia.com> Acked-By: Timo Kokkonen <timo.t.kokkonen@nokia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: update/improve/consolidate watchdog driverRandy Dunlap
Move the limited watchdog driver help from kernel-parameters.txt to Documentation/watchdog/watchdog-parameters.txt and add info to it for all watchdog drivers except the ones that have driver-specific files already. Correct minor comments and MODULE_PARM_DESC() text in 2 places. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: booke_wdt: fix ioctl status flagsWim Van Sebroeck
The WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS ioctl calls return the WDIOF_* flags and nothing else. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: fix several MODULE_PARM_DESC stringsRandy Dunlap
Fix MODULE_PARM_DESC() strings in several watchdog drivers. Some are simple as add a parenthesis. Others are problems from __stringify() being used on a variable name instead of a macro name, so the variable name is produced in the string instead of its build-time value. In these cases, create a macro for the value so that the module param description string is useful. Only pc87413_wdt has been built (due to toolchains). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: bfin: use new common Blackfin watchdog headerMike Frysinger
use new common Blackfin watchdog header Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-12ARM: 6126/1: ARM mpcore_wdt: fix build failure and other fixesSrinidhi Kasagar
This fixes the build failures seen when building mpcore_wdt and it also removes the nonexistent ARM_MPCORE_PLATFORM dependency, instead make it dependent on HAVE_ARM_TWD. Also this fixes spinlock usage appropriately. Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-03watchdog: ep93xx_wdt.c fix default timout value in MODULE_PARM_DESC string.Wim Van Sebroeck
The WATCHDOG_TIMEOUT macro does not exist. The default timeout value is WDT_TIMEOUT. Fix the MODULE_PARM_DESC so that the code can compile again. reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-27watchdog: booke_wdt: fix build - unconstify watchdog_infoAnton Vorontsov
commit 42747d712de56cf2087b702d2ad90af114c53138 ("[WATCHDOG] watchdog_info constify") introduced the following build failure: CC booke_wdt.o booke_wdt.c: In function 'booke_wdt_init': booke_wdt.c:220: error: assignment of read-only variable 'ident' Fix this by removing 'const' qualifier from watchdog_info struct. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2010-04-26watchdog: sbc_fitpc2_wdt: fixed "scheduling while atomic" bug.Denis Turischev
spinlock need to be replaced by mutex because of sleep functions inside wdt_send_data. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-26watchdog: sbc_fitpc2_wdt: fixed I/O operations orderDenis Turischev
There are fitpc2 compatible boards that hang with existent i/o operations order. Solution is to switch between writing to data and command ports. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-26Watchdog: sb_wdog.c: Fix sibyte watchdog initializationGuenter Roeck
Watchdog configuration register and timer count register were interchanged, causing wrong values to be written into both registers. This caused watchdog triggered resets even if the watchdog was reset in time. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-16[WATCHDOG] max63xx driver depends on ioremap()Geert Uytterhoeven
Correct fix for the "ioremap() causes build failure on S390" should have been a dependancy on HAS_IOMEM. So we add this dependancy also (and leave the driver in the ARM section for now). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-16[WATCHDOG] max63xx: be careful when disabling the watchdogMarc Zyngier
When shutting down the watchdog timer, special care must be taken not to overwrite other bits in the register, as it may be shared with other peripherals. For example, on the Arcom Vulcan, the register is shared between the watchdog and the PCI reset line... Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-16[WATCHDOG] fixed book E watchdog period register mask.Luuk Paulussen
A previous fix changed the WDTP function to use the period directly, rather than subtracting from 63. However the mask generation was not changed, so the mask was coming out as 0. This patch fixes it. Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-16[WATCHDOG] omap4: Fix WDT KconfigSantosh Shilimkar
This patch allows Watchdog timer to be selected for OMAP4 by fixing Kconfig entry Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] hpwdt - fix lower timeout limit [WATCHDOG] iTCO_wdt: TCO Watchdog patch for additional Intel Cougar Point DeviceIDs [WATCHDOG] doc: Fix use of WDIOC_SETOPTIONS ioctl. [WATCHDOG] doc: watchdog simple example: don't fail on fsync() [WATCHDOG] set max63xx driver as ARM only [WATCHDOG] powerpc: pika_wdt ident cannot be const
2010-04-06[WATCHDOG] hpwdt - fix lower timeout limitThomas Mingarelli
[Novell Bug 581103] HP Watchdog driver has arbitrary (wrong) timeout limits. Fix the lower timeout limit to a more appropriate value. Signed-off-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2010-04-06[WATCHDOG] iTCO_wdt: TCO Watchdog patch for additional Intel Cougar Point ↵Seth Heasley
DeviceIDs This patch adds the Intel Cougar Point PCH LPC Controller DeviceIDs for iTCO Watchdog. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2010-04-03[WATCHDOG] set max63xx driver as ARM onlyMarc Zyngier
Use of ioremap() causes build failure on S390. Restrict the driver to ARM until another architecture comes along and enables the driver for its own use. Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2010-04-03[WATCHDOG] powerpc: pika_wdt ident cannot be constSean MacLennan
The watchdog_info struct cannot be a const since we dynamically fill in the firmware version. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08[WATCHDOG] i6300esb.c: change platform_driver to pci_driverWim Van Sebroeck
Since the intel 6300esb platform uses a dedicated PCI ID for it's watchdog timer (00:1d.4), it's better and easier to have this as a pci_driver. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-08[WATCHDOG] i6300esb: fix unlock register withWim Van Sebroeck
Before you can read or write from the i6300esb memeory mapped registers, you need to unlock these. This is done by writing the magic numbers 0x80 and 0x86 to the reload register. The size of the reload register is 32bit though. Also binary 11 is hex 0x03 and not 0x11. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] drivers/watchdog/wdt.c:wdt_ioctl(): make `ident' non-staticAndrew Morton
Making this instance static exposes the code to SMP races, etc. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] change reboot_notifier to platform-shutdown method.Wim Van Sebroeck
Platform device drivers can use the .shutdown method to handle soft shutdown's instead of reboot_notifier's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] gef_wdt: Author corrections following split of GE Fanuc joint ventureMartyn Welch
This patch corrects author and copyright notices following the split-up of the GE Fanuc joint venture. Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] iTCO_wdt: clean up probe(), modify err msgNaga Chumbalkar
It's possible that the platform is not allowing reboot via TCO timer expiration. Also, differentiate between not finding a chipset that has TCO, and the case where TCO is present but the driver fails to initialize for some reason. Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] ep93xx: watchdog timer driver for TS-72xx SBCs cleanupWim Van Sebroeck
Clean-up driver: * make release the reverse of probe so that both are consistent * add WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS ioctls. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] support for max63xx watchdog timer chipsMarc Zyngier
This driver adds support for the max63{69,70,71,72,73,74} family of watchdog timer chips. It has been tested on an Arcom Zeus (max6369). Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-06[WATCHDOG] ep93xx: implemented watchdog timer driver for TS-72xx SBCsMika Westerberg
Technologic Systems TS-72xx SBCs have external glue logic CPLD which includes watchdog timer. This driver implements kernel support for that. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-01Merge with mainline to remove plat-omap/Kconfig conflictTony Lindgren
Conflicts: arch/arm/plat-omap/Kconfig
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-27MIPS: AR7: Implement clock APIFlorian Fainelli
This patch makes the ar7 clock code implement the Linux clk API. Drivers using the various clocks available in the SoC are updated accordingly. Signed-off-by: Florian Fainelli <florian@openwrt.org> Acked-by: Wim Van Sebroeck <wim@iguana.be> To: linux-mips@linux-mips.org Cc: Wim Van Sebroeck <wim@iguana.be> Cc: netdev@vger.kernel.org Cc: David Miller <davem@davemloft.net> Patchwork: http://patchwork.linux-mips.org/patch/881/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-21[WATCHDOG] bfin: fix max timeout calculationMike Frysinger
Relying on overflow/wrap around isn't exact because if you wrap far enough, you get back to "valid" values. Reported-by: Thorsten Pohlmann <pohlmann@tetronik.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
