Fix some booke wdt ioctls return value error.
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
Acked-by: Timur Tabi <timur@freescale.com>
Pull arm-soc Marvell Orion device-tree updates from Olof Johansson:
"This contains a set of device-tree conversions for Marvell Orion
platforms that were staged early but took a few tries to get the
branch into a format where it was suitable for us to pick up.
Given that most people working on these platforms are hobbyists with
limited time, we were a bit more flexible with merging it even though
it came in late."
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits)
ARM: Kirkwood: Replace mrvl with marvell
ARM: Kirkwood: Describe GoFlex Net LEDs and SATA in DT.
ARM: Kirkwood: Describe Dreamplug LEDs in DT.
ARM: Kirkwood: Describe iConnects LEDs in DT.
ARM: Kirkwood: Describe iConnects temperature sensor in DT.
ARM: Kirkwood: Describe IB62x0 LEDs in DT.
ARM: Kirkwood: Describe IB62x0 gpio-keys in DT.
ARM: Kirkwood: Describe DNS32? gpio-keys in DT.
ARM: Kirkwood: Move common portions into a kirkwood-dnskw.dtsi
ARM: Kirkwood: Replace DNS-320/DNS-325 leds with dt bindings
ARM: Kirkwood: Describe DNS325 temperature sensor in DT.
ARM: Kirkwood: Use DT to configure SATA device.
ARM: kirkwood: use devicetree for SPI on dreamplug
ARM: kirkwood: Add LS-XHL and LS-CHLv2 support
ARM: Kirkwood: Initial DTS support for Kirkwood GoFlex Net
ARM: Kirkwood: Add basic device tree support for QNAP TS219.
ATA: sata_mv: Add device tree support
ARM: Orion: DTify the watchdog timer.
ARM: Orion: Add arch support needed for I2C via DT.
ARM: kirkwood: use devicetree for orion-spi
drivers/watchdog/orion_wdt.c
Pull ARM updates from Russell King:
"First ARM push of this merge window, post me coming back from holiday.
This is what has been in linux-next for the last few weeks. Not much
to say which isn't described by the commit summaries."
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (32 commits)
ARM: 7463/1: topology: Update cpu_power according to DT information
ARM: 7462/1: topology: factorize the update of sibling masks
ARM: 7461/1: topology: Add arch_scale_freq_power function
ARM: 7456/1: ptrace: provide separate functions for tracing syscall {entry,exit}
ARM: 7455/1: audit: move syscall auditing until after ptrace SIGTRAP handling
ARM: 7454/1: entry: don't bother with syscall tracing on ret_from_fork path
ARM: 7453/1: audit: only allow syscall auditing for pure EABI userspace
ARM: 7452/1: delay: allow timer-based delay implementation to be selected
ARM: 7451/1: arch timer: implement read_current_timer and get_cycles
ARM: 7450/1: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs
ARM: 7449/1: use generic strnlen_user and strncpy_from_user functions
ARM: 7448/1: perf: remove arm_perf_pmu_ids global enumeration
ARM: 7447/1: rwlocks: remove unused branch labels from trylock routines
ARM: 7446/1: spinlock: use ticket algorithm for ARMv6+ locking implementation
ARM: 7445/1: mm: update CONTEXTIDR register to contain PID of current process
ARM: 7444/1: kernel: add arch-timer C3STOP feature
ARM: 7460/1: remove asm/locks.h
ARM: 7439/1: head.S: simplify initial page table mapping
ARM: 7437/1: zImage: Allow DTB command line concatenation with ATAG_CMDLINE
ARM: 7436/1: Do not map the vectors page as write-through on UP systems
Add device tree support to the Orion watchdog timer, and enable its
use in the kirkwood devices using device tree.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com>
Tested-by: Simon Baatz <gmbnomis@gmail.com>
Pull watchdog changes from Wim Van Sebroeck:
- conversion of iTCO_wdt and orion_wdt to the generic watchdog API
- uses module_platform_driver() for s3c2410_wdt
- Adds support for Jetway JNF99 Motherboard
- various fixes
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: orion_wdt: Convert driver to watchdog core
watchdog: s3c2410_wdt: Use module_platform_driver()
watchdog: sch311x_wdt: Fix Polarity when starting watchdog
Watchdog: OMAP: Fix the runtime pm code to avoid module getting stuck intransition state.
watchdog: ie6xx_wdt: section mismatch in ie6xx_wdt_probe()
watchdog: bcm63xx_wdt: fix driver section mismatch
watchdog: iTCO_wdt.c: convert to watchdog core
char/ipmi: remove local ioctl defines replaced by generic ones
watchdog: xilinx: Read clock frequency directly from DT node
watchdog: coh901327_wdt: use clk_prepare/unprepare
watchdog: f71808e_wdt: Add support for Jetway JNF99 motherboard
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Benjamin Herrenschmidt:
"Notable highlights:
- iommu improvements from Anton removing the per-iommu global lock in
favor of dividing the DMA space into pools, each with its own lock,
and hashed on the CPU number. Along with making the locking more
fine grained, this gives significant improvements in multiqueue
networking scalability.
- Still from Anton, we know provide a vdso based variant of getcpu
which makes sched_getcpu with the appropriate glibc patch something
like 18 times faster.
- More anton goodness (he's been busy !) in other areas such as a
faster __clear_user and copy_page on P7, various perf fixes to
improve sampling quality, etc...
- One more step toward removing legacy i2c interfaces by using new
device-tree based probing of platform devices for the AOA audio
drivers
- A nice series of patches from Michael Neuling that helps avoiding
confusion between register numbers and litterals in assembly code,
trying to enforce the use of "%rN" register names in gas rather
than plain numbers.
- A pile of FSL updates
- The usual bunch of small fixes, cleanups etc...
You may spot a change to drivers/char/mem. The patch got no comment
or ack from outside, it's a trivial patch to allow the architecture to
skip creating /dev/port, which we use to disable it on ppc64 that
don't have a legacy brige. On those, IO ports 0...64K are not mapped
in kernel space at all, so accesses to /dev/port cause oopses (and
yes, distros -still- ship userspace that bangs hard coded ports such
as kbdrate)."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/mpic: Create a revmap with enough entries for IPIs and timers
Remove stale .rej file
powerpc/iommu: Fix iommu pool initialization
powerpc/eeh: Check handle_eeh_events() return value
powerpc/85xx: Add phy nodes in SGMII mode for MPC8536/44/72DS & P2020DS
powerpc/e500: add paravirt QEMU platform
powerpc/mpc85xx_ds: convert to unified PCI init
powerpc/fsl-pci: get PCI init out of board files
powerpc/85xx: Update corenet64_smp_defconfig
powerpc/85xx: Update corenet32_smp_defconfig
powerpc/85xx: Rename P1021RDB-PC device trees to be consistent
powerpc/watchdog: move booke watchdog param related code to setup-common.c
sound/aoa: Adapt to new i2c probing scheme
i2c/powermac: Improve detection of devices from device-tree
powerpc: Disable /dev/port interface on systems without an ISA bridge
of: Improve prom_update_property() function
powerpc: Add "memory" attribute for mfmsr()
powerpc/ftrace: Fix assembly trampoline register usage
powerpc/hw_breakpoints: Fix incorrect pointer access
powerpc: Put the gpr save/restore functions in their own section
Convert orion_wdt driver to use watchdog framework API.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
module_platform_driver() replaces module_init() and module_exit()
and makes the code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Some motherboards like the Advantech ARK3400 documentation
use a non-inverted GPIO pin. We fix this by assuming that
the BIOS will set the Polarity bit for the GPIO correctly
at startup and we keep the Bit-setting intact when we start
and stop the watchdog.
Reported-by: Jean-François Deverge <jf.deverge@gmail.com>
Signed-off-by: Dave Mueller <d.mueller@elsoft.ch>
intransition state.
OMAP watchdog driver is adapted to runtime PM like a general device
driver but it is not appropriate. It is causing couple of functional
issues.
1. On OMAP4 SYSCLK can't be gated, because of issue with WDTIMER2 module,
which constantly stays in "in transition" state. Value of register
CM_WKUP_WDTIMER2_CLKCTRL is always 0x00010000 in this case.
Issue occurs immediately after first idle, when hwmod framework tries
to disable WDTIMER2 functional clock - "wd_timer2_fck". After this
module falls to "in transition" state, and SYSCLK gating is blocked.
2. Due to runtime PM, watchdog timer may be completely disabled.
In current code base watchdog timer is not disabled only because of
issue 1. Otherwise state of WDTIMER2 module will be "Disabled", and there
will be no interrupts from omap_wdt. In other words watchdog will not
work at all.
Watchdong is a special IP and it should not be disabled otherwise
purpose of it itself is defeated. Watchdog functional clock should
never be disabled. This patch updates the runtime PM handling in
driver so that runtime PM is limited only during probe/shutdown
and suspend/resume.
The patch fixes issue 1 and 2
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
ie6xx_wdt_probe() calls ie6xx_wdt_debugfs_exit() as part of
it's error cleanup path, and ie6xx_wdt_debugfs_exit() is
currently annotated __devexit.
Signed-off-by: Gerard Snitselaar <dev@snitselaar.org>
bcm63xx_wdt was used as a platform_driver but was not suffixed with
_driver, thus causing section mismatches, fix that.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This patch converts the iTCO_wdt watchdog driver to use the
generic watchdog framework.
Do not use clock-frequency property from parent node.
Use it from watchdog node.
Acked-By: Alejandro Cabrera <acabrera@udio.cujae.edu.cu>
Make sure we prepare/unprepare the COH901327 watchdog timer
as is required by the clk API especially if you use common
clock.
Reviewed-by : Pankaj Jangra <jangra.pankaj9@gmail.com>
The Jetway JNF99 motherboard features a F71869 SuperIO chip, but its
watchdog chipset ID appears to be 1007 (as opposed to 0814). Some testing
confirmed it behaves the exact same as 0814. So add this chipset ID to the
module's ID list so that the Fintek watchdog driver can correctly identify
and access it.
Signed-off-by: Justin Wheeler <jwheeler@datademons.com>
Acked-by: Giel van Schijndel <me@mortis.eu>
CONFIG_FSL_BOOKE is only defined in 32-bit, CONFIG_PPC_FSL_BOOK3E is
defined in both 32-bit and 64-bit, so use CONFIG_PPC_FSL_BOOK3E to make
driver work in 32-bit & 64-bit.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Make the OS timer registers have IOMEM like properities so they can
be passed to readl_relaxed/writel_relaxed() et.al. rather than being
straight volatile dereferences. Add linux/io.h includes where
required.
linux/io.h includes added to arch/arm/mach-sa1100/cpu-sa1100.c,
arch/arm/mach-sa1100/jornada720_ssp.c, arch/arm/mach-sa1100/leds-lart.c
drivers/input/touchscreen/jornada720_ts.c, drivers/pcmcia/sa1100_shannon.c
from Arnd.
This fixes these warnings:
arch/arm/mach-sa1100/time.c: In function 'sa1100_timer_init':
arch/arm/mach-sa1100/time.c:104: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type
arch/arm/mach-pxa/time.c: In function 'pxa_timer_init':
arch/arm/mach-pxa/time.c:126: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type
Add device table for omap_wdt to support dt.
Signed-off-by: Xiao Jiang <jgq516@gmail.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
In commit 7a87982420e5e126bfefeb42232d1fd92052794e we added
a wrapper for the WDIOC_GETSTATUS ioctl call. The code results
however in a different behaviour: it returns an error if the
driver doesn't support the status operation. This is not
according to the API that says that when we don't support
the status operation, that we just should return a 0 value.
Only when the device isn't there anymore, we should return an
error.
This patch is to unregister for NMI events upon exit. Also we are now
making the default setting for allow_kdump enabled.
Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com>
The recent conversion of iTCO_wdt resulted in the driver no longer
getting loaded automatically, since it no longer has a
MODULE_DEVICE_TABLE() included. As the lpc_ich driver now creates a
platform device, auto-loading can easily be done by having a respective
module alias in place.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Aaron Sierra <asierra@xes-inc.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Cc: Samuel Ortiz <sameo@linux.intel.com>
viresh.kumar@st.com email-id doesn't exist anymore as I have left the
company. Replace ST's id with viresh.linux@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'
Signed-off-by: Viresh Kumar <viresh.linux@gmail.com>
Fix printk format warnings:
drivers/watchdog/iTCO_wdt.c:577:3: warning: format '%04llx' expects type 'long long unsigned int', but argument 2 has type 'resource_size_t'
drivers/watchdog/iTCO_wdt.c:594:3: warning: format '%04llx' expects type 'long long unsigned int', but argument 2 has type 'resource_size_t'
drivers/watchdog/iTCO_wdt.c:600:2: warning: format '%04llx' expects type 'long long unsigned int', but argument 4 has type 'resource_size_t'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
clk_{un}prepare() routines are required for required on some platforms to run
part of clk enable/disable() routines from contexts that can schedule.
This patch adds support for these routines in sp805 driver.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
This patch converts existing sp805 watchdog driver to use already in place
common infrastructure present in watchdog core. With this lot of code goes away.
This driver adds support for the watchdog functionality provided by
the Dialog Semiconductor DA9052 PMIC chip.
Tested on samsung smdkv6410 and i.mx53 QS boards.
Signed-off-by: Anthony Olech <Anthony.Olech@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
If a driver's watchdog_device struct is part of a dynamically allocated
struct (which it often will be), merely locking the module is not enough,
even with a drivers module locked, the driver can be unbound from the device,
examples:
1) The root user can unbind it through sysfd
2) The i2c bus master driver being unloaded for an i2c watchdog
I will gladly admit that these are corner cases, but we still need to handle
them correctly.
The fix for this consists of 2 parts:
1) Add ref / unref operations, so that the driver can refcount the struct
holding the watchdog_device struct and delay freeing it until any
open filehandles referring to it are closed
2) Most driver operations will do IO on the device and the driver should not
do any IO on the device after it has been unbound. Rather then letting each
driver deal with this internally, it is better to ensure at the watchdog
core level that no operations (other then unref) will get called after
the driver has called watchdog_unregister_device(). This actually is the
bulk of this patch.
This patch fixes some potential multithreading issues, despite only
allowing one process to open the /dev/watchdog device, we can still get
called multiple times at the same time, since a program could be using thread,
or could share the fd after a fork.
This causes 2 potential problems:
1) watchdog_start / open do an unlocked test_n_set / test_n_clear,
if these 2 race, the watchdog could be stopped while the active
bit indicates it is running or visa versa.
2) Most watchdog_dev drivers probably assume that only one
watchdog-op will get called at a time, this is not necessary
true atm.
Rewrite and extend the wrapper code so that we can easily introduce
locking (this to be able to prevent potential multithreading issues).
While they are registered all our watchdogs now have a valid device object
so we can in turn use that to report problems nicely.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Create the watchdog class and it's associated devices.
We keep the old /dev/watchdog interface file for the first watchdog via
miscdev. This is basically a cut and paste of the relevant interface code
from the rtc driver layer tweaked for watchdog.
Revised to fix problems noted by Hans de Goede
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Make the functions in watchdog_core.h extern like it should.
The watchdog_core include file should have been named
watchdog_core.h and not watchdog_dev.h . Correct this.
Some watchdog may need to check if watchdog is ACTIVE or not, for example in
their suspend/resume hooks.
This patch adds this routine and changes the core drivers to use it.
prototypes
Include the private watchdog_dev.h header to pickup the prototypes for the
watchdog_dev_register/unregister functions.
This quiets the following sparse warnings:
warning: symbol 'watchdog_dev_register' was not declared. Should it be static?
warning: symbol 'watchdog_dev_unregister' was not declared. Should it be static?
Pull MIPS updates from Ralf Baechle:
"The whole series has been sitting in -next for quite a while with no
complaints. The last change to the series was before the weekend the
removal of an SPI patch which Grant - even though previously acked by
himself - appeared to raise objections. So I removed it until the
situation is clarified. Other than that all the patches have the acks
from their respective maintainers, all MIPS and x86 defconfigs are
building fine and I'm not aware of any problems introduced by this
series.
Among the key features for this patch series is a sizable patchset for
Lantiq which among other things introduces support for Lantiq's
flagship product, the FALCON SOC. It also means that the opensource
developers behind this patchset have overtaken Lantiq's competing
inhouse development team that was working behind closed doors.
Less noteworthy the ath79 patchset which adds support for a few more
chip variants, cleanups and fixes. Finally the usual dose of tweaking
of generic code."
Fix up trivial conflicts in arch/mips/lantiq/xway/gpio_{ebu,stp}.c where
printk spelling fixes clashed with file move and eventual removal of the
printk.
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (81 commits)
MIPS: lantiq: remove orphaned code
MIPS: Remove all -Wall and almost all -Werror usage from arch/mips.
MIPS: lantiq: implement support for FALCON soc
MTD: MIPS: lantiq: verify that the NOR interface is available on falcon soc
MTD: MIPS: lantiq: implement OF support
watchdog: MIPS: lantiq: implement OF support and minor fixes
SERIAL: MIPS: lantiq: implement OF support
GPIO: MIPS: lantiq: convert gpio-stp-xway to OF
GPIO: MIPS: lantiq: convert gpio-mm-lantiq to OF and of_mm_gpio
GPIO: MIPS: lantiq: move gpio-stp and gpio-ebu to the subsystem folder
MIPS: pci: convert lantiq driver to OF
MIPS: lantiq: convert dma to platform driver
MIPS: lantiq: implement support for clkdev api
MIPS: lantiq: drop ltq_gpio_request() and gpio_to_irq()
OF: MIPS: lantiq: implement irq_domain support
OF: MIPS: lantiq: implement OF support
MIPS: lantiq: drop mips_machine support
OF: PCI: const usage needed by MIPS
MIPS: Cavium: Remove smp_reserve_lock.
MIPS: Move cache setup to setup_arch().
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD changes from Samuel Ortiz:
"Besides the usual cleanups, this one brings:
* Support for 5 new chipsets: Intel's ICH LPC and SCH Centerton,
ST-E's STAX211, Samsung's MAX77693 and TI's LM3533.
* Device tree support for the twl6040, tps65910, da9502 and ab8500
drivers.
* Fairly big tps56910, ab8500 and db8500 updates.
* i2c support for mc13xxx.
* Our regular update for the wm8xxx driver from Mark."
Fix up various conflicts with other trees, largely due to ab5500 removal
etc.
* tag 'mfd-3.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (106 commits)
mfd: Fix build break of max77693 by adding REGMAP_I2C option
mfd: Fix twl6040 build failure
mfd: Fix max77693 build failure
mfd: ab8500-core should depend on MFD_DB8500_PRCMU
gpio: tps65910: dt: process gpio specific device node info
mfd: Remove the parsing of dt info for tps65910 gpio
mfd: Save device node parsed platform data for tps65910 sub devices
mfd: Add r_select to lm3533 platform data
gpio: Add Intel Centerton support to gpio-sch
mfd: Emulate active low IRQs as well as active high IRQs for wm831x
mfd: Mark two lm3533 zone registers as volatile
mfd: Fix return type of lm533 attribute is_visible
mfd: Enable Device Tree support in the ab8500-pwm driver
mfd: Enable Device Tree support in the ab8500-sysctrl driver
mfd: Add support for Device Tree to twl6040
mfd: Register the twl6040 child for the ASoC codec unconditionally
mfd: Allocate twl6040 IRQ numbers dynamically
mfd: twl6040 code cleanup in interrupt initialization part
mfd: Enable ab8500-gpadc driver for Device Tree
mfd: Prevent unassigned pointer from being used in ab8500-gpadc driver
Pull arm-soc clock driver changes from Olof Johansson:
"The new clock subsystem was merged in linux-3.4 without any users,
this now moves the first three platforms over to it: imx, mxs and
spear.
The series also contains the changes for the clock subsystem itself,
since Mike preferred to have it together with the platforms that
require these changes, in order to avoid interdependencies and
conflicts."
Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code
removed in one branch, added OF support in another) and
drivers/dma/imx-sdma.c (independent changes next to each other).
* tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits)
clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate().
clk: Provide dummy clk_unregister()
SPEAr: Update defconfigs
SPEAr: Add SMI NOR partition info in dts files
SPEAr: Switch to common clock framework
SPEAr: Call clk_prepare() before calling clk_enable
SPEAr: clk: Add General Purpose Timer Synthesizer clock
SPEAr: clk: Add Fractional Synthesizer clock
SPEAr: clk: Add Auxiliary Synthesizer clock
SPEAr: clk: Add VCO-PLL Synthesizer clock
SPEAr: Add DT bindings for SPEAr's timer
ARM i.MX: remove now unused clock files
ARM: i.MX6: implement clocks using common clock framework
ARM i.MX35: implement clocks using common clock framework
ARM i.MX5: implement clocks using common clock framework
ARM: Kirkwood: Replace clock gating
ARM: Orion: Audio: Add clk/clkdev support
ARM: Orion: PCIE: Add support for clk
ARM: Orion: XOR: Add support for clk
ARM: Orion: CESA: Add support for clk
Pull first set of watchdog updates from Wim Van Sebroeck:
"This pull contains:
- The removal of ixp2000_wdt
- The addition of ie6xx_wdt
- Some documentation fixes
- Small fixes and improvements
(Note: Part 2 will contain generic watchdog core changes + conversion
of some more drivers)"
Documentation/watchdog: Fix the file descriptor leak when no cmdline arg given
Documentation/watchdog: close the fd when cmdline arg given
Documentation/watchdog: Fix a small typo
watchdog: s3c2410_wdt: Set timeout to actually achieved timeout
watchdog: wm831x: Convert to gpio_request_one()
watchdog: via_wdt: depends on PCI
watchdog: ie6xx_wdt needs io.h
watchdog: ie6xx_wdt.c: fix printk format warning
watchdog: Add watchdog driver for Intel Atom E6XX
watchdog: it87_wdt: Add support for IT8728F watchdog.
watchdog: i6300esb: don't depend on X86
watchdog: Use module_pci_driver
watchdog: sch311x_wdt.c: Remove RESGEN
watchdog: s3c2410-wdt: Use of_match_ptr().
watchdog: Device tree support for pnx4008-wdt
watchdog: ar7_wdt.c: use devm_request_and_ioremap
watchdog: remove ixp2000 driver
watchdog: sp5100_tco.c: quiet sparse noise about using plain integer was NULL pointer
Pull SuperH updates from Paul Mundt:
- New CPUs: SH7734 (SH-4A), SH7264 and SH7269 (SH-2A)
- New boards: RSK2+SH7264, RSK2+SH7269
- Unbreaking kgdb for SMP
- Consolidation of _32/_64 page fault handling.
- watchdog and legacy DMA chainsawing, part 1
- Conversion to evt2irq() hwirq lookup, to support relocation of
vectored IRQs for irqdomains.
* tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (98 commits)
sh: intc: Kill off special reservation interface.
sh: Enable PIO API for hp6xx and se770x.
sh: Kill off machvec IRQ hinting.
sh: dma: More legacy cpu dma chainsawing.
sh: Kill off MAX_DMA_ADDRESS leftovers.
sh: Tidy up some of the cpu legacy dma header mess.
sh: Move sh4a dma header from cpu-sh4 to cpu-sh4a.
sh64: Fix up vmalloc fault range check.
Revert "sh: Ensure fixmap and store queue space can co-exist."
serial: sh-sci: Fix for port types without BRI interrupts.
sh: legacy PCI evt2irq migration.
sh: cpu dma evt2irq migration.
sh: sh7763rdp evt2irq migration.
sh: sdk7780 evt2irq migration.
sh: migor evt2irq migration.
sh: landisk evt2irq migration.
sh: kfr2r09 evt2irq migration.
sh: ecovec24 evt2irq migration.
sh: ap325rxa evt2irq migration.
sh: urquell evt2irq migration.
While rebasing my "watchdog_dev: Let the driver update the timeout field on
set_timeout success" patch (before I noticed it was already picked up by Wim),
I noticed that the s3c2410_wdt driver may not always have a 1 second
resolution, this patch changes s3c2410wdt_set_heartbeat to update the
timeout to the actually achieved timeout.
Use the more modern API.
via_wdt is a PCI driver so it should depend on PCI so that
it will not cause build errors.
drivers/watchdog/via_wdt.c:256:1: warning: data definition has no type or storage class
drivers/watchdog/via_wdt.c:256:1: warning: type defaults to 'int' in declaration of 'module_pci_driver'
drivers/watchdog/via_wdt.c:256:1: warning: parameter names (without types) in function declaration
Fix build error by including <linux/io.h>:
drivers/watchdog/ie6xx_wdt.c:97:2: error: implicit declaration of function 'outb'
drivers/watchdog/ie6xx_wdt.c:133:2: error: implicit declaration of function 'outl'
drivers/watchdog/ie6xx_wdt.c:161:2: error: implicit declaration of function 'inb'
drivers/watchdog/ie6xx_wdt.c:199:3: error: implicit declaration of function 'inl'
drivers/watchdog/ie6xx_wdt.c:203:3: error: implicit declaration of function 'inw'
Fix printk format warning; use cast to u64 since resource_size_t can
be either u32 or u64.
drivers/watchdog/ie6xx_wdt.c:261:4: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'resource_size_t'
Add driver for the watchdog timer built into the
Intel Atom E6XX (TunnelCreek) processor.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
This works the same way IT8721F works, but it supports WDT_PWROK
(checked on the datasheet).
Signed-off-by: Diego Elio Pettenò <flameeyes@flameeyes.eu>
