path: root/drivers/xen
2012-01-18xen/xenbus: Reject replies with payload > XENSTORE_PAYLOAD_MAX.Ian Campbell
commit 9e7860cee18241633eddb36a4c34c7b61d8cecbc upstream. Haogang Chen found out that: There is a potential integer overflow in process_msg() that could result in cross-domain attack. body = kmalloc(msg->hdr.len + 1, GFP_NOIO | __GFP_HIGH); When a malicious guest passes 0xffffffff in msg->hdr.len, the subsequent call to xb_read() would write to a zero-length buffer. The other end of this connection is always the xenstore backend daemon so there is no guest (malicious or otherwise) which can do this. The xenstore daemon is a trusted component in the system. However this seem like a reasonable robustness improvement so we should have it. And Ian when read the API docs found that: The payload length (len field of the header) is limited to 4096 (XENSTORE_PAYLOAD_MAX) in both directions. If a client exceeds the limit, its xenstored connection will be immediately killed by xenstored, which is usually catastrophic from the client's point of view. Clients (particularly domains, which cannot just reconnect) should avoid this. so this patch checks against that instead. This also avoids a potential integer overflow pointed out by Haogang Chen. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Haogang Chen <haogangchen@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21xen-gntalloc: signedness bug in add_grefs()Dan Carpenter
commit 99cb2ddcc617f43917e94a4147aa3ccdb2bcd77e upstream. gref->gref_id is unsigned so the error handling didn't work. gnttab_grant_foreign_access() returns an int type, so we can add a cast here, and it doesn't cause any problems. gnttab_grant_foreign_access() can return a variety of errors including -ENOSPC, -ENOSYS and -ENOMEM. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21xen-gntalloc: integer overflow in gntalloc_ioctl_alloc()Dan Carpenter
commit 21643e69a4c06f7ef155fbc70e3fba13fba4a756 upstream. On 32 bit systems a high value of op.count could lead to an integer overflow in the kzalloc() and gref_ids would be smaller than expected. If the you triggered another integer overflow in "if (gref_size + op.count > limit)" then you'd probably get memory corruption inside add_grefs(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11genirq: Add IRQF_RESUME_EARLY and resume such IRQs earlierIan Campbell
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream. This adds a mechanism to resume selected IRQs during syscore_resume instead of dpm_resume_noirq. Under Xen we need to resume IRQs associated with IPIs early enough that the resched IPI is unmasked and we can therefore schedule ourselves out of the stop_machine where the suspend/resume takes place. This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11xen-swiotlb: Fix wrong panic.Konrad Rzeszutek Wilk
commit ab2a47bd242d6cdcf6b2b64797f271c6f0a6d338 upstream. Propagate the baremetal git commit "swiotlb: fix wrong panic" (fba99fa38b023224680308a482e12a0eca87e4e1) in the Xen-SWIOTLB version. wherein swiotlb's map_page wrongly calls panic() when it can't find a buffer fit for device's dma mask. It should return an error instead. Devices with an odd dma mask (i.e. under 4G) like b44 network card hit this bug (the system crashes): http://marc.info/?l=linux-kernel&m=129648943830106&w=2 If xen-swiotlb returns an error, b44 driver can use the own bouncing mechanism. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-15xen/irq: Alter the locking to use a mutex instead of a spinlock.Konrad Rzeszutek Wilk
When we allocate/change the IRQ informations, we do not need to use spinlocks. We can use a mutex (which is what the generic IRQ code does for allocations/changes). Fixes a slew of: BUG: sleeping function called from invalid context at /linux/kernel/mutex.c:271 in_atomic(): 1, irqs_disabled(): 0, pid: 3216, name: xenstored 2 locks held by xenstored/3216: #0: (&u->bind_mutex){......}, at: [<ffffffffa02e0920>] evtchn_ioctl+0x30/0x3a0 [xen_evtchn] #1: (irq_mapping_update_lock){......}, at: [<ffffffff8138b274>] bind_evtchn_to_irq+0x24/0x90 Pid: 3216, comm: xenstored Not tainted 3.1.0-rc6-00021-g437a3d1 #2 Call Trace: [<ffffffff81088d10>] __might_sleep+0x100/0x130 [<ffffffff81645c2f>] mutex_lock_nested+0x2f/0x50 [<ffffffff81627529>] __irq_alloc_descs+0x49/0x200 [<ffffffffa02e0920>] ? evtchn_ioctl+0x30/0x3a0 [xen_evtchn] [<ffffffff8138b214>] xen_allocate_irq_dynamic+0x34/0x70 [<ffffffff8138b2ad>] bind_evtchn_to_irq+0x5d/0x90 [<ffffffffa02e03c0>] ? evtchn_bind_to_user+0x60/0x60 [xen_evtchn] [<ffffffff8138c282>] bind_evtchn_to_irqhandler+0x32/0x80 [<ffffffffa02e03a9>] evtchn_bind_to_user+0x49/0x60 [xen_evtchn] [<ffffffffa02e0a34>] evtchn_ioctl+0x144/0x3a0 [xen_evtchn] [<ffffffff811b4070>] ? vfsmount_lock_local_unlock+0x50/0x80 [<ffffffff811a6a1a>] do_vfs_ioctl+0x9a/0x5e0 [<ffffffff811b476f>] ? mntput+0x1f/0x30 [<ffffffff81196259>] ? fput+0x199/0x240 [<ffffffff811a7001>] sys_ioctl+0xa1/0xb0 [<ffffffff8164ea82>] system_call_fastpath+0x16/0x1b Reported-by: Jim Burns <jim_burn@bellsouth.net> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-10xen: xen-selfballoon.c needs more header filesRandy Dunlap
Fix build errors (found when CONFIG_SYSFS is not enabled): drivers/xen/xen-selfballoon.c:446: warning: data definition has no type or storage class drivers/xen/xen-selfballoon.c:446: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' drivers/xen/xen-selfballoon.c:446: warning: parameter names (without types) in function declaration drivers/xen/xen-selfballoon.c:485: error: expected declaration specifiers or '...' before string constant drivers/xen/xen-selfballoon.c:485: warning: data definition has no type or storage class drivers/xen/xen-selfballoon.c:485: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE' drivers/xen/xen-selfballoon.c:485: warning: function declaration isn't a prototype Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03xen/self-balloon: Add dependency on tmem.Konrad Rzeszutek Wilk
Without enabling CONFIG_XEN_TMEM we get this: drivers/xen/xen-selfballoon.c:461: undefined reference to `tmem_enabled' Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03xen/balloon: Fix compile errors - missing header files.Konrad Rzeszutek Wilk
With a specific enough .config file compile errors show for missing workqueue declarations. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03xen/grant: Fix compile warning.Konrad Rzeszutek Wilk
drivers/xen/grant-table.c:85: warning: ‘rc’ may be used uninitialized in this function Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03xen/pciback: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in drivers/xen/xen-pciback/xenbus.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-25xen/balloon: memory hotplug support for Xen balloon driverDaniel Kiper
Memory hotplug support for Xen balloon driver. It should be mentioned that hotplugged memory is not onlined automatically. It should be onlined by user through standard sysfs interface. Memory could be hotplugged in following steps: 1) dom0: xl mem-max <domU> <maxmem> where <maxmem> is >= requested memory size, 2) dom0: xl mem-set <domU> <memory> where <memory> is requested memory size; alternatively memory could be added by writing proper value to /sys/devices/system/xen_memory/xen_memory0/target or /sys/devices/system/xen_memory/xen_memory0/target_kb on dumU, 3) domU: for i in /sys/devices/system/memory/memory*/state; do \ [ "`cat "$i"`" = offline ] && echo online > "$i"; done Memory could be onlined automatically on domU by adding following line to udev rules: SUBSYSTEM=="memory", ACTION=="add", RUN+="/bin/sh -c '[ -f /sys$devpath/state ] && echo online > /sys$devpath/state'" In that case step 3 should be omitted. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'stable/drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS and XEN_PCIDEV_BACKEND_VPCI xen/pciback: Remove the DEBUG option. xen/pciback: Drop two backends, squash and cleanup some code. xen/pciback: Print out the MSI/MSI-X (PIRQ) values xen/pciback: Don't setup an fake IRQ handler for SR-IOV devices. xen: rename pciback module to xen-pciback. xen/pciback: Fine-grain the spinlocks and fix BUG: scheduling while atomic cases. xen/pciback: Allocate IRQ handler for device that is shared with guest. xen/pciback: Disable MSI/MSI-X when reseting a device xen/pciback: guest SR-IOV support for PV guest xen/pciback: Register the owner (domain) of the PCI device. xen/pciback: Cleanup the driver based on checkpatch warnings and errors. xen/pciback: xen pci backend driver. xen: tmem: self-ballooning and frontswap-selfshrinking xen: Add module alias to autoload backend drivers xen: Populate xenbus device attributes xen: Add __attribute__((format(printf... where appropriate xen: prepare tmem shim to handle frontswap xen: allow enable use of VGA console on dom0
2011-07-20Merge branch 'stable/xen-pciback-0.6.3' into stable/driversKonrad Rzeszutek Wilk
* stable/xen-pciback-0.6.3: xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS and XEN_PCIDEV_BACKEND_VPCI xen/pciback: Remove the DEBUG option. xen/pciback: Drop two backends, squash and cleanup some code. xen/pciback: Print out the MSI/MSI-X (PIRQ) values xen/pciback: Don't setup an fake IRQ handler for SR-IOV devices. xen: rename pciback module to xen-pciback. xen/pciback: Fine-grain the spinlocks and fix BUG: scheduling while atomic cases. xen/pciback: Allocate IRQ handler for device that is shared with guest. xen/pciback: Disable MSI/MSI-X when reseting a device xen/pciback: guest SR-IOV support for PV guest xen/pciback: Register the owner (domain) of the PCI device. xen/pciback: Cleanup the driver based on checkpatch warnings and errors. xen/pciback: xen pci backend driver. Conflicts: drivers/xen/Kconfig
2011-07-19xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS ↵Konrad Rzeszutek Wilk
and XEN_PCIDEV_BACKEND_VPCI .. compile options. This way the user can decide during runtime whether they want the default 'vpci' (virtual pci passthrough) or where the PCI devices are passed in without any BDF renumbering. The option 'passthrough' allows the user to toggle the it from 0 (vpci) to 1 (passthrough). Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Remove the DEBUG option.Konrad Rzeszutek Wilk
The latter is easily fixed - by the developer compiling the module with -DDEBUG. And during runtime - the loglvl provides quite a lot of useful data. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Drop two backends, squash and cleanup some code.Konrad Rzeszutek Wilk
- Remove the slot and controller controller backend as they are not used. - Document the find pciback_[read|write]_config_[byte|word|dword] to make it easier to find. - Collapse the code from conf_space_capability_msi into pciback_ops.c - Collapse conf_space_capability_[pm|vpd].c in conf_space_capability.c [and remove the conf_space_capability.h file] - Rename all visible functions from pciback to xen_pcibk. - Rename all the printk/pr_info, etc that use the "pciback" to say "xen-pciback". - Convert functions that are not referenced outside the code to be static to save on name space. - Do the same thing for structures that are internal to the driver. - Run checkpatch.pl after the renames and fixup its warnings and fix any compile errors caused by the variable rename - Cleanup any structs that checkpath.pl commented about or just look odd. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Print out the MSI/MSI-X (PIRQ) valuesKonrad Rzeszutek Wilk
If the verbose_request is set (and loglevel high enough), print out the MSI/MSI-X values that are sent to the guest. This should aid in debugging issues. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Don't setup an fake IRQ handler for SR-IOV devices.Konrad Rzeszutek Wilk
If we try to setup an fake IRQ handler for legacy interrupts for devices that only have MSI-X (most if not all SR-IOV cards), we will fail with this: pciback[0000:01:10.0]: failed to install fake IRQ handler for IRQ 0! (rc:-38) Since those cards don't have anything in dev->irq. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen: rename pciback module to xen-pciback.Ian Campbell
pciback is rather generic for a modular distro style kernel. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2011-07-19xen/pciback: Fine-grain the spinlocks and fix BUG: scheduling while atomic ↵Konrad Rzeszutek Wilk
cases. We were using coarse spinlocks that could end up with a deadlock. This patch fixes that and makes the spinlocks much more fine-grained. We also drop be->watchding state spinlocks as they are already guarded by the xenwatch_thread against multiple customers. Without that we would trigger the BUG: scheduling while atomic. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Allocate IRQ handler for device that is shared with guest.Konrad Rzeszutek Wilk
If the device that is to be shared with a guest is a level device and the IRQ is shared with the initial domain we need to take actions. Mainly we install a dummy IRQ handler that will ACK on the interrupt line so as to not have the initial domain disable the interrupt line. This dummy IRQ handler is not enabled when the device MSI/MSI-X lines are set, nor for edge interrupts. And also not for level interrupts that are not shared amongst devices. Lastly, if the user passes to the guest all of the PCI devices on the shared line the we won't install the dummy handler either. There is also SysFS instrumentation to check its state and turn IRQ ACKing on/off if necessary. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Disable MSI/MSI-X when reseting a deviceKonrad Rzeszutek Wilk
In cases where the guest is abruptly killed and has not disabled MSI/MSI-X interrupts we want to do it for it. Otherwise when the guest is started up and enables MSI, we would get a WARN() that the device already had been enabled. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: guest SR-IOV support for PV guestZhao, Yu
These changes are for PV guest to use Virtual Function. Because the VF's vendor, device registers in cfg space are 0xffff, which are invalid and ignored by PCI device scan. Values in 'struct pci_dev' are fixed up by SR-IOV code, and using these values will present correct VID and DID to PV guest kernel. And command registers in the cfg space are read only 0, which means we have to emulate MMIO enable bit (VF only uses MMIO resource) so PV kernel can work properly. Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Register the owner (domain) of the PCI device.Konrad Rzeszutek Wilk
When the front-end and back-end start negotiating we register the domain that will use the PCI device. Furthermore during shutdown of guest or unbinding of the PCI device (and unloading of module) from pciback we unregister the domain owner. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2011-07-19xen/pciback: Cleanup the driver based on checkpatch warnings and errors.Konrad Rzeszutek Wilk
Checkpatch found some extra warnings and errors. This mega patch fixes them all in one big swoop. We also spruce up the pcistub_ids to use DEFINE_PCI_DEVICE_TABLE macro (suggested by Jan Beulich). Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: xen pci backend driver.Konrad Rzeszutek Wilk
This is the host side counterpart to the frontend driver in drivers/pci/xen-pcifront.c. The PV protocol is also implemented by frontend drivers in other OSes too, such as the BSDs. The PV protocol is rather simple. There is page shared with the guest, which has the 'struct xen_pci_sharedinfo' embossed in it. The backend has a thread that is kicked every-time the structure is changed and based on the operation field it performs specific tasks: XEN_PCI_OP_conf_[read|write]: Read/Write 0xCF8/0xCFC filtered data. (conf_space*.c) Based on which field is probed, we either enable/disable the PCI device, change power state, read VPD, etc. The major goal of this call is to provide a Physical IRQ (PIRQ) to the guest. The PIRQ is Xen hypervisor global IRQ value irrespective of the IRQ is tied in to the IO-APIC, or is a vector. For GSI type interrupts, the PIRQ==GSI holds. For MSI/MSI-X the PIRQ value != Linux IRQ number (thought PIRQ==vector). Please note, that with Xen, all interrupts (except those level shared ones) are injected directly to the guest - there is no host interaction. XEN_PCI_OP_[enable|disable]_msi[|x] (pciback_ops.c) Enables/disables the MSI/MSI-X capability of the device. These operations setup the MSI/MSI-X vectors for the guest and pass them to the frontend. When the device is activated, the interrupts are directly injected in the guest without involving the host. XEN_PCI_OP_aer_[detected|resume|mmio|slotreset]: In case of failure, perform the appropriate AER commands on the guest. Right now that is a cop-out - we just kill the guest. Besides implementing those commands, it can also - hide a PCI device from the host. When booting up, the user can specify xen-pciback.hide=(1:0:0)(BDF..) so that host does not try to use the device. The driver was lifted from linux-2.6.18.hg tree and fixed up so that it could compile under v3.0. Per suggestion from Jesse Barnes moved the driver to drivers/xen/xen-pciback. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2011-07-11xen/pci: Remove 'xen_allocate_pirq_gsi'.Konrad Rzeszutek Wilk
In the past (2.6.38) the 'xen_allocate_pirq_gsi' would allocate an entry in a Linux IRQ -> {XEN_IRQ, type, event, ..} array. All of that has been removed in 2.6.39 and the Xen IRQ subsystem uses an linked list that is populated when the call to 'xen_allocate_irq_gsi' (universally done from any of the xen_bind_* calls) is done. The 'xen_allocate_pirq_gsi' is a NOP and there is no need for it anymore so lets remove it. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Squash pci_xen_initial_domain and xen_setup_pirqs together.Konrad Rzeszutek Wilk
Since they are only called once and the rest of the pci_xen_* functions follow the same pattern of setup. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-08Merge branch 'xen-tmem-selfballoon-v8' of ↵Konrad Rzeszutek Wilk
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem into stable/drivers * 'xen-tmem-selfballoon-v8' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: tmem: self-ballooning and frontswap-selfshrinking
2011-07-08xen: tmem: self-ballooning and frontswap-selfshrinkingDan Magenheimer
This patch introduces two in-kernel drivers for Xen transcendent memory ("tmem") functionality that complement cleancache and frontswap. Both use control theory to dynamically adjust and optimize memory utilization. Selfballooning controls the in-kernel Xen balloon driver, targeting a goal value (vm_committed_as), thus pushing less frequently used clean page cache pages (through the cleancache code) into Xen tmem where Xen can balance needs across all VMs residing on the physical machine. Frontswap-selfshrinking controls the number of pages in frontswap, driving it towards zero (effectively doing a partial swapoff) when in-kernel memory pressure subsides, freeing up RAM for other VMs. More detail is provided in the header comment of xen-selfballooning.c. Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> [v8: konrad.wilk@oracle.com: set default enablement depending on frontswap] [v7: konrad.wilk@oracle.com: fix capitalization and punctuation in comments] [v6: fix frontswap-selfshrinking initialization] [v6: konrad.wilk@oracle.com: fix init pr_infos; add comments about swap] [v5: konrad.wilk@oracle.com: add NULL to attr list; move inits up to decls] [v4: dkiper@net-space.pl: use strict_strtoul plus a few syntactic nits] [v3: konrad.wilk@oracle.com: fix potential divides-by-zero] [v3: konrad.wilk@oracle.com: add many more comments, fix nits] [v2: rebased to linux-3.0-rc1] [v2: Ian.Campbell@citrix.com: reorganize as new file (xen-selfballoon.c)] [v2: dkiper@net-space.pl: proper access to vm_committed_as] [v2: dkiper@net-space.pl: accounting fixes] Cc: Jan Beulich <JBeulich@novell.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: <xen-devel@lists.xensource.com>
2011-06-30xen: Add module alias to autoload backend driversBastian Blank
All the Xen backend drivers are assigned to a special bus type xen-backend. This patch exports xen-backend:* names through modalias and uevent to autoload them. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-30xen: Populate xenbus device attributesBastian Blank
The xenbus bus type uses device_create_file to assign all used device attributes. However it does not remove them when the device goes away. This patch uses the dev_attrs field of the bus type to specify default attributes for all devices. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-21Merge branch 'stable/frontswap-tmemonly' of ↵Konrad Rzeszutek Wilk
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem into stable/drivers * 'stable/frontswap-tmemonly' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: prepare tmem shim to handle frontswap
2011-06-20Merge branch 'stable/bug.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/setup: Fix for incorrect xen_extra_mem_start. xen: When calling power_off, don't call the halt function. xen: Fix compile warning when CONFIG_SMP is not defined. xen: support CONFIG_MAXSMP xen: partially revert "xen: set max_pfn_mapped to the last pfn mapped"
2011-06-17xen: prepare tmem shim to handle frontswapDan Magenheimer
Provide the shim code for frontswap for Xen tmem even if the frontswap patchset is not present yet. (The egg is before the chicken.) Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Konrad Wilk <konrad.wilk@oracle.com>
2011-06-15xen: Fix compile warning when CONFIG_SMP is not defined.Konrad Rzeszutek Wilk
.. which is quite benign. drivers/xen/events.c:398: warning: unused variable ‘desc’ Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-09Merge branch 'stable/xen-swiotlb.bugfix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6 * 'stable/xen-swiotlb.bugfix' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb-2.6: swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.
2011-06-06swiotlb: Export swioltb_nr_tbl and utilize it as appropiate.FUJITA Tomonori
By default the io_tlb_nslabs is set to zero, and gets set to whatever value is passed in via swiotlb_init_with_tbl function. The default value passed in is 64MB. However, if the user provides the 'swiotlb=<nslabs>' the default value is ignored and the value provided by the user is used... Except when the SWIOTLB is used under Xen - there the default value of 64MB is used and the Xen-SWIOTLB has no mechanism to get the 'io_tlb_nslabs' filled out by setup_io_tlb_npages functions. This patch provides a function for the Xen-SWIOTLB to call to see if the io_tlb_nslabs is set and if so use that value. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-31xen: use the trigger info we already have to choose the irq handlerStefano Stabellini
Do not use pirq_needs_eoi to decide which irq handler to use because Xen always returns true if the guest does not support pirq_eoi_map. Use the trigger information we already have from MP-tables and ACPI. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reported-by: Thomas Goetz <tom.goetz@virtualcomputer.com> Tested-by: Thomas Goetz <tom.goetz@virtualcomputer.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26xen: cleancache shim to Xen Transcendent MemoryDan Magenheimer
This patch provides a shim between the kernel-internal cleancache API (see Documentation/mm/cleancache.txt) and the Xen Transcendent Memory ABI (see http://oss.oracle.com/projects/tmem). Xen tmem provides "hypervisor RAM" as an ephemeral page-oriented pseudo-RAM store for cleancache pages, shared cleancache pages, and frontswap pages. Tmem provides enterprise-quality concurrency, full save/restore and live migration support, compression and deduplication. A presentation showing up to 8% faster performance and up to 52% reduction in sectors read on a kernel compile workload, despite aggressive in-kernel page reclamation ("self-ballooning") can be found at: http://oss.oracle.com/projects/tmem/dist/documentation/presentations/TranscendentMemoryXenSummit2010.pdf Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (34 commits) PM: Introduce generic prepare and complete callbacks for subsystems PM: Allow drivers to allocate memory from .prepare() callbacks safely PM: Remove CONFIG_PM_VERBOSE Revert "PM / Hibernate: Reduce autotuned default image size" PM / Hibernate: Add sysfs knob to control size of memory for drivers PM / Wakeup: Remove useless synchronize_rcu() call kmod: always provide usermodehelper_disable() PM / ACPI: Remove acpi_sleep=s4_nonvs PM / Wakeup: Fix build warning related to the "wakeup" sysfs file PM: Print a warning if firmware is requested when tasks are frozen PM / Runtime: Rework runtime PM handling during driver removal Freezer: Use SMP barriers PM / Suspend: Do not ignore error codes returned by suspend_enter() PM: Fix build issue in clock_ops.c for CONFIG_PM_RUNTIME unset PM: Revert "driver core: platform_bus: allow runtime override of dev_pm_ops" OMAP1 / PM: Use generic clock manipulation routines for runtime PM PM: Remove sysdev suspend, resume and shutdown operations PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM PM / AVR32: Use struct syscore_ops instead of sysdevs for PM ...
2011-05-19Merge branches 'stable/irq', 'stable/p2m.bugfixes', 'stable/e820.bugfixes' ↵Linus Torvalds
and 'stable/mmu.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: do not clear and mask evtchns in __xen_evtchn_do_upcall * 'stable/p2m.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/p2m: Create entries in the P2M_MFN trees's to track 1-1 mappings * 'stable/e820.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/setup: Fix for incorrect xen_extra_mem_start initialization under 32-bit xen/setup: Ignore E820_UNUSABLE when setting 1-1 mappings. * 'stable/mmu.bugfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen mmu: fix a race window causing leave_mm BUG()
2011-05-19Merge branches 'stable/balloon.cleanup' and 'stable/general.cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/balloon.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/balloon: Move dec_totalhigh_pages() from __balloon_append() to balloon_append() xen/balloon: Clarify credit calculation xen/balloon: Simplify HVM integration xen/balloon: Use PageHighMem() for high memory page detection * 'stable/general.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: drivers/xen/sys-hypervisor: Cleanup code/data sections definitions arch/x86/xen/smp: Cleanup code/data sections definitions arch/x86/xen/time: Cleanup code/data sections definitions arch/x86/xen/xen-ops: Cleanup code/data sections definitions arch/x86/xen/mmu: Cleanup code/data sections definitions arch/x86/xen/setup: Cleanup code/data sections definitions arch/x86/xen/enlighten: Cleanup code/data sections definitions arch/x86/xen/irq: Cleanup code/data sections definitions xen: tidy up whitespace in drivers/xen/Makefile
2011-05-19Merge branches 'stable/backend.base.v3' and 'stable/gntalloc.v7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/backend.base.v3' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pci: Fix compiler error when CONFIG_XEN_PRIVILEGED_GUEST is not set. xen/p2m: Add EXPORT_SYMBOL_GPL to the M2P override functions. xen/p2m/m2p/gnttab: Support GNTMAP_host_map in the M2P override. xen/irq: The Xen hypervisor cleans up the PIRQs if the other domain forgot. xen/irq: Export 'xen_pirq_from_irq' function. xen/irq: Add support to check if IRQ line is shared with other domains. xen/irq: Check if the PCI device is owned by a domain different than DOMID_SELF. xen/pci: Add xen_[find|register|unregister]_device_domain_owner functions. * 'stable/gntalloc.v7' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/gntdev,gntalloc: Remove unneeded VM flags
2011-05-19drivers/xen/sys-hypervisor: Cleanup code/data sections definitionsDaniel Kiper
Cleanup code/data sections definitions accordingly to include/linux/init.h. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12xen: tidy up whitespace in drivers/xen/MakefileIan Campbell
Various merges over time have led to rather a mish-mash of indentation. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel@lists.xensource.com Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
