path: root/drivers/xen/platform-pci.c
2011-02-25xen: no need to delay xen_setup_shutdown_event for hvm guests anymoreStefano Stabellini
Now that xenstore_ready is used correctly for PV on HVM guests too, we don't need to delay the initialization of xen_setup_shutdown_event anymore. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
2011-01-12xen-platform: use PCI interfaces to request IO and MEM resources.Ian Campbell
This is the correct interface to use and something has broken the use of the previous incorrect interface (which fails because the request conflicts with the resources assigned for the PCI device itself instead of nesting like the PCI interfaces do). Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: stable@kernel.org # 2.6.37 only
2010-07-26x86: Unplug emulated disks and nics.Stefano Stabellini
Add a xen_emul_unplug command line option to the kernel to unplug xen emulated disks and nics. Set the default value of xen_emul_unplug depending on whether or not the Xen PV frontends and the Xen platform PCI driver have been compiled for this kernel (modules or built-in are both OK). The user can specify xen_emul_unplug=ignore to enable PV drivers on HVM even if the host platform doesn't support unplug. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-22xen: Add suspend/resume support for PV on HVM guests.Stefano Stabellini
Suspend/resume requires few different things on HVM: the suspend hypercall is different; we don't need to save/restore memory related settings; except the shared info page and the callback mechanism. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-22xen: Xen PCI platform device driver.Stefano Stabellini
Add the xen pci platform device driver that is responsible for initializing the grant table and xenbus in PV on HVM mode. Few changes to xenbus and grant table are necessary to allow the delayed initialization in HVM mode. Grant table needs few additional modifications to work in HVM mode. The Xen PCI platform device raises an irq every time an event has been delivered to us. However these interrupts are only delivered to vcpu 0. The Xen PCI platform interrupt handler calls xen_hvm_evtchn_do_upcall that is a little wrapper around __xen_evtchn_do_upcall, the traditional Xen upcall handler, the very same used with traditional PV guests. When running on HVM the event channel upcall is never called while in progress because it is a normal Linux irq handler (and we cannot switch the irq chip wholesale to the Xen PV ones as we are running QEMU and might have passed in PCI devices), therefore we cannot be sure that evtchn_upcall_pending is 0 when returning. For this reason if evtchn_upcall_pending is set by Xen we need to loop again on the event channels set pending otherwise we might loose some event channel deliveries. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
