path: root/drivers/watchdog
2011-08-02watchdog: Cleanup WATCHDOG_CORE help textJosh Boyer
The newly added WATCHDOG_CORE option is a bool, but the help text suggests it can be built as a module. Fix it up. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-08-02watchdog: Fix POST failure on ASUS P5N32-E SLI and similar boardsMart Gerrits
At present the module does not unset the NO_REBOOT bit upon shutdown, this causes the BIOS to fail the POST once and reset. During the next boot it displays the following error message: ***** Warning: System BOOT Fail ***** Your system last boot fail or POST interrupted. Please enter setup to load default and reboot again. Press F1 to continue, DEL to enter SETUP With this patch the NO_REBOOT flag will be unset on shutdown and thus stop this failure from occurring. Tested on 'ASUS P5N32-E SLI with BIOS revision 1801' and 'ASUS P5N32-E SLI PLUS with BIOS revision 1502'. Signed-off-by: Mart Gerrits <mart1987@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-08-02watchdog: shwdt: fix usage of mod_timerDavid Engraf
Fix the usage of mod_timer() and make the driver usable. mod_timer() must be called with an absolute timeout in jiffies. The old implementation used a relative timeout thus the hardware watchdog was never triggered. Signed-off-by: David Engraf <david.engraf@sysgo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Wim Van sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org>
2011-07-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits) watchdog: WatchDog Timer Driver Core - Add minimum and max timeout watchdog: WatchDog Timer Driver Core - Add ioctl call watchdog: WatchDog Timer Driver Core - Add nowayout feature watchdog: WatchDog Timer Driver Core - Add Magic Close feature watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality watchdog: WatchDog Timer Driver Core - Add basic framework watchdog: hpwdt: add next gen HP servers watchdog: it8712f_wdt.c: improve includes watchdog: at91sam9/wdt: move register header to drivers watchdog: Add Xilinx watchdog timer driver watchdog: remove empty pm-functions watchdog: sp805: Flush posted writes in enable/disable. watchdog: sp805: Don't write 0 to the load value register. watchdog: imx2_wdt: add device tree probe support watchdog: s3c2410: Add support for device tree based probe watchdog: mpcore_wdt: Add suspend/resume support. watchdog: mtx1-wdt: use dev_{err,info} instead of printk() ...
2011-07-28watchdog: WatchDog Timer Driver Core - Add minimum and max timeoutWim Van Sebroeck
Add min_timeout (minimum timeout) and max_timeout values so that the framework can check if the new timeout value is between the minimum and maximum timeout values. If both values are 0, then the framework will leave the check for the watchdog device driver itself. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add ioctl callWim Van Sebroeck
Add support for extra ioctl calls by adding a ioctl watchdog operation. This operation will be called before we do our own handling of ioctl commands. This way we can override the internal ioctl command handling and we can also add extra ioctl commands. The ioctl watchdog operation should return the appropriate error codes or -ENOIOCTLCMD if the ioctl command should be handled through the internal ioctl handling of the framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add nowayout featureWim Van Sebroeck
Add support for the nowayout feature to the WatchDog Timer Driver Core framework. This feature prevents the watchdog timer from being stopped. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add Magic Close featureWim Van Sebroeck
Add support for the Magic Close feature to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and ↵Wim Van Sebroeck
WDIOC_GETTIMEOUT ioctl This part add's the WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl functionality to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctlWim Van Sebroeck
This part add's the WDIOC_SETOPTIONS ioctl functionality to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctlWim Van Sebroeck
This part add's the WDIOC_KEEPALIVE ioctl functionality to the WatchDog Timer Driver Core framework. Please note that the WDIOF_KEEPALIVEPING bit has to be set in the watchdog_info options field. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add basic ioctl functionalityWim Van Sebroeck
This part add's the basic ioctl functionality to the WatchDog Timer Driver Core framework. The supported ioctl call's are: WDIOC_GETSUPPORT WDIOC_GETSTATUS WDIOC_GETBOOTSTATUS Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add basic frameworkWim Van Sebroeck
The WatchDog Timer Driver Core is a framework that contains the common code for all watchdog-driver's. It also introduces a watchdog device structure and the operations that go with it. This is the introduction of this framework. This part supports the minimal watchdog userspace API (or with other words: the functionality to use /dev/watchdog's open, release and write functionality as defined in the simplest watchdog API). Extra functionality will follow in the next set of patches. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: hpwdt: add next gen HP serversThomas Mingarelli
This patch is required to enable hpwdt to work on next generation HP servers with iLO. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26watchdog: it8712f_wdt.c: improve includesWim Van Sebroeck
remove unneeded pci.h include. and include ioport.h to avoid build errors for the region functions. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: at91sam9/wdt: move register header to driversJean-Christophe Plagniol-Villard
move register header to drivers Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: Add Xilinx watchdog timer driverAlejandro Cabrera
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores. It takes watchdog timer configuration from device tree and it needs that its parent has defined the property "clock-frecuency". It is compatible with watchdog timer kernel API, so user apps like watchdogd may talk with it. Signed-off-by: Alejandro Cabrera <aldaya@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: remove empty pm-functionsWolfram Sang
While checking what watchdog drivers usually do in suspend/resume to spot common behaviour for the watchdog framework, I found these drivers which do nothing but add some cruft. Remove it, it is superfluous. New approaches should probably be done with pm_ops anyway. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: sp805: Flush posted writes in enable/disable.Nick Bowler
There are no reads in these functions, so if MMIO writes are posted, the writes in enable/disable may not have completed by the time these functions return. If the functions run from different CPUs, it's in theory possible for the writes to be interleaved, which would be disastrous for this driver. At the very least, we need an mmiowb() before releasing the lock, but since it seems desirable for the watchdog timer to be actually stopped or reset when these functions return, read the lock register to force the writes out. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: sp805: Don't write 0 to the load value register.Nick Bowler
At least on the Versatile Express' V2M, calling wdt_disable followed by wdt_enable, for instance by running the following sequence: echo V > /dev/watchdog; echo V > /dev/watchdog results in an immediate reset. The wdt_disable function writes 0 to the load register; while the watchdog interrupts are disabled at this point, this special value is defined to trigger an interrupt immediately. It appears that in this instance, the reset happens when the interrupts are subsequently enabled by wdt_enable. Putting in a short delay after writing a new load value in wdt_enable solves the issue, but it seems cleaner to simply never write 0 to the load register at all: according to the hardware docs, writing 0 to the control register suffices to stop the counter, and the write of 0 to the load register is questionable anyway since this register resets to 0xffffffff. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: imx2_wdt: add device tree probe supportShawn Guo
Adds device tree probe support for imx2_wdt driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: s3c2410: Add support for device tree based probeThomas Abraham
This patch adds the of_match_table to enable s3c2410-wdt driver to be probed when watchdog device node is found in the device tree. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: mpcore_wdt: Add suspend/resume support.Peter Fordham
Add support for suspend and resume to the MPCore watchdog driver. Signed-off-by: Peter Fordham <peter.fordham@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: mtx1-wdt: use dev_{err,info} instead of printk()Florian Fainelli
use dev_{err,info} instead of printk(KERN_{ERR,INFO} ...) Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: i.MX: use IMX_HAVE_PLATFORM_IMX2_WDT to depend onSascha Hauer
The i.MX architecture provides IMX_HAVE_PLATFORM_* macros to signal that a selected SoC supports a certain hardware. Use them instead of depending on ARCH_* directly. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org
2011-07-22watchdog: add support for the Synopsys DesignWare WDTJamie Iles
The Synopsys DesignWare watchdog is found in several ARM based systems and provides a choice of 16 timeout periods depending on the clock input. The watchdog cannot be disabled once started. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: pc87413_wdt: Cleanup pc87413 watchdog driver to useJonathan McDowell
Inspired by Nat Gurumoorthy's recent patches for cleaning up the it87 drivers to use request_muxed_region for accessing the SuperIO area on these chips, and the fact I have a GPIO driver for the pc8741x basically ready for submission, here is a patch to cleanup the pc87413 watchdog driver to use request_muxed_region for accessing the SuperIO area. It also pulls out the details about the SWC IO area on initial driver load, and properly does a request_region for that area - there's no requirement to touch the SuperIO area after doing the initial watchdog enable and IO base retrieval. While I have hardware with a pc87413 on it it is not wired in a way that allows the watchdog to reboot the machine, so I have not been able to fully test these changes - I have checked that the driver correctly initialises itself still and requests the SWC io region ok. Signed-Off-By: Jonathan McDowell <noodles@earth.li> Signed-Off-By: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: iTCO_wdt: clean-up PCI device ID'sWim Van Sebroeck
Clean up of the iTCO_wdt PCI device ID's. Own macro is replaced by the PCI_VDEVICE macro. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: Use "request_muxed_region" in it87 watchdog driversNat Gurumoorthy
Changes the it87 watchdog drivers to use "request_muxed_region". Serialize access to the hardware by using "request_muxed_region" macro defined by Alan Cox. Call to this macro will hold off the requestor if the resource is currently busy. The use of the above macro makes it possible to get rid of spinlocks in it8712f_wdt.c and it87_wdt.c watchdog drivers. This also greatly simplifies the implementation of it87_wdt.c driver. "superio_enter" will return an error if call to "request_muxed_region" fails. Rest of the code change is to ripple an error return from superio_enter to the top level. Signed-off-by: Nat Gurumoorthy <natg@google.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-17watchdog: hpwdt depends on PCIRandy Dunlap
hpwdt is a PCI driver so it should depend on PCI. Fixes these build errors: drivers/watchdog/hpwdt.c:762: error: implicit declaration of function 'pci_iomap' drivers/watchdog/hpwdt.c:762: warning: assignment makes pointer from integer without a cast drivers/watchdog/hpwdt.c:797: error: implicit declaration of function 'pci_iounmap' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Thomas Mingarelli <thomas.mingarelli@hp.com>
2011-07-16watchdog: fix hpwdt Kconfig regression in 3.0-rcOlaf Hering
Remove Kconfig regression caused by commit a4616153deae053b29a2b7dd9ec4b2a225accfc5 "watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled" With the above change applied, hpwdt will be enabled unconditionally by just entering the Watchdog subscreen in menuconfig. Since this driver is not essential to boot any box it should remain disabled until it gets manually enabled, just like all other drivers. Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Tony Camuso <tcamuso@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2011-06-28watchdog: update author email for at32ap700x_wdtHans-Christian Egtvedt
This patch updates the email address of the at32ap700x_wdt driver supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: gef_wdt: fix MODULE_ALIASAxel Lin
Remove the space between "platform:" prefix and the driver name. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: Intel SCU Watchdog: Fix build and remove duplicate codeJesper Juhl
Trying to build the Intel SCU Watchdog fails for me with gcc 4.6.0 - $ gcc --version | head -n 1 gcc (GCC) 4.6.0 20110513 (prerelease) like this : CC drivers/watchdog/intel_scu_watchdog.o In file included from drivers/watchdog/intel_scu_watchdog.c:49:0: /home/jj/src/linux-2.6/arch/x86/include/asm/apb_timer.h: In function ‘apbt_time_init’: /home/jj/src/linux-2.6/arch/x86/include/asm/apb_timer.h:65:42: warning: ‘return’ with a value, in function returning void [enabled by default] drivers/watchdog/intel_scu_watchdog.c: In function ‘intel_scu_watchdog_init’: drivers/watchdog/intel_scu_watchdog.c:468:2: error: implicit declaration of function ‘sfi_get_mtmr’ [-Werror=implicit-function-declaration] drivers/watchdog/intel_scu_watchdog.c:468:32: warning: assignment makes pointer from integer without a cast [enabled by default] cc1: some warnings being treated as errors make[1]: *** [drivers/watchdog/intel_scu_watchdog.o] Error 1 make: *** [drivers/watchdog/intel_scu_watchdog.o] Error 2 Additionally, linux/types.h is needlessly being included twice in drivers/watchdog/intel_scu_watchdog.c Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: mtx1-wdt: fix section mismatchFlorian Fainelli
Fix section mismatch and remove unused variable 'tmp'. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: mtx1-wdt: fix GPIO togglingFlorian Fainelli
Commit e391be76 (MIPS: Alchemy: Clean up GPIO registers and accessors) changed the way the GPIO was toggled. Prior to this patch, we would always actively drive the GPIO output to either 0 or 1, this patch drove the GPIO active to 0, and put the GPIO in tristate to drive it to 1, unfortunately this does not work, revert back to active driving. Using a signed variable (gstate) to hold the gpio state and using a bit- wise operation on it also resulted in toggling value from 1 to -2 since the variable is signed. This value was then passed on to gpio_direction_ output, which always perform a if (value) ... to set the value to the gpio, so we were always writing a 1 to this GPIO instead of 1 -> 0 -> 1 ... Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2011-06-28watchdog: mtx1-wdt: request gpio before using itFlorian Fainelli
Otherwise, the gpiolib autorequest feature will produce a WARN_ON(): WARNING: at drivers/gpio/gpiolib.c:101 0x8020ec6c() autorequest GPIO-215 [...] Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2011-06-28watchdog: Handle multiple wm831x watchdogs being registeredMark Brown
Due to the whole single instance based watchdog API we use static data for the wm831x watchdog which means that if the system tries to register a second one we end up trying to register the same miscdevice again, corrupting the miscdevice list. Work around this by checking for duplicate registrations until we get a watchdog core. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-05-26mfd: Use mfd cell platform_data for rdc321x cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19MIPS: Alchemy: Clean up GPIO registers and accessorsManuel Lauss
remove au_readl/au_writel, remove the predefined GPIO1/2 KSEG1 register addresses and fix the fallout in all boards and drivers. This also fixes a bug in the mtx-1_wdt driver which was introduced by commit 6ea8115bb6f359df4f45152f2b40e1d4d1891392 ("Convert mtx1 wdt to be a platform device and use generic GPIO API") before this patch mtx-1_wdt only modified GPIO215, the patch then used the gpio resource information as bit index into the GPIO2 register but the conversion to the GPIO API didn't realize that. With this patch the drivers original behaviour is restored and GPIO15 is left alone. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Florian Fainelli <florian@openwrt.org> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: linux-watchdog@vger.kernel.org Cc: Wim Van Sebroeck <wim@iguana.be> Patchwork: https://patchwork.linux-mips.org/patch/2381/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Lantiq: Add watchdog supportJohn Crispin
This patch adds the driver for the watchdog found inside the Lantiq SoC family. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-mips@linux-mips.org Cc: linux-watchdog@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2327/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-26watchdog: iTCO_wdt: TCO Watchdog patch for Intel Panther Point PCHSeth Heasley
This patch adds the TCO Watchdog DeviceIDs for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: Fix iomap resource size miscalculationsJoe Perches
Convert off-by-1 r->end - r->start to resource_size(r) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Florian Fainelli <florian@openwrt.org> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-07watchdog: mpc8xxx_wdt: fix buildPeter Korsgaard
Since 1c48a5c93da6313 (dt: Eliminate of_platform_{,un}register_driver) mpc8xxx_wdt no longer builds as it tries to refer to a 'match' variable rather than ofdev->dev.of_match that it checks just before. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-29watchdog: softdog.c: enhancement to optionally invoke panic instead of ↵Anithra P Janakiraman
reboot on timer expiry This is needed for determining the reason for failure when a softdog timeout occurs. We use softdog to watch for critical application failures and at the minimum a snapshot of the system would help to determine the cause. In such a scenario the application could fail but there isn't a softlockup as such, hence the detect softlockup feature does not help. The patch adds a module parameter soft_panic which when set to 1 causes softdog to invoke panic instead of reboot when the softdog timer expires. By invoking panic we execute kdump if it is configured and the vmcore generated by kdump should provide atleast a minimal idea of the reason for failure. Based on an original patch by Ken Sugawara <sugaken.r3@gmail.com> Signed-off-by: Anithra P J <anithra@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
